Author Topic: [IC] ePBT Royal Alpha  (Read 122066 times)
Offline pcire
Re: [IC] ePBT Royal Alpha
« Reply #200 on: Tue, 04 June 2019, 00:51:59 »
Received the updated samples from ePBT a few days ago. When I have a chance I'll go over them and check that everything is up to snuff before continuing on.
Awesome news!
Offline pepo2181
« Reply #201 on: Tue, 04 June 2019, 06:52:17 »
Ohh didn't see this before!! Now I want it!!
Offline donutcat
  • I have ideas. Sometimes they're even good ideas.
    • Donut Cables
« Reply #202 on: Sun, 09 June 2019, 03:47:19 »
Got a chance to open the set up and see what's what:
Base kit - notice I'm missing the ISO Enter
Intl kit
Looking at warping in the big spacebars
Loooking at warping in the other longer keys
Good news: It looks good. Alignment seems quite good with many of the special characters being much improved.
Bad news: Long keys are pretty warped. In the very small amount of time I've had to check in on stuff I had seen some mention of recent ePBT stuff having more warping due to changing colors. When I get in touch I'll try to see if there's any info about working on that before the set is ready to run.
Unrelated: I really need to get a display board for full sets so I don’t have to try and line up keys manually. PCB for a standardized full set display board ? :thonk:
« Last Edit: Sun, 09 June 2019, 03:59:53 by donutcat »
Offline cldskt
  • Wallet and hobby aren't friends
« Reply #203 on: Sun, 09 June 2019, 04:17:06 »
Intl kit
Yep that’s the usual warping. Not sure if anything can be done about that at this point tbh.
"Addiction is buying the things that I don't need with the money I don't have." - me
"Spending $500 on your first custom is justified." - also me
Offline donutcat
    • Donut Cables
« Reply #204 on: Sun, 30 June 2019, 02:04:03 »
Finally had the time to get the set onto a board. Consistency and alignment are much better *across the board* than the first batch. I'm pretty happy with the current look of the set.
I did put what long keys I could on stabs to see how bad the warping would affect them. The long spacebars seem fine, a couple of the 2u-2.75u seem a little sticky, I couldn't test the 3u. I'll talk with them and see if the warping was just this sample being rushed out and if for the GB QA for warping will be a bit more stringent.
Offline laserbeamspewpew
« Reply #205 on: Sun, 30 June 2019, 08:25:17 »
Are those green accents part of this set? Can we get some of the lighter green color?
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #206 on: Sun, 30 June 2019, 09:42:28 »
Wow, EPBT actually did reverse dye sub? Is that a first?
Edit: oops, those look like GMK caps.
Offline EMC Labs
« Reply #207 on: Sun, 30 June 2019, 18:18:49 »
Did this ever drop by any chance? It's quite old but it is still in IC.
Offline donutcat
    • Donut Cables
« Reply #208 on: Sun, 30 June 2019, 20:54:48 »
Still working on it. Waiting for a bit more feedback on this stage and then the next step is hopefully discussing specifics of the GB process with KBDFans.
Offline EMC Labs
« Reply #209 on: Sun, 30 June 2019, 22:13:32 »
Oh okay. I really like the design and wish it makes GB. Thanks for letting me know.
Offline donutcat
    • Donut Cables
« Reply #210 on: Tue, 30 July 2019, 21:10:06 »
So, back to working on this and I've hit a point where feedback is needed. Lots of people are wanting some accent keys keys for the set. After talking with Gok about his experience with reverse subs from ePBT, his statement was that it's not as sharp as the normal subbing and the color has some inconsistency in it. So here's a strawpoll to see where people's opinions lie for this https://www.strawpoll.me/18401714. I'll let this run for awhile and see where it sits before moving forward.
Offline EMC Labs
« Reply #211 on: Tue, 30 July 2019, 21:39:22 »
Great to hear!
« Reply #212 on: Mon, 05 August 2019, 21:38:33 »
I think a couple accents like kuro/shiro had wouldn’t increase the cost too much, no? I suggest a couple of green CODE keys like the RA typewriter this set is based on instead of the traditional Esc-Enter. Or just make it a separate kit.
Offline ideus
  • Björkö.
« Reply #213 on: Tue, 06 August 2019, 09:50:22 »
My wallet has a conflict of interest between this and 9009 r3. Cannot get both.  :'(
« Reply #214 on: Tue, 06 August 2019, 09:50:52 »
Easy:
ePBT > GMK.
Offline ideus
  • Björkö.
« Reply #215 on: Tue, 06 August 2019, 09:53:02 »
Easy:
ePBT > GMK.
