Author Topic: [IC] Carbon Fiber Case Extravaganza (TKL, 65%, 60%, 45%, 40%, Keypad)  (Read 68159 times)
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
COME ONE COME ALL! WE HAVE EVERYTHING! TKLs! 60%! SMALLER THINGS!
FORM HERE
Instead of doing a singular 40% GB, foggyflute are considering offering four mini-boards (JD40, JD45, Planck, Minivan), the two cases offered in previous buys (TKL [B87 or nerD compatible] and 60% [Standard and HHKB compatible]) and two brand-spankin' new offering (65% and a keypad/numpad). Orders will take place for these simultaneously using a single order form, so feel free to order any combination of cases that your heart desires.
General material specs are as follows:
~ 1.6mm matte carbon fiber
~ Frosted white/solid black acrylic midpiece
~ Switch-mount PCB
~ M3 screws/posts
~ Acrylic feet (angles will be 7 degrees for TKL, 65%, and 60% and 5 degrees for 45%, 40%, and Keypad/Numpad)
Pricing:
TKL (nerD V2/B87):               $149 + shipping
65% (22mini rev-B/Tada68)   $109 + shipping
60% (Standard/HHKB):          $99 + shipping
45%( Minivan/Planck/JD45):   $~89 + shipping
40% (JD40)                           $~89 + shipping
Keypad (Cospad?):                 $~59 + shipping
Links to all prior GBs and the 40% IC thread are below:
CF-LITE IC
CF-LX R2
CF-LXXX TKL
CF-LX R1
« Last Edit: Fri, 13 April 2018, 13:50:33 by hwood34 »
Offline hwood34
  • underwater squad
  • #1 CL stan
Re: [IC] Carbon Fiber Case Extravaganza (TKL, 60%, 45%, 40%, Keypad)
« Reply #1 on: Wed, 28 March 2018, 00:25:59 »
As always please let me know if anything is missing or off
Offline fcoury
« Reply #2 on: Wed, 28 March 2018, 00:35:22 »
Here's hope Minivan layout makes it! Huge fan of the keyboard!
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #3 on: Wed, 28 March 2018, 00:42:39 »
Our MOQ isn't bad, so a good chance it does
Offline jimirolln
« Reply #4 on: Wed, 28 March 2018, 01:21:46 »
« Last Edit: Thu, 29 March 2018, 19:37:50 by jimirolln »
Offline xondat
  • i'm not a star
« Reply #5 on: Wed, 28 March 2018, 05:28:02 »
Filled in the form.
It's early, so I could just be getting confused, but doesn't "<7 degrees" mean anything smaller than 7? shouldn't it be the other way around? :))
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #6 on: Wed, 28 March 2018, 05:56:50 »
Did you really mean 1.6cm and not 1.6mm?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #7 on: Wed, 28 March 2018, 08:29:51 »
Filled in the form.
yep, changed. I'm learning a lot in college....
I do not. changed :thumb:
could you wip up something for the lets split...don't know how long before mehkeys get ahold of the trrs jacks and i can't source them but i would for sure be down to grab a carbon fiber plate case/sandwich to put on the back burner
probably gonna just try and stick to the cases I have now. Just looking for major keypads to get the compatibility of
« Reply #8 on: Wed, 28 March 2018, 08:47:47 »
The form link doesn't show up for me in tapatalk on android just an FYI.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #9 on: Wed, 28 March 2018, 11:42:04 »
tried flipping the size modifier to outside the hyperlink. work now?
« Reply #10 on: Wed, 28 March 2018, 11:44:10 »
It does! Thanks.  :)
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #11 on: Wed, 28 March 2018, 11:45:46 »
It does! Thanks.  :)
I see you went all-out with the Spam lol
Offline peggisan
« Reply #12 on: Wed, 28 March 2018, 13:36:20 »
what layouts will the 60% support?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #13 on: Wed, 28 March 2018, 19:43:06 »
I'd say check the old GB thread for some pics, but pretty standard variety of enter and bottom row compatibility
Offline euphxenos
« Reply #14 on: Wed, 28 March 2018, 22:02:47 »
Is there any possibility you could do a 65% this time?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #15 on: Wed, 28 March 2018, 22:22:01 »
The 60% are so popular even in this IC that if I do it, it'll probably be it's own GB after this. I'll definitely earmark it and get some stuff planned out though.
