Author Topic: E6.5 - 65% custom keyboard(GB already open )  (Read 99826 times)
Offline excluisve
  • Making & Thinking.
« on: Mon, 28 January 2019, 08:08:10 »
Interest Checks for E6.5 - 65% custom keyboard.
Groupbuy link:    https://geekhack.org/index.php?topic=99655.0
E6.5
Hello everyone Excluisve here
This time we bring nametag back again with rgb diffuser .about E6.5 we have much options let`s see it . :thumb:
Make sure to fill this form if you are interested :https://docs.google.com/forms/d/1qe1ENjwrOQ4bxtqVDLfxSHNkdrp-6X2omiyAp4ZQABk/edit
__________________________________________________________________
Some new features:
                                            *This time Polycarbonate case will be available,it will be frosted.https://i.imgur.com/jdeNvKA.jpg
                                            *Four Top layout we could choose also we get a new HHKB https://i.imgur.com/2hFb7Vb.png
                                            *I thinks we should try some new mount ,this time it should be  gasket mount same as OTD 356minihttps://i.imgur.com/1JddzcC.jpg
                                             red circle is the rubber like 356https://i.imgur.com/5vmDZLt.jpg
                                            *since in E6-V2 only FE can get pvd options for nametag ,now is open.https://i.imgur.com/Wx3NlZq.jpg
                                            *plate logo and pcb also have some new changes https://i.imgur.com/ChKpx9M.jpg
                                            * Full brass version (limited to 10)
About colors
                                            * Matte clear PC
                                            * E-white /E-black/Mao
                                            * Anodizing : dark grey/dark red/wathet
                                            * PVD Gold /PVD silver/PVD rose gold,optionshttps://imgur.com/a/pZOAKKn
More pictures
                            More renders pictures :https://imgur.com/a/Uz8JqTd/
                                                    Layout:https://i.imgur.com/c51Pa9t.jpg
                                               - Prototypes were manufacturing.
Each boards cant be 100% but i will try my ability do it perfectly .
if you cant accept a little Inevitable ,especially PVD stuff (Quality is hard to control )please thinks twice before purchanse
For some orders i will consider to sale .thanks evryone : )
Free to leave suggestion and question.---
« Last Edit: Sun, 01 September 2019, 21:39:37 by excluisve »
Offline excluisve
Re: E6.5 - 65% custom keyboard
« Reply #1 on: Mon, 28 January 2019, 08:10:08 »
Reserved
Offline Poesjuh
« Reply #2 on: Mon, 28 January 2019, 08:11:43 »
Nice project! Some constructive feedback :P Mostly just my 2 cents.
The side bezels look too thin to me to justify the left blocker, as someone in our slack said it's taller than it's wide which makes it looks weird.
Offline comdata55
« Reply #3 on: Mon, 28 January 2019, 08:16:11 »
definitely interested!
Offline ChrisSwires
« Reply #4 on: Mon, 28 January 2019, 08:25:22 »
Would you be able to share an image of the full plate? It looks like the back has tabs for top mount? Are they present on the front too?
Offline donut_sauce
« Reply #5 on: Mon, 28 January 2019, 08:29:02 »
in for a polycarb
Offline MoarCoffeePlzzz
  • Formerly Deeptek
« Reply #6 on: Mon, 28 January 2019, 08:32:30 »
Very interested in a WK with Blockers. I would like to see a Silver color offered but if not I will go with PC or Gray.
Do you have a targeted price range?
Offline Coolbeanz
« Reply #7 on: Mon, 28 January 2019, 08:36:14 »
Will there be a limit on the number of keyboards for sale? Hopefully I will able to snatch one!
Offline otanishock
  • One of the cool kids :>
  • ファーストラブ
« Reply #8 on: Mon, 28 January 2019, 08:41:47 »
Will be 100. Like every other exclusive's gb.
Offline ptiede
« Reply #9 on: Mon, 28 January 2019, 08:43:59 »
Guess I am getting this as well.  ;D
Offline eyedrop
« Reply #10 on: Mon, 28 January 2019, 08:45:13 »
The year of the 65.
