Author Topic: [GB] Fox Lab - Leaf 60  (Read 353978 times)
Offline boog
Re: [GB] Fox Lab - Leaf 60
« Reply #800 on: Fri, 17 May 2019, 18:42:59 »
Finally got around to unboxing this thing. Mine came with a few blemishes I'll need to contact Senter about, but overall, it's a really nice board. The brass plate and weight really make this feel super solid.
Does anyone else have these weird circle marks on the leaf?
Yeah, I have these marks and the light scratch marks under the weight on the back
Offline nephlock
« Reply #801 on: Fri, 17 May 2019, 23:17:15 »
Mine as well. Seems like a pretty consistent problem, so likely something to do with the manufacturing process.
Offline ArchDill
« Reply #802 on: Sat, 18 May 2019, 00:04:43 »
Offline LuiKang
« Reply #803 on: Sat, 18 May 2019, 00:22:21 »
Good to see a PC typing test. Thanks!
Here I have another typing test, this time with SA PBT keycaps.
« Reply #804 on: Sat, 18 May 2019, 10:22:15 »
I sold my PC board, really wish I went for an e-white. Next time, hopefully!
E6-V2 [Tealios] | RAMA M60-A [Zealios] | QXP [Healios]
Offline thatsadmummy
« Reply #805 on: Sat, 18 May 2019, 17:12:12 »
Potato photo but I love this board.  Red samurai + Jamon bacon cap  :)
Offline thearctican
« Reply #806 on: Sat, 18 May 2019, 17:30:13 »
Got it put together! Does anyone know if there is a reset built into the default keymap, or has my eagerness screwed me to take it apart again?
Offline etong415
« Reply #807 on: Sat, 18 May 2019, 17:35:12 »
When program it, you can set one key on a separate layer to be the reset button.
Offline PvtSkittles
« Reply #808 on: Sat, 18 May 2019, 17:43:56 »
Well I was going to say the reset is Fn+Esc but I think the default Fn key is where RWin should be and you're on a winkeyless build... At least it was for me on the hotswap PCB. Not sure if there's another Fn key mapped somewhere.
Offline laserbeamspewpew
« Reply #809 on: Sat, 18 May 2019, 17:47:57 »
Try R. Alt + Esc.
Offline Nostril
  • Synth Labs
« Reply #810 on: Sat, 18 May 2019, 17:56:00 »
Try these methods in the "Put your keyboard into DFU mode" section.
https://beta.docs.qmk.fm/newbs/newbs_flashing
The space+b and unplug method worked for me.
Offline thearctican
« Reply #811 on: Sat, 18 May 2019, 18:07:10 »
That's what I needed. Fingers crossed they included bootmagic in the default build.
Offline Furikurichemy
« Reply #812 on: Sat, 18 May 2019, 19:23:59 »
Fn + escape will work too.
Offline finalarcadia
« Reply #813 on: Sat, 18 May 2019, 19:33:49 »
Can confirm space+b when plugging in works for the hotswap PCB for DFU mode.
Anyone know if these LEDs are RGB? if so, how to use that functionality in QMK (through code)?
Offline thearctican
« Reply #814 on: Sat, 18 May 2019, 19:51:19 »
Just by looking at it they appeared to be two pin SMD LEDs. One color.
« Reply #815 on: Sat, 18 May 2019, 19:53:38 »
Offline spyruf
« Reply #816 on: Sun, 19 May 2019, 00:38:39 »
I tried all of these do you know if there are any other methods?
I flashed a keymap without a reset key and now I can't seem to figure out how to the pcb back in DFU mode.
Offline LuiKang
« Reply #817 on: Sun, 19 May 2019, 00:52:46 »
Fn + Esc while the keyboard is plugged.
Offline spyruf
« Reply #818 on: Sun, 19 May 2019, 00:59:50 »
Afaik that only works because the default key map has a reset key on layer 1. The key map I flashed doesn’t have that unfortunately.
