Author Topic: [GB] Fox Lab - Leaf 60  (Read 345851 times)
Offline senter
Re: [GB] Fox Lab - Leaf 60
« Reply #100 on: Thu, 17 January 2019, 14:00:58 »
is there another page for people in China?
Chinese buy just ended.
Offline senter
« Reply #101 on: Thu, 17 January 2019, 14:03:04 »
Will you be putting together an order list spreadsheet?
The order information will be included in the invoice.
I think it's not necessary to display everyone's ID and options in public.
Offline senter
« Reply #102 on: Thu, 17 January 2019, 14:08:02 »
is there a side - profile view? Thanks!
Quickly check my phone album and didn't find one. Here's a side view of Leaf 80 prototype I shared before. Leaf 60 is pretty much the same.
Offline senter
« Reply #103 on: Thu, 17 January 2019, 14:09:51 »
Wait just to clarify, you will offer the PC plate in dedicated WKL layout? (without the cutout for the winkey?)
You didn't hear me wrong. No cutouts for WK, stepped/non-stepped capslock, 2u BS.
Offline senter
« Reply #104 on: Thu, 17 January 2019, 14:17:15 »
The alps plate should omit the winkey opening as well.  Please consider  :thumb:
With WK cutouts: no problem on alu/opaque cases, having the opportunity to use win keys.
Without WK cutouts: not ideal for clear cases if you don't use win keys.
Hard decision
Offline senter
« Reply #105 on: Thu, 17 January 2019, 14:19:53 »
Will the original WKL plate still retain the cutouts (as shown in the image) that would be under the blockers as well?
The original plate will stay as is. Yep, I will post the new plate's pic later on.
Offline juaninamilli
« Reply #106 on: Thu, 17 January 2019, 14:20:10 »
Singa plates are pretty open on the bottom row. The WKL PC looks fine. I think that the plates for this run have been a little over thought.
Offline senter
« Reply #107 on: Thu, 17 January 2019, 14:23:26 »
Has anyone been invoiced yet?
No worries. It hasn't been started yet.
« Reply #108 on: Thu, 17 January 2019, 14:25:05 »
the less open space in plates the better tbh
the more open space there is in the bottom row, the more prone plate mount switches will be to twisting, which is more annoying than thinking for 45 seconds about what layout you're gonna build your board in
Offline senter
« Reply #109 on: Thu, 17 January 2019, 14:26:19 »
Looking at the Alps Plate, it seems I’ll be able to use this with AEK II keycaps, correct? No need for a 7u spacebar, right?
I don't think 6.5u spacebar will work.
AEK caps work best on curved top cases like on Lunar.
« Reply #110 on: Thu, 17 January 2019, 14:30:07 »
What I'm saying is that a tweaked version of this plate could've been offered... Delete ISO and make sure it has 2u/split bs and normal/stepped caps. Even if the squares are open behind the corner/wkl blockers, it will still look fine (like Singa). No need for all these other VERY specific plates.
« Reply #111 on: Thu, 17 January 2019, 14:30:55 »
Forgot to post the plate lol
« Reply #112 on: Thu, 17 January 2019, 14:35:50 »
this is the most actively normal plate i have ever seen and i do not understand your gripe
although i do agree with delete iso
« Reply #113 on: Thu, 17 January 2019, 14:36:59 »
Are you paying attention? This isn't the plate being offered in the GB.
« Reply #114 on: Thu, 17 January 2019, 14:38:48 »
there are different plate offerings because the holes look weird under PC
i thought that image was from the OP
senter has run his share of GBs and i trust him to handle sorting all the wacky plates
this is basically a non-issue
« Reply #115 on: Thu, 17 January 2019, 14:47:15 »
I feel much better about it now that you've spoken. Thank you so much for involving yourself.
Offline AlcoholEnthusiast
« Reply #116 on: Thu, 17 January 2019, 14:54:25 »
The universal plate will work with the hotswap PCB if we want to use it for a full layout, right? It says HHKB/WKL but I would want the full layout.
Offline dubious
  • 쏘쿨
« Reply #117 on: Thu, 17 January 2019, 15:01:10 »
I would totally pick one up if the timing was different. GL with GB, and nice board  :thumb:
Offline up-in
« Reply #118 on: Thu, 17 January 2019, 15:05:49 »
is it worth it to upgrade the brass plate into PVD coated? Is that just for look or are there any other advantages?
« Reply #119 on: Thu, 17 January 2019, 15:10:46 »
It will be more resistant to tarnishing. Raw brass tends to leave fingerprints from the oils in your hands that don't really wipe off.
Offline Mekuno
« Reply #120 on: Thu, 17 January 2019, 15:19:02 »
I find this very annoying for one of my brass sandblasted plates that I purchased off someone else.. It looks nice but the tarnishing it just annoying especially when they're not my fingerprints. Anyways do you know what you use to clean them off and get them refinished?
Offline MTXjunkie
« Reply #121 on: Thu, 17 January 2019, 15:20:25 »
Ketchup or brasso and a lot of elbow grease.
Sent from my iPhone using Tapatalk Pro
Offline Rorkish
« Reply #122 on: Thu, 17 January 2019, 17:33:31 »
Could someone clarify whether the ALPS plate is available in materials other than PC?
Offline fireworm
« Reply #123 on: Thu, 17 January 2019, 17:40:59 »
ALPS plate is in all materials.
