Author Topic: [IC] KAM Ghost - GB Open June 5th | TKL Covered for $80!  (Read 75160 times)
Offline DisplayERROR
Re: [IC] Ghost - Profile TBD
« Reply #50 on: Wed, 15 May 2019, 13:40:13 »
I'm into it but, probably only if it comes out in DSA. Hope the ghost letters turn out well. Personally, I think the red would work better as stock accents, not a huge fan of the words.
Offline fireworm
« Reply #51 on: Wed, 15 May 2019, 14:24:05 »
Killing me here.  DSA but not the unique feature of DSA (swapping the caps around).  :p
As an update, I'm gonna order samples in DCS and DSA with Grey / White and Grey Red to see how they look in person.
If we do DCS, I'll have to likely shell out for custom mod legends @ $50 a pop, per unique size.  :eek:
Offline fireworm
« Reply #52 on: Wed, 15 May 2019, 15:56:41 »
Finalized samples.
SP says it'll be a month.   :(
I ordered:
Cap Color GSL, Legend Color WA
DSA 1u 'ESC'
DSA 1u 'Q'
DCS R1 1u 'ESC'
DCS R2 1u 'Q'
Cap Color GSL, Legend Color RCQ
DSA 1u 'ESC'
DCS R1 1u 'ESC'
And also a darker gray:
Cap Color GTL, Legend Color WA
DSA 1u 'ESC'
DSA 1u 'Q'
Cap Color GTL, Legend Color RCQ
DSA 1u 'ESC'
I think that will give some ideas of what this will look like in the flesh, more than a render can.   ;)
Offline fireworm
« Reply #53 on: Fri, 17 May 2019, 20:42:59 »
Thinking more about this, I'm gonna call DCS much less likely.
I'm expecting the contrast to be low on the samples, and the thin font won't do favors.  Thickening up the legends will be extremely expensive, and if the FRow / ESC need to be thickened up AS WELL, then we are only using DCS Alpha legends at that point.
I've got an idea for a DCS PBT set, more on that 'soon'.
I've also made a request for renders on polycarb in the meantime as that's an important target for this set to look good on.
Offline zeroisnothing
Re: [IC] [DCS -or- DSA] Ghost
« Reply #54 on: Fri, 17 May 2019, 21:13:11 »
in for DCS
Offline fireworm
« Reply #55 on: Sat, 18 May 2019, 01:49:21 »
in for DCS
Lol, killing me. Literally just downplayed DCS.
Compatibility is gonna be the trade off, due to probable legend cost.
Hopefully samples show it won't be that big an issue.
Offline Rayndalf
« Reply #56 on: Sat, 18 May 2019, 04:07:19 »
I'm probably an outlier, but I actually like the 'Wyse' font used.on older DCS keycaps, of course those thinner legends would look terrible with low contrast colors... DSA really is a better fit for this colorway, but us DCS boys are getting hungry :p (I use an older Kinesis Advantage that has doubleshot DCS caps, and given obscurity of the layout I've learned to love their 'Cherry only its casual Friday' quality).
Offline fireworm
« Reply #57 on: Wed, 22 May 2019, 18:41:02 »
Here's DSA:
Renders by the ever-amazing Oblotzky:
Contrast I think is just right; enough to be legible, not enough to be 'obvious'.
The light gray is slightly warm.
« Last Edit: Wed, 22 May 2019, 18:46:58 by fireworm »
Offline fombat
« Reply #58 on: Wed, 22 May 2019, 22:33:19 »
i thought this sets colors were these but in reverse regardless from the renders the grey looks too dark
Offline fireworm
« Reply #59 on: Wed, 22 May 2019, 22:52:19 »
Welp, that's what renders are for. :)
I actually have a hard time finding a lighter gray in SP colors. Otherwise, it's two creamy white colors.
Samples will help, when I get them.
Offline fireworm
« Reply #60 on: Sun, 26 May 2019, 01:17:34 »
I've had some time to think, play with renders and gain some confidence.
I'm changing to PBT flat profile dyesub. XDA or DSA. (or maybe SP SA PBT R3.)
This has the following implications / reasoning:
1) The spooky words will be way easier / cheaper to make. I think this will add some fun, and stand out among keysets.
2) This let's me try something else interesting and novel... "soon".
