Author Topic: [IC] Sparta - Community feedback required  (Read 21519 times)
Offline crusader_alex
« on: Thu, 19 December 2019, 08:23:02 »
Sparta
As you may or may not know GMK Sparta is a set that was run last month and was regretably cancelled after not being able to hit MOQ.
I know it is probalby too soon but i am making this post to discuss with you the future of Sparta as a project.
Where do we go from here?
Good news is that i plan to rerun the set,however all the details need to be ironed out first.
First things first i need to settle on the profile of the set.Due to the price and high MOQ's of GMK the set is unlikely to return in GMK form unless there is significantly more interest than last time.
Now there are alternatives to GMK and i feel using one of those manufacturers would be the most sensible option.
That said It would be great if you responded to this poll or this post so i can see what you would like in terms of material,manufacturer,profile and kits.Thank you in advance!!!
« Last Edit: Thu, 19 December 2019, 08:33:46 by crusader_alex »
Offline Fredington
    • Instagram
Re: [IC] Sparta - Community feedback required
« Reply #1 on: Thu, 19 December 2019, 08:28:43 »
Your form is only accepting a number response for the open ended prompt. I'll just leave my feedback here.
You could also consider InfiniKey since they can do reverse dye sub as well. I would also suggest including dual legend Greek in the base kit, having separate Latin-only alphas, and abandoning the mono Greek keys.
Also might want to post the old kits here for reference in filling out your form.
Finally, I think the GB was ended too early. It may not have gotten the early numbers you were hoping for, but I think it would have made it to MOQ.
« Last Edit: Thu, 19 December 2019, 08:31:13 by Fredington »
Offline sent-by-an-iPerson
« Reply #2 on: Thu, 19 December 2019, 08:29:09 »
I was on this GB and I honestly don’t know why it failed. It’s a really classy looking set. But I’d be up for it being re-released as GMK or KAT.
I also think the GB was ended too early.
« Last Edit: Thu, 19 December 2019, 08:32:20 by sent-by-an-iPerson »
« Reply #3 on: Thu, 19 December 2019, 08:32:17 »
Sorry,should be fixed now.Also I'll drop a link to the old IC so people can see the old kits like you mentioned.
« Last Edit: Thu, 19 December 2019, 08:34:04 by crusader_alex »
Offline Steezus
  • Keeper of Facts
« Reply #4 on: Thu, 19 December 2019, 08:39:02 »
I'm glad to see this make a comeback. I thought for sure that this set would have been able to meet MOQ the first time around. I'm hoping that the set will re-released as GMK again.
Offline Gondolindrim
    • My GitHub
« Reply #5 on: Thu, 19 December 2019, 08:47:48 »
Really sad this didn't meed MOQ. I was gonna pick it up.
If it comes as KAT or a tall profile like SA it's instabuy for me.
εδώ είναι Σπάρτη!
A pessimist will tell you the cup is half empty. An optimist will tell you the cup is half full. An engineer will tell you it's exactly twice the size it needs to be.
Offline DetectiveNio
« Reply #6 on: Thu, 19 December 2019, 08:49:56 »
I was so hyped for this and the deskmat. I thought it'd go really well marble desk/countertop. I'm down with infinikey
Offline Robosculpts
« Reply #7 on: Thu, 19 December 2019, 08:56:51 »
Totally in for ergo or ortho if they get added. I voted for GMK but really, it doesn't matter to me. This set is beautiful.
Offline Solotov
« Reply #8 on: Thu, 19 December 2019, 08:58:39 »
Really love to see the red color on the alphas instead of gold.
Flex is love, flex is life.
Offline renolo
« Reply #9 on: Thu, 19 December 2019, 09:18:32 »
Rename it GMK Leonidas, People might be more attached to a single historical figure than a civilization
Doritos, Cheetos, or Fritos.
Offline cldskt
  • Wallet and hobby aren't friends
« Reply #10 on: Thu, 19 December 2019, 09:31:43 »
Hoping to see this re-run in GMK
"Addiction is buying the things that I don't need with the money I don't have." - me
"Spending $500 on your first custom is justified." - also me
Offline cyyz
« Reply #11 on: Thu, 19 December 2019, 09:53:07 »
I think the kits are great as is. No need to make Latin alphas a separate kit. The colours are great as is. Only reason i think this set was slow was due to holidays/timing with other bigger sets. And i still think this would have made MOQ near the end.
I would vote to keep it in GMK and use the same kits, however, if you really want to change the profile, i can suggest SA profile.
Offline Shaphyna
« Reply #12 on: Thu, 19 December 2019, 10:06:56 »
Would love to see this on KAT profile! I really loved the deskmat too :)
Offline Ac1221
« Reply #13 on: Thu, 19 December 2019, 10:08:23 »
rerun in gmk
从我的 iPhone 发送,使用 Tapatalk
Offline kaisn
« Reply #14 on: Thu, 19 December 2019, 12:16:07 »
Rerun in GMK I'm sure it will reach MOQ
Offline ivu
« Reply #15 on: Thu, 19 December 2019, 12:55:47 »
Keep latin alphas in base kit. Greek as separate.