The WKL plate has a special version where the WKL holes are removed, in PC only.
Offline dantambok
« Reply #124 on: Thu, 17 January 2019, 17:53:54 »
Uhh i think i want to change my order. Do i just pm? Or can i request my old order to be cancelled and i make a new one?
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline TheArcticFox_27
« Reply #125 on: Thu, 17 January 2019, 18:42:06 »
Isn't the prices for a brass plate and weight a bit high?
Brass plate upgrade usually goes for $10-12, $37 is pretty high
Offline eagleheardt
« Reply #126 on: Thu, 17 January 2019, 19:14:34 »
probably dumb question:
the e-black case - that's made of aluminum, right?
« Reply #127 on: Thu, 17 January 2019, 19:19:14 »
This
Offline mnpq.raven
« Reply #128 on: Thu, 17 January 2019, 19:23:47 »
yes
Offline yemeisong
« Reply #129 on: Thu, 17 January 2019, 19:25:07 »
but I can still order to China right?
Offline Unforgivable
« Reply #130 on: Thu, 17 January 2019, 19:42:16 »
 :thumb:
« Last Edit: Sun, 13 December 2020, 16:03:59 by Unforgivable »
Offline reidd
« Reply #131 on: Thu, 17 January 2019, 21:05:46 »
This
yaaaa
Offline Aevyn
« Reply #132 on: Thu, 17 January 2019, 21:10:10 »
Are all those options supposed to be there for the weight? I'm having a hard time imagining a clear PC weight.
EDIT: After reading again, I'm assuming these are for the leaf shape accessory/logo on the bottom?
EDIT2: If you can get the whole weight in clear PC, do you have a render or photo of a completely clear PC build? (case, plate, weight, leaf accessory). Just trying to imagine what it would look like.
« Last Edit: Thu, 17 January 2019, 21:19:18 by Aevyn »
« Reply #133 on: Thu, 17 January 2019, 21:21:49 »
Also interested on how to change order
Also, does Fox Labs have a discord?
« Reply #134 on: Thu, 17 January 2019, 21:54:07 »
It's in the order link...
Offline ian13
« Reply #135 on: Thu, 17 January 2019, 23:11:05 »
Hi, I really wanted to join but a bit concerned regarding shipping to my country. Will you use a door-to-door shipping method like DHL Express or do I have to pick it up in our local post once it arrives? Customs fees and loooong processing time in our country is a bit of a mess, which is why I asked.
I hope you can provide more info on the shipping proxy that you will use. Thanks, Senter! I'm really looking forward to this!
Yes, I'll use DHL Express, not the local DHL tho. Hongkong DHL is cheaper than in mainland China. All the packages will be shipped to a Hongkong DHL proxy. Then the proxy will distribute the packages to every country.
Thank you for the clarification, Senter! Will finalize the choices then place my order later. GL on this GB!  :thumb:
Offline kialios
« Reply #136 on: Fri, 18 January 2019, 00:25:00 »
pc+1
Offline up-in
« Reply #137 on: Fri, 18 January 2019, 01:51:28 »
yeah, too bad that i really want to get PVD coated brass plate, with the high price, i just pick the normal brass.
Offline meiosis
  • Time
« Reply #138 on: Fri, 18 January 2019, 02:28:41 »
I think it's for a whole extra one
Sent from my ONEPLUS A6013 using Tapatalk
Keyboards:
Aripeko TKL
Offline blizzara01
« Reply #139 on: Fri, 18 January 2019, 03:44:23 »
I hope we have samples of aluminum/PC bottom leaf shape accessory
Offline georgethehuman
    • blorgy
« Reply #140 on: Fri, 18 January 2019, 03:44:34 »
is the weight in the order the form the material of the leaf accessory for the back or are they separate pieces?
« Reply #141 on: Fri, 18 January 2019, 08:17:05 »
There's an upgrade price and an extra price. The extra price seems reasonable... The upgrade price does not, seeing as your giving up the base versions.
Offline etong415
« Reply #142 on: Fri, 18 January 2019, 08:32:24 »
Agree, I followed this through IC, and didn’t expect a brass plate+weight to cost so much more than the base kit.
Offline laserbeamspewpew
« Reply #143 on: Fri, 18 January 2019, 08:36:20 »
I would like to echo this sentiment.
Offline thearctican
« Reply #144 on: Fri, 18 January 2019, 09:22:10 »
Agreed.
Filled out the order with a black plate and unfinished brass weight. Looks good guys.
Offline tiydal
« Reply #145 on: Fri, 18 January 2019, 09:24:38 »
Agreed.
Agreed also, its the reason I havent submitted yet.
Offline JohnWest
« Reply #146 on: Fri, 18 January 2019, 11:16:08 »
In for two, can't wait! :D
Offline pcire
« Reply #147 on: Fri, 18 January 2019, 11:25:42 »
I'm glad I'm not the only one that feels this way
« Reply #148 on: Fri, 18 January 2019, 11:34:46 »
 :I feel the same way fwiw. I still put in an order but didn't upgrade the plate like I usually would.
Offline mog_genius88
« Reply #149 on: Fri, 18 January 2019, 12:15:08 »
I was kinda ok with the plate. It at least serves a function and is in line with how much brass plates nornally cost. Still a little disappointing but fair imo
The brass weight on the other hand....
