Author Topic: E6.5 - 65% custom keyboard(GB already open )  (Read 101013 times)
Offline taropaste
Re: E6.5 - 65% custom keyboard
« Reply #50 on: Mon, 28 January 2019, 17:04:26 »
So its a top mount with a rubber gasket under it?
How does that compare with rubber gasket on top and bottom?
So is this top mounted, with a gasket underneath? Is the gasket just for sound isolation then?
Hi Exclusive. I think you should consider making this more of a sandwich mount like 356mini instead of top mount in order to take advantage of the gasket more.
Otherwise, the design looks great :thumb:! I'm excited for the polycarb version!
Offline reidd
« Reply #51 on: Mon, 28 January 2019, 17:32:12 »
Agreed, this is a great point.
Offline tunadesu
« Reply #52 on: Mon, 28 January 2019, 20:32:06 »
I missed the Kyuu, I missed the No.1/65...I swear I'll get this. Haha please
Offline airlangga07
« Reply #53 on: Mon, 28 January 2019, 21:58:09 »
will probably join for WKL one!
Offline yicaoyimu
« Reply #54 on: Mon, 28 January 2019, 22:44:33 »
I might be interested in a PC version. Looking good!
Offline excluisve
  • Making & Thinking.
« Reply #55 on: Mon, 28 January 2019, 22:50:41 »
About somone said is not truly gasket mount
however,i want say is 100% same as OTD 356 which top pressure to .
i will post more details later due to i am in rural connect not so good
Offline higgga
« Reply #56 on: Tue, 29 January 2019, 04:31:26 »
Are custom nametags coming back and are they the same size as e6-v2?
Offline dantambok
« Reply #57 on: Tue, 29 January 2019, 04:34:56 »
Yes! In for a polycarb for sure!
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #58 on: Tue, 29 January 2019, 07:10:42 »
Based on the renders, it looks like the gasket is optional (you can choose to exclude it from the build if you prefer). Is that correct? If so, that adds some nice versatility to this board. It will be interesting to hear typing tests of the prototype with and without the gasket installed.
Offline excluisve
« Reply #59 on: Tue, 29 January 2019, 07:12:36 »
Nice project! Some constructive feedback :P Mostly just my 2 cents.
The side bezels look too thin to me to justify the left blocker, as someone in our slack said it's taller than it's wide which makes it looks weird.
Truth is block wider than it`s tall
Offline excluisve
« Reply #60 on: Tue, 29 January 2019, 07:13:57 »
Fantastic work again! I will be in for one or two. I will be grabbing WK with blockers in Silver PVD/e-white/e-black for sure.
A couple of questions if you don't mind:
  • To confirm the board is QMK?
  • Any samples of e-black?
  • Any idea on timescales so I can start saving?  ;D
Pcb is QMK and e black sample will get when chinese new year vaction  end ,
Offline excluisve
« Reply #61 on: Tue, 29 January 2019, 07:37:58 »
From somone ask why there is have top mount options and also have gasket mount
1st as i said it before is 100% gasket mount
here is my personal explain :
 you can see here we will get a oring put in there between pcb and plate
then this pic
bottom to the top distance is 8mm.
then bottom also have boss about 3.5mm, however plate is 1.5
so we get space almost 3mm between pcb and plate but we will put 4mm oring to the space
when top and bottom was screwed,it will compress oring from 4mm to 3mm ,oring will push the plate up
2nd,oring is under plate but outside the pcb so will touch the boss when we are type we will get feeback from oring
that is how gasket work .
3rd,somone ask why not two oring (on top and bottom ) because when we screw up ,oring will push plate go up .
during type we push plate down then oring  will give feedback but if have two oring plate will be hang so there is no
feedback due to one push up and one push down
4th,gasket will do not need screw to top .if ppl do not want gasket mount ,use 8 screws m2,5 →it will be top mount as E7
when you want gasket mount just do not need screw up to top
thanks here is my explain ,not good at english hope ppl can understand it . lol
« Last Edit: Tue, 29 January 2019, 07:41:07 by excluisve »
Offline excluisve
« Reply #62 on: Tue, 29 January 2019, 08:08:05 »
Request: split left shift (ISO), please.
