Author Topic: Spray Lubing switches - A guide  (Read 382741 times)
Offline Leslieann
« on: Sun, 23 August 2020, 06:46:01 »
Someone made a comment we need to make one of these so here it is.
If a mod could sticky this that would be great as we have had a few mentions of it lately.
DO NOT SPRAY LUBE SWITCHES.
Don't try brushing the stem from the outside with grease or oil either.
We do not care that some Youtuber showed it was okay, DO NOT DO IT.
Sprays are for use in places you can flush out contaminants and leave a lubricating coating like exposed hinges on a door or a bicycle chain. There is no way to flush contaminants from a switch. Plus, all that solvent, which is atomized more than the lube, may have just destroyed any lube in places you can't reach and is now breaking down and will further contaminate the switch as it does so. So while it may seem great now, it may be a whole lot worse in a few hours, days or weeks from now or it may be fine (much less likely).
As for brushing the stem from the outside with grease or oil, while this looks like an easy way to do it you have no idea what's on that stem or around the hole it passes through. What's the difference between this and taking it apart if you're lubing the same part? When you disassemble and lube you are brushing on lube and carrying away contaminants (switches are often new and clean as well), you also direct how much and where it goes (IMPORTANT!). By lubing outside in you are purposely pushing things in, you have no idea what else is being carried in (brush bits, dirt from the housing, etc..) and you have no way to direct where it goes once inside or how much, you are literally just shoving everything in and hoping.
Keep in mind I said may, it may be fine, but you're playing with fire. If you can afford to replace it or don't mind the cleanup, do what you want, just don't do this if you aren't prepared for the consequences. In most cases, most switches today are pretty good from the factory, lube doesn't instantly make a switch good or better. While there are some that benefit greatly others are just a waste of time and money to lube, you may want to ask before you bother. Personally, I think lubing stabs is far more universally satisfying than lubed switches but some switches do need lube.
What to do if you did this?
Unfortunately you don't have much in the way of options.
If it works, leave it. There's no guarantee it will work, fail or go bad, only odds. If it's working fine for now, leave it, just be aware it may come back to haunt you at some point.
If it does go bad, what are your options?
You can try an ultra sonic cleaner (if you have Monterey switches this is your only option), but at best you return to what it was when you bought it so it's a gamble, and since odds are you don't have one, especially one large enough, you could just apply that towards a new board.
To really fix this, you will need to open the switches (the very thing you tried to avoid), once open you will need to use contact cleaner on the contact leaf inside, something like Deoxit D5 would probably work (beware this is nasty stuff), be sure to douse every switch's internals good. Then clean the stem, spring and top housing with an ultra sonic cleaner, or a tooth brush and either warm soapy water (as hot as you can handle) or (preferably) some citrus cleaner (Goo Gone works), rinse, then either let it sit for a few days to air dry (one day will not be enough unless it's VERY hot and dry) or dunk them in isopropyl alcohol to displace the water then let them sit for a few hours. Now you can start lubing them the right way before reassembling. Then you get to hope nothing was damaged or else you did all this for nothing.
In other words, just replace it.
Seriously, even with hot swap this is easily 5+ hours of rather tedious work to do right plus drying time and you still need lube, contact cleaner and preferably something like Goo Gone. If you have to desolder this is an entire weekend worth of work plus some supplies for that. Call it an expensive lesson, but don't throw this out just yet, you can use this to learn to solder/desolder so you can get something even nicer or just install different switches.
« Last Edit: Wed, 02 September 2020, 22:28:34 by Leslieann »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline _PixelNinja
  • C=Q/V=ε(A/t)
Re: Spray Lubing switches - A guide
« Reply #1 on: Sun, 23 August 2020, 08:25:32 »
#NoSpray
Offline jamster
« Reply #2 on: Sun, 23 August 2020, 08:31:50 »
I'm sure this will save people pain, time and money.
Though I do wonder... how many people are going to read this, then say to themselves "nah, I am sure those experts on YouTube must know what they are talking about" and go ahead anyway.
Offline ddrfraser1
  • RIP Neil
« Reply #3 on: Sun, 23 August 2020, 08:45:21 »
Glad I asked  ;D
Plus, I think I figured out a way to open my Montereys anyway.
