Author Topic: [GB] KIRA80 & KIRA S  (Read 399339 times)
Offline Choppersuey
Re: [GB] KIRA80 & KIRA S
« Reply #1000 on: Fri, 12 April 2019, 22:16:31 »
i started realizing the manufacturers lack in the threading department i chase all the threads in every case i buy with a tap and clean them up then dab some oil inhtem to make life easier and ensure i dont get stripped holes.
What tap size and what kind of screws did you use?
Offline aszyd
« Reply #1001 on: Fri, 12 April 2019, 23:08:00 »
The only area that I have had a problem with so far is the alu back plate. I can get the screws in and out, but there is a section in the middle of the threading that is tough to get past.
Whatever happened with the Kira S 10 key? I realized I might want one after all.
Offline thesiscamper
    • Keyrenders
« Reply #1002 on: Fri, 12 April 2019, 23:39:59 »
Screws should all be M3, that's what I used for my prototype and I don't think EVE changed them. No word from zF yet, I don't have any updates.
"haters are confused admirers"
Offline Jkush463
« Reply #1003 on: Fri, 12 April 2019, 23:55:23 »
yeah, all M3 and i use stainless hardware from an RC company i deal with, they use the same hardware and sell them with different heads and lengths.
Offline Choppersuey
« Reply #1004 on: Sat, 13 April 2019, 00:07:58 »
Thanks, thesis and jkush!
Offline takai
« Reply #1005 on: Sat, 13 April 2019, 05:18:43 »
Received a second shipping invoice  :rolleyes: :rolleyes: :rolleyes:
Solved
« Last Edit: Sat, 13 April 2019, 05:48:41 by takai »
Offline Hamel
  • KBDLAB
« Reply #1006 on: Tue, 16 April 2019, 07:19:46 »
Has anyone who joined the priority buy received an shipping invoice yet?
Offline Create_alt_delete
« Reply #1007 on: Tue, 16 April 2019, 07:58:43 »
Priority buy participant here. No invoice yet.
Sent from my SM-G955U using Tapatalk
Offline Bubblegum
« Reply #1008 on: Tue, 16 April 2019, 08:35:40 »
Same here, no invoice nor mail reply. Not sure what the point of the priority buy was if everyone else are getting their boards ahead of time. Don't think they would need 2-4 extra weeks just to engrave the numbers. I'm sure we will all get it eventually, but it's frustrating.
Offline jumpmineralwater
    • jumpmineralwater IG
« Reply #1009 on: Tue, 16 April 2019, 09:10:44 »
Joined for a priority board and still waiting for a shipping invoice.
Offline sroop
« Reply #1010 on: Tue, 16 April 2019, 09:12:49 »
Same. Priority buy, Poseidon blue, brass and alu plates - no invoice or email communication.
Offline Etherealsound
« Reply #1011 on: Tue, 16 April 2019, 10:36:03 »
Priority buyer for moon grey. Received and paid invoice more than a week ago but no tracking or communication.
Offline Hamel
  • KBDLAB
« Reply #1012 on: Wed, 17 April 2019, 06:08:03 »
Update: Received a DHL tracking few hours ago, deep black, priority buy.
나의 SM-G950N 의 Tapatalk에서 보냄
Offline vafan
« Reply #1013 on: Wed, 17 April 2019, 21:35:38 »
Paid the shipping invoice about 2 weeks ago and have no tracking info for now.
Update: Well, 5 hours after this post. I got a call from DHL. No tracking mail or anything. What a surprise!
And here you are
https://imgur.com/a/ImmDi6L
« Last Edit: Thu, 18 April 2019, 02:39:27 by vafan »
« Reply #1014 on: Thu, 18 April 2019, 12:18:32 »
And here you are
Wait what. Are you in the US by chance.
« Reply #1015 on: Thu, 18 April 2019, 13:01:39 »
Emailed back and forth with Alex yesterday. He said the rest of the shipping invoices would be going out "soon."
