Author Topic: [IC] GMK Bleached | GB Live! | AKI-S Giveaway  (Read 148830 times)
Offline noodleman
Re: [IC] GMK Bleached | (2/6) All vendors announced! New proposed kits
« Reply #150 on: Fri, 21 February 2020, 13:40:32 »
wouldn't the r4 1.5u Fn key in the extension kit make more sense to be spelled out like the 1.5u r2 Function Key?
Offline konstantin
  • Formerly constexpr
« Reply #151 on: Sat, 22 February 2020, 01:10:54 »
As it stands, the extension kit is too small, so the cost per keycap will be high and the risk of it not hitting MOQ greater. A few keys that I see are missing that you might want to add to it are: R3 1.75u stepped Control, R3 1.75u Function (although I'm assuming that's what the current 1.5u key is supposed to be), R4 2u Shift, R4 1u Shift, extra R4 1u Ctrl. Maybe even move the F13 there.
Take a look at the Nautilus 2 extension kit and see if you can draw any conclusions from there.
« Last Edit: Sat, 22 February 2020, 01:12:36 by constexpr »
Offline bsanto
« Reply #152 on: Tue, 25 February 2020, 01:08:26 »
Just copy the layout made in GMK minimal and my money is all yours!
Offline Chuttau
  • Formerly botallu
Re: [IC] GMK Bleached | (3/1) New kits, New IC form
« Reply #153 on: Sun, 01 March 2020, 11:22:53 »
Updated the Kits and a new IC form,
Please fill in the new IC form again if you are interested, many thanks.
Offline FRANCO
« Reply #154 on: Sun, 01 March 2020, 12:04:32 »
Can you add an option to add your email in the IC form? Just want to make sure I don't miss this GB =)
Offline Chuttau
  • Formerly botallu
« Reply #155 on: Sun, 01 March 2020, 12:08:00 »
Done
Offline yhs
Re: [IC] GMK Bleached | (3/1) New kits, PLZ FILL IN THE NEW IC FORM
« Reply #156 on: Mon, 02 March 2020, 01:47:43 »
I’m in! Let’s go
Offline aboreo
« Reply #157 on: Mon, 02 March 2020, 05:20:30 »
The new kits are perfect for me. Thanks!
« Last Edit: Mon, 02 March 2020, 05:22:30 by aboreo »
Offline Hoipolloi
« Reply #158 on: Mon, 02 March 2020, 06:22:46 »
Anyone interested in Text-Only mods? I feel like icon+text is too busy. Either Text-Only or Icon-Only works better imo.
Offline VipermanGT2
« Reply #159 on: Tue, 03 March 2020, 01:00:31 »
YES YES and more YES. Love the base kit now. This may the first keycap set I buy MULTIPLES of!!!! Cannot wait!
Offline damsenviet
« Reply #160 on: Tue, 03 March 2020, 01:38:33 »
Text only mods look a lot cleaner imo
Offline yicaoyimu
Re: [IC] GMK Bleached | (3/2) RAMA Caps, PLZ FILL IN THE NEW IC FORM
« Reply #161 on: Wed, 04 March 2020, 12:56:52 »
Just wanted to say that the novelties kit from GMK Noel could be a perfect accent kit for Bleached.
Offline Shutter_Shock
« Reply #162 on: Thu, 05 March 2020, 00:51:17 »
I’m probably not going to get the GMK keycaps. Not because I don’t like the set, just because I have too many and BoW isn’t really my thing. That being said, I might try to pick up several of the X and O Rama caps to fill a macro pad with them if it fits into my budget when the time comes.
Offline lush_bunny
« Reply #163 on: Thu, 05 March 2020, 09:20:46 »
As someone who has never been interested in a RAMA cap till now, what row is that X/O cap?
