Author Topic: E8.5 - 80% custom keyboard.(Groupbuy open)  (Read 177796 times)
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: E8.5 - 80% custom keyboard.(Prototypes pictures come )
« Reply #250 on: Sun, 17 November 2019, 09:18:48 »
The protos look sharp E, awesome work as usual!
Offline wukong_bot
« Reply #251 on: Sun, 17 November 2019, 09:43:02 »
Hey could someone drop an invite to the discord please? Previous links aren't working
Sent from my GM1917 using Tapatalk
https://discord.gg/cxGCKd
Thanks
Offline aa212121
« Reply #252 on: Sun, 17 November 2019, 11:04:32 »
What's the difference between e coating and anodizing. Why do you need e coating after you have anodized the board??
Offline iaman
« Reply #253 on: Sun, 17 November 2019, 12:24:36 »
It’s just a different surface treatment with different color options you can’t get through anodization. An e-coated board isn’t anodized.
Offline jooobe
« Reply #254 on: Sun, 17 November 2019, 15:14:01 »
Google is your friend, those techniques aren't specific to keyboards
Sent from my SM-N960F using Tapatalk
Offline lovelovelovely
« Reply #255 on: Sun, 17 November 2019, 18:15:59 »
In for  e white +pink accent/light blue  :D
cant wait !
Offline Visionaire
« Reply #256 on: Sun, 17 November 2019, 21:56:17 »
This guide should point out the color options you can choose from. I'll update the image if there's something incorrect
  • You can swap top and bottom colors in the same order, so long as they're both aluminum
  • The middle gasket part is optional (costs more $$) and only comes in aluminum e-white or e-black
  • The founder's edition has a e-white and e-black treatment to the bras you can choose from as well
  • You cannot mix PC top / bottom with an aluminum or brass top or bottom
Offline jooobe
« Reply #257 on: Sun, 17 November 2019, 22:28:26 »
I'm thinking Green top and bottom, e-black accent, weight, gasket, and poly(or e-white) plate? What do y'all think?
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #258 on: Sun, 17 November 2019, 22:30:06 »
No chance for a PVD silver weight with aluminum?  Too bad since PVD silver is available on the accent piece.
Offline Solotov
« Reply #259 on: Sun, 17 November 2019, 22:58:12 »
Is there a picture or a render of how the white or black inner middle looks inside the PC board?
Flex is love, flex is life.
Offline Tekniqs
« Reply #260 on: Mon, 18 November 2019, 02:31:25 »
black case with pink weight/accent/plate
Offline excluisve
  • Making & Thinking.
« Reply #261 on: Mon, 18 November 2019, 09:14:32 »
More photos :
take by my another friend.
https://imgur.com/a/Q17GLxg
Offline Robosculpts
« Reply #262 on: Mon, 18 November 2019, 09:22:16 »
Yo, that purple board looks awesome. Kinda want to see what Skeletor looks like on that.
Offline hiko13
« Reply #263 on: Mon, 18 November 2019, 09:30:27 »
Wow, that purple is sharp. See how that looks with Unit 01.
Offline excluisve
« Reply #264 on: Mon, 18 November 2019, 09:38:00 »
Groupbuy really
Soon™️ :D
Offline SolidCactus
« Reply #265 on: Mon, 18 November 2019, 09:58:09 »
The purple looks incredible! Very excited for the group buy!
Any idea on timings (other than SoonTM) as I want to make sure I'm available?
Offline Robosculpts
« Reply #266 on: Mon, 18 November 2019, 10:02:20 »
The alternate alphas would look ace on that purple board!
Offline _nowai
« Reply #267 on: Mon, 18 November 2019, 12:21:18 »
Hi,
how does Titanium and Brass differ in feel? I love the sturdiness of steel plates and hate the sound and feel of aluminum plates.
Can the inner middle be seen from the outside? How does a Gasket change the keyboard?
Is ISO supported?
Sorry for the basic questions. I've been out of the loop for quite some time.  :-[
Cheers!
Offline cicatriz
« Reply #268 on: Mon, 18 November 2019, 12:51:41 »
Does the PCB support RGB?
« Reply #269 on: Mon, 18 November 2019, 13:19:06 »
Pic's of the profile, back, and base?
« Last Edit: Mon, 18 November 2019, 14:18:18 by Critical_Thinker_ »
Offline Visionaire
« Reply #270 on: Mon, 18 November 2019, 15:00:57 »
PCB will not come with RGB LEDs soldered on (since you won't be able to see them for non-PC cases), but will be provided if you want to add them.
Offline Visionaire
« Reply #271 on: Mon, 18 November 2019, 15:02:10 »
Offline breckstar
« Reply #272 on: Mon, 18 November 2019, 18:39:33 »
Hi,
1. how does Titanium and Brass differ in feel? I love the sturdiness of steel plates and hate the sound and feel of aluminum plates.
2. Can the inner middle be seen from the outside? How does a Gasket change the keyboard?
3. Is ISO supported?
Cheers!
Most of if not all your questions can be searched for in the OP or googled.
1. Titanium and Brass will most likely feel like steel. Titanium will be lighter but both will flex very little. I've never typed on titanium plate, but brass and steel feel the same imo, especially when they are like >1mm thickness.
2. On PC, yes. Aluminum or brass, no. Gasket changes the way the plate interfaces with the board. Should allow for more plate to case flex which will translate to your typing being more flexible/bouncy. It can also translate to different sound since the vibration can be absorbed through the gasket instead of directly translated from the plate to the case.