Offline vafan
« Reply #1016 on: Thu, 18 April 2019, 19:35:55 »
And here you are
I am not, sorry. Asia here
Offline forevermadrigal
« Reply #1017 on: Thu, 18 April 2019, 20:01:47 »
And here you are
You can tell it's from asia cause it actually says kira on the plate smh
Offline vafan
« Reply #1018 on: Fri, 19 April 2019, 02:13:33 »
And here you are
I do not buy it through Asia channel, its International channel.
Btw, any suggestion for keycaps color? Thanks
Offline Choppersuey
« Reply #1019 on: Fri, 19 April 2019, 02:57:22 »
Built mine two days ago with Tangerines:
« Last Edit: Fri, 19 April 2019, 07:21:46 by Choppersuey »
« Reply #1020 on: Fri, 19 April 2019, 03:14:49 »
second pic is very good
Offline yap68
« Reply #1021 on: Fri, 19 April 2019, 03:47:55 »
And here you are
Does the Poseidon Blue look ok to you?
« Reply #1022 on: Fri, 19 April 2019, 09:44:58 »
Moon grey is really clean :eek:
Offline spyruf
« Reply #1023 on: Fri, 19 April 2019, 10:34:30 »
Muted with 9009 accents ?
Offline okidna
« Reply #1024 on: Fri, 19 April 2019, 11:00:24 »
I think that's EPBT 9009, judging by the stacked Prt Sc | Sys Rq & Pause | Break legend.
Offline Choppersuey
« Reply #1025 on: Fri, 19 April 2019, 11:09:28 »
just ePBT 9009
« Reply #1026 on: Fri, 19 April 2019, 11:43:12 »
That's clean af. Kinda sad to see that the "grey" really did turn out to be just silver though .
Offline iEatPuppers
« Reply #1027 on: Sun, 21 April 2019, 02:43:04 »
Any advice on the screws? Joining the plate to the top seems super difficult without stripping the screw heads.
Offline Jkush463
« Reply #1028 on: Sun, 21 April 2019, 12:20:39 »
Just went to build one of my boards and realized the USB port on one of my PCB's is smashed and pretty much unfixable, anywhwere i can buy a new one and just de solder this one? or should i hit up ZF and just pray they feel like helping me.
« Reply #1029 on: Sun, 21 April 2019, 14:04:19 »
you can always buy hiney's pcb and just use that.
« Reply #1030 on: Sun, 21 April 2019, 14:28:03 »
i recommend this option
send him a pm he prolly has a few extra kicking around
EDIT: i took some liberty and just messaged him and he doesn't have any
but switchmod absolutely does have some
« Last Edit: Sun, 21 April 2019, 14:30:13 by Puddsy »
« Reply #1031 on: Sun, 21 April 2019, 15:43:22 »
Regardless of how you go about it, I'd recommend contacting zfrontier about getting a replacement. It's not like the kit was cheap. It's pretty ridiculous to pay and get a broken pcb and just leave it at that. Definitely see about getting it replaced
Offline Jkush463
« Reply #1032 on: Sun, 21 April 2019, 17:34:43 »
yeah ill send ZF a message and see what can be done im not in a rush its my spare pcb for my brass plate but i do want it fixed so when i want to build that plate i can. i may order a few usb mini ports and try to fix it my self tho too.
Offline kokugatsu
« Reply #1033 on: Mon, 22 April 2019, 00:13:57 »
Still no shipping invoice for "priority" Poseidon Blue, jesus
Offline schlep
« Reply #1034 on: Mon, 22 April 2019, 08:44:53 »
Where are you located? I haven't received mine either and mine is the same colour as yours. Could it be due to the colour?
I emailed zFrontier abt 2 weeks ago and he said he will send me an invoice soon. That was on April 8th and until now I have not received any shipping invoice nor the board.
I am based in Singapore by the way.
Offline Brammm87
« Reply #1035 on: Mon, 22 April 2019, 11:43:37 »
No shipping invoice for my poseidon blue either. Located in Belgium.
pls gief bbv2
Offline sroop
« Reply #1036 on: Mon, 22 April 2019, 11:45:32 »
Same here except I haven't bothered to email because what's the point?