But GMK has all the molds for my 50 oddness requirements and the great R5 bottom row. An old fart like me cannot let the Classic to pass.
« Reply #216 on: Tue, 06 August 2019, 10:16:36 »
Easy:
ePBT > GMK.
Oh... I see.
Offline EMC Labs
« Reply #217 on: Sat, 17 August 2019, 04:05:19 »
Any updates on this?
Offline donutcat
    • Donut Cables
« Reply #218 on: Sat, 17 August 2019, 09:18:23 »
Working on getting some updated quotes to consider the effect the reverse subs could have on the set price if implemented. The results of the poll were quite close so I'm wanting a bit more information to work with.
Offline EMC Labs
« Reply #219 on: Sat, 17 August 2019, 09:25:26 »
Great to hear. Excited about this set.
Offline Rayndalf
« Reply #220 on: Sat, 17 August 2019, 14:46:17 »
Please considered 'barred only' (or 'scooped only' if ePBT has molds) instead of 'barred and scooped' homing keys.
Offline donutcat
    • Donut Cables
« Reply #221 on: Sun, 01 September 2019, 02:25:25 »
Small update, getting quotes for base kits both with and without some reverse subbed keys added in to see how significant the difference is. This should also be when I get my quotes for what KBDFans' pricing will be for the GB process since I've elected to go through them due to my current situation.
Offline donutcat
    • Donut Cables
« Reply #222 on: Mon, 09 December 2019, 03:06:52 »
So it's been a hot minute since the last update; stuff just kinda got buried under work to do and things that needed more of my attention. I'm back in touch with Wei and we're knocking out the final details right now. What I can tell you right now is we are looking to go forward with a couple reverse-subbed accent keys as long as the samples for them look good.
Of note is I'm also currently in a situation concerning the "international kit": ePBT's MOQ is 200, so I'm almost sure an international kit wouldn't hit that, but on the other hand it's a lot of keys to tuck into the base kit. I'm not wanting to ditch it completely but I'm sure keeping "unnecessary keys" in the base is of concern for people. Something I have to think on.
Offline bananasplit_00
« Reply #223 on: Mon, 09 December 2019, 03:15:46 »
I think these look pretty great, interested for sure!
Really enjoy my Budget96 and i think these would look nice on it  ;D
Offline scoopbb
« Reply #224 on: Mon, 09 December 2019, 10:37:17 »
ortho kit please. epbt has molds and its super cheap usually
« Reply #225 on: Mon, 09 December 2019, 10:57:04 »
Kinda silly but how about green 1u blanks instead? Might be cheaper.
Offline scoopbb
« Reply #226 on: Mon, 09 December 2019, 12:10:08 »
ortho kit is like 12 - 18 bucks for the epbt sets. thats already cheap in my book
Offline Slayer77
« Reply #227 on: Mon, 09 December 2019, 23:52:09 »
Please keep 2u shift in base
Sent from my GM1911 using Tapatalk
Offline Zurg Eon
« Reply #228 on: Tue, 10 December 2019, 09:57:05 »
Very interested in this. Hoping the international kit stays. A 1.5u green backspace like the original typewriter had could have been nice.
Offline rockydbull
« Reply #229 on: Tue, 10 December 2019, 10:38:30 »
Interesting, I was under the impression from other custom epbt sets run recently that the MOQ of 200 is for the base kit and the child kits don't have a MOQ. Looking at 2048 and SJA I can't imagine all of those child kits got to 200.
Offline ideus
  • Björkö.
« Reply #230 on: Tue, 10 December 2019, 12:35:13 »
There is no international kit in the OP. What do you mean? Even if it were included it only may be manufactured if vendors help to support it reaching MoQ. Also, an international kit would be redundant with the green international sub legends.
Offline Zurg Eon
« Reply #231 on: Tue, 10 December 2019, 12:50:44 »
I mean this:
Intl kit
Offline ideus
  • Björkö.
« Reply #232 on: Tue, 10 December 2019, 14:01:20 »
Thank you for the answer. If this were included, I would be in. I do not use the US ANSI anymore, so I need a set that covers Nords layouts. By the way, it is missing a R4 <>| key.
Offline eskimojo
    • KeycapLendar
« Reply #233 on: Thu, 12 December 2019, 09:23:10 »
So MOQ Hit?
Yes. It was 200 for the base kit. That’s all :thumb:
Did something change on the ePBT side? biip and his vendors were very clear that the 200 MOQ was only for base, and child kits effectively had a MOQ of 1.
