Author Topic: [IC] IRON180 by Smith + Rune (GB Nov 14th, 10am EST worldwide!!)  (Read 346749 times)
Offline voxkey
Updates, Nov 11th, 2020
The Group Thread: https://geekhack.org/index.php?topic=109513.0
Updates, Oct 24th, 2020
Colors announced! DeskHero will also be joining us for this run, having 100 additional boards for sale! Go Canada!
The IRON180 will be offered in the following colors, each available with an optional brass base.
- Graphite
- Midnight Green
- E-White
Updates, Oct 9th, 2020
Vendors, quantities, and pricing announced!
CannonKeys (200 boards, region locked)
$585 w/aluminum base
$835 w/full brass base
DeskHero (100 boards, region locked for the first 5 minutes)
780 CAD w/aluminum base
1115 CAD w/ full brass base
MyKeyboard.eu (100 boards, region locked)
589€ inc/VAT w/aluminum base
845€ inc/VAT w/full brass base
iLumkb (300 boards, region locked for the first 5 minutes)
799 SGD w/aluminum base
1138 SGD w/full brass base
Group Buy Date: November 14th, 2020, 10am EST
Join Smith + Rune Discord
Follow us on Instagram
Iron180 Features
The Iron180 is the second board in the IRON series, sharing the same aesthetic and design language of our debut board, the Iron165.
  • 7 Degree Typing Angle
  • Full Gasket Isolation Mount
  • Low-profile Front Height (less than 17mm)
  • Seamless Case Design
  • QMK/VIA compatible PCB, designed in collaboration with Gondolindrim
  • Unified C3 USB-C daughterboard (centered on case)
  • Optimized plate for consistency on every key press (see analysis below)
  • Color-matched Rune artisan keycap
  • Polished stainless steel Rune in base
Iron180 Colors
Each board can be purchased either with a black anodized aluminum base or with a full brass base (media blasted, UV coated).
  • Graen (Midnight Green)
  • Graphite
  • E-white
Supported Layouts
There will be three plate layout options, semi-fixed. All plates support split backspace and split right shift. ISO plates may not be available from all vendors.
  • Tsangan (7u bottom row)
  • ANSI (6.25u bottom row)
  • ISO
What's In The Box
  • Iron180 Keyboard
  • Brass Plate
  • PCB, USB-C Daughterboard, and JST cable
  • Stainless and Black Screws (for different aesthetics)
  • Screw spacers (for flush mount look)
  • Gaskets
FEA Plate Analysis
Keyboard plate FEA analysis was needed to measure deflection and try to achieve a uniform plate deflection distribution across the keyboard.  This was a continuation of the work done on our Iron165 Keyboard.  You can read more up on it here and our testing methodology:
https://geekhack.org/index.php?topic=101470.0
For the Iron180 I started with the same basic principles but instead of starting from scratch I imported a lot of the design features from the Iron165, added some relief cuts to better suit a TKL and began modeling.  The first results were less than ideal, as expected working with a much larger plate.  Here are the initial results.
Results had a large range from 0.2532mm down to 0.0990mm.  The upper relief cuts needed to start disappearing quickly to even this up.
Much better in the upper left, but bottom row still wasn’t where we wanted it.
Horizontal cuts below the ‘B’ key really helped get them in line.  Plus added a lot of cuts between mod keys
Removed more relief cuts from the top, and added a connection in one to lower the right bracket key value.  Also added a connection beneath the ‘B’ key but it added way to much support.
More small changes, reverted ‘B’ key connection
More a quality of life, replaced all the ugly cuts at the top with the mod relief cuts, cleaned up more spots.
This was intended to be the final one but I wanted to run more test to see what difference adding some cuts to the number row would make on the alphas below them.
Finalized plate!
Monochrome - Renders by MacSurfy
Graen - Renders by Abec
Botanical - Renders by Abec
Special Thanks
  • LBaron, the other half of Smith + Rune!
  • Mods, admin, and of course, the Inner Circle, best team ever!
  • Everyone who has supported us this far. We couldn't have got to this point without you!
« Last Edit: Fri, 13 November 2020, 14:36:29 by voxkey »
Offline voxkey
Re: [IC] IRON180 by Smith + Rune
« Reply #1 on: Sun, 22 March 2020, 19:26:13 »
reserved
Offline Zeelobby
« Reply #2 on: Sun, 22 March 2020, 19:26:34 »
Fuuuuudge. Ok. Gotta get in on this. Been wanting a tkl this year.
Offline jmsp0511
« Reply #3 on: Sun, 22 March 2020, 19:27:58 »
Looking good looking good!
