Author Topic: [GB]LUSTRO Aluminum + Acrylic Custom 60% Case [Packing]  (Read 296701 times)
Offline fancymans
Re: [GB]LUSTRO Aluminum + Acrylic Custom 60% Case
« Reply #350 on: Thu, 09 June 2016, 00:48:32 »
So for the assembly and parts content order, we're planning this:
- PCB will be $68 kit from winkeyless
- 100 LEDs  ($5)
- 70 switches ($0.75 each)
What else are we missing? :-?
Oh right, looking into stab too
75¢ per switch, even for Gaterons? If this is the case, I don't think I'm going to do full assembly anymore.
Edit: You're ordering PCBs from Winkeyless, Cherry switches are max $0.70 from them, and Gaterons are $0.50 max (most of which are $0.33). Where did the price of $0.75 come from?
Sorry for not clarify, 0.75$ is the price for Zealios since the order for Zealios are the most quantity I forgot about other user with Gateron and Cherry MX :(
Gateron and Cherry MX mostly will be cheaper than you suggest :D
 :thumb: I'm going to be so broke, but it'll be so beautiful.
Realforce 87U 55g 10th Silenced | HHKB Silenced | FC660C
Offline foggyflute
  • Amateur Maker
    • Triviumtek
« Reply #351 on: Thu, 09 June 2016, 02:52:49 »
Sandblasted test piece are back. It's as good as expected :)
KEYBOARD MACHINERY SERVICE SINCE 2015.
Website: triviumtek.com
Instagram: instagram.com/triviumkeyboard
Facebook: facebook.com/triviumtek
[GB] Weaven Housing Kit      [GB] Lustro Housing Kit
Offline nickysan92
« Reply #352 on: Thu, 09 June 2016, 03:18:46 »
This pleases my nether regions.
Offline bazh
« Reply #353 on: Thu, 09 June 2016, 03:30:12 »
@Bazh, will the aluminium stands be compatible with other cases like Tex aluminium case?
It can be if you able to drill 4 x 4mm holes with countersink for M4 screw. Or using two side adhesive sticker...
HHKB Pro2 white
Newbie again
Offline foggyflute
  • Amateur Maker
    • Triviumtek
« Reply #354 on: Thu, 09 June 2016, 03:34:24 »
Also TEX case are slim so you will have the Lustro sides poke up.
Offline tomboy
« Reply #355 on: Thu, 09 June 2016, 03:39:32 »
Looks really nice!
I haven't received any invoice yet, should I be worried about that, or is the invoicing still in progress?
Offline bazh
« Reply #356 on: Thu, 09 June 2016, 03:45:11 »
Looks really nice!
Yeah it's still in process :thumb:
HHKB Pro2 white
Newbie again
Offline Gengarfan
« Reply #357 on: Thu, 09 June 2016, 04:16:57 »
That looks amazing? Just a question to clarify, is sandblasted and frosted the same thing?
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #358 on: Thu, 09 June 2016, 06:00:11 »
Thanks for classifying that bazh.
Also, that frosted acrylic is looking great!
Offline fancymans
« Reply #359 on: Thu, 09 June 2016, 06:36:04 »
Sandblasting is a way to get a frosted finish. For clear materials they are the same. But sandblasted could also describe other materials like sandblasted aluminum which we wouldn't call frosted.
Offline Geekmie
« Reply #360 on: Thu, 09 June 2016, 08:25:35 »
Looks great. Wonder if you can make some that is compatible with Weaven as back plate?
Offline Jeu
« Reply #361 on: Thu, 09 June 2016, 08:59:15 »
Looks great!
Offline biocalves
« Reply #362 on: Thu, 09 June 2016, 10:47:30 »
+1
« Reply #363 on: Thu, 09 June 2016, 13:10:56 »
niceeeee!
Offline Ngt
« Reply #364 on: Thu, 09 June 2016, 16:07:47 »
Really nice! I'm thrilled to get my mine! Already worked out my layout on Swill's keyboard editor website. YAY!
Offline WOMBO
« Reply #365 on: Thu, 09 June 2016, 16:48:40 »
which colors dropped?
Offline JDragon
« Reply #366 on: Fri, 10 June 2016, 01:55:35 »
Paid my invoice, looking forward to getting my board :D
Offline murkey
    • murkey's alpaca farm
« Reply #367 on: Fri, 10 June 2016, 02:11:27 »
Ooh, something interesting in my inbox. Paid!
« Reply #368 on: Fri, 10 June 2016, 02:39:46 »
Paid
Offline Atredl
« Reply #369 on: Fri, 10 June 2016, 02:57:00 »
+1
+2
Offline fancymans
« Reply #370 on: Fri, 10 June 2016, 04:47:47 »
Got my full assembly invoice! And paid!  :thumb:
Offline Ngt
« Reply #371 on: Fri, 10 June 2016, 05:01:45 »
Invoice paid as well!
