Author Topic: [GB] Fox Lab - Leaf 60  (Read 351470 times)
Offline senter
Re: [GB] Fox Lab - Leaf 60
« Reply #50 on: Wed, 16 January 2019, 22:31:37 »
How soft is the gasket? Does it add significant flex, or is it purely for vibration/sound dampening?
The gaskets are pretty soft, but they are only 1.5mm thin on both sides of the plate. I'd say it's mainly for sound dampening.
Offline senter
« Reply #51 on: Wed, 16 January 2019, 22:34:44 »
Is it possible to have more photos of black polycarb?
Edit: Also, could you add an option for ordering extra weight?
Here you go https://imgur.com/a/dzHCKBy
You can write a note in the last question in the form. I thought no one wants extra weights.
Offline juaninamilli
« Reply #52 on: Wed, 16 January 2019, 22:37:08 »
Do you have a sample of Mao white? That's kind of a surprise finish.
Offline senter
« Reply #53 on: Wed, 16 January 2019, 22:38:55 »
/u/Peppermint216 posted his MAO Leaf 80 several days ago.
Offline ocnis
« Reply #54 on: Wed, 16 January 2019, 22:39:54 »
+1
I’d really love to have stepped caps and full backspace on WKL too. The universal plate just looks too funky
I didn't even notice that... Yeah... Need stepped caps and full backspace for wkl.
Can we at least get stepped caps lock for the WKL plate? :(
Offline TheArcticFox_27
« Reply #55 on: Wed, 16 January 2019, 22:44:12 »
i wish the wkl plate wasnt split bs only
as you have to get a universal plate for normal bs which isnt ideal
The WKL plate is meant to be used with the hotswap PCB.
Yes, it's not ideal. However, it's not possible to make it ideal for every possible layout.
There are 4 types of plates, 2 types of PCB, 3 types of top case layout. That's best we can do.
I don't think that adding a standard BS and stepped caps option would ruin the plate for the hotswap pcb, i've tested before and it works just fine.
Also, the Tokyo 60 has a stepped cutout
Offline senter
« Reply #56 on: Wed, 16 January 2019, 22:47:36 »
As so many people asked, dedicated WKL plate can be available, but only in black/clear PC.
You can write a note in the last question in the order form and tell me to replace the PC layout to dedicated WKL.
The current "WKL" plate is meant to be used for the hotswap PCB.
The universal plate is a must-have.
The dedicated HHKB plate is requested in the IC.
The ALPS plate is also a must-have.
I can not provide any more options guys LOL
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #57 on: Wed, 16 January 2019, 22:49:27 »
Thanks for the extra pics. :thumb:  Thought black PC could be a bit transparent but nope.  Definitely opaque. :blank:
« Last Edit: Wed, 16 January 2019, 22:51:47 by Sent »
« Reply #58 on: Wed, 16 January 2019, 22:54:13 »
You don't have to provide more options... Just the right ones
Offline slxdegrees
  • Nerds With Keebs
    • Donate to Room To Read!
« Reply #59 on: Wed, 16 January 2019, 23:16:23 »
Hey senter, how heavy does the standard kit weigh when assembled? Tried searching both threads but couldn't find an answer.
Offline ian13
« Reply #60 on: Wed, 16 January 2019, 23:17:32 »
May we know who will do the shipping?
As we're not running the GB through zFrontier (due to the CNY holiday), we'll do the shipping directly. We'll work with a DHL proxy.
The good thing is, the shipping will be much faster. zFrontier second time QC normally take one week or more.
The bad thing is, we don't have the second time QC this time. We'll do the QC more carefully tho.
Hi, I really wanted to join but a bit concerned regarding shipping to my country. Will you use a door-to-door shipping method like DHL Express or do I have to pick it up in our local post once it arrives? Customs fees and loooong processing time in our country is a bit of a mess, which is why I asked.
I hope you can provide more info on the shipping proxy that you will use. Thanks, Senter! I'm really looking forward to this!
« Last Edit: Thu, 17 January 2019, 03:09:41 by ian13 »
Offline otanishock
  • One of the cool kids :>
  • ファーストラブ
« Reply #61 on: Wed, 16 January 2019, 23:40:54 »
So base kit already includes an aluminum/PC weight?