3. Yes, it is in the OP.
Offline _rubik
« Reply #273 on: Mon, 18 November 2019, 19:43:50 »
Wow this IC is coming along very well. I love how customizable this whole thing is. I'll be watching more closely from here on -- can't afford to miss this one :)
Offline A57RO
« Reply #274 on: Mon, 18 November 2019, 22:51:10 »
I’m new here and to all the custom keyboard stuff, I’m really looking forward to this being my first one it looks incredible.
Offline Robosculpts
« Reply #275 on: Mon, 18 November 2019, 22:58:49 »
I notice on the color combo chart it says inner middle gasket. What part is that on your exploded view on page 1? And is it visible when the board is assembled?
Offline excluisve
« Reply #276 on: Mon, 18 November 2019, 23:21:24 »
This time we do not charge extra for E color !
Upgrading
TI plate + 55
brass plate (sand) +$35
Brass side weight (sand)+$40
Brass accent (sand )+$15
Brass accent (pvd silver)$25
Get alu inner middle (black or white )+45  for gasket mount
Extra
Pcb : $48
Alu /pc plate $38
Brass plate (sand) $55
Alu accent :$15
Brass accent(sand):$20
Brass accent(pvd silver):$30
Brass side weight(sand) :$58
No extra inner middle ,no extra ti plate
Extra accents max 3
Offline excluisve
« Reply #277 on: Mon, 18 November 2019, 23:22:15 »
It was inside ,you cant see it
Offline hieughost
« Reply #278 on: Tue, 19 November 2019, 00:40:48 »
Definitely in for E-white + Pink accent!
//I know it's OT but any chance of an E7 groupbuy coming back any time soon? It's my favorite layout but missed the GB last time
Offline Solotov
« Reply #279 on: Tue, 19 November 2019, 01:26:10 »
Upgrading
TI plate + 55
Extra
Pcb : $48
Alu /pc plate $38
Alu accent :$15
Extra accents max 3
Had been pulling my hair out when trying to figure which options to go for. But, now it's much easier since I can just get extras accent/weight  :thumb:
Offline jooobe
« Reply #280 on: Tue, 19 November 2019, 06:52:30 »
More photos :
Is that green or gray in this album?
Offline Prelim
« Reply #281 on: Tue, 19 November 2019, 07:02:17 »
any typing sound test available?
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline iaman
« Reply #282 on: Tue, 19 November 2019, 07:25:18 »
More photos :
It’s grey, with a green corner accent (this was discussed a lot in the Discord)
Offline NitPik
« Reply #283 on: Tue, 19 November 2019, 07:32:12 »
definitely in for green dependent on when this is going to launch. i just had a brief look through the thread but is there an expected start date on the gb yet?
Offline hiko13
« Reply #284 on: Tue, 19 November 2019, 07:52:52 »
Is the side weight visible when assembled?
Offline excluisve
« Reply #285 on: Tue, 19 November 2019, 10:22:32 »
Last updated on pro :
https://imgur.com/a/F7tYgHf
Offline Visionaire
« Reply #286 on: Tue, 19 November 2019, 10:39:20 »
Yes, it is the triangle weight on the back.
Offline clik_clak
« Reply #287 on: Tue, 19 November 2019, 10:44:48 »
Anyone got a link to the discord again? Tried a couple in here and they were invalid.
Offline ywcsam
« Reply #288 on: Tue, 19 November 2019, 11:03:00 »
Just curious, would the Brass and Aluminum version look the same after getting the same surface treatment?
Offline Visionaire
« Reply #289 on: Tue, 19 November 2019, 11:32:24 »
https://discord.gg/HhYRaJe
Offline clik_clak
« Reply #290 on: Tue, 19 November 2019, 11:33:40 »
Thank you!
Offline Nothatso
« Reply #291 on: Tue, 19 November 2019, 11:40:13 »
I'm a bit sad there doesn't seem to be a PVD silver weight being offered for the alu version. Love the look of the black with a silver accent.
Offline wholypantalones
  • text and icon mods plz.
« Reply #292 on: Tue, 19 November 2019, 12:43:08 »
Same, really wanted a silver weight and matching corner accent.
Offline Popopro
« Reply #293 on: Tue, 19 November 2019, 12:59:07 »
It actually should be available for the alu version now if you check visionaire's chart thing.
Offline Nothatso
« Reply #294 on: Tue, 19 November 2019, 15:06:07 »
Maybe I'm blind, but where are you seeing this? The only chart I see (both here and on discord) only seems to show PVD silver accent for the alu version, but not a PVD silver weight. The PVD silver weight only seems to be available for the full brass version of the case.
Offline flippanteer
« Reply #295 on: Tue, 19 November 2019, 15:09:31 »
Yeah it's only available for the Full brass version
Current boards: FLX Virgo w/ NK Drys, E8.5 w/ NK Drys, LZ Physix w/ H1s,  Moon TKL w/ MX Zilents, HAD66 [Alice layout] w/ NK Creams, KBD75v1 w/ Zealios 67g v1
Purchased boards: Infinitum
Past boards: Trinity w/ Tealios v2, Lubrigante w/ Holy YOK Trash Pandas, Kumo w/ Novelkeys Cream, Diverge 2 w/ MX Browns, Planck w/ MOD-H, Anne Pro w/ MX Blue
« Reply #296 on: Tue, 19 November 2019, 15:44:25 »
Only available in full brass tho.
Offline Popopro
« Reply #297 on: Tue, 19 November 2019, 15:44:35 »
Ah my bad, my eyes somehow couldn't align the chart points properly somehow.
« Reply #298 on: Tue, 19 November 2019, 15:52:56 »
No worries, I've been told the quality of the silver pvd is questionable so having hundreds to qc isn't going to happen apperently.
Offline hiko13
« Reply #299 on: Tue, 19 November 2019, 16:20:18 »
Oh! That's what that is. I am super new to all this. Thanks!
