Author Topic: [IC] MAJA (Majapahit) (Group Buy Started, Moving to Group Buy Thread)  (Read 266208 times)
Offline ninjacore
Re: [IC] Majapahit Ergo Keyboard
« Reply #150 on: Fri, 09 August 2019, 11:18:54 »
Saw something on instagram from OP - looked like they're still actively designing it.
Offline g_mr_p
« Reply #151 on: Fri, 09 August 2019, 14:55:01 »
That's good to hear, haven't really looked into these ergonomic designs much and am interested in the layout.
Offline Vulcan
Re: [IC] Majapahit Ergo Keyboard (New Render)
« Reply #152 on: Sat, 10 August 2019, 01:48:03 »
Hey, I just post new render. My target is to get this done in 2 weeks and send it to factory for prototyping.
Offline calveeen
« Reply #153 on: Sat, 10 August 2019, 01:48:55 »
Love you Vulcan for the update <3
Offline Vulcan
« Reply #154 on: Sat, 10 August 2019, 01:55:46 »
Hi, I Finally have time to start working on this keyboard again, here the new render. any feedback? I see many people find the name to hard to pronounce, should we change it or just make it simpler by just calling it "MAJA"
Spec :
- 6061 Aluminum
- Hotswap PCB with RGB Each key
- Thick removable aluminum plate (4.5-5 mm)
- USB type c
The plate is by default thick, but i made it removable and changeable just in case someone want to use flex plate.
Interest Check:
https://goo.gl/forms/4dgDrvRbbdFx2S0H3
Timeline:
- Finish the design in August
- Submit to factory for proto in September
Offline pcire
« Reply #155 on: Sat, 10 August 2019, 01:57:15 »
Awesome news!
Offline mattling9
« Reply #156 on: Sat, 10 August 2019, 03:44:38 »
Spec :
- 6061 Aluminum
- USB type c
Interest Check:
Timeline:
Is it possible to have options to have a thick Brass plate aswell?
When it's ready for GB will it be sold on KBDFans?
Offline Vulcan
« Reply #157 on: Sat, 10 August 2019, 03:56:06 »
Spec :
- 6061 Aluminum
- USB type c
Interest Check:
Timeline:
It's posible, but it would be really expensive, would make this keyboard really suoer heavy and shiping cost will increase.
Yes GB will be on Kbdfans
Offline aleck
« Reply #158 on: Sat, 10 August 2019, 17:01:20 »
Spec :
- 6061 Aluminum
- USB type c
Interest Check:
Timeline:
Nice!
HHKB Pro 2 Type-S (2016)
Offline thornkin
« Reply #159 on: Sat, 10 August 2019, 18:46:36 »
This is looking really nice! Is there a time frame for the GB? How long do I have to save for it?
Offline MeloDet
« Reply #160 on: Sat, 10 August 2019, 21:56:22 »
Looking nice! Would definitely be interested in some other plate materials though. KBDfans is doing polycarb for the Polaris so I would hope either a Polycarb or POM plate might be doable.
Offline Vulcan
« Reply #161 on: Sun, 11 August 2019, 03:55:02 »
Great idea! Thanks for the input. We will consider that
Offline mattling9
« Reply #162 on: Sun, 11 August 2019, 07:30:52 »
Personally i think i would probably take a thin (1.5-2mm) Brass/PC Plate than a thick (4.5-5mm) Alu one. I think a lot of people would prefer for a thinner plate with a higher variety of materials than having a thicker plate in just Alu.
Offline mattling9
« Reply #163 on: Sun, 11 August 2019, 07:41:08 »
I also really like the slight stagger on these three keys on the original Alice design. On the Maja design they are just a vertical line. Would i be possible to get the slight stagger back? Aesthertically i think it looks awesome! :D
Thanks for all your hard work on the project and i really look forward to be able to join the GB! :D
Offline mattling9
« Reply #164 on: Sun, 11 August 2019, 08:10:50 »
Something like this  ;D ;D ;D
Offline Vulcan
« Reply #165 on: Sun, 11 August 2019, 08:33:52 »
Reason i made a thick plate is because the PCB will be a how swap removable switch. A thick plate will allow the PCB to be screwed in and hold firmly to the plate, this will make it easier for the user to install and remove switch.
and yes i understand that some people like a thin normal plate and maybe the want to cut their own plate to make it flex more. that is why I made the thick plate a removable plate.