Offline Jeu
« Reply #372 on: Fri, 10 June 2016, 07:12:47 »
Paid mine today!
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #373 on: Fri, 10 June 2016, 08:21:56 »
Guess I should have asked this before, but the Gaterons are the RGB ones with the clear switch tops, right?
Offline foggyflute
  • Amateur Maker
    • Triviumtek
« Reply #374 on: Fri, 10 June 2016, 09:30:42 »
Well, all of them are milky bottom with clear top but not have space for SMD rgb LED below like cherry RGB, they have a version with 4 pin rgb LED as I remember. I will need to check back if that's what you need.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #375 on: Fri, 10 June 2016, 09:59:17 »
That's perfect since I'll be installing sip sockets. I just want to have the clear switch tops.
I sent a PM too bazh about a tweak to my order but I can't remember who was actually handling the invoices.
Offline foggyflute
  • Amateur Maker
    • Triviumtek
« Reply #376 on: Fri, 10 June 2016, 10:07:13 »
Either bazh or pear_voz, pm me if you need help with technical stuff.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #377 on: Fri, 10 June 2016, 10:09:32 »
Ahh cool. Thanks for confirming everything.
Offline Geekmie
« Reply #378 on: Fri, 10 June 2016, 10:11:00 »
Can you make sandblasted acrylic back plate for Weaven as an option instead of CF?
Offline foggyflute
  • Amateur Maker
    • Triviumtek
« Reply #379 on: Fri, 10 June 2016, 10:55:18 »
I will need to test the 1.5mm acrylic to see if it sturdy enough first, it really easy to crack and we also have to press the pcb down to the back plate with the anti-slip mat in between, that's how it was designed. Maybe an acrylic plate under skeletonized carbon/steel frame or cut out for led diffuse. I will working on that.
Offline Geekmie
« Reply #380 on: Fri, 10 June 2016, 11:08:14 »
That seems quite a bit of work to do. Thanks for the explanation!
Offline Rarabka233
« Reply #381 on: Sat, 11 June 2016, 01:06:40 »
Just paid.
Offline mattycee
« Reply #382 on: Sat, 11 June 2016, 02:30:22 »
so how far are we on billing? excitied to see mine come in  :p
Current: Das 4 MX Blues,  Poker II MX Clears
Offline bazh
« Reply #383 on: Sat, 11 June 2016, 02:36:08 »
YGPM ;)
HHKB Pro2 white
Newbie again
Offline bazh
Hi guys, please note that any further change to your order will only be able to do until tomorrow, starting from next week we'll fix the order, ie no changes allowed after Sunday (12th) :D
HHKB Pro2 white
Newbie again
Offline Geekmie
Paid :)
Offline mattycee
« Reply #386 on: Sat, 11 June 2016, 20:03:32 »
YGPM ;)
hehe sorry about that. Hopefully all resolved.
Offline teemo
Did Orange make it for production? If so I would like to change my Order to Orange, I just ordered an Overcast keycap set from massdrop and would like the case to match.
Offline JDragon
I'd be interested in adding a set of orange stands to my order also.
Offline mattycee
paid
Offline foggyflute
  • Amateur Maker
    • Triviumtek
Orange did make it into final. We will have some surplus for final QC, I will notice you guys about that after checking our inventory in a few next days.
If there's no surplus, we will order more raw materials and do an extended run right after current one finish CNC :)
Offline JDragon
Thank you!
Offline Khuya
still waiting on the update invoice, should i cancel the current one?
  • (⌐■_■)⊃━☆゚.*・。゚
That's what bazh had me do, so most likely.
Offline foggyflute
  • Amateur Maker
    • Triviumtek
Sorry, I suppose to ask you about your assembly detail so I can send the update invoice, just cancel the current one, we will send new one.
Offline bazh
Yes please do so we can keep track of outdated or wrong invoice :thumb:
Also please send us (me or foggy whoever you're exchanging PM with) the detail of the selections of parts you want for updated order and we'll send you the invoice then :thumb:
Sorry for the wait though
HHKB Pro2 white
Newbie again
Offline foggyflute
  • Amateur Maker
    • Triviumtek
YGPM
Offline bazh
Updated: All PCB purchased today! Also stabs and LEDs are all en route
HHKB Pro2 white
Newbie again
niiiiiiiice
Offline Ngt
Damn I'm stupid. I need stabs as well but I didn't speak out ... Forgot about them. I have a PCB at home with switches but no stabs ...
