Author Topic: E8.5 - 80% custom keyboard.(Groupbuy open)  (Read 177789 times)
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: E8.5 - 80% custom keyboard.
« Reply #50 on: Sun, 13 October 2019, 21:01:30 »
The more I see this board the more I am falling in love with it! Just saw the IC over on reddit & took another look, after that I believe I'm sold on this board. Been wanting a high end TKL for awhile even though I tend more towards 65% boards & this looks like the perfect one for me! Especially with you focusing in on the little details like making the screw holes more reliable in PC cases & trying to find a way to mitigate the problems some boards have with gasket mounting & screw-in stabilizers like kronograf also mentioned. I was blown away with the quality of my E6.5 & expect this to turn out even better given your focus on every little detail! Speaking of little details, depending on your design I don't know if screw in stabilizers will be an issue with gasket mounting on this board. I was able to use the gasket mount with GMK screw in stabilizers on my E6.5 & did not have any issues with it. So as long as the gasket get mounted the same as in the E6.5 there should be no issue with screw in stabilizers.
« Last Edit: Sun, 13 October 2019, 21:06:25 by Rob27shred »
Offline heyjaykay
« Reply #51 on: Sun, 13 October 2019, 21:32:16 »
Not really getting the colour options for rows in the form
Sent from my SM-G950F using Tapatalk
Offline isaackang7
« Reply #52 on: Sun, 13 October 2019, 21:49:39 »
I’m in for this one
Offline hicals
« Reply #53 on: Sun, 13 October 2019, 22:00:33 »
Is there a quantity limit?
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
« Reply #54 on: Sun, 13 October 2019, 23:24:35 »
will personalized engraving still be offered on this board?
Offline Surefoot
« Reply #55 on: Mon, 14 October 2019, 03:19:32 »
I suppose it's your favorite colour in order of preference
Offline JSaintS
  • Formerly eNrageDSainT
    • JSaintS
« Reply #56 on: Mon, 14 October 2019, 04:04:22 »
That's how I understood it but I have to admit that was a little confusing ^^'
« Reply #57 on: Mon, 14 October 2019, 08:40:54 »
In for a purp... you know it
Sent from my SM-G955W using Tapatalk
Offline jooobe
« Reply #58 on: Mon, 14 October 2019, 11:10:23 »
Is the crown logo the only option for the bottom case?
Sent from my SM-N960F using Tapatalk
Offline Koï
« Reply #59 on: Mon, 14 October 2019, 11:15:56 »
Definetly in for an e-white.  :D
Offline kronograf
« Reply #60 on: Mon, 14 October 2019, 21:23:50 »
I thought I had an issue with screw-in stabs at first but it was actually a wire pop  ^-^ the gasket seems to work fine with the protruding parts of the screw-in housings, just that visually it’s a bit unappealing (esp on a PC board) as it compresses more between the board edges and those particular pressure points. If he works out a way so the gasket has even pressure all around that’d be awesome.
jane me | 910 me
Offline nathanchere
« Reply #61 on: Tue, 15 October 2019, 06:58:05 »
You mention pink in the post but it's not an option in the IC survey?
Offline excluisve
  • Making & Thinking.
« Reply #62 on: Tue, 15 October 2019, 09:15:45 »
For sure is option
E color :yellow pink white black
« Reply #63 on: Tue, 15 October 2019, 15:13:42 »
filled the form, don't know if i'll be able to afford to buy one but it's a good design
Offline brianjking
  • always carry a towel.
    • @brianjking
« Reply #64 on: Tue, 15 October 2019, 22:01:29 »
No HHKB style backspace support?  :(
Offline Mtalbert
« Reply #65 on: Tue, 15 October 2019, 22:31:42 »
NIIIIIIICE!I'm  interested.
Will keep my eye on this.
Big fan of Daeru
Offline ywcsam
« Reply #66 on: Wed, 16 October 2019, 19:16:43 »
I read the author’s post in Zfrontier and here is some clarification for those who didn’t quite understand the gasket structure like myself.
The rubber gasket is actually not shown in the exploded view. The metal perimeter part that goes between the plate and the bottom piece is not a gasket. That part goes on the bottom piece and provides a structure for the gaskets to sit on. The part is optional, meaning if you want gasket mounting, you would have to purchase that piece separately or you can opt for top mounting. Also, that piece is available in brass, polycarbonate, or aluminum.
Offline excluisve
« Reply #67 on: Thu, 17 October 2019, 10:28:02 »
Updated on 17th:
Just finished the black with pink color combo
also have a pic for pink color
Offline Boy_314
« Reply #68 on: Thu, 17 October 2019, 10:33:00 »
looks amazing  :thumb:
Offline Solotov
« Reply #69 on: Thu, 17 October 2019, 10:36:32 »
Is it just engraving at the bottom for PC version? Wanna have that cool brass weight as well  ;)
Flex is love, flex is life.
Offline DAzz
« Reply #70 on: Thu, 17 October 2019, 11:33:38 »
shut up and take my money!!!
Offline ptiede
« Reply #71 on: Thu, 17 October 2019, 16:40:07 »
Hype building!!!!