Offline SolidCactus
« Reply #11 on: Mon, 28 January 2019, 08:49:17 »
Fantastic work again! I will be in for one or two. I will be grabbing WK with blockers in Silver PVD/e-white/e-black for sure.
A couple of questions if you don't mind:
  • To confirm the board is QMK?
  • Any samples of e-black?
  • Any idea on timescales so I can start saving?  ;D
Offline Vigrith
« Reply #12 on: Mon, 28 January 2019, 08:53:25 »
Request: split left shift (ISO), please.
Offline fatpolomanjr
« Reply #13 on: Mon, 28 January 2019, 09:02:49 »
There are 4 possible options, the top red one you see being the HHKB verson. There's also winkey with or without right blocker and winkeyless with blocker.
Some guys keep on saying they believe in Jesus, and keep doing a lot of shameful things.
Current GH Classified Post (LF Arcade Floor, Garbield and CYM Otter and Keyng)
Offline Starston3
« Reply #14 on: Mon, 28 January 2019, 09:07:43 »
Glad to see that the left blocker is optional.
In for a poly.
Offline nhathoangJS
  • 60% WK is the best layout
« Reply #15 on: Mon, 28 January 2019, 09:14:47 »
OMG, I'm in!!!
Tx60 Champage Gold w SA Chocolatier
Offline JSaintS
  • Formerly eNrageDSainT
    • JSaintS
« Reply #16 on: Mon, 28 January 2019, 09:43:56 »
Please yes.
I assumed the board didn't support ISO since the plate seems to be a fixed ANSI one, but then I saw this but I don't understand why the left shift isn't split then :(
Offline pr0ximity
« Reply #17 on: Mon, 28 January 2019, 09:47:35 »
My constructive feedback: no more 65%, pick 60% or TKL.
Cool board other than that, would love to try it but can't stand 65.
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #18 on: Mon, 28 January 2019, 10:11:47 »
So is this top mounted, with a gasket underneath? Is the gasket just for sound isolation then?
Offline otanishock
  • ファーストラブ
« Reply #19 on: Mon, 28 January 2019, 10:16:22 »
Personally would prefer to see some implementation of the whole brass weight design that covers the entire bottom like this. Just makes the whole structure of the board much more rigid. Feels much nicer and much more premium too. But then again that would probably ramp up the cost to >$500 so might not be actually worth it.
211550-0
Offline eyedrop
« Reply #20 on: Mon, 28 January 2019, 10:28:15 »
But he already did e6-v2 as a 60%.
« Reply #21 on: Mon, 28 January 2019, 10:30:02 »
It's a slab of aluminum, it's already rigid.
Offline megaforce
« Reply #22 on: Mon, 28 January 2019, 10:36:30 »
rgb underglow on pcb yes?
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline pr0ximity
« Reply #23 on: Mon, 28 January 2019, 10:39:56 »
Fair enough, didn't have a wacky mounting system though
Sent from my ONEPLUS A3000 using Tapatalk
Offline realxmlforce
« Reply #24 on: Mon, 28 January 2019, 10:44:12 »
as already suggested: split left shift would be great for proper ISO support.
also: split space bar and a confirmation that the pcb will support QMK
i guess there wont be many that want split space  :( i cant stand boards that waste the space  :cool:
Offline otanishock
  • ファーストラブ
« Reply #25 on: Mon, 28 January 2019, 10:49:37 »
Its not about the waste space. If the stab is lubed and modded correctly, coupled with a nice several hundred dollars kustom, the thock sound and the feel of a regular spacebar is just jizzing.
Offline mrkantz
« Reply #26 on: Mon, 28 January 2019, 10:52:03 »
Nice, I'm in for 1. Not sure on PC or E-white yet.
Offline Regret
  • I regret nothing
« Reply #27 on: Mon, 28 January 2019, 11:10:13 »
I've skipped out on the other exclusive keyboards and I've regretted it each time. In for either PC or E-White!
Don't think the far left blocker top is a good idea, seems odd.