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #4 on: Sun, 23 August 2020, 08:47:14 »
250167-0
Offline Sup
« Reply #5 on: Sun, 23 August 2020, 09:06:55 »
Can a mod pin this  :)
current
Coming soon
Offline powwu
    • Discord
« Reply #6 on: Sun, 23 August 2020, 09:42:20 »
So true. I see people ruining their boards on the daily, hopefully this will help put a stop to it.
Offline Sup
« Reply #7 on: Mon, 24 August 2020, 00:41:37 »
Bump to get attention from moderators day 1  :)
current
Coming soon
Offline Drakenocas
« Reply #8 on: Mon, 24 August 2020, 01:26:48 »
Yeah, I saw that video of that guy spraying lubing, a pretty well viewed enthusiast on YouTube, as well. Not huge,but they get a few thousand views on each video, and I was thinking to myself that too many people are:
1. Going to ruin their PCBs.
2. Destroy other property
3. Give themself cancer.
Perhaps they deserve it if they're dumb enough to try spray lubing.
I really wish the dude would remove that video, for real.  He may be able to do it and be happy with it, but I don't feel like most others will be happy with the results.   You have to be responsible for what you put out.
Offline envyy24
« Reply #9 on: Mon, 24 August 2020, 09:56:19 »
Thank you for saying what I wanted to say for a long time.
Offline ddrfraser1
  • RIP Neil
« Reply #10 on: Mon, 24 August 2020, 10:18:25 »
I've been lubing switches the proper way for years but whenever I see a video with someone trying something new and it works well for them, I think, 'Hey, that's pretty cool, I want to try that.' But yeah, I wondered what this would do to my switches and boards. I knew if I asked Leslie I'd get a straight answer.  :eek: :thumb:
Offline Hipyo
    • Youtube
« Reply #11 on: Mon, 24 August 2020, 19:13:08 »
Edit: I have since dabbled more with spray lubing and admit defeat.. the doing the wrong thing but getting the right results part applies here. Don't spray lube.
« Last Edit: Tue, 23 March 2021, 20:41:00 by Hipyo »
Offline Leslieann
« Reply #12 on: Mon, 24 August 2020, 21:34:51 »
I really have not seen any evidence of spray lubing in particular ruining boards and switches when done correctly
https://geekhack.org/index.php?topic=107654.0
You're spraying blindly, how exactly is there a right and wrong way. Do you honestly think you aiming it at the side of the slider is stopping it from going anywhere else inside the switch?  You're delusional.
Yes, spray lube is lube and may be safe when used properly, the problem is and will remain that you have no idea what lube is in there. Is that solvent compatible? You have no idea. If you use a compatible lube/solvent, yes, all is well. Ever see what happens when it's not? It doesn't matter on a chain or hinge, you wash it all away with solvent, and if you miss any, you get it next time. You can't do that on a switch, the fact that it takes "1-3 days" for the solvent to evaporate tells you how sealed the mechanism is, if the solvent takes that long there's no chance of washing anything away.
I would argue that any form of modding could ruin a part if done wrong, and that is not a reason to tell everyone to avoid it.
You can damage a trace desoldering a switch, certain medications have side effects, however both were being done/used in the proper way.
In both cases the potential for issues outweighs the benefits.
In the case of spray lubing, you're simply HOPING it makes things better without knowing if it will help even if it works the way it should (not all switches benefit from lube).
From what I have seen, and from the main person doing spray lubing who did research on it (:3ildcat on youtube) there are not any crazy long term effects to doing this process. I personally put out a video on spray lubing and have had only positive experiences with it.
So all this is based on yours and a single youtuber's anecdotal evidence, that's not research it's "research".
"It worked for me so you must have done something wrong" is the rallying card for anyone who doesn't properly understand what they're doing. Even when you do something wrong you can still get a positive result, it doesn't make it right. Did either of you even bother to open a switch, let alone many and look at what happens? I'm going to guess no.
