Author Topic: [IC] 60% case w/ brass plate [under glow][Non-floating 7 deg] Group Buy launched  (Read 56286 times)
Offline sennin32
    • Doyu Studio
Hi, guys!
This is idea by a member from New Zealand who's looking for a custom case.
We design and modify based on the sketch.
But it is too hard to make it with single one.
So we're looking for running a GB to make it become real!
Update '18 Feb 9th - Group Buy launched
Group buy thread : https://geekhack.org/index.php?topic=93969
Update '18 Feb 2nd - Price range
We named the Model B as Chiwi60.
And we're doing another poll for hhkb layout.
It is about 6u and 7u spacebar version.
https://goo.gl/forms/tpRwrwIZhqTfBTwu2
If you're not looking for hhkb version, ignore it :)
Update '18 Jan 31 - Price range
Chinese New Year is coming.
Manufacturers are going to enjoy their holiday from early Feb to late Feb.
So leading time will be pretty long.
Estimate time for now is lay may to early June 2018.
Price will around :
Anodized aluminum : $150
Painted white aluminum : $160
Brass : $250
HHKB and universal usb port (Type-C port as default)has extra cost due to quantity.
Update '18 Jan 30 - 2nd sample
Pics : https://imgur.com/gallery/IxE5L/comment/1246798129
The group buy for PCB that support this case is running :
https://geekhack.org/index.php?topic=93685.0
HHKB body(plate in rendering is not for HHKB):
Update '17 Dec 19 - 1st sample
Manufacturer forgot the engrave legends on the bottom  :-[
Here's IC link : https://goo.gl/forms/F9TeptWGMgkfI3jC2
Main Body
made by anodized aluminum.
Maybe provide some PVD brass version.(Very expensive, you know, not possible to order too many XD)
Mount Plate
will offer 2~3 versions or maybe more if layouts if MoQ reached for each layout.
Made by PVD brass.
Also, you guys can cut your own layout base on our files.
Default layout will be, which fits our DO60 PCB: https://geekhack.org/index.php?topic=91773.msg2498690#msg2498690
For default layout, only support plate mounted stabilizer.
Also, standard ANSI, ISO 60% universal will also available, support PCB mounted stabilizer.
Bottom plate
is made by polycarbonate(For now, will  check it again after sampling) with sandblast surface.
Nameplate is also PVD brass, insert in bottom plate.
  • Poll
  • protyping again and again
  • Revise again and again
  • launch GB
  • lManufacturing
Looking for more opinions!
hf.
« Last Edit: Sat, 10 February 2018, 22:46:07 by sennin32 »
Re: [IC] 60% case with brass plate [under glow] [Non-floating] [7 deg]
« Reply #1 on: Thu, 30 November 2017, 00:42:03 »
instabuy
will there be a version with HHKB blockers?
« Last Edit: Thu, 30 November 2017, 00:45:13 by Puddsy »
Offline sennin32
    • Doyu Studio
« Reply #2 on: Thu, 30 November 2017, 00:47:59 »
instabuy
For HHKB layout, we might able to make it as an check option.
If it reach MoQ, we can do it :)
We'll also offer 3u cap as kit option.
Surely, also provide other layout as well.
« Reply #3 on: Thu, 30 November 2017, 01:13:58 »
instabuy
perfect, thank you
Offline Vadurr
  • Valar Morghulis
« Reply #4 on: Thu, 30 November 2017, 01:19:15 »
instabuy
I'm afraid I'll have to buy this as well...If an HHKB version is available at least! :thumb:
Offline superdoedoe
  • ( ͡° ͜ʖ ͡°)
« Reply #5 on: Thu, 30 November 2017, 03:44:08 »
+1 for me pls
Offline duynguyenle
  • Personal text? What personal text???
« Reply #6 on: Thu, 30 November 2017, 04:05:09 »
I was in your GB for Filco case, very happy with that one, I think I will get in this one too. How many orders needed to get Brass version to go ahead? Can you give rough estimates of cost for both aluminium and brass version?
