Author Topic: E8.5 - 80% custom keyboard.(Groupbuy open)  (Read 177786 times)
Offline iaman
Re: E8.5 - 80% custom keyboard.
« Reply #150 on: Sun, 03 November 2019, 08:37:56 »
Do I just have horrible luck or am I doing something wrong? I tried to enter IC and it is closed....as is every IC I look into. Every GB is over as well as every IC on this site. I understand this merch goes fast but that's what I thought the ICs were for. I'm such an overbloated noob that I must be missing something. No market could thrive if it were this hard to get into a GB or IC. Oh well....I'll come back in a few months and see whats going on then.
Buddy just do a quick check like once a week. Board group buys have tiny windows because we’re all trying to get manus to do production runs for things that take a lot of CNC time with low profit margins between their actual steady work.
Offline victorpre
« Reply #151 on: Sun, 03 November 2019, 08:41:41 »
Split spacebar to go with split backspace? :D :D
+1
Would definitely benefit of a split spacebar !!
Offline jacky
« Reply #152 on: Mon, 04 November 2019, 12:54:24 »
+1
split spacebar on tkl it seems not necessary
Offline Popopro
« Reply #153 on: Mon, 04 November 2019, 13:07:12 »
+1
Agreed. Split space is overkill for tkl.
Offline clik_clak
« Reply #154 on: Mon, 04 November 2019, 13:15:24 »
+1
Maybe explaining how this would benefit from a split space would be more beneficial.
Offline Mekuno
« Reply #155 on: Mon, 04 November 2019, 13:22:47 »
Split BS means that I will finally get myself a TKL :)
« Reply #156 on: Mon, 04 November 2019, 13:52:38 »
I really like split space for TKL, it's extremely useful for spaceFN type layouts. I've been converted to spaceFN after using my alice for a while, and it's actively one of my favorite things now
Offline victorpre
« Reply #157 on: Mon, 04 November 2019, 15:11:13 »
+1
It's a matter of preference.. I always use my arrow cluster on hjkl so I don't need to move my hand all the way to nav cluster for arrows. The spaceFN gives a pleasant experience.  That's the benefit for ME.
Offline iaman
« Reply #158 on: Mon, 04 November 2019, 15:36:58 »
Not to say you're wrong or anything, but this has me a bit confused as to why you're in the market for a TKL?
Offline victorpre
« Reply #159 on: Mon, 04 November 2019, 15:46:05 »
To have one TKL on the collection
Offline s3vv4
« Reply #160 on: Mon, 04 November 2019, 18:52:29 »
SpaceFN means tapping space is Space, holding is Function, or? Why does that require split?
« Reply #161 on: Mon, 04 November 2019, 20:57:11 »
doesn't require split, but i can use the small key as another layer, so i have access to three layers with just my left hand, allowing for extremely fast navigation and inputs in excel
the way i personally do it, i have it as tap for space hold for FN1, then the small key is hold/tap for FN2
so, i use my left hand to type in numbers, and my most used commands (=INDEX(MATCH, mostly) are on macros in one of the FN layers)
« Last Edit: Mon, 04 November 2019, 21:03:05 by Puddsy »
Offline excluisve
  • Making & Thinking.
« Reply #162 on: Tue, 05 November 2019, 20:04:49 »
Offline 8six753o9
Re: E8.5 - 80% custom keyboard.(Quick vote for case color )
« Reply #163 on: Tue, 05 November 2019, 20:13:38 »
Just to clarify for everyone:
e-Yellow/Black/White/Pink will remain an opton.
We are just re-voting for ano colors:  Red / Green / Light blue / Dark blue / Grey / Purple (https://imgur.com/a/bqUVdNA)
Online o3okevin
« Reply #164 on: Tue, 05 November 2019, 20:25:56 »
Purple looking good  :thumb:
Offline Willhurt2008
« Reply #165 on: Tue, 05 November 2019, 21:36:13 »
Will GB have limited slots?
Offline jooobe
« Reply #166 on: Tue, 05 November 2019, 22:06:14 »
Still praying for green
Sent from my SM-N960F using Tapatalk
Offline MadsMe
« Reply #167 on: Wed, 06 November 2019, 03:20:46 »
Voted green just for you
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #168 on: Wed, 06 November 2019, 05:34:29 »
Purple looked great!  I hope it makes it.
Offline BlueViola
« Reply #169 on: Wed, 06 November 2019, 08:24:24 »
Purple would be awesome.
Offline 8six753o9
« Reply #170 on: Wed, 06 November 2019, 18:46:55 »
Just a reminder to those that don't like to scroll up to read, please vote again on what colors you would like to seehttps://docs.google.com/forms/d/e/1FAIpQLSfX7_pzz5-6VzocywBVtCUu2hangLjDLVjgbuuC6GjYzyMHhQ/viewform
PC and all the e-coating (Yellow/Black/White/Pink) will remain an option.
Offline cicatriz
« Reply #171 on: Wed, 06 November 2019, 19:32:33 »
Is the PCB RGB supported?
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #172 on: Wed, 06 November 2019, 22:20:20 »
I'm still confused about the gasket solution. Is it "top or gasket" like E6.5?
Can you clarify what the middle piece is for?
Offline TheFugitive
« Reply #173 on: Thu, 07 November 2019, 00:30:06 »
Without the bottom weight, would the weight distribution of the keyboard be very unbalanced? Specifically for the polycarbonate version, given that the material is much lighter.