I'm not trying to trash you but you need to understand this is not right, any of it.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline Hipyo
    • Youtube
« Reply #13 on: Mon, 24 August 2020, 22:04:13 »
« Last Edit: Thu, 29 October 2020, 18:45:50 by Hipyo »
Offline Leslieann
« Reply #14 on: Tue, 25 August 2020, 00:04:16 »
That post you linked does not include spray lubing anywhere in it so I'm not sure what exactly you meant by linking it, there really is not much out there on spray lubing going wrong.
It wasn't spray lube but similar principle, the person lubed from the outside with no idea what was happening inside.
I think your hard-line no spray lubing approach is elitist and taking a more nuanced look at it might help the community explore more ways of enjoying the hobby in the ways that they prefer.
This has nothing to do with being elitist it's about keeping people from making what could be a costly mistake. You want lower barriers of entry, great (!) but destroying someones board isn't going to help with that.
I'm pulling from decades of evidence based standardized lubrication practices. Not just keyboards, everything. Do you think we just decided on a brush and lube because it was convenient?
You're using anecdotal evidence and your "current pool" is but a teeny tiny sample. You have no research, few samples and goes against all standardized lubrication practices. And yes, I looked at that PDF you linked, it says nothing about compatibility with other lubricants only plastics and rubbers. The website says compatible with most but they also expect the solvent to wash everything away leaving a clean surface and then evaporate (quickly!), neither of which is happening inside a switch.
It's possible to do everything wrong and still get a positive result, that doesn't make it right or predictive of future outcomes.
« Last Edit: Tue, 25 August 2020, 01:58:47 by Leslieann »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline jamster
« Reply #15 on: Tue, 25 August 2020, 00:35:31 »
@Hipyo I don't have the patience that Leslieanne has, so I will leave it at this:
What you decry as 'elitist' seems more a complaint that someone with vastly more experience in electronics does not agree with the assertions if someone with vastly... less experience. Citing some YouTuber who had a paid interest in clicks as an appeal to authority is a well known argument fallacy, so well know that it's got its own name in rhetoric. Very few of the more experienced people on GH agree that YouTube is a reliable authority, and reasons for this were already given in the link to the brush lube thread.
From what I have read of your posts, you simply don't understand what you're writing about. Totally random interjections about masks and gloves, along with the 'proper procedure'? Masks and gloves are not relevant when using these aerosol cans (eyewear might be prudent however), and there is no 'proper procedure' defined anywhere.
You need to be able to back up your arguments properly, beyond 'random popular guy on YouTube says so' and address the substantive points made by others. Otherwise cries of 'elitist' is nothing more than a petulant demand for respect or recognition.
« Last Edit: Tue, 25 August 2020, 00:46:34 by jamster »
Offline Sup
« Reply #16 on: Tue, 25 August 2020, 01:05:04 »
New people just like to follow what ever new youtuber pops up and does some "life" hacks for views. Guess what he doesn't care what happens to your board so long he gets the views and ad revenue he/she is content. I can't blame the new people since when they search up lubing you get as 3 and 4th result of "HOW TO LUBE YOUR SWITCHES WITH OUT DESOLDERING".
It may work but it may also leave wrong side effects of dust/dirt debree rubbing inside the switch after the lube has evaporated then the bad stuff will happen like getting a scratchy feeling.
I guess informing people of right ways to lube and how to fix the issue is seen as elitisms. I guess the old enthusiast only care about long term feel of our keyboards?
« Last Edit: Tue, 25 August 2020, 01:12:50 by Sup »
current
Coming soon
Offline Hipyo
    • Youtube
« Reply #17 on: Tue, 25 August 2020, 01:45:51 »
« Last Edit: Thu, 29 October 2020, 18:46:07 by Hipyo »
Offline Leslieann
« Reply #18 on: Tue, 25 August 2020, 03:09:37 »
I know you guys have significantly more experience, all I am saying is your claims that they ruin switches consistently are completely baseless so acting as if it is ruining peoples keyboards is bogus. Sure it might happen, but it is not as if it is an instant death sentence for your board.
I never said it would 100% ruin the board.
Please see the last line of my last post:
On the topic of it might leave residue that leaves it feeling worse, I would love the evidence for that as well! The solvent does not need to flush anything out if there is nothing that needs to be flushed out in the first place right?
