Author Topic: [GB] Lightsaver V3 Kustom Keyboard - All Shipped!  (Read 366634 times)
Offline Blazestorm
Re: [GB] Lightsaver V3 Kustom Keyboard - 1st Batch Shipped, 2nd Batch Pending
« Reply #700 on: Thu, 02 November 2017, 12:53:19 »
I have a spare PCB + Polycarb plate to sell at cost if anyone is interested in grabbing a spare, decided I won't use it. Pending
Back to being available if anyone needs a spare PCB+Plate. Gone
« Last Edit: Wed, 08 November 2017, 13:06:40 by Blazestorm »
Offline megaforce
« Reply #701 on: Thu, 02 November 2017, 13:04:22 »
@Elton
Not much more than what our Korean overlords were asking for  :-*
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline Prankk
« Reply #702 on: Thu, 02 November 2017, 14:20:28 »
Does anyone have any idea why the in switch leds are only turning on and off when i use the led func, modi, alph, or pad options from O2D. Shouldn't using those keys cycle through multiple different led modes?
Offline eldonw
« Reply #703 on: Thu, 02 November 2017, 23:28:19 »
PM'd
Offline elton5354
« Reply #704 on: Fri, 03 November 2017, 15:37:42 »
@Elton
Should be a LED setting for that...there are so many functions it confuses me.
Offline Prankk
« Reply #705 on: Fri, 03 November 2017, 15:42:41 »
@Elton
Yeah, idk either. I thought on the Orion V2 that i had, using those functions cycled through the modes. Not sure what I'm missing.
Offline zoomwalt
« Reply #706 on: Fri, 03 November 2017, 17:00:15 »
PM'd as well.
Offline ihalatch
« Reply #707 on: Sat, 04 November 2017, 07:35:19 »
I soldered the corners switches and started testing the PCB. I noticed that the top right key, the one that is supposed to be PgDn is only affecting the smd rgb leds. It doesn't register as PgDn? Is there anything wrong? It seems to change a few underglow mods.
Offline ctrlX
« Reply #708 on: Sat, 04 November 2017, 09:01:48 »
Also noticed that when I was inspecting and testing the PCB. I also noticed that all underglow RGBs are set to a white colour.. previous PCBs all had colour cycle on by default.
Regarding the key in top right corner.. I assume it can be remapped to whatever using O2D software.
Sent from my Nexus 5X using Tapatalk
Offline ChitownM2
« Reply #709 on: Sat, 04 November 2017, 15:15:55 »
One thing I noticed regarding the RGB  underglow is that the numbers in the configurator do not match up with the board itself. The configurator shows RGB No. 1 being at ~ the F1 location when in fact it is at Left Shift.
So the color you input for No. 1 will actually appear where the configurator shows #16. No. 2 will be at #17, 3 at #1, etc. The order continues on clockwise.
Not a big deal, but maybe something that whoever wrote the software could easily correct on the graphic.
Offline ihalatch
« Reply #710 on: Mon, 06 November 2017, 04:37:19 »
Packaging was impeccable. I built it last night. I'm still playing with its configuration. Sorry for the iPhone shots. I don't use backlighting or underglow normally but I put sip sockets in each switch and indicator leds. A few pictures:
Offline eddible
« Reply #711 on: Tue, 07 November 2017, 11:41:33 »
Finished mine the other day but hadn't got the camera out since!
181762-0
Offline ChitownM2
« Reply #712 on: Tue, 07 November 2017, 13:11:10 »
Yuri is going on mine as well as soon as I get the holtites I've been waiting on.
Offline poolside
« Reply #713 on: Tue, 07 November 2017, 14:47:48 »
Happy to report that my kit got to me safely as well. PCBs working and flawless top and bottom pieces.
That additional packaging was welcomed and did its job. Thank you Elton and the Duck team  :thumb:
Nice!
