Author Topic: [IC] KAT Ice Dragon  (Read 52819 times)
Offline driftingbunnies
[IC] KAT Ice Dragon
« on: Tue, 04 February 2020, 21:04:38 »
Hey everyone! I've been wanting to show off a blue set that I've had in the works for a little bit. The theme is Ice Dragon but I wanted to use the eastern dragon rather than the western dragon. The kit images are just there to demonstrate the keys in each kit. We will be using the default KAT fonts for both regular alphas and Cangjie Alphas. I'll make sure to reach out to zfrontier about the novelty details to confirm if those are possible. I've reached out for some samples and hope to receive some in the next month or so. I don't have a deskmat designed for it yet but if there's enough interest, I'll look to get one done. Without further ado, KAT Ice Dragon!
IC Form
Kits
Deskmat
by caozheng_
Renders
Current list of changes to be made:
  • Update "Ice" character to be the Chinese character rather than Japanese
  • Add R4 Esc
  • Add Norde Kit (North)
  • Separate 40s/Ortho
  • Add mod colored Pipe key for UK ISO
  • Change mod pipe keys to alpha kits
  • Add legends to ergo kit
  • Change mod ~ keys to alpha kits
To dos:
  • Receive samples and feedback from IC
  • Get more renders
  • Get deskmat designed
  • Reach out to vendors
Special thanks
  • MetallicCharles for the quick renders
  • eskimojo for the help with his ai files to get me started
  • MechsOnDeck discord for the feedback
  • DriftMechanics team for the feedback
  • OCM for the awesome novelties and icon mods
Please fill out the IC Form! Thanks!
Discord
Instagram
Please add this to your sig to show support! Thanks!
Code: [Select]
[url=https://geekhack.org/index.php?topic=104535.0][img width=640 height=98]https://imgur.com/3IIsqRC.jpg[/img][/url]
« Last Edit: Tue, 06 October 2020, 15:02:03 by driftingbunnies »
Offline Hisui
  • Team Yeen
Re: [IC] KAT Ice Dragon
« Reply #1 on: Tue, 04 February 2020, 21:10:36 »
I like this but with the current name "Ice" I think a lighter blue would fit better or rather if this was called "Water dragon". Either way, I like the set and its theme pretty good, it's great to see more KAT! Best of luck  :thumb:
Offline KingOfMemes
« Reply #2 on: Tue, 04 February 2020, 21:18:08 »
Kat set. Count me in for colevrak, mods, and alphas at least. Other sets will be a game time decision
Offline Rensuya
  • Blue is my spirit animal
    • Link to the discord!
« Reply #3 on: Tue, 04 February 2020, 21:36:25 »
1. KAT profile
2. Blue colorway
All I needed to know. But for real it looks good, count me in  :thumb:
Offline Audiobs
« Reply #4 on: Tue, 04 February 2020, 22:00:34 »
Nice set! So we are inventing our own Kanji or Chinese character now? That doesn't look like 'Ice' to me.
« Last Edit: Tue, 04 February 2020, 22:02:50 by Audiobs »
« Reply #5 on: Tue, 04 February 2020, 22:25:49 »
haha yes! just kidding. It's the Japanese character. I'll get it fixed soon.
Offline teexcue
« Reply #6 on: Tue, 04 February 2020, 23:57:45 »
This looks great, love the blue! Count me in.
Offline Tefrem34
« Reply #7 on: Wed, 05 February 2020, 00:07:04 »
Are the mods pure white or a very light grey? It would be nice to see some color samples along with the kits. It would be nice if this set makes it.
Offline chanchan
    • atxkb
« Reply #8 on: Wed, 05 February 2020, 00:31:36 »
You have my wallet.
Offline YMwoo
« Reply #9 on: Wed, 05 February 2020, 00:36:28 »
really loving the colors! I'm a big fan of dark alpha and light mods.
However, even though it might be hard, is there any possibility for the following kit?
- icon mod Ergo
- Mono Korean Alpha
It'll be perfect if you have those two  ;D
Offline psxndc
« Reply #10 on: Wed, 05 February 2020, 00:49:06 »
Eh, I'm more of a weeb, so I'll pas... *sees Colevrak support* I'm in.
Ortho. Always.
Offline Joaquox
« Reply #11 on: Wed, 05 February 2020, 01:30:43 »
NorDe kit and I'm in!
Offline Vireca
« Reply #12 on: Wed, 05 February 2020, 03:07:38 »
2 things
Ortho and 40s sets should be 2 kits, justo buy whatever you need. The ortho kit should have two 2u spacebars and two 1.5u spacebars. This is more some ergos like Kyria or Corne
If you are going to make Control un R2 in the capslock position, make a capslock key for R1 too. Same with a FN for R2
Also, theire is no ESC key in R4. You need it for 60-65% users
« Last Edit: Wed, 05 February 2020, 03:12:10 by Vireca »
Offline D3LTA
« Reply #13 on: Wed, 05 February 2020, 07:17:53 »
Thanks for adding Colevrak kit support. Will definitely keep an eye on this IC.
