Author Topic: E8.5 - 80% custom keyboard.(Groupbuy open)  (Read 181487 times)
Offline suparnemo
Re: E8.5 - 80% custom keyboard.(Quick vote for case color )
« Reply #200 on: Mon, 11 November 2019, 14:41:50 »
Unlimited qty for non-pc?
Offline vidoardes
« Reply #201 on: Mon, 11 November 2019, 14:46:46 »
Looks good as always! Does the plate support ISO?
Offline Popopro
« Reply #202 on: Mon, 11 November 2019, 15:00:36 »
Yea alu will be unlimited
Offline Pulstura
« Reply #203 on: Mon, 11 November 2019, 19:54:23 »
I couldn't fill the form but I'm super interested! Where can I see all the colours provided? Are there renders for them?
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #204 on: Tue, 12 November 2019, 07:45:06 »
I'd like to know what the colour choices for the accent piece in the top-right corner will be, and if we'll have the option of getting multiple of them.
Offline excluisve
  • Making & Thinking.
« Reply #205 on: Wed, 13 November 2019, 01:06:51 »
Color updated :
Case
Purple/grey/green  E-white /E-black/E-pink
Plate
green /E-white /E-black/E-pink/E-yellow/sand brass (e-clear)/Ti/pc
top accent
green /E-white /E-black/E-pink/E-yellow/sand brass (e-clear)/pvd silver/pc/light blue
Side weight
Full brass verison  (10 units) $888
top and bottom case :sandblasted (e-clear)  brass do e white or e black  pc
plate :                       sandblasted (e-clear)  brass do e white or e black  pc
top accent:                pvd silver/pvd black /black/white
side weight :              pvd silver/pvd black /black/white
FE orders will get a extra brass sand weight for free (it will design for 3rd  Anniversary)
PCB : Black with gold trace  .we will reserve RGB  LED you can solder it yourself
hotswap pcb layout
https://i.imgur.com/65o03dM.png
Gasket mount need buy the inner middle  ,default kit was top mount
« Last Edit: Wed, 13 November 2019, 01:47:41 by excluisve »
Offline excluisve
Re: E8.5 - 80% custom keyboard.(Group buy will open in next few days )
« Reply #206 on: Wed, 13 November 2019, 03:59:16 »
Pictures will post next two days and then group buy will come closely
ready to go  :thumb:
Offline jacky
« Reply #207 on: Wed, 13 November 2019, 05:51:05 »
Excited !! E whie +E pink match my Bento  :D
anyone have same combo ?
Offline aslanxdeft
« Reply #208 on: Wed, 13 November 2019, 06:24:20 »
Color updated :
Case
Plate
top accent
Side weight
hotswap pcb layout
No split backspace?  :-[
« Reply #209 on: Wed, 13 November 2019, 08:15:20 »
Can we see a rending of that black and white version?
Offline Popopro
« Reply #210 on: Wed, 13 November 2019, 08:25:42 »
Any chance to consider red top accent?
Offline cicatriz
« Reply #211 on: Wed, 13 November 2019, 08:45:30 »
What is the top accent and side weight? Is that the bit on the top right?
Offline 8six753o9
« Reply #212 on: Wed, 13 November 2019, 09:01:20 »
No split backspace?
You need to get the soldered version of the PCB if you want split backspace.  Hotswap layout only has 2u backspace.
Top accent is the top right piece in this picture that is white:
Side weight is the the weight that goes in the back:
Offline Honey
« Reply #213 on: Wed, 13 November 2019, 10:16:05 »
Is it possible to buy more than one accent piece?
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #214 on: Wed, 13 November 2019, 10:22:50 »
Too bad PVD silver isn't an option for the plates and weights on the regular edition.  I think with purple or green ano it would have looked really good.  Especially with the PVD silver accent piece.
Offline Stan137
« Reply #215 on: Wed, 13 November 2019, 11:28:00 »
Any ETA on the GB?