Offline yookwh
« Reply #714 on: Tue, 07 November 2017, 17:26:48 »
Were you going to solder on the hotlites? I heard that there's not a nice fit with them and the PCB
« Reply #715 on: Tue, 07 November 2017, 17:32:56 »
this is a very nice picture
Offline ChitownM2
« Reply #716 on: Tue, 07 November 2017, 19:19:48 »
Don't know exactly what I'm doing until I receive the holtites. I also have some mill max sockets that I can use if the holtites don't fit well or won't stay in place on the bottom row. The LED holtites are all installed and working, but the GB I bought them from shipped led separate from switches so I'm still waiting on them to see exactly how I'm going to do this.
Offline eldonw
« Reply #717 on: Thu, 09 November 2017, 23:58:11 »
I just received my holtites today and the fit is pretty loose. To hold them in place, I added a small amount of solder to the top of the pad/holtite.
Here's a picture under the scope of what I did: https://imgur.com/a/6xf74
« Last Edit: Sun, 12 November 2017, 11:17:33 by eldonw »
Offline ChitownM2
« Reply #718 on: Fri, 10 November 2017, 12:03:32 »
Interesting. I was planning to just tack the holtites in place on the bottom of the PCB.
So does your solder actually flow over the top of the holtite and actually sandwich the top lip against the PCB?
Offline elton5354
« Reply #719 on: Tue, 14 November 2017, 09:04:21 »
No updates from my end yet. Will update as soon as I hear!
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #720 on: Tue, 14 November 2017, 09:59:11 »
Cool, thanks for the status check-in  :thumb:
-Dana
Offline eldonw
« Reply #721 on: Thu, 16 November 2017, 19:42:47 »
Yeah, it appears to flow over the top. Hoping to look back into it this weekend and like you were saying, add some to the bottom as well.
Offline elton5354
« Reply #722 on: Thu, 16 November 2017, 21:41:46 »
Tracking #s are up for the 2nd batch.  All were shipped yesterday except for 1 order which will be shipped shortly.
Thank you all for your patience!
Offline avid
« Reply #723 on: Thu, 16 November 2017, 21:44:08 »
YES!!!!
Thanks for the update.
How close is the JETFIRE?
Offline Atredl
« Reply #724 on: Thu, 16 November 2017, 21:44:46 »
It's happening... they're on the way... and I cant wait!!!
Edit: Holy cow, the package is already in LA  :D
« Last Edit: Thu, 16 November 2017, 21:51:19 by Atredl »
Offline Oblotzky
  • Backspace is for people that make mistakes.
« Reply #725 on: Fri, 17 November 2017, 05:57:07 »
At first I checked in on GH and saw that the title still reads '1st Batch Shipped, 2nd Batch Pending' and was slightly disappointed by another day passing, but then I read up and mine is already in Frankfurt! So excited oh boy
Offline IAmPyhrra
« Reply #726 on: Fri, 17 November 2017, 12:45:33 »
Didnt even know second batch shipped, I am excited!
Offline elton5354
Re: [GB] Lightsaver V3 Kustom Keyboard - All Shipped!
« Reply #727 on: Fri, 17 November 2017, 14:02:39 »
Enjoy friend!
More details about my next GB will be coming soon! ;D
Offline futurecrime
  • Get Zooted
« Reply #728 on: Fri, 17 November 2017, 14:31:27 »
So now I have an LZ and a Duck in the post at the same time.  :)  And I have next week off work so hopefully will have time to build whichever one arrives first. I'm stoked. Race to me my pretties!
Offline briannnn
« Reply #729 on: Sun, 19 November 2017, 03:42:34 »
If someone could point me to the o2d 1.11 software I'd really appreciate it.  I can't find it anywhere (only up to 1.10), and I can't seem to program the split backspace with older versions.
Edit:  Found it http://kbdlab.co.kr/index.php?mid=board_sw&document_srl=100301 of course seconds after I posted this.
« Last Edit: Sun, 19 November 2017, 03:50:32 by briannnn »
Offline mustcode
« Reply #730 on: Sun, 19 November 2017, 14:35:43 »
Received the package a few days ago and just got the time to unpack it. My god, you guys weren't kidding when you said it's well packed!