Offline Jaltr
« Reply #4 on: Sun, 22 March 2020, 19:30:20 »
Very excited!
Offline Crack85
« Reply #5 on: Sun, 22 March 2020, 19:30:28 »
In!! Looks sweet
Sent from my Pixel 3 XL using Tapatalk
Offline Jaltr
« Reply #6 on: Sun, 22 March 2020, 19:30:54 »
How limited will this be? 100 for NA like the 165?
Offline urbantheii
« Reply #7 on: Sun, 22 March 2020, 19:31:07 »
GIMME THE IRON
Offline ttom
  • Formerly tvaro
« Reply #8 on: Sun, 22 March 2020, 19:31:28 »
really regret not getting the 165, will definitely try my luck with this
Hoarder Collector and designer
Classifieds
Offline Furikurichemy
« Reply #9 on: Sun, 22 March 2020, 19:31:58 »
ooooh yesss.
Offline pengoot02
« Reply #10 on: Sun, 22 March 2020, 19:33:05 »
with your plate it seems like you started out with keycults public no.2 plate files 🤔
Offline stopitsme
« Reply #11 on: Sun, 22 March 2020, 19:36:03 »
100% in for this
Offline Tekniqs
« Reply #12 on: Sun, 22 March 2020, 19:36:36 »
oh my!
Offline terrad
« Reply #13 on: Sun, 22 March 2020, 19:36:48 »
The second piece of my IRON collection!
Sent from my SM-G955F using Tapatalk
Offline self
« Reply #14 on: Sun, 22 March 2020, 19:42:14 »
Very interesting!
Will try to join the GB!
Sent from my ONEPLUS A5010 using Tapatalk
Offline Captain Shwah
« Reply #15 on: Sun, 22 March 2020, 19:43:18 »
uhyup, lookin really good!
Offline iNViSiBiLiTi
« Reply #16 on: Sun, 22 March 2020, 19:44:02 »
how come you never measured the spacebar? I'm afraid it's going to feel stiff because of that mounting position.
60%: Prophet, GSKT-00 x2, Poly GSKT-00-Z, Weaven, Sangeo60, Unikorn R2.1, Ciel60, DNworks DM
TKL: TGR Jane V2, Jane V2 CE, KFE, Noxary 280 S, Acrylic Unicorn, Igris V1, LZ-GHv2, Bias R2, HMKB
Misc: Bulgogi Board (VA104M), Belle En Rose, Treeleaf 917, TGR 910 ME, ai03 Vega
Offline evorus5
« Reply #17 on: Sun, 22 March 2020, 19:46:29 »
Yeeeeeahhh.
I'ma need one.
Offline ninlawen
« Reply #18 on: Sun, 22 March 2020, 19:49:01 »
Consider my interest checked.
Offline Lormania
« Reply #19 on: Sun, 22 March 2020, 19:49:47 »
Looks great!
Offline baobaozi
« Reply #20 on: Sun, 22 March 2020, 19:55:15 »
Looking good!
Offline Hawksmoor
« Reply #21 on: Sun, 22 March 2020, 20:03:07 »
Yep. Looks amazing. 100% in.
Can't come soon enough
Offline Jae-3soteric
  • https://www.youtube.com/channel/UCAIHiFKJt69HNad6r
    • Jae | Top Clack
« Reply #22 on: Sun, 22 March 2020, 20:10:19 »
Yes.
What else do I need to say?
Sent from my iPhone using Tapatalk Pro
Offline 7empest
  • ༼ つ ◕ ◕ ༽つ
« Reply #23 on: Sun, 22 March 2020, 20:11:14 »
Very nice. I am interested!
Offline lbaron
« Reply #24 on: Sun, 22 March 2020, 20:12:12 »
I just measure it and it's is a little stiffer than the rest of the alphas.  A little more centered around the gasket relief cut on the Tsangan buttom.  I will keep working and tweaking it for the spacebar to make it more consistent with the alphas.  Thank you for raising the question :)
Offline GPrix
« Reply #25 on: Sun, 22 March 2020, 20:13:31 »
My feelings were a little hurt when I missed the first round, now I'm completely salivating! Heck yes with this one. 💯
Offline blizzara01
« Reply #26 on: Sun, 22 March 2020, 20:15:12 »
I fooled myself that this will be a 1800 layout based on the name. Any renders of bottom?
Offline DeadFalcon
« Reply #27 on: Sun, 22 March 2020, 20:18:53 »
...need...