For legends it would be nice to try a couple of renders with the red color instead of gold in order for community to compare and decide. I think red might be better for contrast tbh.
You might want to consider additional alpha kit with red/gold like the mods. Would sell like hot bread.
Is it possible to achieve the same quality of colors in other profiles/materials ?
Offline deathwalker113
« Reply #16 on: Thu, 19 December 2019, 13:41:13 »
This set is gorgeous ... so GMK FTW !
Offline Ensaum
« Reply #17 on: Thu, 19 December 2019, 17:20:49 »
Keep it GMK pls... Just wait for better timing. So many sets running right now. Only major change I would suggest is to slim down the greek kit to sublegends only and get rid of the mono alphas. It's too expensive with both. I'm curious to see what red alpha legends would look like as well, but I'm concerned that the gold would be underrepresented then. You may also look into separating the numpad to bring down the base set cost. I'm pretty sure the majority of people in this hobby use tkl or smaller. 1800 support could probably move to the numpad set too if you end up separating it.
« Reply #18 on: Thu, 19 December 2019, 17:44:05 »
If you're going to have an alt set of red alphas (which I think would look awesome, like a Spatan Cloak), it would be cool to have more contrasting modifiers or alts in gold.
Offline ever9415
    • EVER STORY
« Reply #19 on: Thu, 19 December 2019, 17:46:15 »
Better change the text color of the Alphas Key before GB starts again.
I don't like the current Alphas Key text color.
Offline click clack jack
« Reply #20 on: Thu, 19 December 2019, 18:04:48 »
Please run again, me and MANY of my discord friends were gunna join we just hadnt yet!
Also, my one recommendation is to make Greek in the default, it fits the theme perfect and people dont wanna buy 2 kits
Offline adxlk
« Reply #21 on: Thu, 19 December 2019, 19:19:12 »
Make the alphas in this style: https://geekhack.org/index.php?topic=102935.0
And..can I suggest R5 bottom row?
Offline SUB01
« Reply #22 on: Thu, 19 December 2019, 21:29:39 »
tbh I thought this was one of the better looking sets of this year. I think the only problem with the set is that it ran to close with too many hyped/anticpated sets of all time like olivia.
Offline senryo
  • Problems are challenges.
    • Thic Thock
« Reply #23 on: Thu, 19 December 2019, 22:01:33 »
exactly, and the payday too. It was shut down just way too early.
I hope the rerun will still be GMK, the quality and the profile are just the perfect match for the set.
Offline Butterbeer
« Reply #24 on: Thu, 19 December 2019, 22:52:45 »
I would personally like to see the set redone to mimic ASHES and losing the accent keys. Ashes covers a lot of boards and the kits are simple yet satisfying. Red/Gold and White/Gold would be interesting.
A couple of observations/suggestions:
1. Get a DISCORD channel
  • Helps with Feedback
  • Helps with Updates
  • Helps with Marketing/Hype
  • Helps the Community Grow
2. Stick to a Group Buy date well in advance and do not change it
  • Shows commitment
  • People will buy and save according to a set purchase window
  • Plan with vendors so that it's not sandwiched between big ass sets
« Last Edit: Fri, 27 December 2019, 04:30:17 by Butterbeer »
Offline nasp
« Reply #25 on: Fri, 20 December 2019, 00:55:07 »
+1 for changing the alphas to the red instead of the gold that they are now. I'd like to see the contrast improved.
Offline RobK_aka
« Reply #26 on: Fri, 20 December 2019, 01:34:09 »
I would have purchased on the original GB but it closed before I could even purchase. I'm in on this set no matter the profile. I'd prefer GMK but KAT would be good too.
Offline terrad
« Reply #27 on: Fri, 20 December 2019, 04:10:34 »
Please keep the colors as they are. One of the best looking sets in a long time IMO.
Sent from my SM-G955F using Tapatalk
Offline infinitykw
  • Amazed by the beauty of industrial design
    • zFrontier Profile
« Reply #28 on: Fri, 20 December 2019, 06:11:02 »
So I observe this early cancellation as a way of getting more attention, and the set deserves GMK.
Offline Solotov
« Reply #29 on: Fri, 20 December 2019, 06:29:13 »
At least if we could get a render of red alpha so that people could compare it with the current gold and see which option they like more  :thumb:
Offline ctrlshiftba
    • ctrlshiftba
« Reply #30 on: Fri, 20 December 2019, 06:48:41 »
As a consumer there is no reason to join a GB early. With 10 GMK sets per month deciding on which to buy is taking more and more consideration. Considering most vendor don’t allow cancelling I think more and more people will wait til the last minute.
This set is amazing and deserves GMK. Find a way to incentivize joining a GB early. Try to schedule it on an off month if it’s even possible. Also a 6 week GB period like Ursa could help.
Also what is it about the key company? I find them to be just as good as other top tier vendors but their key set GB numbers always come in surprising low???
Offline Fredington
    • Instagram
« Reply #31 on: Fri, 20 December 2019, 07:00:41 »
Agree with this.