Offline Chuttau
  • Formerly botallu
« Reply #164 on: Thu, 05 March 2020, 09:27:47 »
They are R1
Offline Jaltr
« Reply #165 on: Fri, 06 March 2020, 08:03:22 »
oof the rama caps look clean af
Offline lush_bunny
« Reply #166 on: Fri, 06 March 2020, 08:43:35 »
They are R1
Thanks! That seemed really obvious in hindsight /facepalm
Offline DuellM
  • Keyboard Fatty
« Reply #167 on: Mon, 09 March 2020, 12:08:46 »
How Awesome Would e-White X & O Rama Caps With White Pearlescent Enamel Infill Look  :))
Offline xiangxp
« Reply #168 on: Mon, 09 March 2020, 13:54:44 »
I love you Chuttau <3
only if I can get that FF edition to go with this ;-;
Offline Chuttau
  • Formerly botallu
« Reply #169 on: Mon, 09 March 2020, 13:56:12 »
:thonk:
Offline Chuttau
  • Formerly botallu
Re: [IC] GMK Bleached | (3/14) April GB
« Reply #170 on: Sat, 14 March 2020, 00:44:37 »
GB date released(sorta)
There will be a giveaway exclusive for GMK Bleached buyers, more information in the discord server.
Offline levitanong
« Reply #171 on: Sat, 14 March 2020, 01:02:30 »
Discord says the invite is invalid :o
Offline Chuttau
  • Formerly botallu
« Reply #172 on: Sat, 14 March 2020, 01:06:13 »
should be fixed
Offline 8idl
« Reply #173 on: Sat, 14 March 2020, 10:16:22 »
Anyone know how the X + O artisans would look with GMK Minimal? Would they look too bright next to the warmer tone? (I really like these artisans but don't really need a second BoW set...) Thanks!
Offline Sycomore
« Reply #174 on: Sat, 14 March 2020, 10:23:22 »
This is the reason I’m excited for this
WS2 matches your average pcb white way better than WS1. Make sure to add plaid/ortho coverage somehow.
https://imgur.com/gallery/yfBye2q
These are the two colours compared. WS1 being Minimal and WS2 being this
« Last Edit: Sat, 14 March 2020, 10:25:56 by Sycomore »
Offline konstantin
« Reply #175 on: Sat, 14 March 2020, 15:58:52 »
It's hard to say, it depends on how well the artisans' e-white coating will match WS2; they're different materials and different finishes after all. However, taking into account just the colors themselves — it would not look good. See the above picture. Minimal's WS1 looks dirty and yellowed in comparison.
Offline 8idl
« Reply #176 on: Sat, 14 March 2020, 16:53:21 »
Ok thanks for the helpful responses!
Offline dom
  • allergic to hypocrisy
« Reply #177 on: Sun, 15 March 2020, 08:03:44 »
Looks solid :)
« Last Edit: Fri, 20 March 2020, 13:54:22 by dom »
Offline spinozsa
« Reply #178 on: Fri, 20 March 2020, 19:55:28 »
Symbol-only mods are nice, would prefer them over the text mods.
Offline BuddhaBen
« Reply #179 on: Sat, 28 March 2020, 18:49:11 »
Is there a date confirmed for this yet?
Offline bigapplepietart
  • Topre Convert
« Reply #180 on: Mon, 30 March 2020, 11:11:49 »
V nice!
Current:
Heavy Grail (Purple DES V1) | hiney tkl one PC (Orange SKCM Alps) | Lunar II (Green SKCL Alps) | Sho S60 V2 (Purple DES V1) | HHKB Hybrid Type-S (45g Stock Domes)
Past:
Razer Blackwidow (MX Blues) | FC660M (MX Blues) | GH60 (Ergo Clears) | 8x mkI (Vintage Blacks) | Klippe (Sakurios) | Equinox (Sakurios) | MGA (Silent Alpacas) | Kei (Creamsicles) | KFE CE (Alpacas) | Rukia R1 (Durock L7) | H60 (Silent Blacks) | E80-1800 (MX Blacks) | Ottantaquattro (Vintage Blacks) | hbcp (Vintage Blacks) | HHKB Pro 2 (45g Aged Domes) | ADK64 (Blue SKCM Alps) | Palmetto (Ultraglides)
Offline JFKroflcopter
« Reply #181 on: Mon, 30 March 2020, 13:55:55 »
Did this change to icon only mods on the base kit? I thought it was locked in as text+icon with an icon child kit.
Offline KnoblesseOblige
« Reply #182 on: Mon, 30 March 2020, 21:15:24 »
Now, if I **** this model...
And she just bleached her *******...
And I get bleach on my T-shirt...
I'ma feel like an *******...
Discord: Taylor#2460
Offline Chuttau
  • Formerly botallu
Re: [IC] GMK Bleached | GB will go live on April 10th! | AKI-S Giveaway
« Reply #183 on: Sat, 04 April 2020, 14:38:51 »
Yes, an update.
sorry for disappearing for so long, I was in a mandatory quarantine for the past few weeks.