Edit: Google form is currently private, can you make it public so people can fill in? Thanks!
« Last Edit: Thu, 30 November 2017, 04:07:50 by duynguyenle »
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline sennin32
    • Doyu Studio
« Reply #7 on: Thu, 30 November 2017, 05:08:24 »
Done
« Last Edit: Thu, 30 November 2017, 06:07:41 by sennin32 »
Offline sennin32
    • Doyu Studio
« Reply #8 on: Thu, 30 November 2017, 06:04:35 »
For full brass version.
Maybe only 10 sets or even lesser.
Price will be pretty high.
Around 1.7~1.8 times price for brass body compare with anodized aluminum body.
So, total price will be around 1.5~1.6 times I think.
And the shipping fee will become higher.
For now, we haven't see the sampling of pvd brass.
We'll make the sample with 3 or more manufacturers to compare the quantity and cost.
Then we'll get precise price.
And there's some extra features we want for this case with effect the price.
For now, I'll say around $150 or lower for aluminum body version.
Offline FailureToLoad
« Reply #9 on: Thu, 30 November 2017, 07:34:08 »
That default layout is pretty unique. I'm very interested, its a really ideal layout for me.
« Last Edit: Thu, 30 November 2017, 07:36:22 by FailureToLoad »
Offline bluesclera
« Reply #10 on: Thu, 30 November 2017, 08:51:45 »
Is it solid brass or just brass coating? I vote for NO underglow
Offline Vigrith
« Reply #11 on: Thu, 30 November 2017, 09:10:06 »
Firstly, HHKB blockers please. After that, if you stay true to your $150~ price estimate for the aluminium version I'll buy multiple. If you go through with the Tiffany blue colour and actually make it look good (yet to see someone anodise it properly) I'll buy at least two in that.
Very interested, obviously.
Offline sennin32
    • Doyu Studio
« Reply #12 on: Thu, 30 November 2017, 09:53:59 »
Solid brass with PVD surface treatment.
We'll provide the plate file on git.
In order people want to make some custom options.
Cause our PCB has build in underglow RGB, so we might only offer under glow bottom :)
Offline bluesclera
« Reply #13 on: Thu, 30 November 2017, 10:01:03 »
Solid brass is super sweet but not sure about the super shiny PVD surface treatment.
Also i've read many many complaints that acrylic bottoms are the first to crack/break/snap - even with the M65-A.
Offline sennin32
    • Doyu Studio
« Reply #14 on: Thu, 30 November 2017, 10:04:49 »
So,
We avoid acrylic, and might go ahead with polycarbonate.
More flexable, brings higher strength.
But we'll compare several materials, and chose proper one.
Offline Vadurr
  • Valar Morghulis
« Reply #15 on: Thu, 30 November 2017, 11:57:56 »
Hoping for a White option :thumb:
Offline TalkingTree
    • My projects
« Reply #16 on: Thu, 30 November 2017, 13:49:22 »
No stepped caps lock support?
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #17 on: Thu, 30 November 2017, 14:19:38 »
I guess that this could easily be supported in the plate but I don't think the PCB itself does.
You could always use a DZ60 instead.
Offline cdn-mini
« Reply #18 on: Thu, 30 November 2017, 14:38:12 »
I would buy brass but how about a brass bottom option?
Offline sennin32
    • Doyu Studio
« Reply #19 on: Thu, 30 November 2017, 14:56:50 »
Sure, it support.
Offline Vigrith
« Reply #20 on: Thu, 30 November 2017, 15:09:08 »
Sure, it support.
Unrelated question but does each colour have their own MOQ, and if so how many cases would that be for each? The Tiffany Blue you suggested, Pink (bubblegum/hot), white (that'd have to be powder coated I suppose), etc. would all be colours I'd love to see.
Offline Vadurr
  • Valar Morghulis
« Reply #21 on: Thu, 30 November 2017, 18:59:38 »
Sure, it support.
