Author Topic: [IC] MAJA (Majapahit) (Group Buy Started, Moving to Group Buy Thread)  (Read 266209 times)
Offline 2QT2BSTR8
Re: [IC] Majapahit Ergo Keyboard (New Render)
« Reply #200 on: Thu, 15 August 2019, 06:54:30 »
Option 2
Offline wholypantalones
  • text and icon mods plz.
« Reply #201 on: Thu, 15 August 2019, 06:59:41 »
The option with no keys on the left side is my choice regardless of stagger or not.
« Last Edit: Thu, 15 August 2019, 09:57:48 by wholypantalones »
Offline strigif0rm3s
« Reply #202 on: Thu, 15 August 2019, 07:37:01 »
Will this have a Windows key option? I love my windows key
Sent from my Nexus 6P using Tapatalk
Offline aleck
« Reply #203 on: Thu, 15 August 2019, 09:13:47 »
I feel like the keyboard is too non symmetrical, if you could add 1 pillar of macros on the left side(staggered) to make the length of the left side and right the same, it would look much nicer imo.
Sent from my SM-G975F using Tapatalk
I agree, thank you for the input, which one do you guys think is better?
Option 1
Option 2
For the stagger i personally thinks it makes the layout looks messy.. I thinks keeping it straight makes it cleaner
Personally, I like 1 the most.
HHKB Pro 2 Type-S (2016)
Offline KingOfMemes
« Reply #204 on: Thu, 15 August 2019, 09:24:44 »
Option 2. Cleaner look overall with less noise
Offline Create_alt_delete
« Reply #205 on: Thu, 15 August 2019, 09:26:43 »
I prefer the original design, but if I had to pick one or the other...
Option 2. Maybe use the blank space under the left-side column for a logo?
Sent from my GM1917 using Tapatalk
« Last Edit: Thu, 15 August 2019, 20:35:04 by Create_alt_delete »
Offline airyimbin
« Reply #206 on: Thu, 15 August 2019, 09:42:26 »
Option 2
Sent from my SM-N960U using Tapatalk
Offline Paddel06
  • Klugscheißer
« Reply #207 on: Thu, 15 August 2019, 09:46:16 »
Personally I would like no left function keys at all.
This is a signature.
Offline KingOfMemes
« Reply #208 on: Thu, 15 August 2019, 09:47:55 »
If this were an option I would also have voted this
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #209 on: Thu, 15 August 2019, 09:52:15 »
I also like no left function keys at all like your original design but staggered function keys on the right.
GON NerD TKL DTA Edition
Offline ninjacore
« Reply #210 on: Thu, 15 August 2019, 10:15:46 »
Original design, best design
Offline mattling9
« Reply #211 on: Thu, 15 August 2019, 10:19:10 »
Agreed!!
Offline KingOfMemes
« Reply #212 on: Thu, 15 August 2019, 10:33:01 »
Offline _ODIN_
« Reply #213 on: Thu, 15 August 2019, 11:01:25 »
+1
Gesendet von meinem H8416 mit Tapatalk
Offline mattling9
« Reply #214 on: Thu, 15 August 2019, 16:56:32 »
This is exactly what I would like too
Offline r4wromg
« Reply #215 on: Thu, 15 August 2019, 18:44:28 »
Agreed, feels a bit too busy with function keys on both sides.
Offline trg1234
« Reply #216 on: Thu, 15 August 2019, 22:19:20 »
prefer original design as well
Offline MeloDet
« Reply #217 on: Thu, 15 August 2019, 22:40:37 »
Another vote for the original design. No left function keys
Offline Dissitesuxba11s
« Reply #218 on: Fri, 16 August 2019, 09:06:22 »
Option 1 or the original design. Go big or go home  ;D
Offline Zilleon
« Reply #219 on: Fri, 16 August 2019, 10:07:13 »
I also vote for original design with no left keys
Offline dankpupdaddy
    • Twitch
« Reply #220 on: Fri, 16 August 2019, 10:16:56 »
No keys on the left, staggered keys on the right would be  :thumb:
Offline airyimbin
« Reply #221 on: Fri, 16 August 2019, 10:22:06 »
We should get another poll going.
Offline mrkantz
« Reply #222 on: Fri, 16 August 2019, 10:38:22 »
Another vote for no left keys
Offline Vulcan
« Reply #223 on: Fri, 16 August 2019, 10:39:37 »
I just saw LZ ergo IC, they have a keyboard with a staggered right function key. I think for Maja it's better to keep the original design.
Offline ninjacore
« Reply #224 on: Fri, 16 August 2019, 14:31:29 »
Nice - I like the decision
Offline airyimbin
« Reply #225 on: Fri, 16 August 2019, 14:40:42 »
Original is great. When is the ETA on GB?
Offline ilpsxnus
« Reply #226 on: Fri, 16 August 2019, 15:00:52 »
Not liking both options, the original layout is still the best so far.
I prefer staggered function keys on the right, but vertically aligned is OK as well.