Already support :
ISO:
Offline Darknight00z
« Reply #63 on: Tue, 29 January 2019, 08:16:47 »
Thanks for the explanation Exclusive! Much appreciated.
Offline ramblinrose
« Reply #64 on: Tue, 29 January 2019, 08:21:27 »
Looks like a nice 65% - nametag is a nice touch. Have you figured out a general timeline for when GB would start?
Offline Puree
« Reply #65 on: Tue, 29 January 2019, 08:21:42 »
Hey Excluisve
I am wondering if sandblasted finish will be available for the FE ?
Cheers  :thumb:
Offline Vigrith
« Reply #66 on: Tue, 29 January 2019, 10:59:07 »
Already support :
Thank you, in the layout picture in the OP it wasn't shown which was why I asked for it. Glad to see it!
Offline ptiede
« Reply #67 on: Tue, 29 January 2019, 11:10:15 »
The explanation of how you are acheving gasket mount is great! Makes me even more excited to try this board.
Offline Vireca
« Reply #68 on: Tue, 29 January 2019, 11:22:12 »
Do we have an estimated price?
Offline KaosJ
« Reply #69 on: Tue, 29 January 2019, 12:59:30 »
Seriously, wtf is this?
are you referring to the hhkb blockers? Just something exclusive is experimenting with.
b.b...but that's not even a hkkb blocker
Offline ptiede
« Reply #70 on: Tue, 29 January 2019, 13:45:51 »
But you get a bottom row configuration that looks hhkb like, with 1U 1.5U 7U 1.5U 1U
Offline s3vv4
« Reply #71 on: Tue, 29 January 2019, 14:19:32 »
Do the nametags by any chance fit an E6-V2? I want to have a different color for mine.
Offline oldcat
  • 65% is Life
« Reply #72 on: Tue, 29 January 2019, 16:48:27 »
then this pic
I think some people are concerned that the gasket (made with rubber?) may turn softer or age to a less elastic state after some time of use and there will be some fit issues between the plate the the case as time goes by, so having a top mount backup plan isn't too bad.
That said, maybe providing an additional set of gaskets in the kit for potential backup?
Offline oh_chesteroni
« Reply #73 on: Tue, 29 January 2019, 16:51:41 »
I like the idea of having an option to purchase an extra set of gasket(s).
Offline Marutks
« Reply #74 on: Tue, 29 January 2019, 19:45:58 »
interested in aluminium case
Offline HAYAN
« Reply #75 on: Tue, 29 January 2019, 21:31:56 »
65% clear pc case?
I'm in
Offline bciamny
« Reply #76 on: Tue, 29 January 2019, 21:40:17 »
awesome design. i wasn't a fan of the e8/e6 design language but this is much more suited to my tastes. i also really dig the weight design. i'm probably in for one (depending on ano colors available) but i would love to see this design (including gasket mount) in a tkl too!
as someone mentioned above, the width of the sides of the top piece seem a bit too narrow in comparison to both the width of the top and bottom of the top piece and the depth of the top piece. a little thicker there improves would improve how it looks to me.
great job with this excluisve.
Offline Keebmeupscotty
« Reply #77 on: Tue, 29 January 2019, 23:14:36 »
Been waiting for this for a while now. Can't decide if I love or hate that hhkb-ish layout, but I think I'm leaning toward love. I'd like to see some  more renders of that layout with keycaps if possible. Great design and really excited about being able to get in on this. Fingers crossed I see it soon enough and can find the cash when it makes it to GB.
Offline smoian
« Reply #78 on: Wed, 30 January 2019, 00:41:24 »
Very much interested in the polycarb version. Great IC page excluisve, appreciate all the effort put into this.
