Author Topic: [GB] E8-V1 Custom TKL - SORTING THE BOARDS  (Read 1739839 times)
Offline YH YOON
Re: [GB] E8-V1 Custom TKL - SORTING
« Reply #400 on: Sat, 08 April 2017, 05:54:15 »
April!  ;D ;D :thumb:
Offline jhoang
  • Matrix Lover
« Reply #401 on: Sun, 09 April 2017, 11:40:07 »
Another quick update: Nothing much, just want to show some progress, these are some images I got from the factory, hopefully I'll get more news for you guys soon  :D
165227-1
165229-2
Offline mmdango
« Reply #402 on: Sun, 09 April 2017, 15:08:24 »
Appreciate the updates jhoang :]
Offline pixelpusher
« Reply #403 on: Sun, 09 April 2017, 15:57:22 »
It looks very nice.
But, for the 4th time now, I ask.  How do we tell you what we want on the badge?  What are the dimension limits of what we can have engraved?  How do we pay you?
Thanks for the updates  :thumb:
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #404 on: Sun, 09 April 2017, 16:51:01 »
Awesome, we're getting close! Thanks for the update  :thumb:
Offline Unforgivable
« Reply #405 on: Sun, 09 April 2017, 17:17:09 »
Looks fantastic!
Will you be updating the spreadsheet for the orders soon?
Your team said via comments that the update was good, but I just want to confirm with you that my case will be ceramic white, and that my extra switch plate will still be Red Aluminum (Not steel). (2x Red aluminum switch plates in total). Thanks! (:
« Last Edit: Sun, 09 April 2017, 17:21:29 by Unforgivable »
Offline jhoang
  • Matrix Lover
« Reply #406 on: Mon, 10 April 2017, 23:54:40 »
It looks very nice.
Looks fantastic!
Sorry to both you guys for late response, for the custom badge I'll get back to you once I have confirmation from E. But you can submit your design to me and I'll forward it, a simple logo with a few texts should be no problem, complicated designs need to be double-checked because the results may come out not very good.
Yes Unforgivable I have noted down all the changes after the GB closed in a separated spreadsheet to send to the factory. Will be updating in the main sheet soon™ :thumb:
Offline Aperture_Sci
  • ZZ96 / 65g Zealios / GMK Sky Dolch
« Reply #407 on: Tue, 11 April 2017, 18:54:31 »
I remember in the initial google doc we were supposed to provide the link of what we wanted for custom engraving - I remember putting a link with text on it and picking out the font. Right?
Offline Photoelectric
« Reply #408 on: Tue, 11 April 2017, 19:46:20 »
Perhaps just PM jhoang with your preferred text and/or hosted image (via imgur, google drive, onedrive, etc.)   That's what I did before the GB closed--I never noticed a dedicated link to submit that information.
« Reply #409 on: Wed, 12 April 2017, 16:25:47 »
It looks very nice.
Looks fantastic!
I have sent you a PM jhoang :)
Offline Auxo
  • Formerly CJD_Anthony
« Reply #410 on: Wed, 12 April 2017, 18:35:05 »
So.. making sure im reading this correctly, all the submissions we sent for custom badges/nameplates can be edited and customized at a later date?
Offline Aox
« Reply #411 on: Wed, 12 April 2017, 22:17:40 »
I'm pretty sure it is, but just to make sure, the LED backlighting you can turn on and off, correct?
Can RGB LED's be put in for backlighting?  It looks like the firmware supports it, is that correct, or is that just for the bottom sidelighting?
Offline Ser[A]ph
« Reply #412 on: Fri, 14 April 2017, 05:50:55 »
Were all the invoices for assembly stage finally out, jhoang bro :D
Offline gt1989
« Reply #413 on: Fri, 14 April 2017, 05:56:28 »
I haven't received mine, if they have gone out already.