My question is if there are any other key combos to reset or will I have to short certain pins on the pcb?
Offline senter
« Reply #819 on: Sun, 19 May 2019, 01:11:14 »
Yes.
There are no physical reset buttons on the PCB but you can contact the RE pin with the GND on the PCB. There are two RE pins near the MCU. Either one should work.
Offline nephlock
« Reply #820 on: Sun, 19 May 2019, 02:30:31 »
Hold spacebar + B while plugging the board in, should work
Offline yemeisong
« Reply #821 on: Sun, 19 May 2019, 04:56:26 »
has anyone tried to add underglow strips?
Offline spyruf
« Reply #822 on: Sun, 19 May 2019, 09:10:23 »
Thanks! That worked.
Yes.
Offline thearctican
« Reply #823 on: Sun, 19 May 2019, 09:52:02 »
Yes.
Bootmagic space+B worked for me. Thanks for confirming no reset button Senter.
Also, the LEDs are indeed white single color for those asking.
Offline ArchDill
« Reply #824 on: Sun, 19 May 2019, 11:16:47 »
These are the pins that you can jump to reset the board.
The far right RE (both pins) and the G on the VOG. Use tweezers or paper clips. When it is plugged into QMK, jump before you flash and it should work.
219662-0
Offline spyruf
« Reply #825 on: Sun, 19 May 2019, 12:57:39 »
Yes.
Thanks guys, got it working a couple hours ago.
Offline Lormania
« Reply #826 on: Sun, 19 May 2019, 15:42:48 »
Has anyone found the same sized bumpons but clear online anywhere?
Offline spyruf
« Reply #827 on: Sun, 19 May 2019, 16:58:49 »
Leaf 80, Holy Chickies, XDA Oblique (waiting for GMK Minimal)
Leaf 60, Orange Alps, Japan AEK Keycaps
Leaf 60, Gateron Linjar, GMK 9009
« Last Edit: Sun, 19 May 2019, 17:00:38 by spyruf »
Offline merlin64
    • MechMerlin
« Reply #828 on: Sun, 19 May 2019, 17:05:44 »
@thearctican @ArchDill I have implemented Bootmagic Lite, so the escape key will work as a reset while you're plugging in.
Offline cijanzen
« Reply #829 on: Sun, 19 May 2019, 17:10:45 »
I really like the shared design language through this series. Can’t wait for the Leaf Numpad!
Offline boog
« Reply #830 on: Sun, 19 May 2019, 19:47:23 »
I found these. I think they may be slightly smaller than the ones that came with the board, but I won’t know how well it works until it arrives (4 days from now).
3M Bumpon SJ5306 Clear Bumper/Spacer Pad - Hemispherical Shaped Bumper - 0.375 in Width x 0.15 in Height - 67560 [PRICE is per PAD] https://www.amazon.com/dp/B0080HNTH6/ref=cm_sw_r_cp_api_i_wDF4CbBZ6E0M0
Offline ArchDill
« Reply #831 on: Sun, 19 May 2019, 22:01:09 »
Ahh nice! That will help a lot when flashing. I think on my current layout I made fn+esc my reset.
Offline boog
« Reply #832 on: Sun, 19 May 2019, 23:34:33 »
Loving mine. I wish I would have gotten 2 cases now.  :D
Offline patch
« Reply #833 on: Mon, 20 May 2019, 09:20:34 »
if anyone has an extra pcb (alps or hotswap is fine) and is for sale, let me know. very much interested!
MX:
Aeboards Aegis (Silver) | Aeboards EXT65 (Black #3)
TGR Alice (Silver) | TGR Alice (Black) | TGR Jane V2 (Silver) | Keycult No2 SS (7/10) | Keycult No2 Brass #6 |
Topre:
HHKB Type-S (White) | HHKB Pro2 Hi-Pro(Black) | Norbaforce (Veracity Steel) | Monolith Heavy 6
Offline geewizwow
« Reply #834 on: Mon, 20 May 2019, 09:34:54 »
Anyone heard or got a pm from Senter recently?
