Author Topic: [IC] Doro67 - Integrated Plate 65% (Updated RGB PCB option, GB coming real soon)  (Read 74937 times)
Offline adamcobabe
Re: [IC] Doro67 - Integrated Plate 65% (Updated RGB PCB option, GB coming real soon)
« Reply #250 on: Fri, 07 September 2018, 06:47:47 »
Unless I'm mistaken, Plate Option 4 in the group buy doesn't seem to support the 3 1u keys on the bottom row when looking at the holes to be cut. Might want to fix the images if true.
Offline Gghi
« Reply #251 on: Fri, 07 September 2018, 09:28:21 »
Thanks, you're right! I made a mistake, will fix that.
Offline oldcat
  • 65% is Life
« Reply #252 on: Fri, 07 September 2018, 11:50:30 »
Geekback Groupbuy Post has been submitted, now pending approval.
Offline PoochZag
« Reply #253 on: Fri, 07 September 2018, 14:45:49 »
Just wanted to verify that both the RGB and normal PCB options have the switches facing south?
Thanks
TX-CP, TX60, Campine Mk. III, Mira SE
Offline Marutks
« Reply #254 on: Fri, 07 September 2018, 14:54:41 »
good question
Offline Rubbermilitia
« Reply #255 on: Fri, 07 September 2018, 16:38:04 »
Thanks
good question
South
Offline PoochZag
« Reply #256 on: Fri, 07 September 2018, 16:40:31 »
Thanks
good question
Thanks for that, most likely in for sure now
South
Offline Photoelectric
« Reply #257 on: Fri, 07 September 2018, 17:41:28 »
Please proceed to the Group Buy thread for continued discussion.