Offline scoopbb
« Reply #184 on: Sat, 04 April 2020, 18:05:08 »
lol that 40s kit fully gone. guess ill just buy this to flip instead of use.
  • Topre Convert
« Reply #185 on: Sun, 05 April 2020, 10:44:11 »
Will there be price drops as the kits sold increase, or it the price fixed?
Current:
Past:
Offline Artemie
  • Don't Let Your Memes Be Dreams
« Reply #186 on: Sun, 05 April 2020, 10:57:14 »
Why does the kit for fullsize compat cost $150 using GMK colours.
| 420CL | Fanoe | Porpoise | KFE R1 Silver| MxSS |  is0 Pink & Silver | HBCP Polycarbonate | Matrix 2.0 Additional Purple | TGR Police | Singa Jaguar Green | KFE R2 Blue | RS so lit | Dolch CR Black | Jelly 60 Blue | Belle en Rose | Kei R2 Olive | Dalco 959 Mini | Aripeko
Boards in GB: | IU board |
Previous Boards: QXP | Singa  | UTD | Taichi | Jane v2 Red | Jane v2 CE
Offline dallman5
« Reply #187 on: Sun, 05 April 2020, 11:45:11 »
For real, plenty of GMK sets have run with way more compatibility for like $110-120 recently
LF: OG Cherry APL (lasered), Artisans
Current collection:
Norbatouch (Galaxy Blue) | Mira SE (Lunar Grey, WKL) | HHKB Pro 1 (KB300BN) | Noxary X60 (Grey, HHKB) | KBDFans 5 Degree (Silver) | AEK64 (Grey) | Norbaforce (Tactical Black, WKL)) | Realforce 86U (White) | TGR 910 RE (Polycarbonate) | LZ-SQ (Black) | LZ-CLS (Grey, WKL) | Duck Orion v1 (Silver, WK)) | Nissho KB106DE | HHKB Pro 1 (KB300B) | LZ CLS-S (Blue, Poker) | Realforce 87U 10th Anniversary) | Realforce 104UK | TGR Alice (Grey on Pink) | Singa (Blue, WKL)  | Quantrik QXP (Blue Grey, WKL) | LZ-GH v2 (Black, WK) | KMAC Happy (Red, Poker)) | IBM Model M SSK (APL) | TGR 910 SE (Pink on Blue) | GSKT-00 (Silver, Poker) | OTD Koala (Silver, WKL) | Realforce R2 PFU Edition (Ivory) | IBM 3279 Beamspring (APL) | TGR Tris (Blue) | LZ-GH v2 (Blue, WKL)) | TGR Jane v2 (Blue-grey, WKL) | LZ-MP (Shine Grey, WKL)  | TGR x Singa Unikorn (Purple) | Justsystems x Realforce 108UG) | IBM Model F Unsaver (APL) | TGR Jane V2 CE (Multicolor, WKL) | Realforce 87U (Blank Black) | Lin Montage (Light Blue, WKL) | GSKT-00 AEK R2 (Grey, HHKB) | Leopold FC660C (Blank Black) | Duck Viper v3 (Grey on Black) | Rama Works M6-C RWxRW | LZ-GH v1 (Black, WKL) | Gok 7v (Grey) | biso x beaming Kei (SS, HHKB) | zacheadams x bisoromi little z | Matrix Noah (Silver/Grey, WKL) | Lin Whale (Pink, WKL) | TGR Alice (Polycarbonate) | Rama Kara (Noct) | Lin Whale75 (Burgundy, F13) | Realforce 89 (Ivory) | Hand Engineering Haus (Bluegrey) | Haytco CAKE60_R1 (Pantone 4167C) | LZ-XE (Grey, WKL) | Noxary X60 V2 (Grey, WK) | Daji Ochocuatro (Grey, WKL) | HHKB Hybird Type-S 25th Anniversary (Snow) | LZ-REs (Grey, WKL) | Matrix 8xv 3.0 (Blue-Black/Deep Grey, WKL) | Realforce 23UB | Biso RS60 (Black, WK) | TGR x MXF Koala (Grey/Black, WKL)
Italics = Incoming, Black = Gone
Offline konstantin
« Reply #188 on: Sun, 05 April 2020, 12:15:04 »
That's the trade-off of having small, more affordable base kits.