Offline befbef
« Reply #835 on: Mon, 20 May 2019, 11:11:51 »
Wrote him 5 days ago because I got the wrong plate color. No answer until now.
Offline spyruf
« Reply #836 on: Mon, 20 May 2019, 12:53:22 »
I just realized I have extras of orange alps, aek keycaps, leaf pcbs, pc plate which is everything needed for an alps build. If anyone wants to buy this stuff let me know.
spyruf#5870
Offline ArchDill
« Reply #837 on: Mon, 20 May 2019, 14:19:48 »
Looking for an extra alu or brushed brass hhkb plate
Offline Nostril
  • Synth Labs
« Reply #838 on: Mon, 20 May 2019, 18:31:10 »
This was actually the same exact situation that I was in which led me to look this up. But yeah, as others have said the space+B method worked for me. Keep holding it after plugging it in until you hear the windows alert chime on your computer.
Offline Esheu2
« Reply #839 on: Mon, 20 May 2019, 20:00:21 »
Anybody else's weight kinda wobbly? It seems like even after I completely tighten the weight screws, there is still wiggle room for it.
Ojou
Offline reidd
« Reply #840 on: Mon, 20 May 2019, 21:01:20 »
Yeah mines like that too. It's not terrible so I figured it wasn't a big deal.
Offline reidd
« Reply #841 on: Mon, 20 May 2019, 21:01:56 »
Anyone figured out how to set up the lighting?
Offline senter
« Reply #842 on: Mon, 20 May 2019, 23:32:01 »
Hi geewizwow, I neither sent PMs to you nor received one from you. Please PM me again if you have questions.
Oh, I missed your message. A reply is coming.
Offline senter
« Reply #843 on: Mon, 20 May 2019, 23:46:45 »
I guess the screws were not tightened enough due to the e-coating in the screw holes. It was a common issue with e-coating. You can remove the coating with an angle tip tweezer then try to tighten the screws again.
I noticed this issue as early as in the Leaf 80 GB. In this GB, some of the screw holes were blocked before E-coating. Some are not for various reasons. Now as we've learned how to do it, all the screw holes in future E-coating cases will be blocked properly. I'm sorry for the additional confusions and the troubles you got in this GB.
Offline DePulse
« Reply #844 on: Mon, 20 May 2019, 23:48:59 »
Hey Senter. I sent you a message too! :D since last week I believe
Offline befbef
« Reply #845 on: Tue, 21 May 2019, 02:00:50 »
Thanks, and replied. Is there a better way to contact you? It's really easy to miss pms here.
Offline merlin64
    • MechMerlin
« Reply #846 on: Tue, 21 May 2019, 08:04:53 »
Hey all, I worked with Master Zebra this weekend and fixed the HHKB layout on the Configurator. It should all be working now
https://config.qmk.fm/#/foxlab/leaf60/universal/LAYOUT_60_hhkb
Offline gnhuy91
« Reply #847 on: Tue, 21 May 2019, 08:44:26 »
thats awesome! thanks Senter for testing and giving out best practices for the community
Offline Depresso-the-clown
  • yee haw
    • lmao it's literally just an instagram page
« Reply #848 on: Wed, 22 May 2019, 19:59:31 »
Also looking for this answer, I want to add unnecessary RGB to all my stuff plz
:thumb:
Offline yemeisong
« Reply #849 on: Wed, 22 May 2019, 20:42:01 »
I was able to solder WS1812 strips to the back of the PCB. Connect the 5v wire to the V pin on the PCB, Data to O, and Ground to G. It's an "open circuit", the arrows should be pointing away, and you don't need to 'close' the circuit by adding more wires.
However, there isn't enough space for the LEDs in the case so you may have to sand the bottom case.
