Author Topic: [IC] Doro67 - Integrated Plate 65% (Updated RGB PCB option, GB coming real soon)  (Read 74936 times)
Offline oldcat
  • 65% is Life
Re: [IC] Doro67 - Integrated Plate 65% (Brass Bottom Poll Open, GB coming soon)
« Reply #200 on: Fri, 31 August 2018, 18:51:27 »
So no Group Buy thread on geekhack?
Just remember the rules if you do decide to post something for the GB:
- geekhack.org is a community of keyboard enthusiasts and not simply an advertising platform for keyboard-related sales.  Thus we request that any group buy organizers who post their group buy threads in this section also provide updates in the thread they have started until the conclusion of the group buy, even if updates are also posted somewhere else.  Group buy threads made here are for group buy progress discussion as well as open discussion of any quality control issues.   If a group buy organizer decides to provide an off-site instant message chat option for faster order support (for example Discord), any such communication needs to be optional when it comes to non-sensitive* order information.
There will be a GB post on GH. After we fully test our (second) prototype.
« Last Edit: Fri, 31 August 2018, 18:53:19 by oldcat »
Offline pixelpusher
« Reply #201 on: Fri, 31 August 2018, 19:04:30 »
Glad to hear it.  Im looking forward to joining.
Offline cldskt
  • Wallet and hobby aren't friends
« Reply #202 on: Fri, 31 August 2018, 21:13:24 »
What's the issue?  The group buy for this hasn't opened yet, has it?  I wouldn't expect them to start a group buy thread until they're actually ready to start taking orders, so what are you objecting to?
I think what he was referring to is the statement “GB will start in Discord” by oldcat, implying that those who are not in the channel might lose out. Not necessarily true, but I can see the sentiment when some of the GBs are more “private” than usual. I don’t blame those either, since GH can be ****y at times.
Why not join us in the Discord channel and chat with us too while waiting for the GB? :)
"Addiction is buying the things that I don't need with the money I don't have." - me
"Spending $500 on your first custom is justified." - also me
Offline euphxenos
« Reply #203 on: Fri, 31 August 2018, 22:03:19 »
Ahh, thanks -- I missed that comment about it starting in Discord.
Offline pixelpusher
« Reply #204 on: Fri, 31 August 2018, 22:36:56 »
Yeah, this was an issue a few months back because xondat was running a GB on here but was updating in Discord.  The main issue was having important GB detail ONLY in the discord channel and not on Geekhack as well.  That's why they added that rule.  Keeping the group buy status and issues on Geekhack helps preserve that information for the community.
« Last Edit: Fri, 31 August 2018, 22:47:10 by pixelpusher »
Offline dario
  • obsessive–compulsive hardware slut
« Reply #205 on: Sat, 01 September 2018, 04:54:45 »
2 additional prototypes have been made. ALF will pick up and ship to our tester next Tuesday. As soon as we make sure everything works fine, GB will start in Discord.
What is Discord? Can't we just have normal GB?
Offline Gghi
« Reply #206 on: Sat, 01 September 2018, 16:23:35 »
We will launch on Discord first. Will update on GH later.
Offline KaosJ
« Reply #207 on: Sat, 01 September 2018, 17:09:09 »
good boi
Offline gbchk
« Reply #208 on: Sun, 02 September 2018, 12:07:59 »
Would this be compatible with SMK switches and a PCB from LFKeyboards?
Offline euphxenos
« Reply #209 on: Sun, 02 September 2018, 12:47:53 »
I completely agree with you; I had simply missed oldcat's comment about Discord.  I was actually in xondat's Noxary 268 gb.  It was a very negative experience.  Even the mention of Discord in a gb now makes me reconsider whether I want to join.
Offline Gghi
« Reply #210 on: Sun, 02 September 2018, 13:54:42 »
I agree. Generally, we update details both here and Discord channel. Usually, we update discord first to get immediate feedback and some less important pics. We will launch this GB first on our channel because we wanna have a test run first in case we miss anything.
Offline pixelpusher
« Reply #211 on: Sun, 02 September 2018, 15:32:33 »
Layout would work, and it would probably fit (I used one on my m65-a and only had to shave 1mm off the pcb in 2 spots), but I’m not sure the smk board has an JST-PH option. If it does it will most likely work.