Offline peggisan
« Reply #16 on: Thu, 29 March 2018, 01:17:23 »
I filled out 60% in the form but if you're offering 65% I would get that instead
Offline Kevadu
« Reply #17 on: Thu, 29 March 2018, 01:29:21 »
I would love to see this in 65% or 75%.  The lack of options between 60% and TKL is kind of disappointing.
Offline tanvir175
« Reply #18 on: Thu, 29 March 2018, 01:37:37 »
Interested in the 60%
Will the plate support mx+alps & cherry+costar and, also, is the price including the acrylic midpiece?
Offline chuckdee
« Reply #19 on: Thu, 29 March 2018, 11:18:09 »
Woot on that.  I'd love to build one not in the CNC case.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #20 on: Thu, 29 March 2018, 16:01:04 »
The plate just supports MX at the moment to my knowledge, but that is an idea. I messaged foggyflute to see if it is costar compatible. And the price does include the midpiece, only in the first CF-LX did it not :thumb:
Offline tanvir175
« Reply #21 on: Thu, 29 March 2018, 16:21:38 »
Dope!
MX is all I would need, as someone on reddit said SKCC fits pretty well in MX plates but not Alps plates, which seems to be true. Costar would be nice so I can stabilize the spacebar, although I could probably work out a mod, if needed.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #22 on: Thu, 29 March 2018, 16:38:19 »
OK so I don't really how to make the question more clear on the form, but when I ask what keypad PCB compatibility you'd like to see, I was referring to keypads, not 60% (which is almost literally the only thing I've gotten so far). I'll probably just end up making them compatible with the FC210TPs and the Majetouch keypads, so standard with the 4-key on top.
Offline tanvir175
« Reply #23 on: Thu, 29 March 2018, 16:44:03 »
Not interested in the keypad so I didn't fill it out (I like a 5x5 layout for that, personally) but the Cospad seems to be a popular one.
BTW, some people might be confused because most, as far as I know, call it a numpad.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #24 on: Thu, 29 March 2018, 16:47:47 »
Well, I usually just knew it as keypad distinguishing it as a seperate thing. But yea, I'll change it in the form just in case. I'll look into the Cospad too.
Offline peggisan
« Reply #25 on: Thu, 29 March 2018, 17:39:09 »
Oh. I didnt know what a keypad was but if its a numpad I would def be interested in cospad
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #26 on: Thu, 29 March 2018, 17:45:43 »
Ah, well ****. I changed the entry in the form to try and clear things up, but I guess it only really matters come GB time
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #27 on: Thu, 29 March 2018, 17:49:44 »
Who actually makes the Cospad? I see listings on Aliexpress but I don't have any idea whose PCB it is
Offline tanvir175
« Reply #28 on: Thu, 29 March 2018, 17:59:31 »
I believe KPRepublic
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #29 on: Thu, 29 March 2018, 18:32:35 »
Perfect, thanks. And yep, just Cherry support for the stabs
Offline tanvir175
« Reply #30 on: Thu, 29 March 2018, 18:48:58 »
Alright sounds good, I'll look into potential mods I could do.
Offline 2zar
« Reply #31 on: Fri, 30 March 2018, 04:35:40 »
i wonder if you have a plan to add translucent acrylic midpiece option it would be nice :)
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #32 on: Fri, 30 March 2018, 09:08:33 »
Nope, sorry
Offline lac29
« Reply #33 on: Fri, 30 March 2018, 09:13:11 »
I want to throw my hat into the 65% ring too.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #34 on: Fri, 30 March 2018, 09:18:57 »
What boards would you all like to see compatibility for? MOQ is 5 for anything new, so if y'all are for the same board (or boards that are compatible with one another) I'll see what I can do.