Offline excluisve
« Reply #79 on: Wed, 30 January 2019, 07:07:03 »
Hey Excluisve
Cheers  :thumb:
Yes if you don’t want pvd but still purchase fe it can be sandblasted
Offline excluisve
« Reply #80 on: Wed, 30 January 2019, 07:07:55 »
We have four kinds of top case it may have one of you need
Offline jacky
« Reply #81 on: Thu, 31 January 2019, 23:00:30 »
Glad try to my first gasket mount keyboard !
Interested in  pc case with champagne pvd  :thumb:
Offline excluisve
« Reply #82 on: Fri, 01 February 2019, 21:50:29 »
Some updated:
Factory was in vacation that prototype will be make after two weeks .i will sort IC spreadsheet about colors and layout after ten days
If you are interested in this board vote you favorite colors and layout  :thumb:
Offline Regret
  • I regret nothing
« Reply #83 on: Fri, 01 February 2019, 21:51:45 »
Oh my a half plate option?!
No.2 Rev.1 | Gat Black Inks | OG Dyesubs \\ No.1/65 Silver & Brass | Retooled Cherry Blacks | GMK Coniferous \\ Ai03 Lunar | SKCM Blues | AEK \\ Aeryx Aegis 1800 | C3 Tangerines | GMK WoB
Offline b3nkei
« Reply #84 on: Fri, 01 February 2019, 22:01:48 »
Are you going to use a new weight design on this board? I really liked the weight of the e7-v1.
Offline excluisve
« Reply #85 on: Sat, 02 February 2019, 06:30:15 »
Yea weight gonna change
That weight blongs to E7-V1 :D
Offline taropaste
« Reply #86 on: Sat, 02 February 2019, 12:35:12 »
Yes! I really like the new weight design :)). It's more interesting and different. But does the inside of the logo on the weight have to be blue or can we choose?
Offline hq
« Reply #87 on: Sat, 02 February 2019, 12:59:42 »
Do openings at the bottom of the case bring about a difference in sound? e.g. louder?
And thanks for including ISO! cant wait till this gets rolling, insta buy from me if the price is fair.
« Last Edit: Sat, 02 February 2019, 13:33:08 by hq »
Offline RETURNISO
  • I do get excited about keyboard stuff..
« Reply #88 on: Sat, 02 February 2019, 15:33:51 »
Already support :
ISO:
NICE!  :thumb:
« Reply #89 on: Sun, 03 February 2019, 11:29:37 »
Will the full brass version be PVD polished like E6 and E7?
Offline _ODIN_
« Reply #90 on: Sun, 03 February 2019, 11:30:36 »
I hope that the weight won't be dual colored.
Gesendet von meinem H8416 mit Tapatalk
Offline tunadesu
« Reply #91 on: Sun, 03 February 2019, 11:56:06 »
I hope the weight is dual colored
« Last Edit: Sun, 03 February 2019, 12:07:26 by tunadesu »
Offline thearctican
« Reply #92 on: Sun, 03 February 2019, 12:06:26 »
This looks great. Keeping an eye out for the group buy.
Offline 6FeaT
« Reply #93 on: Sun, 03 February 2019, 13:18:46 »
Loving this more and more. Excited for the GB!
Offline excluisve
« Reply #94 on: Sun, 03 February 2019, 20:23:06 »
Yes same as E7 PVD finish .
Offline Vireca
« Reply #95 on: Mon, 04 February 2019, 12:11:14 »
Do we know an estimated price for the aluminium version?
Offline etong415
« Reply #96 on: Mon, 04 February 2019, 12:33:40 »
Is there a possibility of making the side bezels slightly thicker? They look a little disproportionally thin compared to the top and bottom bezels
« Reply #97 on: Mon, 04 February 2019, 15:40:57 »
Exclusive already spoke about it. We will know more when he gets the prototype in late Feb.
Offline b3nkei
« Reply #98 on: Mon, 04 February 2019, 15:47:19 »
Are you getting a polycarbonate prototype? It would be interesting to see how it looks with the rgb and the diffuser.
Offline etong415
« Reply #99 on: Mon, 04 February 2019, 16:51:49 »
I was under the impression that was about the blocker, and not the bezel itself