Offline jooobe
« Reply #216 on: Wed, 13 November 2019, 12:12:41 »
Any ETA on the GB?
He literally made a post 11hr ago saying more renders and date are coming. Use China time to your time, he's probably sleeping right now
Sent from my SM-N960F using Tapatalk
Offline nathanchere
« Reply #217 on: Wed, 13 November 2019, 12:38:20 »
Any ETA on the GB?
So... any ETA?
Offline jooobe
« Reply #218 on: Wed, 13 November 2019, 12:45:12 »
Any ETA on the GB?
So... any ETA?
Ya
Offline Mekuno
« Reply #219 on: Wed, 13 November 2019, 12:48:37 »
Any ETA on the GB?
So... any ETA?
Ya
Yes
Offline jooobe
« Reply #220 on: Wed, 13 November 2019, 12:54:43 »
Any ETA on the GB?
So... any ETA?
Ya
Yes
For sure
Offline A.Belousov
« Reply #221 on: Thu, 14 November 2019, 05:52:32 »
Guys, as I understand I will have to solder LEDs by myself, but does hot swappable PCB also allow LEDs or
i will need to get solderable PCB to have ability to use LEDs? sorry for my english, not native..
Offline excluisve
« Reply #222 on: Thu, 14 November 2019, 06:49:53 »
Solder pcb you need solder switch led by youself ,hotswap pcb dont need since it already have switch led (white color )
two kind of pcb were qmk
Offline kawaiicheung
« Reply #223 on: Thu, 14 November 2019, 07:33:39 »
jiajia niubi :thumb: :thumb: :thumb:
Offline JSaintS
  • Formerly eNrageDSainT
    • JSaintS
« Reply #224 on: Thu, 14 November 2019, 08:58:08 »
Any indication on pricing for the regular version?
Also, any ETA for the GB?  :p
Offline olsen34
« Reply #225 on: Thu, 14 November 2019, 09:16:04 »
Updated:
Sorry for the delay i have just sort the color voting :
Anodized color :Purple/grey/green
Price               : Start at $365
PC case           : 50 units  (we have been try many times cnc on pc case but the problem still there
1. Generally speak PC material was flexible when start cnc the case would be a little warped and hard to control the quality
especially tkl top case .However,when you screw up you  wont see the warpe
2.About the tool marking on the bottom .i get feed back from E6.5 . It just a little case have it .you can see the marking clear
but you cant fee it .pc and alu were same CNC process but when sandblasted the alu case tool marking will be recover but pc
case cant .so we need do the pc bottom slow than alu to  reduce marking appearance .but i cant promise make it perfect
3.For sure we want make the pc case quality better but for now we have limitations, so make sure when you purchase PC case
care about those phenomenon or not . On the contrary,you can go for alu case since options always there .
English not my native language, hope you can understand what i am typing here .
Thanks everyone ,if you have any question pm me or touch me on discord .
Bty,Prototypes were done ,photo will show next two days and group buy approaching .before open groupbuy i will announce here again
Offline JSaintS
    • JSaintS
« Reply #226 on: Thu, 14 November 2019, 09:26:01 »
Updated:
Ooof, sorry for that ! I check his latest update and saw the price for the full brass but nothing on the other and found that odd!
Edit: also, the ETA question was a joke in line with the previous posts asking for the ETA - I guess it didn't sound like one considering I asked for the price which had been disclosed earlier... ^^'
Offline aodaliya1234
« Reply #227 on: Thu, 14 November 2019, 12:48:19 »
Guys for the plate one of the options is sand brass eclear, is it ok if some vetrans can explain what that is? Is it just a brass plate? Also, what material plate will the coloured options be made out of?