3) I can finally make progress on kits. Kits can be way more flexible (easier to design as well).
4) This lets me likely have lower / cheaper moqs. (I feel it's unrealistic to hit 250 moq with how quiet this thread as been. 100 is where I'm thinking.)
5) White on gray is likely out (unless I get keyreative dsa). Gray on white or gray on paper lighter gray is likely in. (Renders will come soon enough.)
6) I felt the gray was too warm and too dark. And the ABS colors didn't have enough flexibility to fix this.
I wish I made this decision before ordering samples, but oh well. Lesson for other folks: renders first, then samples.
Let me know what you think!
Things I need to settle:
Actual colors. White, light gray. Plus red. (If not red, what?)
Kits (but this should come soon).
Which profile. (I need to get in contact with some China folks.)
Proxies. (I'm the US / CA vendor, likely mykeyboard.eu for EU, and likely kbdfans? for Asia).
Offline eas
Re: [IC] [XDA -or- DSA] Ghost - Flat Profile Update
« Reply #61 on: Sun, 26 May 2019, 13:56:33 »
Looks awesome. I'd love XDA or PBT SA
Offline fireworm
« Reply #62 on: Tue, 28 May 2019, 15:36:15 »
Here's some preliminary kits:
COLORS ARE NOT ACCURATE.
NOVELTIES COMING SOON.
ISO / Int'l coming soon.
I split out FRow, since I think there are more 60's folks that will benefit from possibly cheaper prices.
Question for you: Does this cover what you need?
« Last Edit: Tue, 28 May 2019, 15:37:51 by fireworm »
Offline fireworm
Re: [IC] [XDA -or- DSA] Ghost - Flat Profile Update | Added Prelim Kits
« Reply #63 on: Wed, 29 May 2019, 17:36:03 »
Needs tweaking, but this is where I'm headed:
Custom font, gray on gray.
And yes, your eyes are playing tricks on you, the letters are not wholly formed  :cool::
Offline fireworm
Re: [IC] [XDA -or- DSA] Ghost - May 29: Font + Teaser Render
« Reply #64 on: Fri, 07 June 2019, 16:48:05 »
Updated main post with renders and more context / info.
Offline gotemall
Re: [IC] XDA Ghost - June 7 - Renders / Revamp.
« Reply #65 on: Fri, 07 June 2019, 20:03:24 »
I like the set but can we get some "Ghost Accents" with some nice flat pastel colors to match?
Offline fireworm
« Reply #66 on: Fri, 07 June 2019, 21:09:52 »
I'm sticking with the lightest possible colors here.  Literally found these 'next to gray' in a pantone picker.   :p
Is this what you had in mind?
Offline eas
« Reply #67 on: Fri, 07 June 2019, 21:16:47 »
I do not want to buy anymore sets but I'd buy this.  :))
Offline fireworm
« Reply #68 on: Sun, 09 June 2019, 10:58:10 »
Hey folks,
Doesn't seem like I've hit the mark.
I've gotten feedback that more or less says the features I'm aiming for aren't quite gelling yet. Phrases like "too low contrast" "font is illegible" etc.
I'll leave the form open for feedback.
Also feel free to DM me any other thoughts on discord: fireworm#4461
Offline dr_unconscionable
    • [sqeleton]
« Reply #69 on: Sun, 09 June 2019, 11:13:22 »
Literally the whole point of this set was to be low contrast. People complaining about that seems stupid -- it's just not for them in that case probably. Every IC has these comments from people saying basically "I'd love this if only it were completely different".
Offline fireworm
« Reply #70 on: Sun, 09 June 2019, 12:19:09 »
Thanks for the support!
While I think I have some strong supporters, the numbers don't show.
My form, which is really just one checkbox, only got 50 responses. Most responses here aren't the responses I see in other ICs like "take my money!!" or "GB when???".
This signals to me that I'm missing "something", so I'll play around a bit more and see what I can find.
It will still be low contrast white. :)
Offline glubazoid
« Reply #71 on: Sun, 09 June 2019, 12:36:48 »
Not really a fan of the humanist-ish typeface, but I get what you're going for.