It'd be nice to see all these unique colors :]
Offline sennin32
    • Doyu Studio
« Reply #22 on: Thu, 30 November 2017, 21:54:26 »
Sure, it support.
At least 15~20 I think.
Offline Vigrith
« Reply #23 on: Fri, 01 December 2017, 11:12:02 »
Got it. Not a super small amount of units but I'm pretty sure that with this design and pricing most colours wouldn't have a problem making the cut.
I assume you plan on having some small samples of each colour made at some point?
Offline senter
« Reply #24 on: Fri, 01 December 2017, 15:57:04 »
Polycarbonate bottom case is nice but I still hope there's an option for bottom aluminum case.
Offline sennin32
    • Doyu Studio
« Reply #25 on: Sat, 02 December 2017, 02:41:23 »
Not really possible.
We might able to ask for some small piece anodized aluminum samples.
But not able to make samples with different colors for full case.
It cost over $250 for each sample.
If we make sample for each color, it cost thousands.
Offline mike873
« Reply #26 on: Sat, 02 December 2017, 07:57:03 »
Can you post the pics of the ISO layout variants on the IC form?
Offline Vigrith
« Reply #27 on: Sat, 02 December 2017, 09:11:16 »
Perfectly understandable - thank you for answering my questions, will be following this closely for further updates. Best of luck!
Offline bminhz
« Reply #28 on: Sat, 02 December 2017, 16:34:45 »
Very nice looking, can't wait to see some samples  ;)
Only suggestion is may be put a name to the whole thing for easy remember. "Model B" sounds too soft, called it I don't know sennin60 or kiwi60 or something
Cheers  :thumb:
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #29 on: Sun, 03 December 2017, 19:06:15 »
Cheers  :thumb:
Chiwi60?
Offline sennin32
    • Doyu Studio
« Reply #30 on: Thu, 07 December 2017, 07:39:12 »
Lolita60  :p
Offline bminhz
Offline sennin32
    • Doyu Studio
Offline arsenic
« Reply #33 on: Thu, 07 December 2017, 14:43:01 »
Lolita60  :p
DO IT  ;D
feminists will hang me on the cross  :eek:
Female feminist chiming in-  +1 for Lolita60! Even if the subject is pretty gross, the book is pretty incredible and so is this!
Offline ideus
  • Björkö.
« Reply #34 on: Thu, 07 December 2017, 15:07:30 »
As any expensive metal case should, this one looks nice, it cannot be other way with any over three hundred bucks buy, but this is nothing new, just another n-th iteration of the same style aluminum-machined-anodized-ala-Mac-case. To say that someone "invented" it is just an exaggeration.
Offline sennin32
    • Doyu Studio
« Reply #35 on: Thu, 07 December 2017, 21:18:00 »
Haha,
I mean, some body give me the idea of this.
Can not find proper word back to when I post this.
Not my native language T_T
I've edited it, sorry for the wrong words :(
Offline pixelpusher
« Reply #36 on: Thu, 07 December 2017, 22:18:11 »
Haha,
I've spoken English for close to 40 years and I do not understand this post or the one by ideus above...
Offline sennin32
    • Doyu Studio
« Reply #37 on: Sat, 09 December 2017, 06:55:31 »
Update :
Kit options will be :
1. Case kit only
2. Case + PCB kit
3. Case + PCB + laser engraved white/black keycap kit for default layout
*optional 1 : 70 pcs Kailh Box / Cherry switches include
*optional 2 : cherry PCB stabilizer/plate stabilizer(default layout only)
From IC form,
We will go ahead with following colors:
1. PVD Brass (With limited quantity only)
2. Anodized Black
3. Anodized Gray
4. Anodized purple
5. Anodized rose gold
*6. Powdercoated white (Never tried, we have to make some sample see if the surface is strong enough)
And we'll provide layouts (All mount plate is PVD brass)
1. ANSI universal
2. Our default layout
3. HHKB
4. Split space bar fit most PCBs
5. ISO universal
*6. universal for ANSI/ISO (Only make it under Moq reached)
Offline bluesclera
« Reply #38 on: Sat, 09 December 2017, 08:17:34 »
Update :
1. Case kit only
2. Case + PCB kit
From IC form,
2. Anodized Black
3. Anodized Gray
4. Anodized purple
1. ANSI universal
3. HHKB
5. ISO universal
Can i reserve a PVD Brass now so i dont miss out?
