Author Topic: [IC] Type K - Tented Ergo keyboard (10/08/2023 - GB STARTING ON AUGUST 20TH)  (Read 703861 times)
Offline beekey
Re: [IC] Type K - Tented Ergo keyboard
« Reply #300 on: Wed, 23 September 2020, 10:07:53 »
Wondering about the reason to split 3u, with the bigger 2u on the outside and the 1u on the inside. Would not 1u 2u 2u 1u be more "natural"? I typically use the inner most keys as space. How do others do this?
« Last Edit: Wed, 23 September 2020, 12:19:12 by beekey »
Offline socalmitch
« Reply #301 on: Wed, 23 September 2020, 12:07:56 »
Ok Ok! Interested
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #302 on: Wed, 23 September 2020, 15:50:40 »
It is more about thumb placement. The middle of a traditional spacebar is centred on the B key but depending on whether you use your left hand or right hand for spacebar, it would typically land between V-B or around N respectively.
Offline ricepixer
« Reply #303 on: Thu, 24 September 2020, 01:03:33 »
The 3u spacebar option is very welcome.  I was worried since I use my right thumb under the b-n area when typing and that it would be a major adjustment to type on the 1u-2u split.
Offline pcire
« Reply #304 on: Thu, 24 September 2020, 01:17:25 »
The bottom looks sexy af!
Offline Xpliscit
« Reply #305 on: Fri, 25 September 2020, 09:12:23 »
can't wait for this!
Offline Sun
« Reply #306 on: Wed, 30 September 2020, 14:49:25 »
This is too sick! I want this. I like how it matches the 7V aesthetics since i got one.
Offline konstantin
  • Formerly constexpr
« Reply #307 on: Wed, 30 September 2020, 14:58:49 »
The new layout is just phenomenal.
Offline chestera
« Reply #308 on: Fri, 02 October 2020, 20:18:14 »
Any chance of arrow keys? Would love this as a productivity board for work
Offline dom
  • allergic to hypocrisy
« Reply #309 on: Fri, 02 October 2020, 21:05:13 »
Please believe me, once you finally get this board in your hands (after a year), you'll prefer boards without arrows  ;)
Offline KingOfMemes
« Reply #310 on: Fri, 02 October 2020, 21:25:35 »
this would destroy the symmetry and aesthetic imho
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #311 on: Sat, 03 October 2020, 04:05:15 »
Pretty much zero chance. Split spacebar 60% have enough keys and this even has an extra column so that tilde can be in its natural position.
If you are using left hand + mouse for productivity, you are better off with a non-split board.
I've got a minor update which is that I have finished the CAD design for the wrist-rest. I've added a render of it.
I will probably be ordering the next prototype in a couple of weeks.
Offline krey
« Reply #312 on: Sat, 03 October 2020, 09:14:15 »
i'm thinking the concept is this is amazing.
i never owned an ergo so i'm not familiar how it works. what keys do people generally use in the layers to access the up, down, left and right keys?
Kepler FC65 | 7v | Think6.5 v1 | Maja | G60 | TX75v2 | Fjell | Klippe x2 | Acrylic Tofu | CA66 | Norbaforce
Offline tacahiroy
« Reply #313 on: Sat, 03 October 2020, 09:24:44 »
As a Vim user, I basically use LOWER (left thumb) + hjkl, coz arrow keys are far away from the home position.
Tapatalk を使用して私の SH-M07 から送信
Offline Gnarled
« Reply #314 on: Sun, 04 October 2020, 18:31:29 »
Make the wristrest smoky-black PC! If it's a KR inspo, then it's the tinted windshield.
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #315 on: Sun, 04 October 2020, 19:59:40 »
Smokey PC is nice but scuffs are really obvious on it which is why I try to avoid using it on exposed faces and a wrist rest would be prone to wear and tear.
Offline Gnarled
« Reply #316 on: Mon, 05 October 2020, 03:49:52 »
Hm. What about epoxy resin? If I'm not mistaken, higher scratch resistance and easy maintenance if need be.
Offline shensmobile
« Reply #317 on: Mon, 05 October 2020, 17:36:16 »
To be fair, with the 2u-1u-1u-2u split you have now, the edge of the spacebar is between V-B.
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #318 on: Mon, 05 October 2020, 19:02:11 »
Yeah, you are right. You wouldn't be splitting your dominant side though and I'd rather have the extra key towards the centre which is the traditional placement for the extra split key.
Offline shensmobile
« Reply #319 on: Tue, 06 October 2020, 00:58:57 »
That's fair.  It might just be me, but I really do prefer the look of 2u-1.25u + 2.75u spacebars on these Alice keyboards.  Staggered is already non-symmetrical by nature, the bizarre split of the spacebar keys just gives it... a unique flair.
Offline noorejji
« Reply #320 on: Tue, 06 October 2020, 07:36:36 »
Reckon the use of a wrist rest will be a must when typing on this keyboard? Asking since I'm not a fan of wrist rests.
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #321 on: Tue, 06 October 2020, 13:06:54 »
I don't usually use them but I found it nice when using the Microsoft sculpt ergo.
I don't think it's a must though.