You are aware the factory puts some lube in switches right and that solvent is there to break down contaminants and old lubricant so it can be flushed out? Where is all of that going to go? It's not going to evaporate with the solvent.
Dust and debree will get in your switch if you lubed it by hand as well.
You're right,
Dust and debris can get in when you hand lube but by using a brush you remove and push things into places that don't matter. Instead of being in the slider it may get clumped with a bit of extra lube on the underside of the stem where it becomes harmless (which by the way is also part of a lubricants job during application). Where did it wind up when you spray lubed, the contacts?
Also there is no facts or evidence that it would ruin your board long term, other than a feeling based on experience?
Ignore experience at your own peril.
If someone is enjoying themselves in a hobby we should not gate-keep them. I am not claiming elitism because someone disagrees with my opinion, which I am open to changing if presented with some real facts. I am claiming elitism because of the stance being taken that something is instantly bad because it isn't the standardized practice.
No one is gatekeeping, I didn't come over and rip the can from your hand, you're just angry because someone told you "NO."
« Last Edit: Tue, 25 August 2020, 03:11:15 by Leslieann »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline jamster
« Reply #19 on: Tue, 25 August 2020, 04:02:47 »
The inability to identify nuance in this thread is mindblowing. All because people didn't welcome another Youtube video about a quick and dirty keyboard 'life hack' with open arms.
Offline envyy24
« Reply #20 on: Tue, 25 August 2020, 06:08:13 »
Since when recommending good practice gate keeping? In fact it is not only good but the best practice so far, any one offering you spray lubing service???
Offline ddrfraser1
  • RIP Neil
« Reply #21 on: Tue, 25 August 2020, 08:22:58 »
Well more it came about because people saw the video and started asking if this was a good idea. I’ve got some switches and boards that are damn near impossible to get apart so I wondered if this could be a good solution. The steel series apex pro is one I can’t figure out how to open. Monterey switches are others that are difficult but not impossible. I would never consider spray lubing ordinary switches and I certainly won’t try it on the difficult to open switches either.
However, after reading the hilarious reactions to this thread, all I want to do is get out my discarded cherry switches and spray lube ‘em just so I can confirm ‘oh yeah, it totally ruins them’
A point on the youtuber. Pretty sure he says in the video that these are just crappy switches on a crappy board and he is just experimenting ie, he doesn’t recommend it. I think that’s great. We need more experimentation. We learn as much or more from what doesn’t work.
Another point, he also introduced me to a method of applying dielectric grease to stabs with a dental pick/brush thing. Again, this is an intentional short cut on a cheap board and he’s not really promoting it as an alternative to properly lubing stabs. However, again, this was the perfect thing for me to try on my stubborn, apparently unopenable steel series apex pro. Link to results:
I’ll probably do it to another board that I built years ago before I learned about lubing stabs as I can’t be bothered to desolder the whole thing.
Offline jamster
« Reply #22 on: Tue, 25 August 2020, 08:52:26 »
I don't think that anyone has reasonably said "OMG you will totally 100% roooon ur switches," it's more like "this is really not a good idea if you value your board, because you can't control it, you are likely to screw things up long term, and if you do, it's a total write off." Most boards are not suddenly 'made' through lubrication. It's a mild improvement with a finite lifespan- it's not like lube stays in place for decades, it just rubs away eventually. The risk/reward is really questionable.
If I had a board I didn't care about, I'd be willing to give it a shot too just to see what happened. I would fully expect it to feel better (well, smoother, I would not have high hopes for tactility, which is something I value a lot). But I also wouldn't insist 'gatekeeper elitest because you don't agree with me.'
I agree that experimentation is good. But so is reasoning, and an understanding of the principles involved. Basic things like knowing what a solvent actually is, and what it's going to do to existing lubrication is, are also pretty key. Latching onto external authority over an an effort to understand (in this case very, very simple) principles is never a good thing.
That was an 8 second video, was it what you meant to post? It only showed him pressing some keys.
I've always lubed stabs the lazy way- just take the keys off and use a syringe to jam some grease in there. Stabs are not at all delicate like switch internals so I am not worried about extremely tight tolerances or foreign materials (grease doesn't flow like lube). And if I apply too much, it's pretty easy to clean out.