« Reply #62 on: Wed, 16 January 2019, 23:51:24 »
Is the sandblasted weight/plate raw, or does it have a clear coat?
Offline yemeisong
« Reply #63 on: Wed, 16 January 2019, 23:53:24 »
is there another page for people in China?
Offline gnhuy91
« Reply #64 on: Thu, 17 January 2019, 00:38:22 »
Can you provide sample of MAO white? How is it in comparison with E-white?
Offline bengine
« Reply #65 on: Thu, 17 January 2019, 00:54:30 »
Will you be putting together an order list spreadsheet?
Offline spyruf
« Reply #66 on: Thu, 17 January 2019, 01:33:00 »
Yes. For $275 (excluding fees and shipping) you can get everything you need to build a keyboard
Go look at the initial GB post for the leaf 80 on reddit. There’s direct comparison pictures. Otherwise there’s a lot of posts of e white and a couple mao on the leaf 80 GH thread and on reddit
I don’t think he’s done this before so I wouldn’t expect one. It would be helpful though.
Offline bengine
« Reply #67 on: Thu, 17 January 2019, 01:47:04 »
Here's the comparison in Leaf 80 GB: https://imgur.com/5NyCjC6. Left is e-White, right is MAO White.
« Last Edit: Thu, 17 January 2019, 01:49:04 by bengine »
Offline gnhuy91
« Reply #68 on: Thu, 17 January 2019, 01:51:21 »
thanks mate, going e white now
Offline Coolbeanz
« Reply #69 on: Thu, 17 January 2019, 02:07:04 »
Thank you so much for this compromise!
Offline pr0ximity
« Reply #70 on: Thu, 17 January 2019, 05:44:02 »
+ stabs, switches, and caps  ;)
Offline Nigolski
« Reply #71 on: Thu, 17 January 2019, 05:50:15 »
dang this is nice
Offline edasaur
« Reply #72 on: Thu, 17 January 2019, 05:53:33 »
looks fantastic! very tempted to join in.
is there a side - profile view? Thanks!
Offline Captainbuttmonkey
« Reply #73 on: Thu, 17 January 2019, 06:19:52 »
Is it possible to do an ALPS WKL build?
Offline Keltop
  • sleepy
« Reply #74 on: Thu, 17 January 2019, 06:22:29 »
Is the Universal PCB soldered or not?
Offline slxdegrees
  • Nerds With Keebs
« Reply #75 on: Thu, 17 January 2019, 06:25:49 »
No.
Sent from my LYA-L29 using Tapatalk
Offline slxdegrees
  • Nerds With Keebs
« Reply #76 on: Thu, 17 January 2019, 06:26:48 »
Yes.
Offline rope
  • yeet
« Reply #77 on: Thu, 17 January 2019, 06:27:35 »
pm'ed for brass kit!  :D
« Last Edit: Thu, 17 January 2019, 06:30:04 by rope »
« Reply #78 on: Thu, 17 January 2019, 06:32:03 »
Yes.
Great, I assume I'd just specify a WKL top and then the alps plate and pcb?
Offline slxdegrees
  • Nerds With Keebs
« Reply #79 on: Thu, 17 January 2019, 06:36:13 »
Yes.
Please read thru the thread wrt the wkl plate. There is something you should probably take note of.
« Last Edit: Thu, 17 January 2019, 06:38:47 by slxdegrees »
« Reply #80 on: Thu, 17 January 2019, 06:39:46 »
Yes.
Oh I saw that about the backspace but I assume I can't use the WKL plate with alps anyway due to different cutouts? I would need to use the alps plate and pcb and just leave a gap on the winkeys?
Offline Keltop
  • sleepy
« Reply #81 on: Thu, 17 January 2019, 06:40:25 »
No.
What about  the Hot swappable?
Offline slxdegrees
  • Nerds With Keebs
« Reply #82 on: Thu, 17 January 2019, 06:41:25 »
No.
Yes. The hotswap sockets are soldered.