Also, I love low contrast sets. Keep on keepin' on
Offline gotemall
« Reply #72 on: Sun, 09 June 2019, 14:27:14 »
That is exactly what had crossed my mind, to spice it up a bit.  :thumb:
Offline fireworm
« Reply #73 on: Sun, 09 June 2019, 15:36:00 »
Yea, font seems to be really hit and miss with folks. Even those who liked it said merely "interesting" and "I like it". So feels like it's not really adding anything, only changing something. It also makes it a little difficult to balance low contrast on the mods, since I have to go darker in font color.
Cool.
Here's a render, playing with those colors, and trying darker mods.  I don't like the darker mods, practically no contrast.
Offline vicissitude
« Reply #74 on: Sun, 09 June 2019, 19:10:04 »
This is so cool.
Love it.  :thumb:
Offline gotemall
« Reply #75 on: Sun, 09 June 2019, 21:03:17 »
Oh that looks nice, need a nice orange in there also then its complete.
You said you are also working on some novelties? Like to see what you come up with.
« Last Edit: Sun, 09 June 2019, 21:20:13 by gotemall »
Offline fireworm
« Reply #76 on: Sun, 09 June 2019, 21:12:21 »
https://i.imgur.com/nw3ZpBf.png
This is where I was headed, though it's pretty much a WIP at this point.  Not even sure I like the font.
Idea is that since we are flat profile, you could move the words around to create spooky / no so spooky messages.
Offline gotemall
« Reply #77 on: Sun, 09 June 2019, 21:27:41 »
Oh ok, I see where you are going, you mean "GMK Ghost" like in a rated R/Horror Movie/Scary type ghost/related.
I thought you were go with a more friendly/fun/funny type ghosts, the likes of say Casper/Boo (Mario)/Ghost buster or even Like the Pac Man type ghosts and things that related to that genera, etc.
Offline fireworm
« Reply #78 on: Sun, 09 June 2019, 21:55:39 »
Yea, the font really goes straight to horror movie, which is why I'm not sold yet.
I wanted to allow both horror and fun. "I have candy it's OK" can be both sinister and consoling.
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #79 on: Mon, 10 June 2019, 20:29:51 »
Woah.... if you added gold coloured letters it would look classy. But it already does. Good.
Just my thoughts
Offline fireworm
« Reply #80 on: Tue, 11 June 2019, 11:02:33 »
Thanks for your support!
Please take 2 seconds to fill out the form here.  :)
Offline Abec13
« Reply #81 on: Wed, 12 June 2019, 14:39:33 »
Just came here to post this.
45-ATS | Adelie | Gentoo | Volcano 660 | Think 6.5 v2 | SKOG | 7V | Hello M0110
[/url]
Offline fireworm
« Reply #82 on: Wed, 19 June 2019, 13:00:44 »
Hey folks:
Another update:
Things I changed:
Font: Back to a 'normal' font.  The new font was too busy on the mods, and coupled with low contrast, made them more difficult to read than they should be.  I'll consider using Roman font for novelties.
Colors: I went for a more traditional two tone, with mods having a darker base than alphas.  I tried to keep alphas gray, but there wasn't enough contrast between them and the mods.  So, I made the alphas white to keep everything feeling clean and light.  The mod color itself is now 'WFJ' from SP, which is technically a white color. (I find it amusing that I'm still using white for 'dark' mods.)  I did some guerrilla polling and found this to quite popular.  Let me know what you think!
Profile: I forgot that KAM was an option.  KAM is thicker than XDA.  It is also slightly more expensive.  No sets have run with KAM yet, so there is likely risk for production delays.  The caps are spherical like DSA, but taller.
Fill out the form.
Things I need to change:
Kits: I need to redo mod kits to reflect the new color scheme.  I need to pick another accent color; I think red text is perhaps too bold.  I'm leaning towards Blue Gray base, plus Gray text.
Novelties: I need to pick a better font. And update the mock ups.
Offline fireworm
Re: [IC] XDA Ghost - June 19 - Colors + Font change
« Reply #83 on: Sun, 23 June 2019, 12:49:37 »
Welp.
Please cast your vote if you haven't: https://forms.gle/heGCUVSgoW8kfDn3A
Offline Rayndalf
« Reply #84 on: Sun, 23 June 2019, 14:30:20 »
Judging by the samples for KAM Wraith, KAM is extremely shiny compared to all other PBT dyesubbed caps, which might make some already faint legends a bit too ethereal for some people.
https://geekhack.org/index.php?topic=97181.150
Offline fireworm
« Reply #85 on: Wed, 26 June 2019, 12:46:33 »
Final results:
I'm calling this a tie, as the margin is small.