Offline Shurakai
« Reply #14 on: Wed, 05 February 2020, 07:25:18 »
I love the colors and the novelties so far. We need more dark alpha sets like this.
Also, second the ortho comments here:
2 things
Especially the 2 1.5 and 2u space key part. That would be great for split orthos like the Corne and Kyria, but also for some ortho layouts that just use a 2x2u layout.
Offline Galdom
« Reply #15 on: Wed, 05 February 2020, 07:44:09 »
Amen on that!  :-*
« Reply #16 on: Wed, 05 February 2020, 08:13:11 »
2 things
I'm not sure I understand the Caps lock in R1. Would it be a 1.25u or 1.5u? Do people even use that? Also, Ctrl for R2 is already kind of niche, I would think FN R2 for 1.75 would be even more. People would probably just use Ctrl instead.
I appreciate the feedback though. I'll look to separate the 40s/ortho, add spacebars for ortho and add the ESC for R4.  Thanks!
Offline depletedvespene
    • Keyboard-related resources.
« Reply #17 on: Wed, 05 February 2020, 12:14:46 »
2 things
Some people swap the Ctrl and Caps Lock keys (so Control will be between Shift and Tab, as was the custom before the Enhanced layout came out); if using an R3 (R2 in KAT parlance) Ctrl keycap for the position, the keyboard will now have three keys labelled as such, but one (the bottom left corner key, typically) will not really be Ctrl). Some sets, most notably sets from Originative, include two R4 (R1 in KAT parlance) Caps Lock keys, in 1.5U and 1.25U sizes, to provide for this.
Offline kzwai
« Reply #18 on: Wed, 05 February 2020, 19:05:31 »
i am a weeb but i like the color scheme. am in
Offline Vizir
« Reply #19 on: Thu, 06 February 2020, 14:33:45 »
any plans on adding legends or icons to the ergo set?
Offline vaf1en
« Reply #20 on: Thu, 06 February 2020, 14:44:59 »
I like these colours; they're quite subtle.
Would like to see your take on accents – I am thinking a lighter blue, maybe even turqoise.
Offline dmatx1
« Reply #21 on: Thu, 06 February 2020, 16:08:55 »
Nice colors and it has text mods variant of the 40/ortho set :thumb:
Offline honoka
« Reply #22 on: Fri, 07 February 2020, 01:27:13 »
I would love to see blue color mods aswell for a uniform look
Offline tanega
« Reply #23 on: Fri, 07 February 2020, 06:58:47 »
Hi very nice set !
Could you consider adding an international kit similar too the one in othe Kat GB? Keyreative moq principle makes it possible to offer maximum compatibilities for European regional layouts, it would be sad to drop it.
Offline chriszhu
  • (* ̄(エ) ̄*)''
« Reply #24 on: Fri, 07 February 2020, 08:37:47 »
Lovely subtle colours!
« Reply #25 on: Fri, 07 February 2020, 09:15:05 »
Hi very nice set !
I'll try to work on including int'l kits. Which region are you looking for?
Offline DaMnED
« Reply #26 on: Sat, 08 February 2020, 11:42:29 »
South kit plz. Insta buy.
Offline honoka
« Reply #27 on: Sat, 08 February 2020, 11:53:11 »
nordic kit aswell, probably called North
and as I asked for, blue mods
Offline YMwoo
« Reply #28 on: Sat, 08 February 2020, 23:06:25 »
hi, just want to make sure about my previous comment about Mono Korean Alpha, will it be possible?
I know it's a longshot, but I personally would love it.
also Korean dragon is considered as Eastern Dragon too anyway  :))
« Reply #29 on: Mon, 10 February 2020, 17:12:27 »
Hey! I think Mono korean alphas might be too much. i'm not sure if it would match with the novelties. I think it might look good separately but I don't think it fits as a whole. Thanks for your feedback though!
Offline YMwoo
« Reply #30 on: Mon, 10 February 2020, 18:43:29 »
Understood. Thanks for confirming.
If I may have some other question/suggestions:
  • Any ETA when you will run this?
  • 1u keys for inner column on ergo kits
will wait for the icon mods for ergo kits too. have some worries but will wait for your update first
Offline Vizir
« Reply #31 on: Mon, 10 February 2020, 22:22:42 »
Yes. R3/R2/R1 each 2x1u would be useful for inside row ergo kits.
Sent from my Pixel 4 XL using Tapatalk
« Reply #32 on: Tue, 11 February 2020, 14:30:24 »
I hope to spend some working on the ergo and splitting the 40s/ortho kits this week and next week.
I haven't heard anything from zfrontier about the samples but I'm 99% sure they're still not really operating due to the coronavirus. I update the thread once I receive more information from them. If they're able to do it, I'll get quotes and reach out to vendors to see when they have slots available. If there are any vendors interested, please point them my way. Thanks!