Offline yuuS0cut3
  • Stay young
« Reply #32 on: Fri, 20 December 2019, 07:58:57 »
100% agree. Should GB on a time that isn't the same as some really hyped keyset, such as Olivia, Metaverse, Obvilion,...
Offline kokugatsu
« Reply #33 on: Fri, 20 December 2019, 10:52:19 »
GMK for sure, only qualm I have is with the Rama design.
Honestly I felt the cancellation in the middle of the month was premature, I was sure a lot more people would have joined once they got their paychecks, myself included.
Offline SlurmsMacKenzie
« Reply #34 on: Fri, 20 December 2019, 14:23:52 »
This is how I feel as well, though they must have been pretty sure it wasn't going to make it, I would have been curious to see what would have happened if they left it open for the full GB period.  But yeah, I think the set is great the way it is, I was going to buy it as well.  I really like the gold on white alphas personally.
Offline SuddenlyDonkey
« Reply #35 on: Fri, 20 December 2019, 18:43:08 »
Legionnaire kit with red alphas and gold lettering   :-*
« Reply #36 on: Sat, 21 December 2019, 00:58:50 »
As an alt set of alphas, definitely.
Offline euphxenos
« Reply #37 on: Sat, 21 December 2019, 16:43:17 »
I was in when it ran, and I'll be in when you're ready to try again.  This was bad timing more than anything else -- lots of sets were running, some of them very popular sets, it was right before the holidays, *and* over Black Friday.  Wait six months and give it another try.
Offline hyperdolch
« Reply #38 on: Sun, 22 December 2019, 00:09:06 »
Rerun please!!
Offline shansoft
« Reply #39 on: Sun, 22 December 2019, 12:20:45 »
Keep it as what it is. The GB time is a bit off with other sets, and it closed way too early IMO.
Offline cldskt
« Reply #40 on: Sun, 22 December 2019, 20:29:20 »
Actually interested to see what would the alpha set look like with maroon legends and beige base, as well as gold legends and maroon base.
« Last Edit: Mon, 23 December 2019, 01:53:50 by cldskt »
Offline Tyson
« Reply #41 on: Mon, 23 December 2019, 01:32:57 »
I'm of the same mindset, I really liked the way the set looked, would love to buy it again at the right time.
Offline JDwrx
« Reply #42 on: Mon, 23 December 2019, 15:20:01 »
I'm definitely interested, even though I don't have a keyboard for it yet.  Hopefully I find a GB for that, as well.  I can't fill out the form due to a cert error.
Offline Hackerpilot
« Reply #43 on: Mon, 23 December 2019, 22:06:11 »
If this runs again, I'll probably join it again. I'm interested in split spacebars, Greek sublegends, and any possibility of Ergodox/Boardwalk support.
Offline ivu
« Reply #44 on: Tue, 24 December 2019, 01:35:10 »
Here is my feedback so far:
- Keep it GMK as it will look the best. Not sure how the colors would look like in PBT. Will do Moq for sure either way.
- Add a secondary alphas kit with red base and gold legends. Will be an instant buy for many ppl.
- Red legends might be a better choice for base alphas. Much better contrast.
- Request which might be only by me...1.5u R4 FN key. Not as important ofc ;)
Enjoy your holidays!
« Last Edit: Tue, 24 December 2019, 08:54:04 by ivu »
Offline alternisciel
« Reply #45 on: Tue, 24 December 2019, 08:17:13 »
Love the regal look of this set, I think GMK and epbt does look the best, dont really dig the legends of KAT unless its similar to Milkshake's alphas. Saving money for this, will definitely pick this up as my first keycap set for my first ever build! All the best!
Offline midnatwili
« Reply #46 on: Tue, 24 December 2019, 11:07:18 »
I love this set; the color combination, novelties, and greek letters look amazing. I was surprised this didn't hit MOQ. Will not hesitate buying a full set again when this launches in the future.  :thumb:
« Reply #47 on: Thu, 26 December 2019, 11:34:58 »
Hello everyone!
First things first,I want to wish you all a merry Christmas.This has been a great year even though we had some setbacks.
Since it's the holidays i would like to post a short update to not take much of your time.
To address a couple of things based on the current feedback:
  • New kits will only be added if the set is not GMK unfortunately as right now it's impossible to hit MOQ
  • The Greek Kit will probably be worked on to decrease the price,even though it's not ideal it's most likely getting slimmed down to just the mixed greek keys
  • Some changes will most likely be made to the base like adding the second B for Alice users
  • Regarding the maroon with gold alternate base keys I didn't include them in the first run mainly because of cost and secondly because I thought it would be too similar to Red Sam however if you'd like to see that I wouldn't be against adding it
  • Finally I made a render using maroon legends instead of gold but it strays too much from my idea of the set so I don't think anything will be done with it
Thank you for bearing with me on this update and happy rest of the holidays!!!
Offline gordonderp
« Reply #48 on: Thu, 26 December 2019, 13:55:43 »
Yeah not really feeling it without the gold. Have you considered going with JTK?
Offline DanBe
« Reply #49 on: Thu, 26 December 2019, 14:06:10 »
Agreed, it's not very Spartan without the gold imo