Offline Jkush463
« Reply #1037 on: Mon, 22 April 2019, 20:26:22 »
wild, sent ZF a complaint on my kira pcb, alex responded in about 20 minutes and said hell have a replacement on the way this next Monday. didn't ask about my priority board i probably should have.
Offline vafan
« Reply #1038 on: Mon, 22 April 2019, 20:57:22 »
And here you are
It's good, however for me this colour is quite hard to find the keyset.
    • Keyrenders
« Reply #1039 on: Mon, 22 April 2019, 20:57:50 »
Alex hasn’t responded to my messages, I can see they’re still shipping albeit slowly. I assume several people who have not received a shipping invoice was assigned a board with issues. There really is nothing for me to share, but I will keep trying to reach zF.
Offline kokugatsu
« Reply #1040 on: Tue, 23 April 2019, 12:48:03 »
Also in SEA, and yeah I believe the delay is mainly because of our colour.
FYI I got an email from Alex, saying the invoice should be going out this week. Will let you know when I get mine  :)
Offline takai
« Reply #1041 on: Tue, 23 April 2019, 18:10:24 »
I got my board last week and found some scratches on the plate.
zF quality control seems not good.
thesiscamper: do you have plan to share plate data?
Offline redbanshee
  • actually Dade Murphy
« Reply #1042 on: Wed, 24 April 2019, 10:06:53 »
I love how these guys (zfrontier) just think that we need to be attentive to their every whim, on their schedule, with no clue as to when things will happen.
Im heading out of the country (for an extended period of time) next week and now I have to bring my electronics to constantly check my email daily to pay this shipping invoice whenever they feel like sending it. So i can actually get my damn keyboard that I paid for.
Boycotting zfrontier, and smearing this joke-of-a-company every chance I get. Incompetence, 0 communication, emails ignored, 0 customer service.
« Last Edit: Wed, 24 April 2019, 18:10:15 by redbanshee »
    • Keyrenders
« Reply #1043 on: Wed, 24 April 2019, 18:40:32 »
I don't think EVE changed anything (ie. screw holes), I've attached the file.
edit: to the guy who downloaded the earlier file this new attachment might work better.
« Last Edit: Wed, 24 April 2019, 18:43:37 by thesiscamper »
Offline takai
« Reply #1044 on: Thu, 25 April 2019, 00:27:16 »
You’ve really helped me out here. Thanks so much!
    • Keyrenders
« Reply #1045 on: Fri, 26 April 2019, 07:13:51 »
EVE just informed me through Louis that zF should be shipping out the numpads within 15 to 20 days, he doesn't know the plan for the kits with the wrong colors though. He also apologized for his mistakes and promises to take customers more seriously.
Offline Okonomiyaki#2832
  • Eating Okonomiyaki
« Reply #1046 on: Fri, 26 April 2019, 10:40:23 »
Saw a similar notice on QQ, zf had contacted Eve and promised to send the payment for the numpads. Should the payment arrive, the numpads will shipped out within 15 to 20 days. Apologies for the delay, on behalf of zf.
Offline Bubblegum
« Reply #1047 on: Tue, 30 April 2019, 03:21:27 »
Did you get an invoice? Nothing here so far, and no reply to mails. I picked Poseidon Blue case and Pearl Blue plate, both "problem" colors. Maybe Pearl Blue is holding my order back, but who knows since there's no communication? I've seen Poseidon Blue Kira TKL go up on mechmarket already, and my "priority" GB board might not even be finished...
Offline sroop
« Reply #1048 on: Tue, 30 April 2019, 11:20:43 »
Hi thesis, do you have an ANSI plate file by chance? Looking to make a POM plate if or when I eventually get this kit.
Offline Jkush463
« Reply #1049 on: Tue, 30 April 2019, 21:22:16 »
wait what there shipping them next week but i didnt get to buy one did i miss the buy or?
