Author Topic: [IC] ELEMENTO X zFrontier. Fr87 PRICING and More! GB starts in 2 hours!  (Read 41159 times)
Offline fine_italian_leather
Re: [IC] ELEMENTO X zFrontier. FR87 Half-plate & Bluetooth All new renders! Feb8
« Reply #100 on: Sat, 10 February 2018, 09:29:34 »
Looks great! Totally on board.
Offline gorauskas
« Reply #101 on: Sat, 10 February 2018, 10:55:44 »
+ 1
Offline zFrontier
Chinese Website: https://www.zFrontier.com/
English Website: https://en.zFrontier.com/
Facebook: https://www.facebook.com/zFrontier/
Email: support@zFrontier.com
Offline zFrontier
Re: [IC] ELEMENTO X zFrontier. FR87 Half-plate & Bluetooth GB soon! Feb12
« Reply #103 on: Mon, 12 February 2018, 06:28:24 »
Here's a nice wallpaper for you  ;)
Updated with some GB info in OP, feel free to shoot us any question you have.
188687-0
Offline Choppersuey
« Reply #104 on: Mon, 12 February 2018, 07:45:20 »
Looks great, very excited for the price reveal and the full plate options :thumb:
I don't know if this can be answered yet, but what level of anodizing can we expect?
Also, is the plate top mount or sandwiched? Looking at the renders it seems to be the latter
Offline Darknight00z
« Reply #105 on: Mon, 12 February 2018, 14:50:24 »
Does the PCB support holtite?
Offline Peiweisgreat
« Reply #106 on: Mon, 12 February 2018, 19:55:50 »
It's too bad we won't have some bolder colors on a board that is taking things in a very experimental route. With the sleek design classic colors like this won't fail to impress though. Very interested, but will have to see what the price is looking like before I can commit. Gotta save up that M60-A still.
Offline K.Mak
« Reply #107 on: Mon, 12 February 2018, 23:05:23 »
Since the SMD LEDs can't be moved, will you just be picking one bottom row layout?
Offline cloud8992
« Reply #108 on: Mon, 12 February 2018, 23:56:15 »
will this keyboard support split backspace and will you have full plate option?
Offline plus_one
« Reply #109 on: Tue, 13 February 2018, 14:28:48 »
I love the design!  I'm very interested in buying this if my wallet allows.
Does the PCB support PCB-mounted stabilizers (specifically the Zeal stabs), or just plate-mounted?
Offline zFrontier
« Reply #110 on: Tue, 13 February 2018, 20:36:58 »
top mount ;)
The bottom row should fit a WKL and WK the SMD LED would be bright enough to shine through
Offline zFrontier
« Reply #111 on: Wed, 14 February 2018, 00:51:57 »
Yes there will be a full plate but no backspace i afraid.
PCB mount
Offline zFrontier
Re: [IC] ELEMENTO X zFrontier. Fr87 PRICING and More! GB will start on Feb 18!
« Reply #112 on: Fri, 16 February 2018, 07:40:48 »
 :thumb:
Happening very soon on zFrontier! Check OP for options and detailed pricing ;)
188989-0
188991-1
188993-2
188995-3
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #113 on: Fri, 16 February 2018, 08:12:53 »
Thanks for the update with pricing.  Could you let us know what the weight of the different combinations are?  Or even min/max of the options?
Offline Devkey
« Reply #114 on: Sat, 17 February 2018, 13:18:47 »
So if there are dip switches does this mean the PCB won't be fully compatible with, say, QMK?
Edit: Whoops, didn't read the thread closely enough. Pay no mind.
Offline zFrontier
Re: [IC] ELEMENTO X zFrontier. Fr87 PRICING and More! GB starts in 2 hours
« Reply #115 on: Sun, 18 February 2018, 00:11:16 »
GB will start in 2 hours, GB post already submitted and is waiting approval :thumb:
this thread will be closed once the GB go live and for future discussion please move to the GB thread
Thank you for your support!
« Last Edit: Sun, 18 February 2018, 00:22:02 by zFrontier »
Offline RavenPanther
« Reply #116 on: Sun, 18 February 2018, 00:30:21 »
I posted some questions on reddit but they haven't been answered, and since I want to get in early I'll ask them here before the GB starts:
Will you be offering an offset caps lock option? What safeguards are in place to prevent destroying the board if it's plugged in while there's batteries in it/while it's switched on? What kind of stabilizers will it support? Can the battery cover be flipped to expose the "structural" shapes on the back while mounted? (The switch for power is my concern here, if it's not centered then the panel can't be flipped)
As a final note, I think a black PCB is a good choice, since nobody else spoke up on that.
Offline Photoelectric
Re: [IC] ELEMENTO X zFrontier. Fr87 PRICING and More! GB starts in 2 hours!
« Reply #117 on: Sun, 18 February 2018, 01:41:26 »
Please click here for group buy information and discussion: https://geekhack.org/index.php?topic=94140.0