Offline ZombieOfZimbabwe
« Reply #212 on: Sun, 02 September 2018, 16:29:49 »
Really hoping for a confirmation, this board is a dream, I would just prefer backlighting
Offline oldcat
  • 65% is Life
« Reply #213 on: Sun, 02 September 2018, 19:29:56 »
Sorry to hear that you had that bad experience with another maker. I am not sure what happened there so I cannot comment.
Discord is a great channel for quick updates and fun things (e.g., ALF's daily activities) GH doesn't care about. That said, we will initiate a GB post on GH after Discord launch, as 80ultraman has said. I hope that is not a violation of the terms of use for GH.
Offline oldcat
  • 65% is Life
« Reply #214 on: Sun, 02 September 2018, 19:32:00 »
The GB will include a PCB. It is not certain whether other PCBs will fit at all, because there are no standardized PCBs in 65% (even if there is, most makers don't follow the standards). Maybe 80Ultraman can chime in on this.
Offline oldcat
  • 65% is Life
« Reply #215 on: Sun, 02 September 2018, 19:34:11 »
Will check with 80ultraman if he can make the PCB backlighting compatible.
Uodate: 80ulteaman said we can have a pcb with in-switch LED options if enough people join this GB (factory machine solders with a MOQ).
« Last Edit: Sun, 02 September 2018, 20:34:51 by oldcat »
Offline oldcat
  • 65% is Life
« Reply #216 on: Mon, 03 September 2018, 02:33:56 »
Just talked 80ULTRAMAN into offering RGB PCB option at a very small cost (~$10).
Default PCB (without RGB LEDs) compatible with split/iso will still be offered.
Offline depreshun
  • Reddit: risingremains
« Reply #217 on: Mon, 03 September 2018, 03:29:08 »
At $250 this seems like a great GB. I filled out the survey. I noticed that you just said an RGB PCB will also be available, have you considered a hotswapabble PCB?
Offline Gghi
« Reply #218 on: Mon, 03 September 2018, 06:15:34 »
Thanks for the feedback!
There will no hot-swap PCB, however, we can offer pre-solder if you have trouble with soldering.
Offline Marutks
« Reply #219 on: Mon, 03 September 2018, 14:32:56 »
fine with me,  I don't need hotswap PCB
when is this GB going to start?
Offline TheAutoManCan
« Reply #220 on: Mon, 03 September 2018, 14:39:33 »
Is the split space layout still TBD? If so what would be your thoughts on a 2.75/2.25/1.25 split? I personally think the best and most comfortable splits would have the two large keys split down or near the middle of the G and H keys. Plus this way there would be 3 1.25u keys on each side of the 'spacebars'.
Offline oldcat
  • 65% is Life
« Reply #221 on: Mon, 03 September 2018, 14:39:50 »
As early as this week :)
Second prototype is shipping to our tester tomorrow
Offline Gghi
Re: [IC] Doro67 - Integrated Plate 65% (Updated RGB PCB option, GB coming soon)
« Reply #222 on: Tue, 04 September 2018, 08:36:42 »
update white bot with logo. more to come in the next 2 days
Offline ye_cole
« Reply #223 on: Tue, 04 September 2018, 18:57:36 »
removed
(asked for colors, they're in the OP)
« Last Edit: Tue, 04 September 2018, 19:00:45 by ye_cole »
Offline Gghi
« Reply #224 on: Tue, 04 September 2018, 22:52:20 »
weight, caps pics come tomorrow.
Offline Hodgeman
« Reply #225 on: Tue, 04 September 2018, 23:06:04 »
Looking forward to it!
Offline prod
« Reply #226 on: Wed, 05 September 2018, 09:37:19 »
I really like this logo!
Chicory|YDPv2(BLUP)|BLE40|Daisy|YDPM|YD40w|Golbat
Offline pixelpusher
« Reply #227 on: Wed, 05 September 2018, 10:34:34 »
Me too.  I'm always in favor of keyboard themes and logos that are actually related to computers.  +1 on that logo
Offline OracleKev
« Reply #228 on: Wed, 05 September 2018, 11:44:40 »
What did the poll say?  Personally I like the logo, but not "BACKPROP"
Offline cldskt
« Reply #229 on: Wed, 05 September 2018, 12:00:39 »
+1
That’s what I put in the form as well.