Offline excluisve
« Reply #72 on: Fri, 18 October 2019, 00:18:34 »
Yes ,alu and pc also engraving at bottom since we already have side weight so cancel the weight(shape of logo )
Offline Water lee
« Reply #73 on: Fri, 18 October 2019, 00:27:03 »
Good design ,can i know the price ?
more $400 or under $400
thanks ,exclusive
« Last Edit: Fri, 18 October 2019, 00:30:40 by Water lee »
make it better!
Offline badboy731
« Reply #74 on: Fri, 18 October 2019, 00:51:42 »
Just want to know if it’s limited or not unit wise thanks.
E7-V1 | TGR Jane v2 CE | HBCP | GSKT-00 | Raine | AOS
Offline Rejeckted
  • Fe, Fi, Fo, Fum... I smell Kraft dinnah
« Reply #75 on: Fri, 18 October 2019, 03:35:01 »
I love that polycarb. can't wait for more details.  :thumb:
Offline excluisve
« Reply #76 on: Fri, 18 October 2019, 21:55:56 »
thanks ,exclusive
Under $400
Offline evorus5
« Reply #77 on: Sat, 19 October 2019, 01:23:55 »
awesome!
Offline haitacxyz
« Reply #78 on: Sat, 19 October 2019, 03:48:15 »
Will it support the last row with layout 1.5 1 1.5 7 1.5 1.5?
Offline Heiser
« Reply #79 on: Sat, 19 October 2019, 08:20:27 »
thanks ,exclusive
Under $400
ohmygod!!!
Offline Rob27shred
« Reply #80 on: Sat, 19 October 2019, 09:47:59 »
Yes it should have winkeyless support. Although there will be a blocker between alt & ctrl.
Offline Gosling_dkc
« Reply #81 on: Sun, 20 October 2019, 03:46:30 »
Welp this is the one! Found my first TKL GB! Those look so good. I will most definitely put myself down for PC. Shoot I would take just about any of them lol. Looking forward to finding out more. The saving begins!!
Also, filled out the IC form!! I am 100% in for one of these. I would LOVE -
All PC case top and bottom. With rose gold or brass plate. And Rose gold accents.
Many more options I would love lol. Thats just my top. But loving that black and pink render you posted recently... SO MUCH GOOD! lol.  ;D
« Last Edit: Sun, 20 October 2019, 22:17:28 by Gosling_dkc »
Offline Degree
« Reply #82 on: Sun, 20 October 2019, 22:17:39 »
Going to miss that crown weight since it's something I've always loved with your boards, regardless I think this will be the TKL I go for next. Can't wait.
I also don't understand what row 1/2/3 ano color means either on the IC
« Last Edit: Sun, 20 October 2019, 22:24:17 by Degree »
Offline h.parks
« Reply #83 on: Sun, 20 October 2019, 22:55:31 »
PC? tkl? actively improving design? count me in
Bottom-Mount Alps Dactyl | Ergodox | PLA75 | SA Penumbra | DSA Blanks | GMK First Love
Offline excluisve
« Reply #84 on: Sun, 20 October 2019, 23:50:53 »
It means you need choose the color of case in all anode colors
Offline excluisve
« Reply #85 on: Sun, 20 October 2019, 23:54:44 »
Green color on E6.5
the real one is a bit green than pictures .
« Last Edit: Sun, 20 October 2019, 23:56:32 by excluisve »
Offline higgga
« Reply #86 on: Mon, 21 October 2019, 00:53:48 »
Are we going to be able to get custom text on the toblerone weight?  Thanks and looking forward to this!
Offline s3vv4
« Reply #87 on: Mon, 21 October 2019, 03:23:16 »
Is there an option to not have the top right nameplate? It's too funky for me
Offline jacky
« Reply #88 on: Mon, 21 October 2019, 10:26:57 »
When is GB  E
i am in for white and light blue  :D
Offline _nowai
« Reply #89 on: Mon, 21 October 2019, 12:06:36 »
The green one looks amazing. I hope I won't miss this group buy like I usually do  :))
« Reply #90 on: Mon, 21 October 2019, 23:30:55 »
Green color on E6.5
that's a very good color
Offline consumer
« Reply #91 on: Mon, 21 October 2019, 23:38:59 »
Will the h87a PCB fit this case?
« Reply #92 on: Mon, 21 October 2019, 23:41:19 »
that is a very good question
i suspect yes, given the USB slot move, but there could always be some weirdness
Offline Esheu2
« Reply #93 on: Mon, 21 October 2019, 23:57:25 »
It has an F13 key, so no h87a. Maybe would work with the upcoming h88a?
Ojou
Offline consumer
« Reply #94 on: Tue, 22 October 2019, 02:24:18 »
Ok, I didn't know they are coming up with an h88a, thanks for the headsup.
Offline aslanxdeft
« Reply #95 on: Tue, 22 October 2019, 10:24:57 »
Is split backspace supported?
Offline kiriiya
« Reply #96 on: Tue, 22 October 2019, 21:51:47 »
So when's the groupbuy?
Offline NoxNoxNox
« Reply #97 on: Tue, 22 October 2019, 21:57:31 »
Wow loving the designs here.  I'm in.
Offline mrsnifflez
« Reply #98 on: Tue, 22 October 2019, 23:43:22 »
Definitely in for one!
Would love to have rose gold as an option! <3
Offline Popopro
« Reply #99 on: Tue, 22 October 2019, 23:47:52 »
Will there be options for the accent colors or will each color combo be fixed?