No.2 Rev.1 | Gat Black Inks | OG Dyesubs \\ No.1/65 Silver & Brass | Retooled Cherry Blacks | GMK Coniferous \\ Ai03 Lunar | SKCM Blues | AEK \\ Aeryx Aegis 1800 | C3 Tangerines | GMK WoB
Offline The_judge_168
« Reply #28 on: Mon, 28 January 2019, 11:32:30 »
Interested! And putting my vote for green as a case color
Offline dyrdevil
« Reply #29 on: Mon, 28 January 2019, 11:33:06 »
The left blocker looks much better to me after seeing the mockup you linked with keycaps.
It is an interesting solution to bottom row symmetry + blocker issues on 65 and 75 boards.
Offline PikaJoyce
« Reply #30 on: Mon, 28 January 2019, 12:02:45 »
He also did the E8-V1 as a TKL.
« Reply #31 on: Mon, 28 January 2019, 12:04:31 »
i agree
65% is a layout for people who can't commit
Offline ninjacore
« Reply #32 on: Mon, 28 January 2019, 12:12:24 »
i agree
I like 65% because it gives you a little bit of visible bezel without it seeming like wasted space. :shrug:
I have no opinion one way or another regarding this particular board, however.
Offline nasp
« Reply #33 on: Mon, 28 January 2019, 12:15:02 »
Does RGB light come out the bottom?
Also, the brass weight at the bottom, will they all have the blue insert?
Offline nasp
« Reply #34 on: Mon, 28 January 2019, 12:16:02 »
What do you have against 65% boards? Just curious
Offline _ODIN_
« Reply #35 on: Mon, 28 January 2019, 12:16:11 »
Amazing! Can you add stepped caps lock support?
Gesendet von meinem H8416 mit Tapatalk
Offline oldcat
  • 65% is Life
« Reply #36 on: Mon, 28 January 2019, 12:20:42 »
price estimate?
« Reply #37 on: Mon, 28 January 2019, 12:40:38 »
it's already there, you can see it in the render
Offline etong415
« Reply #38 on: Mon, 28 January 2019, 12:47:28 »
I've never used a 65% board before, so apologies if this is a stupid question. But will there be a possibility for split backspace support? Or for anyone who has switched between split backspace and normal backspace fairly frequently, what's that adjustment like? Thanks!
Offline _ODIN_
« Reply #39 on: Mon, 28 January 2019, 12:53:03 »
Ahh just looked at the layout image. Thanks
Offline oh_chesteroni
« Reply #40 on: Mon, 28 January 2019, 12:53:05 »
This has split backspace support, and switching between the two takes a couple of minutes for me.
Offline etong415
« Reply #41 on: Mon, 28 January 2019, 12:53:38 »
Awesome, thanks for the help!
Offline Ashardalon
  • Ashkeebs
    • Ashkeebs Lubing Service & Shop
« Reply #42 on: Mon, 28 January 2019, 13:09:21 »
Thoroughly interested in this; Exclusive products are always so high-class. Definitely in! Would love a price estimate and idea of when GB will start.
Offline nephlock
« Reply #43 on: Mon, 28 January 2019, 13:25:33 »
not sure how i feel about the odd HHKB top, but im glad there are other options!
Offline ptiede
« Reply #44 on: Mon, 28 January 2019, 13:39:15 »
For some reason, the hhkb top has really grown on me. I am going to try to get one of those.
Offline PikaJoyce
« Reply #45 on: Mon, 28 January 2019, 13:57:23 »
This. :)
I love that there are so many different layout options, and that the name tag was brought back.
Offline hq
« Reply #46 on: Mon, 28 January 2019, 14:12:49 »
Looks nice! Would be in, if full ISO happens.
so I second the request for ISO left shift  :D
Offline Darknight00z
« Reply #47 on: Mon, 28 January 2019, 16:43:25 »
So its a top mount with a rubber gasket under it?
How does that compare with rubber gasket on top and bottom?
Offline KaosJ
« Reply #48 on: Mon, 28 January 2019, 16:50:07 »
Seriously, wtf is this?
« Reply #49 on: Mon, 28 January 2019, 16:58:55 »
are you referring to the hhkb blockers? Just something exclusive is experimenting with.