Offline Visionaire
« Reply #322 on: Tue, 06 October 2020, 13:31:01 »
Sorry if this has been shared elsewhere, but what's the range of the height on the front? Desktop to lip of the keyboard? Curious especially about the high point (thinking about the need for the wrist rest).
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #323 on: Tue, 06 October 2020, 15:06:34 »
It's close to 35mm high at the apex of the front without bumpons.
Offline SenseiJia
  • Hey you.
« Reply #324 on: Tue, 06 October 2020, 22:34:49 »
Everyday we're getting closer and closer to this. Eager for A CHANCE to get one! Bless me gok  :p
Offline syke
« Reply #325 on: Thu, 08 October 2020, 11:27:51 »
The only keyboard that i will buy this year.
Out of curiosity, why is 6 on the left half of the keyboard, shouldn't it be on the right?
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #326 on: Thu, 08 October 2020, 13:43:09 »
If you take B is the actual centre of the alphas, it will be slightly towards the left.
This is proven by the fact that it would cross the tented ridge line if it were on the right half.
Offline neilli
« Reply #327 on: Mon, 12 October 2020, 09:12:30 »
I would also love it more if it has arrow keys... I know there is basically 0 chance though...
Offline syke
« Reply #328 on: Sun, 18 October 2020, 09:26:21 »
What is the estimated timeline for this keyboard?
Offline Zeelobby
« Reply #329 on: Sun, 18 October 2020, 09:45:58 »
Think he said after 7v delivers
Offline UberPlatypus
« Reply #330 on: Sun, 18 October 2020, 18:30:10 »
Looks expensive... But looks great for a tented board. Reminds me of KITT and a B2 stealth bomber!
Offline generic_panda
« Reply #331 on: Mon, 19 October 2020, 00:31:50 »
As far as the EM7/Alice layout goes, this feels like the next big (non clone) iteration.  I absolutely love how it looks and I hope I can get one when they're ready.  Really keen to continue following this project
Offline demonahz
« Reply #332 on: Mon, 19 October 2020, 19:22:49 »
every single day since this IC was release, I pray for every single divine entity (even being atheist) for this to be like 500.000 units so I can get one. as I have an interplanetary fame for only being able to get the keyboard I want from flippers :(
Offline whykayallday
« Reply #333 on: Tue, 20 October 2020, 18:40:59 »
As someone who uses the alice layout daily this is a grail.
Going to have to practice using left shift more though because that right shift is really small.
edit: I was worried about keycap compatibility but I just found out that ISO utilizes 1.25 shift.
« Last Edit: Tue, 20 October 2020, 18:44:18 by whykayallday »
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #334 on: Tue, 20 October 2020, 18:58:23 »
If you are comfortable with using your thumb for Fn, you could use a 2.25u on your right shift instead of splitting it.
Offline captainscurvy7
« Reply #335 on: Fri, 23 October 2020, 12:04:20 »
That wrist rest is clean. Nice job.
Offline Thighs
  • Thighs#0100
« Reply #336 on: Fri, 23 October 2020, 18:19:56 »
Sexy board. Hoping for an ewhite.
Offline DasGnome
« Reply #337 on: Fri, 23 October 2020, 18:53:13 »
Isn't the name "Type K" a bit close the existing "K-Type" lol
Offline quazikun
« Reply #338 on: Fri, 23 October 2020, 18:55:14 »
Discussed in OP lol
Offline DasGnome
« Reply #339 on: Fri, 23 October 2020, 19:19:49 »
Discussed in OP lol
Reading comprehension fail. Still a bad idea for them imo from a product-recognizability standpoint.
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #340 on: Fri, 23 October 2020, 19:56:19 »
Discussed in OP lol
I'm not concerned about that at all since the Type K isn't meant to be a mass market product.
I have to admit that I'm not good at names though.
Offline ttttug
« Reply #341 on: Sun, 25 October 2020, 10:18:03 »
Really awesome, exactly the type of minimalist, while still being very interesting design I need in my life, can't believe I haven't seen it until now. Thank you for this!
Offline T.Pineapples
« Reply #342 on: Sat, 31 October 2020, 16:23:36 »
This board has got me feeling something fierce
Offline Ustinj
« Reply #343 on: Sat, 31 October 2020, 17:17:35 »
The only board I've currently got my eyes on (and actually looking to pick up if the opportunity arises).
Offline Visionaire
« Reply #344 on: Sat, 31 October 2020, 22:01:21 »
Aside from the Phase, of course. :)
Offline diddymechakeebs
« Reply #345 on: Tue, 03 November 2020, 01:15:20 »
Reserved
Offline pleasega
« Reply #346 on: Thu, 05 November 2020, 09:40:21 »
i will get this.
Offline UGunaLOSE
« Reply #347 on: Thu, 05 November 2020, 09:43:32 »
Definitely interested in the progress of this IC. Looking forward to this one :)
Offline KucherenkoZZZ
« Reply #348 on: Sat, 07 November 2020, 16:28:27 »
This is Alice i've been waiting for all of my life
Offline TPSM_00
« Reply #349 on: Sun, 08 November 2020, 16:11:33 »
I love this so much, I am def going to try to get one when it comes out. I need this in my life and I need this on my desk  :D
