Author Topic: [IC] KAT Shogōki [Deskmat updated]  (Read 76547 times)
Offline Kyosurai
Re: [IC] KAT Shogōki [Deskmat updated]
« Reply #100 on: Wed, 29 July 2020, 19:00:18 »
Sorry for the lack of updates.
Deskmat added. Enjoy ;)
Offline Shadowtrance
« Reply #101 on: Thu, 30 July 2020, 15:23:21 »
Loving it!
Would love to see full board coverage, numpad needs love too.  :p
And some of us do actually have close to full size boards (melody96 here).
I suggested it in the form anyway.
Looking forward to more pics and progress.  :thumb:
Offline Willtato
  • I like small Keyboards
« Reply #102 on: Fri, 31 July 2020, 17:06:59 »
I'm looking to build a 40%.  So far your 40% set seems to be the only one which has all the key sizes I need (with the right printing/function).  The problem is that the rows may not match up to what I intended.  So I'm curious what the profile on the caps are, if I were to essentially 'mix and match rows'.
Thanks
(Prior to this, my only option was to splurge on multiple sets or go the cheap option of a blank DSA set.)
Sent from my HD1913 using Tapatalk
Offline Oddstag
« Reply #103 on: Fri, 31 July 2020, 17:17:54 »
Oh, so that deskmat is a must buy huh? Wallet is getting pretty dinged up these days...
Offline psxndc
« Reply #104 on: Sat, 01 August 2020, 04:23:30 »
Looks dope! ne icon mods for ortho?
Will work on it tomorrow for Ortho and Ergos :)
Did icon mods for ortho ever happen?
Ortho. Always.
Offline Kyosurai
« Reply #105 on: Sat, 01 August 2020, 11:53:14 »
It will. I'm terribly sorry on the lack of updates on the kits due to work. I'll try to update it up by end of next week.
Thanks for your interest on the set! :)
Offline Masticccc
« Reply #106 on: Fri, 14 August 2020, 08:18:18 »
Any update yet for the kits, estimate pricing and gb date?
Offline arq1999
« Reply #107 on: Sat, 15 August 2020, 21:54:09 »
I kind of regret getting gmk mech-01 now. This looks really good!
Offline nuldabz
« Reply #108 on: Sun, 16 August 2020, 00:36:07 »
Definitely in for a deskmat or two! Well done with these designs
Offline Emolokz
« Reply #109 on: Sat, 22 August 2020, 01:53:43 »
Interested, would like to see more vibrancy in the colors in the samples for sure.
Offline MIXO Cables
« Reply #110 on: Sun, 13 September 2020, 22:59:53 »
looking like mecha01  :) :)
Offline Zanhana
« Reply #111 on: Wed, 07 October 2020, 21:09:15 »
Such a fantastic colorway and the kitting looks great! I'd love to see this happen, especially with KAT profile. Any updates?  :)
Offline low_key_keyboards
  • I like to make custom keyboard cases.
    • Low Key Keyboards
« Reply #112 on: Wed, 07 October 2020, 21:53:32 »
New deskmats are absolutely sick.
I would love the hexagon pattern to cover more of the mat if possible.
Offline Hellenic94
« Reply #113 on: Fri, 30 October 2020, 08:03:15 »
Will be definitely getting 2 deskmats, maybe keycaps too but already have cyberspace and mecha-01.
Offline zeejet
« Reply #114 on: Tue, 03 November 2020, 10:13:30 »
Would have loved kata subs but I guess that doesn't happen much with KAT keycaps?
Offline kidviddy
    • 駄日記
« Reply #115 on: Tue, 03 November 2020, 11:03:19 »
This is a really nice set! I like the hiragana look, but I agree that Katakana may suit the Eva theme better.
While you’re looking at the kana set, please consider making the following changes/additions (here I have used the standard notation of using R1 for the top row and R4 for the bottom, which appears to be the reverse of how you have the rows labelled):
  • Replace R1 む with ー, or add an R1 ー key. This is the syllable extending line character, not the kanji for “1” or anything like that.  It’s often inside a dotted box on Japanese keyboards.
  • Add an R3 む key
  • Add an R4 ろ key
These keys are required for correct placement for people who are actually typing using kana input; also, without the R3 む, ISO users won’t be able to use the kana set either. For kana-only sets, I believe these changes represent a nice compromise that allows JIS, ISO, and ANSI users all to get the most out of the set without having to add to many keys, and I would love to see this become the standard layout for those creating Japanese alpha sets.
If you want to support JIS users further, the inclusion of a 2U shift (which you have! Thank you!) allows for the extra ろ key on the bottom row, and a 3U space bar allows space for the English/Kana keys that go either side of the space bar on a Japanese keyboard.
Thanks for your consideration!  Please feel free to hit me up if you have any questions about JIS layout.