Offline mattling9
« Reply #166 on: Sun, 11 August 2019, 09:27:00 »
Oh that's awesome, i completely forgot that this will be hotswap compatible! In that case i agree with you completely, a thick plate is best! If it's possible to be able to get a thick Brass or Polycarbonate plate option that would be amazing and i would definitely be willing to pay a premium for it. :D
Offline cari
« Reply #167 on: Sun, 11 August 2019, 12:15:31 »
Hotswap!  :eek: Very looking forward to this then! (since I can't solder for life)
Offline kchlam
« Reply #168 on: Sun, 11 August 2019, 14:05:22 »
would be awesome if there was a thick polycarb or pom plate!!! Can't wait to see more updates!
Offline omjak
« Reply #169 on: Mon, 12 August 2019, 01:50:47 »
I like "MAJA"
Offline mattling9
« Reply #170 on: Mon, 12 August 2019, 02:12:48 »
I like "MAJA"
I know it's not the name of the board, but i would prefer to see Vulcan engraved on the brass weight  :D
Offline strigif0rm3s
« Reply #171 on: Mon, 12 August 2019, 06:07:59 »
Spec :
- 6061 Aluminum
- USB type c
Interest Check:
Timeline:
I vote to change the name. Something "cooler"
Sent from my Nexus 6P using Tapatalk
Offline 2QT2BSTR8
« Reply #172 on: Mon, 12 August 2019, 08:10:54 »
Full word 'Majapahit' looks gorgeous on the render.
Offline ninjacore
« Reply #173 on: Mon, 12 August 2019, 08:26:43 »
Geometric pattern > text
Offline KingOfMemes
« Reply #174 on: Mon, 12 August 2019, 08:37:56 »
Spec :
- 6061 Aluminum
- USB type c
Interest Check:
Timeline:
I think it's pretty cool considering it's the name of one of the finest Hindu Empires
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #175 on: Mon, 12 August 2019, 13:08:50 »
Spec :
- 6061 Aluminum
- USB type c
Interest Check:
Timeline:
Wait so does this mean... An unlimited GB?  :eek:
Offline Hell-es
« Reply #176 on: Mon, 12 August 2019, 14:54:10 »
Means, no limit on produced keyboards.
Offline tonydatigeryo
« Reply #177 on: Mon, 12 August 2019, 16:10:08 »
No limit is excellent as it allows a lot of people to get in on it without paying huge on the secondary market... one of my biggest gripes with this hobby!
Offline Aevyn
« Reply #178 on: Mon, 12 August 2019, 22:58:29 »
The non staggered three keys on the top right kill it for me.
Sent from my GM1915 using Tapatalk
Offline PikaJoyce
« Reply #179 on: Tue, 13 August 2019, 01:21:14 »
+1 I think the staggered keys on the right give the entire board more balance compared to non staggered.
I was also thinking of maybe a design for the weight instead of just the text for majapahit. Not a huge fan of the font :(
« Reply #180 on: Tue, 13 August 2019, 05:17:53 »
This is from the wiki on Majapahit.....maybe a logo or graphic similar-  on the bottom? Instead of text.
Offline wholypantalones
  • text and icon mods plz.
« Reply #181 on: Tue, 13 August 2019, 07:22:54 »
But it also means longer production and QC times ;)
Offline roguesystem087
« Reply #182 on: Tue, 13 August 2019, 08:19:15 »
yea other than the weird text on the weight, it looks sweet man, hope this makes it to GB
Offline KingOfMemes
« Reply #183 on: Tue, 13 August 2019, 08:27:46 »
And it can be nice to have a keyboard that nobody else has. The limited/unique factor is nice
Offline bru
« Reply #184 on: Tue, 13 August 2019, 09:50:25 »
+1 this would be :fire:
« Reply #185 on: Tue, 13 August 2019, 12:04:51 »
Also selling it for $3k+ is fun sometimes I hear.
Offline ppnp253
« Reply #186 on: Tue, 13 August 2019, 12:11:52 »
I'm leaning more towards "MAJA" only because I can never spell or pronounce Majapahit correctly.
+1 to additional plate materials. I'd be willing to pay more for different plates.
+1 to a geometric/logo on weight vs text. Majapahit also has a lot of references to the sun/mandala/Hindu gods patterns, so I think a patterned weight would look nice.
Also, is there enough interest to make it gasket mounted? Since you asked the question on the IC form.