Offline Gghi
« Reply #230 on: Wed, 05 September 2018, 12:39:02 »
Update new pics. GB start this week!!!
Doro(with SA R3) vs Skog(with GMK)
« Last Edit: Wed, 05 September 2018, 12:40:44 by Gghi »
Offline dario
« Reply #231 on: Wed, 05 September 2018, 12:55:37 »
Not bad at all. Not dissapointed.  ;)
Offline Marutks
« Reply #232 on: Wed, 05 September 2018, 14:00:13 »
looks awesome with SA keycaps  :thumb:  do you have photos of grey case?  I think I will go for grey color. I am going to use dev/tty keycaps. They have grey mods.
Offline Gghi
« Reply #233 on: Wed, 05 September 2018, 14:24:53 »
+1
Sorry but not have a logo without text. I will explain the options later.
Offline Gghi
« Reply #234 on: Wed, 05 September 2018, 14:26:06 »
We do offer grey color, but didnt make a grey doro sample.
Offline JDragon
« Reply #235 on: Wed, 05 September 2018, 19:30:39 »
Is there a color sample of the grey? Or did I just miss it somewhere in the thread?
Offline Gghi
« Reply #236 on: Wed, 05 September 2018, 20:35:26 »
we didnt made a grey doro, but here's a grey sample of other hardwares.
Offline Lyle88
Re: [IC] Doro67 - Integrated Plate 65% (Updated RGB PCB option, GB coming real soon)
« Reply #237 on: Thu, 06 September 2018, 01:37:50 »
Ooooh. Are those white on black caps SP or MaxKeys? It looks super tough with black case + WoB caps!
Offline meliewx
« Reply #238 on: Thu, 06 September 2018, 04:44:04 »
I really want that deskmat
Offline beekey
« Reply #239 on: Thu, 06 September 2018, 05:01:02 »
These are from MaxKeys: https://kbdfans.cn/collections/maxkey/products/maxkey-black-doubleshot-abs-sa-keycaps
Offline Gghi
« Reply #240 on: Thu, 06 September 2018, 09:07:52 »
Actually the caps are SP :)
Offline oldcat
  • 65% is Life
« Reply #241 on: Thu, 06 September 2018, 12:14:59 »
We will post on GB section of Geekhack tomorrow (needs approval time too). And all details and updates will be posted to GH, in addition to Discord.
If you want to join early, join ALF discord, or visit: https://alfstudio.club/doro67-GB/
Offline wanewang
« Reply #242 on: Thu, 06 September 2018, 12:28:48 »
definitely in for one!!!!
can't wait to see it start!
Offline Rubbermilitia
« Reply #243 on: Thu, 06 September 2018, 12:52:05 »
Where did you get SP WoB set if you don't mind me asking? I have the maxkeys WoB but prefer SP.
Offline Gghi
« Reply #244 on: Thu, 06 September 2018, 14:15:42 »
Sorry, my friend took those pictures. I think he combines black alpha with Blood and Sallow modifiers
Offline oldcat
  • 65% is Life
Re: [IC] Doro67 - Integrated Plate 65% Customized Keyboard
« Reply #245 on: Thu, 06 September 2018, 15:36:29 »
split backspace please !
Don't they have different colors?   Dark blue,  dark grey,  for example, would look much better.
We are drafting our GH GB post in the GB section, which will also take some time for approval. At this time you can check this out for details, or join early: https://alfstudio.club/doro67-GB/
Offline chuckdee
« Reply #246 on: Thu, 06 September 2018, 19:26:28 »
It looks like one of 7bit's rounds from the ESC key.
« Reply #247 on: Thu, 06 September 2018, 22:57:54 »
I don't know about that... it looks literally identical to the maxkeys WoB caps. Maybe the person who owns them forgot where he got them.
You can even tell SP from maxkeys just by looking. Maxkeys has a more dry, matte look, whereas SP is more glossy. These def look matte.
Offline beekey
« Reply #248 on: Fri, 07 September 2018, 00:52:55 »
The space split support is only 2.75,1.25,2.2.25, right? No 2.25,1.25,2.2.75 split possible?
Offline chuckdee
« Reply #249 on: Fri, 07 September 2018, 06:44:44 »
That DT key is what gives it away.  And it definitely has the same finish as the rest. That's a deskthority key, and Maxkeys doesn't have that.