Sent from my Nexus 6P using Tapatalk
Offline alveeno
« Reply #414 on: Fri, 14 April 2017, 22:48:44 »
Should be just for the bottom sidelighting, and led backlight can be turned on and off.
This may be inaccurate but it's what I understand
Offline roostrc0gburn
  • its just plastic
« Reply #415 on: Fri, 14 April 2017, 23:15:21 »
interested to see how the micro-arc anodization is going with the factory
Offline Aox
« Reply #416 on: Sat, 15 April 2017, 12:04:12 »
Ok, right on, that's what I understand as well.  I'm not a huge fan of LED backlighting, and when I do use it, it's red, so I ordered red, but I'd like to be able to turn it off.
Does anyone else know if RGB Led's are compatible with the key backlight sockets?
« Reply #417 on: Sat, 15 April 2017, 12:21:50 »
I doubt it, RGB LEDs use more than 2 pins.  It would be specially advertised here if this keyboard were RGB LED-compatible.
This will probably be the regular kind of PCB where there are preinstalled RGB LEDs on the underside for underglow and then 2 holes per switch for normal LEDs for top side illumination.  All custom keyboards with LEDs so far have had the option to turn LEDs on and off.
Offline Aox
« Reply #418 on: Sun, 16 April 2017, 18:33:36 »
Awesome info, that answers all my questions, I was not aware the RGB led's were three conductor, but that makes sense, you have to control them somehow separate from voltage.
Thanks a ton.
Offline pixelpusher
« Reply #419 on: Fri, 21 April 2017, 10:07:20 »
jhoang,
I sent you a PM about custom badge file.   :thumb:
Offline Darthbaggins
  • PC Cannibal
« Reply #420 on: Fri, 21 April 2017, 18:29:08 »
Will there be another GB opportunity for one of these KB's? Love the look and options.
Offline excluisve
  • Making & Thinking.
« Reply #421 on: Sat, 22 April 2017, 00:09:05 »
Perhaps it will have .
  join us hope it not late. :D
Offline YH YOON
« Reply #422 on: Sun, 23 April 2017, 10:42:25 »
pm'd!  ;D
Offline Faux
« Reply #423 on: Sun, 23 April 2017, 15:46:43 »
Does it look like we are on track for the april ship date?
Offline kuang2
« Reply #424 on: Mon, 24 April 2017, 21:27:12 »
:thumb:
we are still on researching for more and more keyboard. can you suggest us something that make next E-Team's keyboard really crazy?
Offline gt1989
« Reply #425 on: Mon, 24 April 2017, 21:32:39 »
Are you still planning on having a group buy for the numpad?
Offline excluisve
« Reply #426 on: Mon, 24 April 2017, 21:58:15 »
Yep ,it will have
Offline gt1989
« Reply #427 on: Mon, 24 April 2017, 22:02:00 »
Yep ,it will have
Any general idea when that will happen?
Offline pixelpusher
« Reply #428 on: Tue, 25 April 2017, 09:05:48 »
Does anyone have an email for jhoang?  If so, can you PM it to me.   :thumb:
Offline TerryMathews
« Reply #429 on: Tue, 25 April 2017, 21:22:26 »
Yep ,it will have
Please offer a few units in MAO finish. I need one to match my E8 badly.  :thumb:
Offline smittysteve
  • Tea > Coffee. Clack > Thwock.
« Reply #430 on: Tue, 25 April 2017, 21:23:33 »
Yep ,it will have
+1 for this!!
Offline mmdango
« Reply #431 on: Thu, 27 April 2017, 02:07:06 »
4 more days until end of April... No invoices for assembly yet, but can't imagine you guys starting it before getting paid for it...
Is there a more detailed status update we can get?
Offline whentheclouds
« Reply #432 on: Thu, 27 April 2017, 02:55:37 »
shipping in April for unassembled orders is my guess
Offline scttooo
« Reply #433 on: Thu, 27 April 2017, 07:25:48 »
Has anyone been able to get a hold of jhoang lately? I tried PMing here and reddit with no luck. I'm moving tomorrow and dont want my keyboard to get shipped to my old address.
