Author Topic: [IC] BP80 keyboard  (Read 10555 times)
Offline Levan
[IC] BP80 keyboard
« on: Tue, 23 October 2018, 22:57:58 »
Hi, this is BP80.
BP80 inspired by Black Panther.
Still need more advice for the bottom.
206059-0
206061-1
206063-2
206065-3
206067-4
206069-5
206071-6
206073-7
And I made a prototype
206075-8
206076-9
206079-10
206081-11
206083-12
« Last Edit: Wed, 24 October 2018, 11:48:35 by Levan »
Offline Artemie
  • Don't Let Your Memes Be Dreams
Re: [IC]BP80 keyboard
« Reply #1 on: Tue, 23 October 2018, 23:01:14 »
Wakanda Forever
| 420CL | Fanoe | Porpoise | KFE R1 Silver| MxSS |  is0 Pink & Silver | HBCP Polycarbonate | Matrix 2.0 Additional Purple | TGR Police | Singa Jaguar Green | KFE R2 Blue | RS so lit | Dolch CR Black | Jelly 60 Blue | Belle en Rose | Kei R2 Olive | Dalco 959 Mini | Aripeko
Boards in GB: | IU board |
Previous Boards: QXP | Singa  | UTD | Taichi | Jane v2 Red | Jane v2 CE
Offline Shadohhh
« Reply #2 on: Tue, 23 October 2018, 23:01:17 »
Those renders look very 2 dimensional... I personally cannot tell how tall/thick the keyboard. Also how is this mounted, it looks tray mounted.
Okay, the prototype looks decent. However, if your case is the same as the renders your keycaps might rub on the case.
« Last Edit: Tue, 23 October 2018, 23:14:35 by Shadohhh »
Offline appaboy
« Reply #3 on: Tue, 23 October 2018, 23:02:43 »
this is the most "generic gaming" styled custom keyboard ive seen
PC Singa, MIR80, TX84se, g80-3314, g80-0427, g80-5000 + 5700, G80-3700, g81-3000 HBU (og wob)
HASRO keycaps
OG POM keycaps
SAI OG Italian dyesubs
Scarface Fn blank
Offline Remsky
  • Lubed switch count > Puddsy post count
« Reply #4 on: Tue, 23 October 2018, 23:07:57 »
So thats why the pcb is northfacing w/o pcb mount holes.
TGR Jane v2 - GSKT00(coming) - TGR Jane CE V2 - TGR Poly alice - LZ Physix - Matrix 8XV 2.0 - RS - LZ FE - Dalco 959 Mini GT edition (coming) - Mc65 - Hiney TKL one - HHKB Pro 1 - 25th anniversary edition HHKB pro Hybrid - 30th anniversary Filco 2S keyboard
Offline M
« Reply #5 on: Tue, 23 October 2018, 23:10:18 »
is that supposed to be a wrist rest?
Offline Remsky
« Reply #6 on: Tue, 23 October 2018, 23:10:27 »
Costar stabilized capslock is the biggest brane thing I have ever seen on this site, next to metal Pok3r.
Offline Levan
Re: BP80 keyboard
« Reply #7 on: Tue, 23 October 2018, 23:11:47 »
This reeks of chyna design. Did you get a quote for a proto yet? Looks hard to machine.... Also no holes for pcb mount switches?
I uploaded some pictures for sample.
« Reply #8 on: Tue, 23 October 2018, 23:12:24 »
you ever played final fantasy?
Offline weaston
« Reply #9 on: Tue, 23 October 2018, 23:16:00 »
And I made a sample
The floor of the inside is not sitting parallel to the top face of the board.  Doesn't this mean that the caps would be mounted at a negative angle and not go through the top cutouts?  Also what is the mounting?  The inside of the case has no standoffs for tray mount and the plate has no wings for top mount.  I am very confused and concerned about the viability of this design.
DK Saver | Kingsaver | OTD 360 Corsa | OTD 456GT | OTD Cheat | KMAC 1.3 | KMAC 1.2 | KMAC Happy | KMAC Pad | KMAC Mini (Revo) | Singa | HHKB Pro 1 | GSKT-00 | IBM 5251 | IBM Model F XT | IBM Model M | Dolch PAC | Kinesis Advantage
« Reply #10 on: Tue, 23 October 2018, 23:20:04 »
And I made a sample
not if the plate mounts to the top part of the case
Offline Levan
« Reply #11 on: Tue, 23 October 2018, 23:22:32 »
nope, I don't play final fantasy. Just LOL and PUGB.
Offline Levan
« Reply #12 on: Tue, 23 October 2018, 23:23:39 »
And I made a sample
Yes , pcb mount to the top layer. Not the bottom case.