Offline lac29
« Reply #35 on: Fri, 30 March 2018, 09:34:20 »
https://geekhack.org/index.php?topic=94467.0
I'm not sure what the best 65% pcb would be since there really isn't several big ones besides maybe Tada. I do like the layout options for Krelbit's MEME project.
Offline Choppersuey
« Reply #36 on: Fri, 30 March 2018, 09:34:33 »
For 65%, I'd recommend making the case compatible for the Sentraq65/Tada68/Winkeyless 22mini-B since all three have pretty much the same USB placement and you can buy the PCB alone.
Offline lac29
« Reply #37 on: Fri, 30 March 2018, 09:40:05 »
None of those have upgraded to USB-C right? And do they do QMK? USB-C and QMK are kinda what I'm personally looking for in almost all my purchases moving forward.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #38 on: Fri, 30 March 2018, 09:52:40 »
They started putting ****in USB-C in boards? Man, I've fallen behind lol... The board you posted seems to have basically the same layout I've seen on most other 65% boards. So as long as they share screw and USB placements they should be fine. Even if some are micro-USB and some are USB-C, as long as the hole is large enough to accommodate C we should be fine.
« Last Edit: Fri, 30 March 2018, 09:54:45 by hwood34 »
Offline Choppersuey
« Reply #39 on: Fri, 30 March 2018, 09:55:28 »
Nope, none of them has USB-C but AFAIK all three can run QMK.
However I do remember reading something about KBDFans bringing out a PCB with USB-C, Bluetooth and TMK that fits the TADA case. Here it is.
Offline lac29
« Reply #40 on: Fri, 30 March 2018, 10:00:13 »
I totally forgot about that one. Battery space would unfortunately be an issue trying to fit it into this CF case though?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #41 on: Fri, 30 March 2018, 10:06:27 »
Battery placed where?
Offline lac29
« Reply #42 on: Fri, 30 March 2018, 10:09:56 »
I think that KBD bluetooth 65% will need to have case considerations for a battery area: https://cdn.shopify.com/s/files/1/1473/3902/files/7_d3a6a939-e57c-46e8-9069-77296e1613a4.jpg?v=1521018382
I dunno how much you want to wade into specific design changes to accommodate different 65% pcb (bluetooth or not). I don't have enough detailed knowledge but it would take a bit of research to see what 65% are out there and figure out their differences in terms of USB position, bluetooth or not (and battery space case changes), etc.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #43 on: Fri, 30 March 2018, 10:15:34 »
Space between the PCB and case bottom would obviously be a problem (I'm not sure it would fit at all currently). Also, adding something to the bottom CF plate to ensure the battery doesn't slide around (though I suppose one could just tape it down).
Offline lac29
« Reply #44 on: Fri, 30 March 2018, 10:17:25 »
Yeah, ultimately it depends on how ambitious you want to be with the 65%. The reason why I particularly like the MEME pcb is because of USB-C, QMK, and split spacebar options (I don't think any 65% has this option yet?).
Offline euphxenos
« Reply #45 on: Fri, 30 March 2018, 12:52:26 »
Agreed.  Also, I don't care about usb-c or wireless; mini usb is just fine.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #46 on: Fri, 30 March 2018, 13:24:32 »
Accounting for usb-c doesn't really require much change at all, if any. Probably just extending the hole by a few mm
« Reply #47 on: Sat, 31 March 2018, 08:23:27 »
Is it possible to order only the diffuser and black spacers?  I was part of the first group buy.
Offline Kevadu
« Reply #48 on: Sat, 31 March 2018, 22:47:25 »
My preferred 65% is probably more the FC660/Clueboard variety, but honestly I would be fine with Tada68 support.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #49 on: Sun, 01 April 2018, 13:55:28 »
Yep. On the GB form I'll put an option for just the acrylic pieces.