Sent from my Pixel 3a XL using Tapatalk
Offline bthezebra
« Reply #28 on: Sun, 22 March 2020, 20:29:40 »
Love the philosophy of 165 def would like to try the TKL
Offline Aiwanei
    • ThocKeys.com
« Reply #29 on: Sun, 22 March 2020, 20:34:47 »
You had me at TKL.
ThocKeys.com
Offline kiyoboard
  • https://www.youtube.com/kiyoboard
« Reply #30 on: Sun, 22 March 2020, 21:03:19 »
Really liked Iron165 but I am a TKL user. I will definitely try to snatch one of these :)
Offline evorus5
« Reply #31 on: Sun, 22 March 2020, 21:05:29 »
Wait. But does the plate reach convergence in your FEA!?
Offline Abdallah9
« Reply #32 on: Sun, 22 March 2020, 21:10:25 »
I am so excited for another S&R board. Just one question, will you offer WKL as an option?
Offline voxkey
« Reply #33 on: Sun, 22 March 2020, 21:15:59 »
Yep! We just haven't had it rendered just yet!
Offline psvntrm
« Reply #34 on: Sun, 22 March 2020, 21:18:26 »
Hot swap?
Offline Novafish
« Reply #35 on: Sun, 22 March 2020, 21:18:44 »
wkl?  :-*
Offline are2dcrz
« Reply #36 on: Sun, 22 March 2020, 21:28:07 »
in! going to be my first custom, if i get lucky
Offline hmfactor
« Reply #37 on: Sun, 22 March 2020, 21:37:14 »
oh rip my wallet i guess
Offline upas
« Reply #38 on: Sun, 22 March 2020, 21:49:48 »
Nice.
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #39 on: Sun, 22 March 2020, 21:52:16 »
 I assume the GB for this will be a bloodbath, but I'll start saving up anyway.
Offline ilikerustoo
« Reply #40 on: Sun, 22 March 2020, 22:21:05 »
I'm in
Offline Langelandia
« Reply #41 on: Sun, 22 March 2020, 22:26:05 »
lulwut
First - nope. that's not how it was done.
Second - you intentionally typed "public" - had they used them (which they didn't) why is your comment even valid? They made them public for people to use...
"I see you've used the Drop-owned public forum, Geekhack, to post your [IC] 🤔" <---this is how you sound
Apologies for being spicy - but your comment does nothing positive for anyone.
Offline Cardistryan
« Reply #42 on: Sun, 22 March 2020, 22:36:51 »
Would love to see the smith & rune logo somewhere on the front, even if subtle. I really want that extra designer detail like the iron165 if you would consider it :)
Offline Surefoot
« Reply #43 on: Sun, 22 March 2020, 22:56:59 »
That dark green color in the first picture is amazing. Hope it's to be one of the options.
Offline lbaron
« Reply #44 on: Sun, 22 March 2020, 23:01:48 »
So for a logo and f13, our idea is to include an artisan anodized and matched to the color of the top case for a couple reasons.
Not a lot of keycaps sets cover f13, this way it blends right into the case and doesn’t stand out like a sore thumb. Second, if you don't like branding cause I know there are TKL purist you can remove it all together. And lastly, if you do have a F13 keyset you can simply use F13 key and move it to escape or another location if you like the logo.
We liked the idea of people being able to reuse the badge or extra badges purchased with the Iron165 but couldn’t find a good fit for it on the board.
Offline WeathermanKarlos
« Reply #45 on: Sun, 22 March 2020, 23:09:44 »
Looks great!
IMO, a logo engraving above the arrow keys generally looks good on TKLs. I think the artisan idea is neat, but I joined the aeboards Aegis GB and they did a similar thing with a custom Rama cap. I love the board, but have literally never seen a picture with someone using the keycap. Just my two cents.
Offline Shutter_Shock
« Reply #46 on: Sun, 22 March 2020, 23:13:34 »
I think it’s a great idea. I agree with your logic and love the flexibility to have the branding if you want it and skip it if you don’t. Plus having a cap for F13 when sets don’t cover it. Brilliant!
Offline DurtyKurty
« Reply #47 on: Sun, 22 March 2020, 23:20:02 »
This is exactly what I've been looking for to go with the GMK botanical that I ordered! Either that dark green, or that white would be amazing!! Looking good, will buy.
Offline jpg2401
« Reply #48 on: Sun, 22 March 2020, 23:25:25 »
I cannot wait for the WKL renders!
Savage 65 | GSKT-00 || Valhalla | X60 V2
Offline PotatoTM
« Reply #49 on: Sun, 22 March 2020, 23:42:32 »
Am a fan of f13 keys in general, looking forward to this!