Thank you for your suggestions! I'll take in the suggestions and add the keys as optional keys :)
I know you’ve been busy and haven’t been able to post kit updates recently, but I just wanted to confirm that these changes are likely to make it into the set.  I am considering getting the matching shogoki switches but I only want to do that if I know this keyset is going to be usable for me, too ;-)
KAT Monochrome is a good example of a full kana keyset, if you want a guide to which keys should be included (I would recommend maintaining the angled version of ゛ you currently have rather than going vertical like KAT Monochrome, though; that’s a very specific design choice).  In case you ever do decide to explore sublegends, konstantin has a great guide to the various layouts involved.
Finally, I see you have pretty good international support including North, South, and French sets.  I would love to see a JIS kit so I could use standard alphas on a Japanese-layout keyboard.  If it’s too late for this, fair enough, but if this is something you’d consider please let me know and we can go over the keys that would be required. Feel free to contact me via DM or Discord, or just reply in this thread.
Offline grabmienutz
« Reply #116 on: Wed, 04 November 2020, 10:05:53 »
This set looks dope as hell, pls get a canadian vendor :D
Offline Grog
« Reply #117 on: Tue, 10 November 2020, 13:36:09 »
It's been years since I watched Eva. This set is definitely hitting nostalgia for me. Looks great!
Offline Jasonissm
« Reply #118 on: Mon, 23 November 2020, 06:10:51 »
Any updates on this? Got my Shogoki switches ordered and would love to get especially the deskmat!
Offline v683
« Reply #119 on: Mon, 23 November 2020, 22:32:06 »
Have you got any renders for the red alpha set? I wouldn't mind the options for red (ortho) mods and colevrak.
Offline bryoz
« Reply #120 on: Mon, 30 November 2020, 06:16:24 »
Hey - looking forward to this. Any updates?
Offline geewizwow
« Reply #121 on: Mon, 30 November 2020, 06:25:30 »
Love this! Fully onboard if it runs, even if it's just a base kit with alphas, colorway is great
Offline underling
« Reply #122 on: Tue, 08 December 2020, 18:46:15 »
+1 wishing for updates and this would be a "for sure" buy for me...
*please run this*
Offline -janitor-
« Reply #123 on: Mon, 14 December 2020, 18:56:15 »
100% in.
Offline kajahtaa
« Reply #124 on: Mon, 14 December 2020, 21:28:20 »
is this dead ?
Offline Kyosurai
« Reply #125 on: Thu, 24 December 2020, 10:08:07 »
is this dead ?
Not really.. I just got real busy due to the end of my semester and was focusing on my finals and assignments.
Novelties (Enter key and Backspace key) are kinda done.
I'm sorry for the lack of updates lately.. I'll add some sneakpeek for the novelties by end of the year. Thanks!
Though, I might put this project on hold until KAT's QC and Delay issues are solved or gets better. Nonetheless, I'll continue updating as I continue working on the novelty.
Merry Xmas everyone! :) Thanks for your continuous support on this set.
P.S.: Would a "Shinji, Get in the Robot" for the spacebar be of interest to anyone? hahaa
Offline Sunriz3D
« Reply #126 on: Mon, 04 January 2021, 20:43:13 »
Looking good ! hope your finals went fine :)
Cheers
Offline LordOwen
« Reply #127 on: Mon, 18 January 2021, 06:37:45 »
Happy New Year! I'm looking forward to (hopefully) a GB in 2021 :)
Offline ManoliVisuals
« Reply #128 on: Mon, 18 January 2021, 11:14:32 »
Love this alot, are you considering doing novelties though?
Offline Havattack
« Reply #129 on: Mon, 18 January 2021, 12:39:47 »
Would of preferred the far superior sub-legends over mono, and Katakana over Hiragana.
Offline Oddstag
« Reply #130 on: Fri, 26 March 2021, 06:24:54 »
Hey is this still a thing?
Offline atyxiao
« Reply #131 on: Wed, 31 March 2021, 09:57:44 »
Just stumbled across this and fingers crossed for a GB this year! Missed out on Mecha-01 but this looks so much cleaner
Offline thelateclacker
« Reply #132 on: Sat, 17 April 2021, 04:01:34 »
i might be in the minority here, but imo the purple is a little too super neon.  On the other hand the purple in the original renders are a little too muted.  Lookin at some source material and the purple looks a bit more in between these two.  Any chance the neon could be toned down just a tad??
Offline shirokori
« Reply #133 on: Sat, 17 April 2021, 06:16:14 »
I don't think the neon would look like that in a real world setting, is there any way to provide a reference for that?
Offline Oddstag
« Reply #134 on: Wed, 12 January 2022, 06:59:49 »
281150-0
« Last Edit: Wed, 12 January 2022, 07:01:45 by Oddstag »
