Author Topic: [GB] KKINGKKONG 660 Keyboard | closed  (Read 177387 times)
Offline chanmin kang
« on: Mon, 01 June 2020, 23:15:01 »
ㄲㅣㅇㄲㅗㅇ
660
by Chanmin Kang
Interest Check post
Hello, I'm Chanmin Kang. We are making a keyboard in Korea.
We designed and manufactured some keyboards, but we are not very well known abroad.
We are pleased to introduce KKINGKONG 660. This keyboard is all made in Korea for precision and quality.
This time, we brought a simple and slim design keyboard.
In line with the slim concept, we have reduced the number of parts and increased the choice of case color and plate material.
This relatively small keyboard over the TKL has advantages in good space utilization and portability.
We hope you like it.
Features
 - 7-degree typing angle
 - slim and simple design
 - Bottom mount plate
 - Centered USB Type-C Port
 - Aluminium, Brass, PC, Carbon fiber plates option
 - QMK supported PCB
 - 20mm height from the front
Included
Case
 - CNC machining 606X aluminum case
 - Approx. 2 kg weight
 - bottom-mount
 - Plates, PCBs and can be purchased additionally
 - Top and bottom can be ordered in two-tone colors differently.
Plate
 - Cherry MX switch support
 - The plate is fixed bottom using special fixing screws, giving a uniform feel.
 - You can choose between four plate types. Brass, aluminum, PC, Carbon fiber
 - The brass plate is made of a precision CO2 laser and has a deburring finish.
 - Large switches that usually don't fit well into the plate are also stably inserted.
PCB
 - QMK firmware Support
 - Cherry MX compatible
 - All SMD components are pre-soldered in the factory.
 - Switch, switch LED (Optional) soldering required
 - Standard, WKL layout compatible
Spring
 - For buyers only, we offer 70 compatible springs for Cherry MX for free.
 - You can choose between 50g, 57g, 64g, and 71g.
 - This spring, which we have produced, has passed the Vertical Profile Test, Lubricative Test, Surface Roughness Test.
 - We put a lot of effort into this spring, and it's made very precisely. The spring has an error rate of ±0.5 g. It is glossy and upright when compared to other springs.
Support layout
Options
Top Case type
 - Standard
 - Winkeyless
Top color / Bottom color
 - Anodizing: Black, Gray, Silver, Red, Blue, Purple, Orange gold, Metal Green, Rose gold, Champagne gold
 - Cerakote™: Black, White, Beige, Gray, Pink, Navy, Yellow
Plate color / material
 - Aluminium: Black, Gray, Silver, Red, Orange gold, Metal Green, Rose gold, Champagne gold
 - Brass
 - PC (Polycarbonate, transparent)
 - Carbon fiber
Pricing
 - Base kit - $240 (Anodizing, Cerakoat™ charges additional cost depending on the option)
 - Extra PCB - $35
 - Extra Plate - $30 (Aluminium)
Includes in Basekit (Anodizing Option)
 - 1x 606X Aluminium Top Case
 - 1x 606X Aluminium Bottom Case
 - 1x 606X Aluminium Cherry MX Plate
 - 1x KKINGKKONG 660 PCB
 - 1x DGL Spring pack (for Cherry mx, 70pcs)
※Can be modified as desired in the above configuration (additional cost incurred)
※Shipping charges are not included and the price varies depending on the destination.
Order here!
closed
https://forms.gle/ek1J4MxarBbLQLteA
When you have completed the order form, we will review the contents and send an invoice.
This process takes up to 24 hours. If the invoice doesn't arrive after a day, there may be something wrong. Please contact kkingkkongworks@gmail.com or DM.
Timeline
Group Buy will be open 2020.06.01 - 2020.06.15 ( 15 days )
Delivery will start in September.
We will do our best to meet the schedule.
But we don't know exactly what will happen in the future.
If there is a delay in the delivery schedule due to unavoidable reasons, we will notify you quickly.
Opportunity to get it quickly
[/s]
Before we started GB, we completed some keyboards.
Among the keyboards that have the Anodizing option selected, 20 of the keyboards that have been paid first will be sent first on July 1.
Amount error in Form was fixed.
Cerakote option is +$35 equal to top and bottom. Due to a typographical error that was only in the form
This was an error only in the order form, so $35 was normally requested for the invoice.
We apologize for any inconvenience. Please contact us by e-mail to modify, cancel or refund your order.
Gallery
Lubricated T1 switch, Brass plate
Anodizing Color (Silver, Red, Black)
Cerakote Color (Navy, White, Pink)
« Last Edit: Tue, 21 July 2020, 04:17:17 by chanmin kang »
Re: [GB] KKINGKKONG 660 Keyboard
« Reply #1 on: Tue, 02 June 2020, 11:38:45 »
Approved :thumb:
Offline logo4poop
  • Talk to me on discord @logoooo
« Reply #2 on: Tue, 02 June 2020, 11:39:45 »
looks nice, but why aren't you waiting until DGL tkl to be shipped?