« Last Edit: Tue, 25 August 2020, 08:55:25 by jamster »
Offline ddrfraser1
  • RIP Neil
« Reply #23 on: Tue, 25 August 2020, 09:24:07 »
That was me. Just showing the results.
As far as lubing stabs, I like to grease the sliders with teflon grease, bandaid mod the plate, and clip the feet. These things are worth additional effort.
« Last Edit: Tue, 25 August 2020, 09:25:44 by ddrfraser1 »
Offline Leslieann
« Reply #24 on: Tue, 25 August 2020, 21:33:33 »
We had one person try shoving lube down the sides, someone linked a video, two people asked if it was safe and then I got private messages asking about it as well.
That may not seem like a lot but it all happened in only about 2 weeks.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline Leslieann
« Reply #25 on: Tue, 25 August 2020, 22:09:33 »
This is the problem, it's a gamble and a one way trip.
Risk and experimentation is fine, but who's most likely to do this? It's not someone like me, it's most likely someone young, probably spent their allowance or birthday money on it and looking for a cheap and easy way to do this.
I would also expect someone to show something more than just "it worked for me" before spreading it around.
I'm all for experimentation (Jailhouse Blues?).
Why use a whole board?
All anyone needs to do is to grab a spare switch, spray it, then open it up and take a look inside, it wont change the contamination aspect (which is the bigger issue and more difficult to see) but you could as least verify the lube went where it should and maybe where the solvent went. As far as I can tell none of these guys have even done that, which to me is the most basic "research", I really was hoping one of them would do this and yet none did which tells me exactly how interested they are in "research" and just want to do it the easy way.
I also would have done that before YOLO'ing an entire board and posting it online.
This also hints at where their priorities lie.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline Drakenocas
« Reply #26 on: Tue, 25 August 2020, 22:41:02 »
I really have not seen any evidence of spray lubing in particular ruining boards and switches when done correctly, especially to the extent to which this post makes it seem. But if there is evidence that it does more harm than good I would be open to it. I would argue that any form of modding could ruin a part if done wrong, and that is not a reason to tell everyone to avoid it.
So while it may seem great now, it may be a whole lot worse in a few hours, days or weeks from now.
From what I have seen, and from the main person doing spray lubing who did research on it (:3ildcat on youtube) there are not any crazy long term effects to doing this process. I personally put out a video on spray lubing and have had only positive experiences with it. This does not mean it is totally harmless, so I did not recommend it in my video rather I just documented the process. However, I do think that if someone is adequately informed and uses the proper protective mask and gloves they should not feel discouraged. It has been proven to make switches feel and sound better for very little effort and that is its selling point. Obviously hand lubing is a superior process, but for some its okay that they might not want to take that route.
To be fair, I don't worry about you guys that have a good idea of what you're doing.  You're all adults and can do whatever you like.  However, I worry about the younger people, who don't have a clue.  Some of them are adults too.  My kid actually showed me the :3ildcat video, and asked if we could do it with his Ducky.  Of course, it just didn't look like a good idea to me, but he's impatiently waiting on me to desolder and stick the lubed reds back in and resolder (time, if we only had more time).  What I fear is that if I hadn't had talked to him about it, he would have just done it in the floor in his bedroom without two thoughts, probably ruining my flooring. He is 17, so safety and technical cleanliness aren't top priorities at this stage in life.
Is spray lubing for me, no.  I don't want to tell anyone what they can't do, though I don't think it should be done, but I think it should only be fair that if you're doing something like spray lubing and show it off to the world on a social media platform, then you should explain responsibly that it should be done outside, with some protective gear (eye goggles and a cheap painter's mask), and point out what materials to use to clean the PCB afterwards, or to a link on cleaning PCBs.
Offline baysic
« Reply #27 on: Tue, 25 August 2020, 23:57:07 »
Any recommendation on plate mount soldered in keyboard? Like filco for example soldered in and switch top is not openable too.
How do I make my cherry red slippery smooth. lol.