Offline jooobe
« Reply #228 on: Thu, 14 November 2019, 12:49:49 »
Brass plate with clear coat, and probably anodized alu
« Last Edit: Thu, 14 November 2019, 12:52:22 by jooobe »
« Reply #229 on: Thu, 14 November 2019, 17:44:19 »
G
Tytytyttytytytytytytytytytytyty
« Reply #230 on: Thu, 14 November 2019, 18:54:05 »
Sorry just a few more questions (a bit new to the keyboard scene):
Should I be worried about getting a brass plate and it oxidising in my keyboard after I build it?
How would the ti (titanium?) plate sound and feel?
Does the hotswappable PCB cost extra then the solder PCB?
Tyty
Offline Sic_Alpha
« Reply #231 on: Thu, 14 November 2019, 19:06:53 »
Brass plate should come PVD coated, oxidizing won’t be a concern.
Offline jacky
« Reply #232 on: Thu, 14 November 2019, 21:04:02 »
Now it seems get e clear not pvd coated .
« Reply #233 on: Thu, 14 November 2019, 21:20:29 »
regardless, oxidization shouldn't be an issue
i can link the pics of my alice plate again if you don't wanna believe me on the importance of a real coating on the plate
« Reply #234 on: Fri, 15 November 2019, 11:06:55 »
Na that's ok, I'll weigh the risks myself i guess. Would going for a pc plate change the acoustic by a lot tho?
Offline bball2
« Reply #235 on: Fri, 15 November 2019, 11:34:18 »
With how awesome the E6.5 group buy went and the price for this one, I'm definitely in!!!
Offline synmuffin
« Reply #236 on: Fri, 15 November 2019, 14:39:41 »
Will there be a polycarbonate version?
Offline d00deitsnik
  • Grails: SA Olivia, 1800 w/ only Latriualum keycaps
« Reply #237 on: Fri, 15 November 2019, 15:19:58 »
They mentioned a PC version but also commented about potential difficulties due to bending or something during production
Offline 8six753o9
« Reply #238 on: Fri, 15 November 2019, 15:20:54 »
Yes that's the PC kit.  It will be limited to 50 and it's FCFS (first come first server).
Offline Heiser
« Reply #239 on: Fri, 15 November 2019, 16:30:27 »
same!!! e-white top and e-pink bottom?
« Reply #240 on: Fri, 15 November 2019, 17:10:35 »
a little yeah but if you want the brass sound, get brass
tbh i think CF has the best sound and it sounds sort of like PC so do whatever you want basically
« Reply #241 on: Fri, 15 November 2019, 22:25:21 »
The brass sound? Have you heard taeha types build the zephyr? I'm trying to go for that sound, regardless of the keycaps and switches, what material would produce that sound? Is that the brass sound?
Offline hyppialonso
« Reply #242 on: Sat, 16 November 2019, 00:10:09 »
could we have a color sample?
Offline Visionaire
« Reply #243 on: Sat, 16 November 2019, 07:30:38 »
Protos are being made.
Offline asianfork
  • Alice
« Reply #244 on: Sat, 16 November 2019, 11:08:54 »
Very nice, can't wait for GB!
Offline hyppialonso
« Reply #245 on: Sun, 17 November 2019, 00:47:31 »
OOPS, I just found it, sorry
Offline excluisve
« Reply #246 on: Sun, 17 November 2019, 07:43:41 »
Just get some photos already updated on home pages
more photos will add on tmr
https://imgur.com/a/iHrFC6W
Offline SolidCactus
« Reply #247 on: Sun, 17 November 2019, 07:46:07 »
Looking tasty! Awesome work exclusive! I’m in for sure
Offline wukong_bot
Re: E8.5 - 80% custom keyboard.(Prototypes pictures come )
« Reply #248 on: Sun, 17 November 2019, 08:30:18 »
Hey could someone drop an invite to the discord please? Previous links aren't working
Sent from my GM1917 using Tapatalk
Offline truval
« Reply #249 on: Sun, 17 November 2019, 09:11:08 »
https://discord.gg/cxGCKd