Offline pixelpusher
« Reply #434 on: Thu, 27 April 2017, 09:29:42 »
I've been trying and cannot get a response.  I assume he's just busy but I'm anxious to hear back from him
Offline excluisve
« Reply #435 on: Thu, 27 April 2017, 22:11:58 »
NO,worries bro .
jhoang had said paypal  hold the money last month those was out of our planning .
 that is why had delay .
Offline excluisve
« Reply #436 on: Thu, 27 April 2017, 22:14:40 »
post u address here or PM me :D
Offline excluisve
« Reply #437 on: Thu, 27 April 2017, 22:25:06 »
Hello guys
   some things wanna tell you ,i will update more details about the keyboard .
   we are always on the road, for those make yours keyboard more perfect .
   it could be better than prototype.
   thanks all.
« Reply #438 on: Thu, 27 April 2017, 23:16:49 »
Hello guys
   thanks all.
New details? Don't tease us!  :'(
So excited for this board! Not sure about the news you have but it sounds awesome. (:
Offline mmdango
« Reply #439 on: Thu, 27 April 2017, 23:55:19 »
NO,worries bro .
Thanks for the update! Sorry for being so antsy >_< just so excited for this keyboard
Offline actualglacier
  • ¯\_(ツ)_/¯
« Reply #440 on: Fri, 28 April 2017, 09:06:23 »
Hello Kuang2, I pm'd you about a change in my assembly option! It's not letting me change it anymore so I'm sending the details to you instead.
actualglacier on youtube
  • its just plastic
« Reply #441 on: Fri, 28 April 2017, 12:31:30 »
Hello guys
   thanks all.
so.. does that mean there will be an update soon?
Offline excluisve
« Reply #442 on: Fri, 28 April 2017, 21:53:10 »
Guys have any idea PM me is ok
     i will reply at once  :thumb:
Offline onmybikedrunk
    • Danny Woods - Industrial Designer
« Reply #443 on: Fri, 28 April 2017, 23:20:19 »
If anyone is selling PM me.  :-\
Offline Faux
« Reply #444 on: Sun, 30 April 2017, 20:32:45 »
Now that it's the last day of April, were the E8-V1 shipped out? If not, could we get a status update  :D
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #445 on: Sun, 30 April 2017, 21:02:02 »
As Faux said, a status update would be nice.
Offline jhoang
  • Matrix Lover
« Reply #446 on: Mon, 01 May 2017, 06:17:51 »
Hey guys, jhoang here. Sorry I haven't logged in GH recently, shipping time will be delayed to late May/early June. Machining for the keyboards is 2/3 done, I will update some photos here once it's complete. Also, some invoices for assembly has been sent and kuang2 is preparing/sourcing the components. I'm sorry we couldn't have the GB finished by the expected timeline and due to my personal work I couldn't provide enough updates or answered your pms in a timely manner. It was mostly me communicating with Exclusive but don't worry, I got help from some friends and all your changes were noted in a separate spreadsheet, will reply and confirm them right now
« Last Edit: Mon, 01 May 2017, 08:17:38 by jhoang »
Offline jhoang
  • Matrix Lover
« Reply #447 on: Mon, 01 May 2017, 06:28:28 »
Regarding the pms about extras I will check and post it here later as there were some units from unpaid orders still being produced.
For now, order #11 (mrboovn) is up for grabs. PM me your info (pp email, name, shipping address, phone number) if you are interested.
Offline itskuroi
« Reply #448 on: Mon, 01 May 2017, 08:05:31 »
Should we still pm you with files for the weight/name plates?
Offline jhoang
  • Matrix Lover
« Reply #449 on: Mon, 01 May 2017, 08:19:08 »
yes I got some files that you guys have sent here and will send them to Exclusive, if there's something needed to be change I will contact you back
