Author Topic: [IC] Modern Dasher D60 (GB open)  (Read 44432 times)
Offline Jkush463
Re: [IC] Model Dasher - D60 (2nd prototype finished)
« Reply #100 on: Sat, 29 September 2018, 17:33:55 »
damn thats nice,
Offline young_won
« Reply #102 on: Sat, 29 September 2018, 21:37:15 »
i want to split space bar
Offline ihalatch
« Reply #103 on: Sat, 29 September 2018, 21:58:02 »
In my opinion, slightly more recessed caps, so that a few millimetres of their base is in the body of the keyboard,  would be even better.
Offline beekey
« Reply #104 on: Sat, 29 September 2018, 23:23:02 »
Offline pixelpusher
« Reply #105 on: Sun, 30 September 2018, 10:54:00 »
Totally agree.  I would put the base of the keycaps about 1.5mm below the surface of the blue border section.... maybe even more.  Can you give us a photo of just straight on?  Like what you would see if you were seated in front of the board and typing on it?  Also, are there plans for any kind of badge in the top right?  I feel like it needs something.
Offline Starius
« Reply #106 on: Sun, 30 September 2018, 11:20:46 »
I concur with these sentiments!
Offline Vizir
« Reply #108 on: Sun, 30 September 2018, 11:48:17 »
+3 for split spacebar
Offline Baron
  • oops its me
« Reply #109 on: Sun, 30 September 2018, 12:40:36 »
there isnt much in the category of blanks that i know of for splitting and keeping a dasher set on it
is there any kit or any unsculpted dasher stuff for that?
Offline Ramiel
    • SwitchOverflow
« Reply #110 on: Sun, 30 September 2018, 14:13:23 »
Here is the side view. The bottom of the keycaps is aligned with the edge.
I'm planning to order some stickers.
Offline Ramiel
    • SwitchOverflow
« Reply #111 on: Sun, 30 September 2018, 14:19:46 »
+1
+2
+1
This is a universal 60% case. There won't be a split spacebar pcb but it's possible to have a split space plate option. Which layout do you want? The DZ60 spacebar layout?
Offline Ramiel
    • SwitchOverflow
« Reply #112 on: Sun, 30 September 2018, 14:21:15 »
I guess not everyone wants to choose the og dasher colorway and put SA dasher/dancer caps on it. There will be multiple color options.
Offline _ODIN_
« Reply #114 on: Wed, 03 October 2018, 06:21:50 »
Can you post a picture of the supported layout?
Offline Starius
« Reply #115 on: Wed, 03 October 2018, 06:49:38 »
Who else would love to see a version of this board that had a 96 key layout?
(Cause I know I would.)
Offline helix999
« Reply #116 on: Wed, 03 October 2018, 10:16:58 »
Absolutely... 96 or 1800 layout would be fantastic.
Offline Starius
« Reply #117 on: Wed, 03 October 2018, 10:39:48 »
I didn't even think about the 1800 layout.  You're right, that would be awesome too.
Offline KeyCap75
« Reply #118 on: Thu, 04 October 2018, 01:11:31 »
vote for 1800  :thumb:
Offline beekey
« Reply #119 on: Thu, 04 October 2018, 01:16:14 »
+1
+2
+1
Yes DZ60 would be nice. For me, I only need a 2.25,1.25,2.75 split space, then I'm happy. :)
Offline Ramiel
    • SwitchOverflow
« Reply #120 on: Thu, 04 October 2018, 07:28:40 »
What's the hight of the front site of the keyboard?
22mm without rubber feet
Offline Ramiel
    • SwitchOverflow
« Reply #121 on: Thu, 04 October 2018, 07:30:30 »
This is just a case. You can use most 60% PCBs you can find.
Offline Ramiel
    • SwitchOverflow
« Reply #123 on: Wed, 10 October 2018, 15:21:18 »
I thought you mentioned you're doing 65% for this GB?
unfortunately I didn't
Offline Ramiel
    • SwitchOverflow
Re: [IC] Modern Dasher D60 (2nd prototype finished)
« Reply #124 on: Wed, 10 October 2018, 15:22:12 »
It looks better with stickers
Offline zwartho
« Reply #125 on: Wed, 10 October 2018, 15:31:46 »
I agree. It definitely looks better with the sicker imo, but I think the final product should have a badge instead.
Offline Ramiel
    • SwitchOverflow
« Reply #129 on: Fri, 12 October 2018, 12:12:55 »
imo a badge will be even better.
+1
What shape and position do you guys want the badge to be?
Offline Ramiel
    • SwitchOverflow
« Reply #130 on: Fri, 12 October 2018, 12:14:37 »
Looks fantastic. When will this GB start?
After I figure out the sticker/badge problem.
Offline _ODIN_
« Reply #131 on: Fri, 12 October 2018, 12:18:41 »
+1
Top right
Offline mkarlsson
« Reply #132 on: Fri, 12 October 2018, 12:21:22 »
Top right, like the original.
Offline piercejenkins
« Reply #133 on: Fri, 12 October 2018, 12:22:40 »
As close to the original as possible.
Offline Ramiel
    • SwitchOverflow
« Reply #134 on: Fri, 12 October 2018, 12:37:57 »
That's also what I was thinking of. The problem is the color limitation of the aluminum/brass badge. The sticker can have multiple colors but the badge can only have one. I printed some stickers with different colors to match the colors of cases and they look good. I don't know how the single color badge will look like. I'll do a render and see.
Offline laserbeamspewpew
Re: [IC] Modern Dasher D60 (GB open)
« Reply #136 on: Thu, 25 October 2018, 19:36:36 »
Any progress here? I'm waiting impatiently for the GB.
It’s open now...
Offline Starius
« Reply #138 on: Thu, 25 October 2018, 20:14:32 »
Oh hell, I didn't know it was open yet either!