Offline Sup
« Reply #28 on: Wed, 26 August 2020, 11:10:32 »
Just keep typing on it aka breaking them in and they will become smooth over time. Or desolder and open the switches and lube the friction points.
current
Coming soon
Offline ddrfraser1
  • RIP Neil
« Reply #29 on: Wed, 02 September 2020, 09:03:12 »
Looks like he's doubling down.
Offline Leslieann
« Reply #30 on: Wed, 02 September 2020, 22:31:26 »
Did some minor reformating, corrected some errors, it's a little less harsh.
I still do not recommend doing this at all.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline treeleaf64
    • treeleaf64
« Reply #31 on: Sat, 05 September 2020, 13:46:15 »
Ok,  come on. It will only take like 2 hours to do the whole thing.   (desolder and lube)
Unless you're severely  time strapped, it's not even that hard.
Everyone must pay the cat tax
Offline Leslieann
« Reply #32 on: Sat, 05 September 2020, 22:03:41 »
Under 2 hours for a switch swap using a desoldering gun, sure, I can see that.
Under 2 hours (for a noob) to desolder with a $30 iron and some cheap braid, opening every switch and scrubbing out the silicone lube, drying, re-lubing, reassembling then re-soldering. Not on your life.
Anyone with the equipment to do this quick probably isn't going to spray lube and you're not the person this post is aimed at. Also, have you not seen the posts about people messing up installing switches? it happens all the time and that's the easy part.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline jamster
« Reply #33 on: Sun, 06 September 2020, 02:22:42 »
No freaking way.
Do you think that people who are thinking "hey jamming a spray nozzle into my keyboard is a good idea because YouTube" own quality soldering stations and mechanised desoldering guns? And have experience using them?
I've tried to desolder a board using wick and a manual pump. I'm done two boards that way and I'm never doing that again. My time is far more valuable than that.
« Last Edit: Sun, 06 September 2020, 02:26:21 by jamster »
Offline Leslieann
« Reply #34 on: Sun, 06 September 2020, 03:11:52 »
By the way, something I don't think people understand, Silicone is a MOTHER to remove.
It repels water and soap, citrus will help but it's not going to dissolve it and wash it away, it more or less allows you to scrub it away is all. Have fun scrubbing it from the springs and stems and all those little nooks and crannies. It's fantastic stuff when it's someplace you want it, it's HORRIBLE when it's someplace you don't.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline Sup
« Reply #35 on: Mon, 07 September 2020, 07:07:11 »
No freaking way.
Depends on what solder pump though. With the Engineer SS-02 one pump for one solder best solder pump i have ever gotten can desolder under 1 hour watching videos or something and chill out.
current
Coming soon
Offline JianYang
« Reply #36 on: Mon, 07 September 2020, 07:42:54 »
I read the title and thought - must be a ****post, there is no way. Then I saw the author and thought, okay, maybe I'm missing something...
Thanks for the entertainment!
Offline Darthbaggins
  • PC Cannibal
« Reply #37 on: Wed, 07 October 2020, 14:59:18 »
I know of one Youtuber who has done this and I know he's added to use spray at your own risk and that there is a chance of damaging something - they also note opening and manually lubing the switch properly is the best and safest way to do it.   Most of the boards I've seen him spray lube are cheap enough to warrant the science project.
I'm still for learning to solder and de-solder, they are great things to learn and not really difficult to do so - also in some cases therapeutic.  Also taking apart a switch can teach you alot of it's inner workings so you can understand it more.
Why take a "short cut" that could kill your $100+ board over spending the time and research on learning to do it right the first time - I hate having to go back a re-do a job/project and want to get it right the first time and be done with it.  You have people with far more experience and have gone before you and learned this, might want to listen to them - I know I do.
Offline sloth.
  • Corne gang
« Reply #38 on: Sun, 01 November 2020, 12:05:03 »
I just want to say thank you for this thread. A lot of new people joining in the community are truly astonished and impressed about how fast and effective (from a video) these techniques are, so they just want to go with it, but most of the time the fastest is not the best or viable at all.
Offline jamster
« Reply #39 on: Sun, 01 November 2020, 20:40:16 »
Huh, it certainly takes a degree of bravery to admit this. What happened to change your mind- did anything go wrong with a board, or was it something else?
