Author Topic: [IC] Modern Dasher D60 (GB open)  (Read 44433 times)
Offline bkim14
Re: [IC] Model Dasher - D60
« Reply #50 on: Sun, 13 May 2018, 01:28:53 »
awesome
Offline Baron
  • oops its me
« Reply #51 on: Sun, 13 May 2018, 11:24:37 »
could it maybe have some logo in the top right like the original?
Offline _ODIN_
« Reply #52 on: Sun, 13 May 2018, 11:45:02 »
i think it would look a lot cleaner without the logo
Offline PernusBernus
  • Form is emptiness, emptiness is form
« Reply #53 on: Sun, 13 May 2018, 13:08:26 »
a minimalist version of that logo would be nice
"IBM Model M blue label" title="IBM Model M blue label" "Pok3r" title="Pok3r"
Offline Ramiel
    • SwitchOverflow
« Reply #54 on: Sun, 13 May 2018, 13:13:02 »
I do plan to order some stickers like this. It's not considered as a part of this project tho.
Offline enrique.aliaga
« Reply #55 on: Sun, 13 May 2018, 13:42:32 »
Could there be any legal issues?
Offline Ramiel
    • SwitchOverflow
« Reply #56 on: Sun, 13 May 2018, 14:04:03 »
Maybe? The legal issue is a concern to me because I know nothing about it. Data General company has been long gone tho.
I said the stickers won't be considered as a part of the project just because of this reason.
I will make some stickers for myself. I'm pretty sure that's legal at least.
Offline Ramiel
    • SwitchOverflow
« Reply #57 on: Mon, 14 May 2018, 12:54:42 »
Offline elfick
  • Can I get Colemak and a side of fries with that?
« Reply #58 on: Mon, 14 May 2018, 14:32:19 »
Did you consider having the connector recessed and just having a slot for the cable to run out like the original (having a slot, I'm guessing the original cable was soldered or crimped).
Offline Ramiel
    • SwitchOverflow
« Reply #59 on: Mon, 14 May 2018, 15:40:36 »
Yes, I have considered hiding the cable connector under the case. The cable will be still detachable.
However, the slot under the case must be large enough to support all possible connectors. I don't think it's a good idea to cut a slot large enough for Yarbo connectors.
Offline Lormania
« Reply #60 on: Sun, 20 May 2018, 18:27:10 »
Count me in on this one!
Offline _ODIN_
« Reply #61 on: Mon, 21 May 2018, 02:47:42 »
will there be other colours as well?
Offline bkim14
« Reply #62 on: Mon, 21 May 2018, 12:35:48 »
wish there is an option for sus plate too
Offline RSC
« Reply #63 on: Mon, 11 June 2018, 14:54:28 »
Any updates on this?
Offline portbaron
« Reply #64 on: Mon, 11 June 2018, 15:18:14 »
Well I'd get it.
| LIVING THE 1800 LIFE |
Offline oumakavoula
« Reply #65 on: Tue, 12 June 2018, 04:43:41 »
would buy had it been a full size, love the colors
Offline adamcobabe
« Reply #66 on: Tue, 12 June 2018, 05:57:23 »
Yeah, I'm sad it's not full size like the original. Cool project though. I love retro-style projects.
« Last Edit: Tue, 12 June 2018, 06:09:41 by adamcobabe »
Offline Lormania
« Reply #67 on: Thu, 14 June 2018, 11:39:43 »
I like the size :)
Offline kimwonsik
« Reply #68 on: Thu, 14 June 2018, 21:15:06 »
I'm so excited.
I decided to buy it.
« Reply #69 on: Thu, 14 June 2018, 22:48:28 »
I like the size
That’s what she...
Sorry, couldn’t help it.
« Reply #70 on: Fri, 15 June 2018, 08:54:58 »
will there be iso support?
Offline _ODIN_
« Reply #71 on: Fri, 15 June 2018, 09:03:13 »
Offline RSC
« Reply #72 on: Sat, 16 June 2018, 04:28:50 »
Offline Rumblehotep
« Reply #73 on: Sun, 17 June 2018, 13:30:47 »
I just realized these keycap sets are perfect Mega Man colors
Offline Rorkish
« Reply #74 on: Mon, 18 June 2018, 05:08:22 »
I'd love to see a WKL top if this gets to GB. I've finally got the funds for a heavy metal custom and this would suit me well.