Offline dantambok
« Reply #83 on: Thu, 17 January 2019, 06:55:02 »
Wait just to clarify, you will offer the PC plate in dedicated WKL layout? (without the cutout for the winkey?)
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline hq
« Reply #84 on: Thu, 17 January 2019, 07:35:37 »
Looks awesome!   :thumb:
but...cries in ISO  :(
Offline mdlt97
  • This **** is still better than Keebtalk
« Reply #85 on: Thu, 17 January 2019, 07:50:05 »
can we see this dedicated wkl plate because imo a dedicated wkl plate should have been the plate you picked originally since like its the proper plate
TX60 | Duck TC-V3 | Duck Eagle V2 1/1 Bottom | Zephyr r2 | Duck Sidewinder | Mech27v2 | TX75 | LZ CLS | Duck Viper v2 | Orion v3 | HHKB pro 1 | TGR 910 | Omega60
Online o3okevin
« Reply #86 on: Thu, 17 January 2019, 08:20:09 »
As per Senter, the dedicated WKL plate he mentioned above will have:
  • No winkey openings
  • Stepped caps
  • Full backspace
PC plates only
Offline pixelpusher
« Reply #87 on: Thu, 17 January 2019, 08:38:47 »
The alps plate should omit the winkey opening as well.  Please consider  :thumb:
Offline eagleheardt
« Reply #88 on: Thu, 17 January 2019, 09:15:15 »
purchased e-black case with brass plate and brass weight!!
I really want the numpad friend to have 24 keys eventually, but I'll be patient and wait till everything is final and try to add what I can.
SOOOO hype for this one!
Is this... endgame?
Offline fireworm
« Reply #89 on: Thu, 17 January 2019, 10:32:19 »
Is this... endgame?
It's an endgame. Until you want to play again.
Offline -musubi
  • Spam rice 'n eggs
« Reply #90 on: Thu, 17 January 2019, 11:44:08 »
Will the original WKL plate still retain the cutouts (as shown in the image) that would be under the blockers as well? It’d be nice for PC cases to have it closed like the HHKB plate since it’s transparent.
Same with the “new” dedicated WKL PC plates, if you can share the design of that as well that would be great. Thanks
Offline ejewell89
  • 4ever Smol
« Reply #91 on: Thu, 17 January 2019, 11:44:56 »
in for poly
Offline slxdegrees
  • Nerds With Keebs
« Reply #92 on: Thu, 17 January 2019, 12:20:15 »
Has anyone been invoiced yet?
« Reply #93 on: Thu, 17 January 2019, 12:27:06 »
Just placed my order.  Will there be a follow up with the details of the order to make sure we got it all in right?
Offline otanishock
  • ファーストラブ
« Reply #94 on: Thu, 17 January 2019, 12:27:55 »
Not possible to have regular caps for dedicated WKL plate?
Offline Unforgivable
« Reply #95 on: Thu, 17 January 2019, 12:59:20 »
Looking at the Alps Plate, it seems I’ll be able to use this with AEK II keycaps, correct? No need for a 7u spacebar, right?
Offline Lormania
« Reply #96 on: Thu, 17 January 2019, 13:18:12 »
Are changes allowed after submitted order? I want to go ahead and place my order
You get two pms to him from reading the op.
I'm super excited for the alps support. Finally a nice case for alps!
My thoughts exactly! What setup are you planning? I hear polycarb makes boards sound better so pairing alps with that could be a good combo. I am between the PC and E-White.
Offline fireworm
« Reply #97 on: Thu, 17 January 2019, 13:32:25 »
I'm pretty sure I'll be buying two (pc alps and brass mx), plus another alps brass plate + pcb.  Zealio V2's are quite nice, and I'm a sucker for Split Space.  Still waffling though.
Offline senter
« Reply #98 on: Thu, 17 January 2019, 13:59:26 »
Yes, I'll use DHL Express, not the local DHL tho. Hongkong DHL is cheaper than in mainland China. All the packages will be shipped to a Hongkong DHL proxy. Then the proxy will distribute the packages to every country.
Offline senter
« Reply #99 on: Thu, 17 January 2019, 14:00:11 »
Sandblasted brass parts are raw.