Either way, I'm still going to buy it.
Offline ppnp253
« Reply #227 on: Fri, 16 August 2019, 15:08:01 »
Original sounds good.
Offline CodeMayhem
« Reply #228 on: Fri, 16 August 2019, 19:59:55 »
Having a second B for ergonomic keyboards is a good feature.
Consider USB-C.
What about a second x for Dvorak users 😅
Offline DSlayerZX
« Reply #229 on: Sat, 17 August 2019, 00:52:03 »
not sure how many people would go with this suggestion.... but how about we make the whole board actually symmetrical
as in the right backspace, enter, etc all the same width as the left side  XD
Offline briemens
« Reply #230 on: Sat, 17 August 2019, 01:59:07 »
Original does it for me as well.
E7-V1 SE / Aanzee / Volcano 660 / Canoe / FC660C / Grid 600 / Space65 / FC750R / 2x Unicomp / Sirius / 3x Doro67 / 2x DC60 / 2x Klippe / Keyboardbelle / 2x Tofu / CTRL / Poker / Anne Pro
Offline omjak
« Reply #231 on: Sat, 17 August 2019, 14:29:41 »
original (no left fn keys)
prefer staggered on right side, but original is excellent
« Last Edit: Sat, 17 August 2019, 14:33:42 by omjak »
Offline mattling9
« Reply #232 on: Sun, 18 August 2019, 15:20:24 »
Hi, I Finally have time to start working on this keyboard again, here the new render. any feedback? I see many people find the name to hard to pronounce, should we change it or just make it simpler by just calling it "MAJA"
Spec :
- 6061 Aluminum
- Hotswap PCB with RGB Each key
- Thick removable aluminum plate (4.5-5 mm)
- USB type c
The plate is by default thick, but i made it removable and changeable just in case someone want to use flex plate.
Interest Check:
https://goo.gl/forms/4dgDrvRbbdFx2S0H3
Timeline:
- Finish the design in August
- Submit to factory for proto in September
Wil there be the option for a Polycarbonate Case at an additional cost like most boards on KBDFans? A few boards now are evening running opaque / black Polycarbonate (Leaf 60 + Think6.5) which i think looks AMAZING. Please Please Please can we try and make this an option. i would happily pay big big $$$$ to get a black / opaque polycarbonate Majaphait!
Offline Protein
« Reply #233 on: Sun, 18 August 2019, 16:19:09 »
The original design is the best imo
Offline Tree_
« Reply #234 on: Sun, 18 August 2019, 22:29:42 »
Original,  :thumb:
Offline sozo
« Reply #235 on: Sun, 18 August 2019, 22:34:00 »
I like the original design
Offline Vizir
« Reply #236 on: Wed, 28 August 2019, 10:55:59 »
another kb which looks quite similar
https://geekhack.org/index.php?topic=102180.new#new
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #237 on: Wed, 28 August 2019, 11:03:28 »
Except that is layered acrylic/POM and sandwich mount lol
There's been a lot of Alice-like boards popping up, can even get PCB from project keyboard and lasercut files that he has publicly available.
Offline mattling9
« Reply #238 on: Fri, 06 September 2019, 07:59:59 »
Any Updates On This Project?
I would be interested if there were options for case and plate materials like Polycarbonate or Brass.
Can you confirm if this will be considered or if it's going to be Aluminium only?
Offline Vulcan
« Reply #239 on: Fri, 06 September 2019, 13:05:30 »
polycarbonate yes, but full brass version probably no
Offline EMC Labs
« Reply #240 on: Fri, 06 September 2019, 20:00:05 »
Any projected GB date as of yet?
Offline Vulcan
« Reply #241 on: Fri, 06 September 2019, 20:29:12 »
we are still waiting for the prototype to finish
Offline Jubileus
« Reply #242 on: Sun, 08 September 2019, 10:47:49 »
Interested!
Offline mattling9
« Reply #243 on: Sun, 08 September 2019, 11:50:38 »
That's awesome! How long can we expect until you receive the prototype?
Offline snaranda0305
« Reply #244 on: Thu, 12 September 2019, 01:20:27 »
when will GB happen ?
Offline PikaJoyce
« Reply #245 on: Thu, 12 September 2019, 01:29:59 »
I gather that it will happen after the Fusion60 GB has completed shipping out and after prototyping has completed.
Offline Vulcan
« Reply #246 on: Thu, 12 September 2019, 09:12:11 »
When is something i cant answer right now, there are things that needed to be discus with kbdfans and factory whether they can handle and manufacture the design or not.
Offline Vulcan
« Reply #247 on: Thu, 12 September 2019, 13:30:27 »
Offline lorenzocodes
« Reply #248 on: Thu, 12 September 2019, 13:37:22 »
Oh my god that's beautiful
Inviato dal mio ONEPLUS A6013 utilizzando Tapatalk
Offline hansikhouse
« Reply #249 on: Thu, 12 September 2019, 13:43:03 »
Love the new inlays. Looking forward to seeing the project progress!