Offline Zuology
  • Why does this rabbit-hole have so many side-quests
« Reply #13 on: Tue, 23 October 2018, 23:25:56 »
I feel like every way I look at this is an optical illusion. Productive feedback (aside from snarky negative jabs) is that it's really over the top and looks cheap (check out gamer design keyboards like Gamdias and other generic-ish manufacturers) despite it obviously taking a lot of time, material, and CNC design work. I do get the BP aesthetic a bit, but I don't think it's a good match for a case design that will attract many interested buyers, at least in this current form.
75%: Scarlet Bandana (TBD) | Singa75 Polycarb (TBD) | SKB75 (TBD) | YMD75 (Box Navy) | XD84 (Outemu Ice) | Plum84 (BKE Redux Heavy)
TKL: ALF X1.1 SE (TBD) | LZ Iron White (TBD) | Fox Labs Orange (TBD) | Alu WASDv2 (Cherry Green) | MechkeyAlpha MA87 (Kailh Box Burnt Orange) | Archon RE:AL Superior EX (Nopre 65g)
Full+: Clueboard Double 1800 (Vint Clears) | IBM Model M | IBM Model F XT
Offline Taeha Types
    • Subscribe to me :D
« Reply #14 on: Tue, 23 October 2018, 23:28:06 »
Wakanda Forever
Make this out of vibranium and I am in :)
Offline zekkin
  • my entire life was unlimited zekk works
« Reply #15 on: Tue, 23 October 2018, 23:40:09 »
this is like a next-gen LZ Iron
Offline Allo
« Reply #16 on: Tue, 23 October 2018, 23:45:10 »
That's a Cadillac
Offline nasp
« Reply #17 on: Wed, 24 October 2018, 00:28:03 »
I dig it. Would love to see some keycaps on it to get a better idea of end product.
Offline [Lewynlight]
  • Formerly Dymloslouire
« Reply #18 on: Wed, 24 October 2018, 00:50:59 »
this design is too radical for me hahaha
TGR Jane V1 CE - TGR Jane V2 CE Black Ano - TGR 910 R1 - TGR 910 RE Polycarbonate - TGR 910v3 Prototype - TGR Tris - RS60 - RS65 "Internet Yamero" - RS TKL
Offline Remsky
« Reply #19 on: Wed, 24 October 2018, 01:09:40 »
Some feedback:
- I'm assuming those are costar stab cutouts, I highly recommend using cherry stab cutouts instead. Few people have keycap sets with costar stabs for stabilized keys. Also, capslock is not a stabilized key.
- How is it mounted? You said it was top mount in the replies, but as someone pointed out already, top mount won't exactly work. Can you confirm that the plate securely fits along with the pcb inside the case?
- Not enough distance between switches cutouts and the edges. Keycaps on the edge such as all caps on the spacebar row will hit the metal bezel. This along with the mounting are the most damning issues right now
Just as something with preference: I would strongly recommend using a pcb with southfacing switches that also has pcb mount cutouts for switches. North facing is notorious for having issues with R3 cherry profile iirc and a lot of people love to use cherry profile keycaps.
Offline Levan
« Reply #20 on: Wed, 24 October 2018, 01:44:46 »
Thanks,but the pcb is parallel to the plate , so keycaps won't rub on the case.
Offline Levan
« Reply #21 on: Wed, 24 October 2018, 01:55:18 »
Thank you very much for your productive feedback.
I'll try more elegant design.
Just wanna know GH's aesthetic orientation.
It is true that this design is very heresy.
Offline Levan
« Reply #22 on: Wed, 24 October 2018, 04:05:59 »
Some feedback:
- I'll try to use a Cherry Stab Cutouts
- I'm trying to optimize the specific installation method
- PCB and locating plate are parallel and have been tested for a distance of about 1 mm on other housings
- Okay, then South Facing Switches
Thank you very much for your suggestion.
Offline _ODIN_
Re: [IC] BP80 keyboard
« Reply #23 on: Wed, 24 October 2018, 06:50:30 »
Holy Jesus! Definitely unique
Offline regionfree
« Reply #24 on: Wed, 24 October 2018, 07:50:33 »
Finally, a keyboard that'll be efficient for slaying my enemies.
Offline Zuology
« Reply #25 on: Wed, 24 October 2018, 08:38:37 »
I take it that you are not yet familiar with the Keeblade Zlant case  :-\
Offline nasp
« Reply #26 on: Wed, 24 October 2018, 09:42:22 »
Maybe he doesn't care for 40% boards?!  :p