LCK75 so lit
Offline Carlobv
« Reply #3 on: Tue, 02 June 2020, 11:46:57 »
Would it be possible to buy the pink kit in the pics to ship in July?  I can pay now.
Offline Mcnos
    • GMK Fuyu
« Reply #4 on: Tue, 02 June 2020, 11:49:19 »
Is there a weight? I see a placement on the back of the beige board
Also is the beige in the photos the cerakote option?
« Last Edit: Tue, 02 June 2020, 11:53:09 by Mcnos »
Offline nu_types
  • Formerly Iredeus
« Reply #5 on: Tue, 02 June 2020, 12:11:24 »
The beige board appears to be a different keyboard.
Offline ubmit
« Reply #6 on: Tue, 02 June 2020, 12:15:24 »
Could you confirm which type of aluminum this is? 606X is too vague
Also, why the left blocker is so thin?
« Last Edit: Tue, 02 June 2020, 12:16:56 by ubmit »
Lyn Whale | KFE CE | Frog | Singa | Dolice | Haus | Kei | Polaris | Prophet | Bongoneko
Offline beerafffe1
« Reply #7 on: Tue, 02 June 2020, 12:19:30 »
Any sample of the metal green color option?
Offline bobaboy
« Reply #8 on: Tue, 02 June 2020, 14:17:31 »
I am interested in buying but I would like to see what the color options look like. Can you post a picture of all the different color options?
Offline jiggyboybrian
  • Darling!
« Reply #9 on: Tue, 02 June 2020, 15:54:23 »
is the purple case color seen in the picture of the completed cases how it is going to look?
Offline marshskitow
« Reply #10 on: Tue, 02 June 2020, 16:06:31 »
It's a really good project, congrat's guys.
But i feel it miss picture for all the colors. With the name on it.
I'm colorblind and it's kinda hard to choose :)
I'll see.
Offline Jyobah
« Reply #11 on: Tue, 02 June 2020, 16:07:59 »
looks great, why no black cerakote for the top only the bottom?
Offline frostfiree
« Reply #12 on: Tue, 02 June 2020, 17:20:33 »
The right and left shift are the same size right?
Jane V2 | Jane V2 CE | Thermal | Kei | GSKT-00 | Duck Orion V3 | U80 | Salvation | 378 | HHKB | Cloudline | Bias | TKL One | Kaze | Jane V2 ME
Offline rooski15
« Reply #13 on: Tue, 02 June 2020, 17:20:53 »
Looks fantastic. I'd like to order, but I don't really see an estimated timeline, just a group-buy window. What's the expected production time?
Offline frostfiree
« Reply #14 on: Tue, 02 June 2020, 17:22:10 »
I believe in the form, it says shipping around September.
Offline rooski15
« Reply #15 on: Tue, 02 June 2020, 17:23:49 »
Ahh, thank you.
Offline jmsp0511
« Reply #16 on: Tue, 02 June 2020, 18:17:49 »
I love the board design over all, i'm a sucker for 660 layouts.
And I love the fact that it's super clean and nothing too fancy.
That said, this GB is lacking a lot of pictures, additional info, and typing test videos that showcase various popular switches at this time.
- Why is there no pictures of the bottom?
- Does this have a bottom weight? There is no mention of one, but I see a picture with the bottom weight cutout.
- How come there aren't more typing tests, more tests with various different switches would help this GB.
Again, I love this clean design. And sincerely hope this does well!!
More GB runners the better, at a time where custom keyboard demand is so high definitely helps this community.
I just hope there were more pictures, typing tests, and information regarding the bottom weight
Offline rooski15
« Reply #17 on: Tue, 02 June 2020, 18:19:08 »
Agree. Would be nice to have all the color samples before the GB ends.
Offline ullr
« Reply #18 on: Tue, 02 June 2020, 18:39:34 »
I really hate to add another request to this thread, but I'd like to see a photo of one with blockers with keycaps on
Keyboard looks great, I'm strongly considering joining.
EDIT: man it's a shame that the cerakote is so much more expensive :(
« Last Edit: Tue, 02 June 2020, 18:42:55 by ullr »
Offline Tree_
« Reply #19 on: Tue, 02 June 2020, 21:43:25 »
Is there an example of the purple ano?
I'm interested in the board and specifically mentioned purple on the IC form. I'm looking to match it with Laser or VoC and am hoping for a darker purple and not a more pink-purple.
Offline dRnRcRr
« Reply #20 on: Tue, 02 June 2020, 21:56:28 »
Looks really clean.
Offline Scottw
    • ScottW's Boards
« Reply #21 on: Tue, 02 June 2020, 22:06:58 »
Can you post a picture of the PCB?
You mentioned LED indicators. Where would these be visible on the case?
« Reply #22 on: Tue, 02 June 2020, 23:00:47 »
Pink is a cerakote. It will be shipped in September.
« Reply #23 on: Tue, 02 June 2020, 23:04:08 »
« Reply #24 on: Tue, 02 June 2020, 23:13:56 »
Blue and purple are new colors added by GB since IC.