Offline Mcnos
    • GMK Fuyu
« Reply #33 on: Tue, 11 February 2020, 15:03:55 »
Can confirm that they are not operational this week
« Reply #34 on: Tue, 11 February 2020, 21:02:50 »
Updated ergodox to include icons, let me know how they look. Thanks!
Offline YMwoo
« Reply #35 on: Tue, 11 February 2020, 21:49:17 »
The expanded kits are very nice  :thumb:
Was hoping at least R2 enter but I know the kits here are the common layout so i guess can't really complain.
I can't decide whether i like this or blank one better :))
Offline terrad
« Reply #36 on: Wed, 12 February 2020, 04:28:51 »
Any possibility of blue mods and white alphas? Considering it's KAT extra kits won't really hurt
Sent from my SM-G955F using Tapatalk
« Reply #37 on: Wed, 12 February 2020, 22:41:04 »
I'll have to play around to see if I like that combination but my initial inclination is to keep the dark alphas light mods look. There are so many sets that have the white alphas dark mods combo already so it would be hard to differentiate if I do include that.
It would also essentially double the kits so blue text and blue icon mods, blue 40s text and icon mods, blue ortho text and icon mods, blue novelties, and blue ergodox.
Offline lakeboredom
« Reply #38 on: Thu, 13 February 2020, 02:13:11 »
Love this, especially the white mods. Not sure if it's possible but I would kill for left-aligned icon mods.
Offline NoChance
« Reply #39 on: Fri, 14 February 2020, 10:06:17 »
The White is great looking.
Offline Aerospiritual
« Reply #40 on: Sat, 22 February 2020, 17:07:39 »
Oh man I love these colours. Count me in!
Offline Rew23
« Reply #41 on: Sun, 23 February 2020, 00:56:24 »
Set looks great. Loving all the new KAT profile colorways coming out and this blue and white combo is one my favorite. Are these going to be ABS doubleshot or PBT?
Offline dmatx1
« Reply #42 on: Sun, 23 February 2020, 00:58:25 »
PBT dyesub and reverse dyesub.
Offline titoepfx
« Reply #43 on: Sun, 23 February 2020, 02:46:25 »
40s/ortho needs another 2u keycap and also consider seperating them
Offline thedavefulton
« Reply #44 on: Thu, 05 March 2020, 08:31:29 »
*sigh* Dude, come on! I wasn't gonna buy any more keycaps for awhile  :mad:
I really dig this colorway! My only note/request would be that the icons are a bit plain for my taste. While they look perfectly nice, I would hope for something a bit more... designy? Is that super helpful?  :D
Seriously though, I'd point you to the last two sets I picked up (KAT Milkshake and Eternal) as examples of what I mean. I understand that a major redesign may be unrealistic but could I suggest expanding the novelties a bit? Perhaps just enough for an HHKB layout? *subtle wink*
Regardless I think you've got me for 2 or 3 kits ;D
Offline Felt
« Reply #45 on: Thu, 05 March 2020, 10:02:54 »
Agreed with ^^.
Set looks bomb, novelties could use work...
« Reply #46 on: Sat, 07 March 2020, 16:32:57 »
Appreciate the feedback. I'm not really an illustrator so I wanted to keep the icons easy for keyreative to use. These are the same icon mods that OCM created for the KAT WoB. Personally I'm still hesitant in keyreative's ability considering that they've delivered one set as of today so I kept fonts and icons as default as they can be.
Agreed with ^^.
Appreciate the feedback. I'm not sure what other novelties might work, any suggestions?
Offline nasp
« Reply #47 on: Sat, 07 March 2020, 20:34:21 »
They've delivered one KAT set as of today. I think that distinction deserves to be mentioned but I agree with your hesitancy nonetheless. That being said, I do prefer these more standard icons over something like KAT Atlantis.
« Reply #48 on: Sat, 07 March 2020, 21:26:22 »
I've finished updating all the kits so please take a look over them if you're interested in this set. Let me know if I'm missing any. If you've already made a kit change request but don't see it up there, please make a post on the thread since so that I'm aware. It's possible that I missed it while going through the comments/feedback. Thanks!
For those who requested a FR kit or South Kit, based on the numbers from other KAT sets, I've decided to not include those here.
Offline YMwoo
« Reply #49 on: Sat, 07 March 2020, 23:16:30 »
personally, after looking at many sets, I think ergo user (and to some extent, 40's/ortho) are the type of users that like to mess up with their layout to find the "best" way.
that makes a lot of these common legends are incorrect to use which can be kind of annoying.
this also applies to 65% users with the rightmost column, but usually it can be covered with novelties.
so if possible, i do like the idea of having a custom, semi-nonsense, icon like Atlantis / Godspeed.
This move can also reduce the number of keys per set which will help in reducing the total cost (since apparently, ergo kit for KAT sets are increasing for each release).
that being said, i do like the very clean, simple default icons.