Offline Popopro
« Reply #174 on: Thu, 07 November 2019, 00:34:48 »
My understanding of it is that this will be able to mount either top or gasket like the e6.5 but the middle piece is an add on piece that allows you to mount the gasket onto. In other words you need to get that add on to gasket mount it.
Offline servo
« Reply #175 on: Thu, 07 November 2019, 05:15:26 »
This looks really nice! Definitely in
Offline excluisve
« Reply #176 on: Thu, 07 November 2019, 06:45:28 »
Correct.
Offline Dakk1d
« Reply #177 on: Thu, 07 November 2019, 08:40:43 »
Will there be a PC plate? Also, will there be an option to have the brass sandblasted instead of coated?
¯\_(ツ)_/¯
Offline soulventic
« Reply #178 on: Thu, 07 November 2019, 11:35:28 »
What program did you use to make these renders?
Nice kb btw
« Reply #179 on: Thu, 07 November 2019, 12:04:52 »
I'll probably join this as long as we can get a "boring" aluminum plate in addition to brass and stuff. Or at least publish a plate file so I can make my own.
Also is there any point in getting a different material for the inner spacer, if it's just there to hold up the gasket? Unless you're getting polycarb and want a specific appearance, it would make sense to just get the cheapest option right?
Offline Popopro
« Reply #180 on: Thu, 07 November 2019, 12:36:14 »
The e6.5 had poly and brass so prob yes for this one as well.
Offline astronavy
« Reply #181 on: Thu, 07 November 2019, 19:45:21 »
i’m in
Offline kronograf
« Reply #182 on: Thu, 07 November 2019, 21:00:34 »
Acoustics?
jane me | 910 me
Offline excluisve
« Reply #183 on: Thu, 07 November 2019, 21:37:35 »
I thinks someone may need different on it .vary with each individual
« Reply #184 on: Fri, 08 November 2019, 00:11:58 »
Acoustics?
Doesn't make much sense to me if it's just holding up a piece of rubber...
Offline A.Belousov
« Reply #185 on: Fri, 08 November 2019, 02:07:32 »
Hi hi. Can anyone help me to understand how to connect to Exclusive's discord server please? im trying to check Exclusive#8666 invite, but no success with it (mistake or outdated..). Thanks in advance.
Offline victorpre
« Reply #186 on: Fri, 08 November 2019, 03:29:43 »
The PC version will be limited to 50u afaik
Offline nulltorious
« Reply #187 on: Fri, 08 November 2019, 04:04:33 »
Invite link here: https://discord.gg/sh9ZJBk
Offline excluisve
« Reply #188 on: Fri, 08 November 2019, 18:46:32 »
Groupbuy delay few days .
Offline jooobe
« Reply #189 on: Fri, 08 November 2019, 19:06:03 »
That's fine, broke right now anyway
Offline Visionaire
« Reply #190 on: Sat, 09 November 2019, 07:53:00 »
Great design. Looking forward to the GB!
Offline truval
« Reply #191 on: Sat, 09 November 2019, 16:52:23 »
How many units will be available?
Offline Popopro
« Reply #192 on: Sat, 09 November 2019, 17:05:22 »
Alu is unlimited and pc is limited to 50 units.
Offline nathey
« Reply #193 on: Sat, 09 November 2019, 21:30:55 »
Hoping for polycarb backplate :))
Offline japancakes
« Reply #194 on: Sat, 09 November 2019, 21:35:47 »
Got scared for a second. Only want to get this for Polycarb + brass!
Offline excluisve
« Reply #195 on: Mon, 11 November 2019, 02:48:00 »
Updated:
Sorry for the delay i have just sort the color voting :
Anodized color :Purple/grey/green
Price               : Start at $365
PC case           : 50 units  (we have been try many times cnc on pc case but the problem still there
1. Generally speak PC material was flexible when start cnc the case would be a little warped and hard to control the quality
especially tkl top case .However,when you screw up you  wont see the warpe
2.About the tool marking on the bottom .i get feed back from E6.5 . It just a little case have it .you can see the marking clear
but you cant fee it .pc and alu were same CNC process but when sandblasted the alu case tool marking will be recover but pc
case cant .so we need do the pc bottom slow than alu to  reduce marking appearance .but i cant promise make it perfect
3.For sure we want make the pc case quality better but for now we have limitations, so make sure when you purchase PC case
care about those phenomenon or not . On the contrary,you can go for alu case since options always there .
English not my native language, hope you can understand what i am typing here .
Thanks everyone ,if you have any question pm me or touch me on discord .
Bty,Prototypes were done ,photo will show next two days and group buy approaching .before open groupbuy i will announce here again
« Last Edit: Mon, 11 November 2019, 02:57:08 by excluisve »
Offline vi0till
« Reply #196 on: Mon, 11 November 2019, 02:51:54 »
Updated:
case cant .so we need do the pc bottom slow than alu to  reduce marking appearance .i cant promise it not show up 100%
3.For sure we want make the pc case quality better but for now we have limitations so make sure when you purchase PC case
see those two points make sure you dont mind those  On the contrary,you can go for alu case since options always there .
I'm ready.
Sent from my VOG-L29 using Tapatalk
Offline ogp3
« Reply #197 on: Mon, 11 November 2019, 07:32:52 »
very excited for this! What is the website where these will be selling?
Offline eniigma
    • Storefront:
« Reply #198 on: Mon, 11 November 2019, 11:17:53 »
exclusive handles his group buys himself iirc
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #199 on: Mon, 11 November 2019, 11:56:15 »
I’m really excited that purple made the cut. Thanks so much!