We are sorry that we cannot show you about this color yet. We will update soon.
« Reply #25 on: Tue, 02 June 2020, 23:14:47 »
It is exactly AL6061.
The blocker of WKL is equal to 0.25u on both sides.
« Reply #26 on: Tue, 02 June 2020, 23:19:16 »
I'll see.
We are sorry for our lack of consideration. We offer 17 color options above and below. There were so many that we couldn't work with all the keyboards we had in different colors.
We will create a reference image through image editing. However, this will take some time.
« Reply #27 on: Tue, 02 June 2020, 23:20:02 »
Sorry. It was our mistake.
Currently selectable. If you fill out the form, you can edit it.
« Reply #28 on: Tue, 02 June 2020, 23:31:55 »
The LED on the capslock switch acts as an indicator.
« Reply #29 on: Wed, 03 June 2020, 00:05:20 »
When we are in the morning, foreign countries are usually night or dawn.
There are time zone differences, and we have 10 times more to deal with than our original estimates.
 We are checking one by one. All inquiries will be processed in sequential order, so if you are missing, please send it again!
really busy handling these! So we haven't sent an invoice yet. sorry
We start sending invoices in about 4 hours.
Invoices are sent in the order in which the forms were completed.
(Because we write invoices in the order in which the forms were created)
The first 20 payments will be sent sequentially from July 1.
And we will upload color samples and additional typing videos tomorrow!
Offline jmsp0511
« Reply #30 on: Wed, 03 June 2020, 00:25:43 »
Thank you! and can you also take some pictures of the bottom as well?
And does it have an option for a weight at the bottom?
Offline MechGroupBuys
« Reply #31 on: Wed, 03 June 2020, 01:27:50 »
Hi,
The date on the google form says it is ending June 15th. But your GH thread says it is ending June 9th. Could you please clarify?
Offline delrn
« Reply #32 on: Wed, 03 June 2020, 02:06:57 »
Quick question, which shipping company are you going to use? (to Germany in particular if that matters)
Offline Vaudevi77ain
« Reply #33 on: Wed, 03 June 2020, 03:13:39 »
Hi, is there a sample of the rose gold?
Offline paulgali
    • SKME
« Reply #34 on: Wed, 03 June 2020, 05:29:35 »
Are there images of the plate design and mounting points?
« Reply #35 on: Wed, 03 June 2020, 08:01:51 »
Hi,
Sorry. The dates in the draft of the GB post were mixed incorrectly. It has been fixed now.
« Reply #36 on: Wed, 03 June 2020, 08:07:02 »
« Reply #37 on: Wed, 03 June 2020, 08:09:05 »
We ship using EMS on koreapost.
Offline delrn
« Reply #38 on: Wed, 03 June 2020, 08:33:04 »
Thanks, appreciate the quick response.
Offline chriszhu
  • (* ̄(エ) ̄*)''
« Reply #39 on: Wed, 03 June 2020, 10:17:33 »
For the first 20 invoices paid, does it matter what options are chosen? Or will it always be fulfilled on July 1, as long it's paid?
« Reply #40 on: Wed, 03 June 2020, 10:50:20 »
Anodizing case, aluminum or brass plate
PC and carbon fibre plates are not pre-prepared as options added after IC.
Offline nu_types
  • Formerly Iredeus
« Reply #41 on: Wed, 03 June 2020, 11:02:34 »
Ah darn, I just paid my invoice. Can I change my options? I chose anodizing because the price for cerakote was a bit too high before.
Edit: I'm bad at reading, email incoming
« Last Edit: Wed, 03 June 2020, 11:08:37 by Iredeus »
Offline dc_in_sf
  • Old Bastard
« Reply #42 on: Wed, 03 June 2020, 12:14:36 »
I'm a bit confused on my invoice, there is a line item for an extra top case
660 Extra Top Case
+ Extra top case
1   $85.00   $85.00
Which I didn't order, and AFAICT there is no there is no extra top case option anyway.
Offline TheHun
« Reply #43 on: Wed, 03 June 2020, 13:40:33 »
I placed an order already, but was wondering if there is a black cerakote option?
Offline rooski15
« Reply #44 on: Wed, 03 June 2020, 13:41:37 »
Isn't there a black cerakote option in the form?
Offline TheHun
« Reply #45 on: Wed, 03 June 2020, 14:00:29 »
Hmm. My wrong. I did not see it yesterday. Any chance I could change my order and make it cerakote in black?
Offline rooski15
« Reply #46 on: Wed, 03 June 2020, 14:01:32 »
If you have not received an invoice, you should be able to modify the form. If you have, I'd send them an email (listed in GB thread)
Offline yohannes
« Reply #47 on: Wed, 03 June 2020, 15:09:16 »
Hi! Can you post a sample color for orange gold?
Offline Pauzzz
« Reply #48 on: Wed, 03 June 2020, 16:39:46 »
What does the back look like?
Offline frostfiree
« Reply #49 on: Wed, 03 June 2020, 16:53:36 »
He is working on getting samples for that color. It wasn't added until after the IC post.