Offline donutcat
    • Donut Cables
« Reply #234 on: Thu, 12 December 2019, 09:55:37 »
So MOQ Hit?
Seems I'll need to go doublecheck on what I was told then. I was fairly sure they said 200 per kit, but there's a chance with everything language barrier included I may have misunderstood.
Offline eskimojo
    • KeycapLendar
« Reply #235 on: Thu, 12 December 2019, 10:07:23 »
By the way, I recommend checking these two articles out for designing an International kit - they helped me out a lot when designing mine.  :D
Possible International Kits for Custom Sets
A Visual Comparison of Different National Layouts on a Computer Keyboard
Offline donutcat
    • Donut Cables
« Reply #236 on: Fri, 10 January 2020, 06:17:48 »
I'll just leave this here. Also, I'm getting the splitting up of the kit and the issue of MOQ for the Intl kit taken care of as well. Hoping we might finally have this ready to get going here shortly.
Offline Fredington
    • Instagram
« Reply #237 on: Fri, 10 January 2020, 06:20:17 »
Looks good but I would really like to see some of the lime green accents on non-traditional accent keys like delete and code (as per the original RA keyboard):
« Last Edit: Fri, 10 January 2020, 07:36:41 by Fredington »
« Reply #238 on: Fri, 10 January 2020, 06:24:58 »
-snip-
So are the lime sublegends going to be there or not? Its really nice either way but they are definitely part of the appeal :)
Offline donutcat
    • Donut Cables
« Reply #239 on: Fri, 10 January 2020, 07:22:59 »
-snip-
Realized I hadn't yet posted a recent mockup for the set:
Hmm, for some reason this pic has issues with embedding well.
« Last Edit: Fri, 10 January 2020, 10:43:00 by donutcat »
« Reply #240 on: Fri, 10 January 2020, 08:55:04 »
-snip-
-snip-
Sweet, looks amazing!
Offline nephlock
« Reply #241 on: Fri, 10 January 2020, 18:52:37 »
-snip-
I’m so hot for this.
Offline Zurg Eon
« Reply #242 on: Fri, 10 January 2020, 19:41:39 »
Looks super nice!
Found an issue with the 9-key in the international section. I believe it should have ) as the sub legend. 8 has (.
Other than that, I feel like I can live without two of the keys that would bring perfect (?) or closer to perfect ISO Nor compat (i.e. 2"@ and 4¤$).
Interesting inclusion of two 3u spacebars. Haven't seen those before, but I guess there's a use for them.
Here's an idea: Include a lime green 2u backspace with box-icon. That's an accent key I would use, just to match the original this is based on for modern layouts. :D (even though the original had a 1.5u backspace in the top right corner)
And also, I would suggest dropping the icon from the shift keys. Would match better with the other mods. OG didn't have icons either, except for backspace. Icons on enter, backspace and tab are fine though.
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #243 on: Fri, 10 January 2020, 20:43:31 »
Looks super nice!
Oops. Nice pick up. I'll get this fixed right now. Cheers.
Offline ideus
  • Björkö.
« Reply #244 on: Fri, 10 January 2020, 21:15:50 »
Does the <> key cap fit better in the international kit? If so it should have the less/greater-than symbols in dark green and the pipe and back slash in light green, and their positions should be switched on the key.
Offline donutcat
    • Donut Cables
« Reply #245 on: Sat, 11 January 2020, 07:45:02 »
It's the R4 key for basic Eng-Intl/ISO support. As with many of the keys in this version, the legends are a bit of a compromise focusing firstly on Eng-Intl(the basis of the set) and *then* adding <> to technically meet the needs of several ISO layouts.
« Reply #246 on: Mon, 03 February 2020, 05:18:19 »
Got any updates on timeline and so on? Vendors? GB time? Looking forward to this set a lot :)
Offline bukowski
« Reply #247 on: Mon, 03 February 2020, 06:10:48 »
The compatibility on the base-set... especially the extra addition of ÖÄÜ will make me join this one! Thanks for your efforts, donutcat
Offline ideus
  • Björkö.
« Reply #248 on: Mon, 03 February 2020, 09:32:09 »
I'm so tempted by the Norse languages support. Also, the care the OP is giving to the quality of the fonts and plastic matching OG's is admirable.  :thumb:
Offline donutcat
    • Donut Cables
« Reply #249 on: Mon, 03 February 2020, 16:33:39 »
This will be handled just by KBDFans just like how Kuro/Shiro was done. For right now I'm basically waiting on CNY to be over and then we can finish up the details to move to GB phase. With the Coronavirus dealio going on there's a chance that could affect our timeline too.