Offline RSC
« Reply #75 on: Sat, 14 July 2018, 04:40:54 »
Offline Ramiel
    • SwitchOverflow
« Reply #76 on: Sat, 14 July 2018, 05:23:01 »
I have made two prototypes but they all have problems. The first one's height was not correct. The second one's bottom was too thin. It will come out eventually but only after I have a perfect prototype.
Offline Peppermint216
« Reply #77 on: Sat, 14 July 2018, 05:34:04 »
Will the blue insert have colour options?
Offline hhkbp2
« Reply #78 on: Mon, 16 July 2018, 03:23:16 »
Wish the blue color would be a perfect match to Dasher keyset, and the HHKB layout with 7u spacebar could be supported.
Offline _ODIN_
« Reply #79 on: Mon, 16 July 2018, 03:55:45 »
ISO support?
Offline sleepybrett
« Reply #80 on: Mon, 16 July 2018, 15:50:21 »
split spacebar support would be nice.
Offline Ramiel
    • SwitchOverflow
« Reply #81 on: Tue, 17 July 2018, 05:54:14 »
Every aluminum part will have multiple colour options.
Offline Ramiel
    • SwitchOverflow
« Reply #82 on: Tue, 17 July 2018, 05:58:32 »
ISO support?
The case will support almost all of the 60% PCBs in theory. I can't provide too many plate options. You can use third-party PCBs and plates with standoffs tho
Offline _ODIN_
« Reply #83 on: Tue, 17 July 2018, 09:27:43 »
ISO support?
Nice!
Offline RSC
« Reply #84 on: Mon, 03 September 2018, 16:03:42 »
No updates on this?
Offline Rubbermilitia
« Reply #85 on: Fri, 07 September 2018, 03:00:51 »
Definitely interested, would like to see this as a 65 or TKL though.
Offline Marutks
« Reply #86 on: Fri, 07 September 2018, 04:49:36 »
yes  65 % !
Offline _ODIN_
« Reply #87 on: Fri, 07 September 2018, 07:02:29 »
Offline coffeeshopcoder
« Reply #88 on: Sat, 08 September 2018, 12:02:14 »
65% or HHKB layout would be nice..
The OG has a space-bar only bottom row, a more modern approximation would be the HHKB layout.
You could also consider the CA 66 layout for HHKB + 65%. I think it would also look nicer/closer to the OG's full size.
Personally I like both 65% as well as 60%, however with 60% you have better PCB compatibility and cost savings...
Offline Zilleon
« Reply #89 on: Sun, 09 September 2018, 00:22:09 »
Hope this one happens, it looks awesome, I would be in for sure!
Offline Ramiel
    • SwitchOverflow
« Reply #91 on: Sat, 22 September 2018, 12:18:28 »
CA66 layout is very nice but I don't want to risk being called a copycat. I don't think copying layout is wrong but I know someone disagrees.
I like 60% over 65% cause the last column keys on 65% can be accidentally pressed.
Offline Ramiel
    • SwitchOverflow
« Reply #92 on: Sat, 22 September 2018, 12:19:47 »
Any progress here?
I'm still waiting for the second proto
Offline _ODIN_
« Reply #93 on: Sat, 22 September 2018, 12:58:10 »
Any progress here?
The proto will obviously be a 60% but can we expect this to change to a 65% keyboard? Many people requested it (me included)?
Great to hear back from you!
Offline Zilleon
« Reply #94 on: Tue, 25 September 2018, 10:16:35 »
Any progress here?
I much prefer 60% :)
Offline Ramiel
    • SwitchOverflow
« Reply #95 on: Sat, 29 September 2018, 11:55:35 »
Any progress here?
I really don't want to discard the current 60% version and change it to 65%. I've ordered two prototypes for D60. The first one had a lot of problems. All the problems have been fixed in the second prototype. Also, I have a source for hot-swappable 60% PCBs and they don't have 65% versions rn. Changing to 65% is too risky and unnecessary for me.
Offline Ramiel
    • SwitchOverflow
Re: [IC] Model Dasher - D60 (2nd prototype finished)
« Reply #96 on: Sat, 29 September 2018, 12:03:24 »
Here are some photos of the second prototype. The first one was totally wrong.
Fox-lab was kind enough to make the second one for me. The bottom case is in the new e-white color.
Offline _ODIN_
« Reply #97 on: Sat, 29 September 2018, 12:07:12 »
 :cool:
Offline bluesclera
« Reply #98 on: Sat, 29 September 2018, 12:09:01 »
hope you decided to build a TKL option one day
Offline beekey
« Reply #99 on: Sat, 29 September 2018, 13:22:23 »
This looks great. Please keep it at 60% for the first round!