Offline bminhz
« Reply #39 on: Sat, 09 December 2017, 08:19:14 »
Update :
1. Case kit only
2. Case + PCB kit
From IC form,
2. Anodized Black
3. Anodized Gray
4. Anodized purple
1. ANSI universal
3. HHKB
5. ISO universal
Think this is FCFS
Offline sennin32
    • Doyu Studio
« Reply #40 on: Sat, 09 December 2017, 13:09:47 »
Update :
1. Case kit only
2. Case + PCB kit
From IC form,
2. Anodized Black
3. Anodized Gray
4. Anodized purple
1. ANSI universal
3. HHKB
5. ISO universal
Hi,
The quotation of brass ver is around 1.6~1.8 times higher than aluminum.
We just need to make sure we won't have too many stock after GB end, or it is too risky  :-X.
We 'll consider the quantity of orders, and make sure orders in first few days will get it.
But for guys order it later, will put on the waiting list.
In order somebody might change their mind, and we can sell them to people on the waiting list.
Offline bluesclera
« Reply #41 on: Sat, 09 December 2017, 13:14:15 »
Update :
1. Case kit only
2. Case + PCB kit
From IC form,
2. Anodized Black
3. Anodized Gray
4. Anodized purple
1. ANSI universal
3. HHKB
5. ISO universal
Hi,
Why not require a deposit? Good for you and good for the serous buyer.
Offline sennin32
    • Doyu Studio
« Reply #42 on: Sat, 09 December 2017, 13:17:35 »
Update :
1. Case kit only
2. Case + PCB kit
From IC form,
2. Anodized Black
3. Anodized Gray
4. Anodized purple
1. ANSI universal
3. HHKB
5. ISO universal
Hi,
If people change their mind.
We won't force them to accept it in any conditions before shipping.
Even for custom orders which already processing.
We'll refund them to prevent more issues.
Offline JDragon
« Reply #43 on: Sat, 09 December 2017, 13:41:26 »
Submitted a form for PVD coated brass case, Tiffany Blue as a backup. Hope this gets made in PVD brass, nothing else like it in the market.  :thumb:
Offline Katsumi
  • HHKB<3
« Reply #44 on: Sun, 10 December 2017, 15:11:11 »
Really interested in Brass and White. Glad to see HHKB support being added from the IC Form.
Offline cdn-mini
« Reply #45 on: Sun, 10 December 2017, 15:20:54 »
Can the keys be reprogrammed? The Alt and Win on the right side dont work for me. And the '?' in place of right shift is wack! or is that a Fn layer?
« Last Edit: Sun, 10 December 2017, 15:55:21 by cdn-mini »
Offline Vigrith
« Reply #46 on: Sun, 10 December 2017, 15:47:54 »
You can pretty much always assume custom boards like this use programmable PCBs (regardless of whether or not they are included in the buy). So yes.
Offline Theconejo
« Reply #47 on: Sun, 10 December 2017, 16:38:44 »
Powdercoated white! Bike frames have been powder coating for a long time and although they put a few layers of clear coat on them the powdercoat is pretty resilient to most light abuse it may get.
I was on the fence but if that powdercoat happens I’m in.
Offline Rumblehotep
« Reply #48 on: Wed, 13 December 2017, 00:45:39 »
Death By Brass!
Offline mudcakehoney
« Reply #49 on: Wed, 13 December 2017, 00:55:10 »
This would look gorgeous in rose gold