Offline KingOfMemes
« Reply #187 on: Tue, 13 August 2019, 12:18:29 »
Buying it for 3k just proves the value of having something limited/unique. Either way, I'm glad there is no limit so I can get one at a good price \o/
« Last Edit: Tue, 13 August 2019, 12:46:52 by KingOfMemes »
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #188 on: Tue, 13 August 2019, 12:54:52 »
I guess I'll throw in a few things since I've been using an Acrylic Alice the past few weeks and want MORE! ;D
Please please pleaasseee offer a PCB that is non-hotswap.
Different material plated would be very nice, my vote is for FR4 or PC, or at the very least upload plate file so we can make our own!
Staggered macro row is definitely more appealing to me, but I'm sure you have your reasons.
Offline KingOfMemes
« Reply #189 on: Tue, 13 August 2019, 13:22:02 »
I second this motion
Offline r4wromg
« Reply #190 on: Tue, 13 August 2019, 19:01:24 »
Has OP confirmed that there is no limit? IIRC his last gb (Fusion60), there was a 50 unit limit even though that was also run on KBDfans
Offline nasp
« Reply #191 on: Tue, 13 August 2019, 19:22:23 »
Has he said that it will be run with the assistance of KBDFans again?
Offline Tre3Cycl3S
« Reply #192 on: Tue, 13 August 2019, 19:31:03 »
I see many people find the name to hard to pronounce, should we change it or just make it simpler by just calling it "MAJA”
I actually much prefer the original name “Majapahit”, in part due to the reference to the ancient empire.
Here is an idea, if you are leaning towards renaming it “MAJA”: apparently, “maja” is Javanese for the bael fruit. So, maybe the design of the brass weight can incorporate this fact, e.g. the brass weight is in the shape of a bael fruit, or an engraving of the fruit on the brass weight.
Incidentally, you could still do that even if you retain the name as “Majapahit”, as “pahit” is the Malay/Indonesian word meaning “bitter”, in reference to the bitterness of the fruit.
QFR           HHKB Pro-2     JD45         VE.A                    XMIT 61-Key       JD40 Mk.II                    Realforce 87U     M65-A                 Custom:Annie      NightFox      Pearl                  E6-V2 R2                          Norbaforce
MX Blue     45g Topre        MX Blue     R5 67g Zealios     50g Hall Effect     Modded Gateron Red     55g Topre           R5 78g Zealios     62g Ergo Grey     Hako True     R9 62g Zilent     Lubed Holy Trash Panda     OG Sony BKE Domes
Offline 2QT2BSTR8
« Reply #193 on: Tue, 13 August 2019, 20:49:12 »
Yes
Offline lolafineday
« Reply #194 on: Tue, 13 August 2019, 22:00:13 »
I feel like the keyboard is too non symmetrical, if you could add 1 pillar of macros on the left side(staggered) to make the length of the left side and right the same, it would look much nicer imo.
Sent from my SM-G975F using Tapatalk
Offline ilpsxnus
« Reply #195 on: Thu, 15 August 2019, 03:23:51 »
+1 staggered 3 function keys on the right
Perhaps consider a Vulcan logo engraved on one of the corners of the rear bezel for infill, and the Majapahit kaliedascope logo on the weight?
Offline Poesjuh
« Reply #196 on: Thu, 15 August 2019, 03:56:07 »
Have been following this IC from the start but somehow only recently noticed that there is a 1.5u mod "missing" and the gap circled feels a bit empty to me.
Any specific reason to leave this gap here? Are you considering a logo of some sort?
Offline Vulcan
« Reply #197 on: Thu, 15 August 2019, 04:21:18 »
I agree, thank you for the input, which one do you guys think is better?
Option 1
Option 2
For the stagger i personally thinks it makes the layout looks messy.. I thinks keeping it straight makes it cleaner
Offline SlamMakanen
« Reply #198 on: Thu, 15 August 2019, 05:09:31 »
For me option 2 is the best looking
Offline mattling9
« Reply #199 on: Thu, 15 August 2019, 05:46:32 »
For me, i think a row of Function keys on each side of the board is too much and looks a bit messy.
I would prefer a single row of staggered function keys on the left or right not both. my preference would probably be on the right to fill up the space made by the arrow keys.
Probably not what you're going for but i would love it if it was changed to the original Alice layout. If it aint broke don't fix it.
« Last Edit: Thu, 15 August 2019, 05:54:43 by mattling9 »