I'm sad to see that there will be no 40% kit. Anyway, GLWB
« Last Edit: Sun, 05 April 2020, 12:39:49 by konstantin »
Offline kokugatsu
« Reply #189 on: Sun, 05 April 2020, 12:42:54 »
Really good price on the base kit, I'm in
Offline ullr
« Reply #190 on: Sun, 05 April 2020, 12:58:02 »
GMK text+icon is so inconsistent. The icons can be tiny (backspace), huge (windows), or intermediate, to the left of the text (shift, enter, backspace), without text (menu, windows), around the text (tab)... There is no rhyme or reason. They also crowd the surface grotesquely on ISO and split shift
The only set made in literally the last thirty years to pull off text and icons is /dev/tty.
I will buy this set if it offers icon mods (my preference) or if it uses text mods. If I wanted a keyset that looked like it came off a cheap old Cherry keyboard, I could quite literally dig one out of the trash.
Offline Artemie
« Reply #191 on: Sun, 05 April 2020, 21:56:58 »
To quote a recent example of GMK Ashes, the base had fullsize and iso support built into the kit, and costed $130.
This was with custom RAL colours and higher MOQ.
This set requires a MOQ of 150 as it’s stock GMK colours.
Offline konstantin
« Reply #192 on: Sun, 05 April 2020, 23:05:55 »
That's not the point I was trying to make. Better value ≠ more affordable. I'm sure this set would have been able to reach the same price point if it had gone for that kind of compatibility. Undoubtedly the value for money is worse with a setup like this, but some designers opt for it anyway just because of how attractive that $100 price point is. The cold, hard truth is that the majority of potential buyers aren't going to need the extra compatibility, so offering a lower price point makes more sense for them. Especially with how many sets are running each month now, each of them vying for those buyers and the buyers having to pick, the low price can really make a difference.
That being said, so can the value. I'm not defending this approach by any means; I'm just saying how it is and what the reasoning behind this kit layout might have been. I personally prefer a base kit with good compatibility that allows me to cover the weird layouts I use without spending too much extra. Simple and versatile sets like this especially should, in my opinion, have a good base kit because they have the potential to work on many different boards. But it is what it is.
Offline lush_bunny
« Reply #193 on: Mon, 06 April 2020, 01:08:30 »
Wait we're back to icons now?
Offline senryo
  • Problems are challenges.
    • Thic Thock
« Reply #194 on: Mon, 06 April 2020, 03:23:32 »
words of wisdom
Offline MacSurfy
  • Designer & 3D artist
« Reply #195 on: Mon, 06 April 2020, 03:28:52 »
Yes, and it is fantastic! No need to buy two kits anymore.
Offline kokugatsu
« Reply #196 on: Tue, 07 April 2020, 11:21:23 »
I believe it is icons only now? Same sentiment btw
Offline Chuttau
  • Formerly botallu
« Reply #197 on: Tue, 07 April 2020, 18:13:11 »
yea, it's icons only now, we've gone a full circle
Offline Chuttau
  • Formerly botallu
« Reply #198 on: Tue, 07 April 2020, 18:39:54 »
There are several reasons that why I have decided to split numpad and iso from the base.
It could help to bring the cost of the base to sub-100 (hence 99.99 we are currently listing), I understand some people prefer to have more compat with a slightly higher price. The thing is most people don't need/don't ever use the numpad keys(also iso). Spliting them can make the Base kit more affordable while supporting most(imho) of the layouts this community use. I personally think a base cost less than 100 will make a big difference in sales, especially there are many sets running this month, and one of them is very similar to Bleached.
The MOQ for the base is set to 500. numpad and spacebars are set to 150, because thats how the IC form reflects. I am not confident to list it at 1000MOQ because (see the line above), so I am trying to do giveaways to the community and GB participants to make this more appealing.
Seperate Numpad kit is always expensive for GMK keysets, not to mention the numpad kit here also includes UKISO.
I know the people wanted more compat will be upset seeing this kitting, I am sorry but this is my apporach to it.
Offline Chuttau
  • Formerly botallu
« Reply #199 on: Tue, 07 April 2020, 18:43:40 »
The prices will be fixed across the whole GB, as the refund policy has changed since then, also refunding to each GB participants is very time comsuming, there is no mass refund function on shopify and vendors have to manually refund to each order.
Instead we will giveaway more stuff as the number of order increases, details can be found on discord, or the GB thread that is coming up soon