Every piece is flawless, very impressed with my first Duck :)
Offline MandrewDavis
  • Chasin' That Neon Rainbow
« Reply #731 on: Mon, 20 November 2017, 11:40:48 »
I am not going to be home when my package arrives, hopefully USPS requires signature confirmation. Can anyone else confirm this to be the case?
Edit: Cool, thanks!
« Last Edit: Mon, 20 November 2017, 13:26:47 by MandrewDavis »
I've come to view humanity as predominantly monkey business.
My Classifieds Thread
Offline aaron6301
  • Pixel Pusher
« Reply #732 on: Mon, 20 November 2017, 12:01:14 »
Yeah, signature was required for LS3.
Sent from my SM-G955U1 using Tapatalk
« Reply #733 on: Mon, 20 November 2017, 15:41:49 »
ALL international packages require a signature with USPS.
Offline Azzures
  • ༼ つ ಥ_ಥ ༽つ PRAISE HELIX ༼ つ ಥ_ಥ ༽つ
« Reply #734 on: Tue, 21 November 2017, 01:50:22 »
Just got mine! Still waiting on switches though, is there an easy way to test the PCB's to make sure they are fine?
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #735 on: Tue, 21 November 2017, 02:23:11 »
Use a pair of metal tweezers and short the two switch pins. Check on a key tester such as Switch Hitter. Rinse and repeat
Sent from my SM-G935T using Tapatalk
Offline zoomwalt
« Reply #736 on: Tue, 21 November 2017, 19:01:00 »
I will buy spare pcb / plate combo if anyone decides to sell later.
Offline OfTheWild
« Reply #737 on: Tue, 21 November 2017, 20:36:22 »
This is what I do too.
A word of caution though, if you're using the needle point electronics tweezers like these do not stick the tweezers into the sockets to make the connection. That is exactly how you rip pads on a pcb.
-Dana
Offline Azzures
« Reply #738 on: Tue, 21 November 2017, 21:33:25 »
Thanks for the warning! Now im terrified though, might just wait for my switches and hope for the best since i have 2 pcbs....Will a multi-meter work?
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #739 on: Tue, 21 November 2017, 22:40:13 »
A multimeter would work! You can do a continuity test.
Offline Azzures
« Reply #740 on: Tue, 21 November 2017, 23:08:03 »
Cool, just to be clear, all i have to do is turn the multi-meter to continuity mode, and test the pins where the switch would go to see if the meter makes a beep? (All while the board is unplugged)
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #741 on: Tue, 21 November 2017, 23:42:33 »
You should plug it in if you'd like to test it. No electricity = no test
Offline Petch
« Reply #742 on: Wed, 22 November 2017, 07:01:50 »
£24.95 customs fee for anyone interested
Offline LDobler
« Reply #743 on: Wed, 22 November 2017, 07:03:33 »
No Customs fees for me :)
Offline Atredl
« Reply #744 on: Wed, 22 November 2017, 22:15:59 »
Picked up mine from the post office today and the anodization looks immaculate  :-* Unfortunately still haven't decided what switches I'm going to build it with though.
Tested the PCB and just wanted to confirm with anyone who might know. The left switch pads of the split backspace don't register as anything. I assume the default layout just doesn't have anything assigned to those pads but since I plan on building it with a HHKB style alpha section I want to make sure that everything is in order.
« Reply #745 on: Thu, 23 November 2017, 03:38:05 »
Default layout doesn't have that. Have fun with o2d.
Offline Atredl
« Reply #746 on: Thu, 23 November 2017, 03:45:18 »
So I’ve heard. Although I’ve already found my ideal layers so it’ll be a set and forget deal.
Offline rasmusx
« Reply #747 on: Thu, 23 November 2017, 09:34:16 »
Anybody tried to run QMK/TMK firmware on this keyboard? Thinking to port it there if not done..
« Reply #748 on: Thu, 23 November 2017, 10:01:43 »
It can be done in theory, since QMK and o2d both require the same controller.
Offline rasmusx
« Reply #749 on: Thu, 23 November 2017, 11:24:17 »
Yes, it shouldn't be very hard. I know there was implementation for Lightsaver v2. Will try to look over weekend into it.