I'll break this tie: Staying XDA.
Reasoning:  Not an overwhelming amount of interest was for KAM, and with KAM still being more expensive and less 'proven', I'm opting for the cheaper more reliable profile.
I appreciate everyone taking the time to participate in the poll.
Next up:
Get some renders with accent colors.
Offline fireworm
« Reply #86 on: Fri, 04 October 2019, 13:58:33 »
This is not dead.
Will have some announcements 'soon'.
Offline Mcnos
    • GMK Fuyu
« Reply #87 on: Fri, 04 October 2019, 14:19:16 »
I also vote for DCS
Offline fireworm
« Reply #88 on: Fri, 04 October 2019, 15:08:03 »
I also vote for DCS
I appreciate your enthusiasm, but I've settled on XDA profile.  Hope that also suits your taste.  :)
Offline bd_slade
« Reply #89 on: Sat, 05 October 2019, 20:31:45 »
I'm new to the keycaps game, so I'm glad this got bumped up! Really like the look of the recent renders and appreciate how much you're working with the community to develop it. I'll be keeping an eye on this set! Good luck! :)
Offline RefrigeratedToiletPaper
« Reply #90 on: Sat, 12 October 2019, 22:18:15 »
I love that this set is XDA. I'm definitely on board with this. Is there a drop date set?
Offline fireworm
« Reply #91 on: Wed, 16 October 2019, 17:33:40 »
More renders, this time with a yellow accent:
Settling some kits, and getting renders for those next.
Offline MdotMaxson
Re: [IC] XDA Ghost - Oct 16 - More Renders
« Reply #92 on: Wed, 16 October 2019, 18:38:00 »
I’ll purchase contingent that ergo blanks stays.
Offline tectonicplate
« Reply #93 on: Wed, 16 October 2019, 23:54:28 »
Previous typeface was so much better for this concept. It's a shame. Loosing that feeling for a barely more legible read is a poor trade IMO, but whatever.
Offline dom
  • allergic to hypocrisy
« Reply #94 on: Thu, 17 October 2019, 05:09:58 »
This is actually the "most exciting" set for me, totally my kind of esthetics and needs :D
Thank you for making it, I'm definitely in!
Will grab them all ;P
BTW: Design is hard. If you feel lost, a good idea is to back to the first design (which is very often the best option). That said, I love the "normal font", XDA and no colors ;)
xoxo
« Last Edit: Thu, 17 October 2019, 05:54:35 by dom »
Offline fireworm
« Reply #95 on: Thu, 17 October 2019, 15:06:06 »
Glad to have your support!
Finalizing details.
xoxo
Tell me about it!  The thing is some refinements are needed regardless, as I can observe how people are reacting, and if they are (mostly) saying things I want.  I also get feedback and ideas that become more obvious, as I'm still learning.  Also, inspiration sometimes just comes from nowhere, and needs to be managed.  :P
I'll be honest, I worried about the excitement over ergo, and like many other sets have decided to drop support for it.  Ortho + 40's is the compromise I've settled on for now, and even then I worry for that kit.
I agree with the point of it being a good concept.  The downside of that font is legibility / busy-ness on smaller mods.  It becomes muddy and harder to read than it should IMO.  I've yet to be confident enough for a post modern keycap set.  ;)
« Reply #96 on: Sat, 26 October 2019, 15:35:40 »
Yes please. I love this set in XDA. **** those novelties though lol
Offline fireworm
« Reply #97 on: Sun, 27 October 2019, 14:25:20 »
Lol, thanks for the support!
Do you have other ideas for novelites? I'm tweaking the novelties, trying to balance "pain" with things like "candy" or "love".
Offline painstar
« Reply #98 on: Mon, 28 October 2019, 16:02:28 »
I really love the pastel modifiers. I wish the font was smaller like canvas Or italic like oblique.
Offline aodaliya1234
« Reply #99 on: Wed, 11 December 2019, 04:42:42 »
Have the outline of a little ghost as one of the novelties to go with the theme?