Offline cashmeerkat
« Reply #40 on: Fri, 11 December 2020, 10:16:28 »
Lubing switches does take a very long time and backbreaking. Was on the fence about this spraying my switches. Glad I stumbled on this post before I did though. Sad to see all these Youtubers talk like experts and the information can be so misleading for the unfortunate rest.
  • PC Cannibal
« Reply #41 on: Mon, 14 December 2020, 08:41:15 »
It sucks that more YT'ers are starting to back spray lubing, trying to convince people there is a shortcut when in reality it's not.  It's worth it in the long run to take the switches apart and lube them (even then you might notice they may need to be filmed as well).  I try to send people to this thread when they mention seeing a YT video on spray lubing still.
Offline w0lfssegner
« Reply #42 on: Sun, 27 December 2020, 00:41:55 »
I spray-lubed my Gateron browns as an experiemnt since they were just placeholders until my yellows arrived (and Krytox is expensive af). While the sound profile and initial switch feel was better, it did get weirdly gummy in feel after a while. Never had that issue with my subsequent switches that I lubed with a brush. Will never spray lube any other switch ever again.
Offline Leslieann
« Reply #43 on: Sun, 27 December 2020, 06:33:22 »
People are lazy and cheap and on the surface it's not entirely a stupid idea.
It is possible to make it work quite well if you put a little thought and effort into it but it still wouldn't be good for anything but linears.
Spray lubing tactiles and clickies will remove the tactility, I don't care how careful you aim.
There's also alternatives to Krytox that are much cheaper.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline w0lfssegner
« Reply #44 on: Mon, 28 December 2020, 02:11:33 »
I was actually okay spray lubing the browns because they were barely tactile as it is. Like I said, it was just an experiment. Lubed all my switches after that with brush and Krytox.
  • PC Cannibal
« Reply #45 on: Tue, 29 December 2020, 08:45:40 »
Krytox really isn't that expensive if you shop around and find a good source for it.  Also as has been mentioned there are definitely more inexpensive options in the market as well.
Offline Leslieann
« Reply #46 on: Wed, 30 December 2020, 04:12:40 »
Per ounce, Krytox makes HP printer ink division jealous.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
  • PC Cannibal
« Reply #47 on: Mon, 04 January 2021, 08:49:24 »
I guess Krytox needs to make their own Instant Lube program like HP, lol.  I normally only get it in small batches, and when I see it for a decent deal from local sellers I try to snag it up.
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #48 on: Tue, 05 January 2021, 09:50:50 »
To be clear for any newcomers: this is about spraying lubricant into fully-assembled switches.
Disassembling your switches and then spraying lubricant onto the sliders is a perfectly valid way to lube your switches. Get a piece of foam and some toothpicks, put one slider on each toothpick (insert the toothpick point into the indentation at the bottom), and apply 1-2 thin even coats of DuPont Dry Film spray or equivalent, making sure to let them dry completely and use a well-ventilated work area.
Note that I haven't done a full build of this, but I did a few test batches and it gave nice results. The only faster/easier method I can think of would be shake lubing (aka "tub lubing"), which I also strongly advocate for.
« Last Edit: Tue, 05 January 2021, 09:53:25 by tex_live_utility »
Offline pmdbt
    • KeebsForAll Storefront
« Reply #49 on: Tue, 05 January 2021, 19:47:44 »
I just want to preface by saying I'm not an expert in electronic hardware, but I have been interested in spray lubing for a while now and I have run a series of tests and will continue to do so. My results so far are pretty inconclusive.
Here is a quick break down of how I'm doing the spray lubing:
1. Quick squirt of super lube on the two opposite sides of the diagonal of the stem.
2. Actuate the switch roughly 10 times after both sprays.
3. Flip the lubing station upside down with the switches in them and leave it for a few days. Usually 2-4 days.
4. Remove the switches from the station after a few days and dry/clean the outside of the switch with a paper towel.
The switches I have tried this on:
- Kailh speed copper
- Gateron Milky Browns
- Gateron Black Inks V2
- Gateron Milky Yellows
Overall, I've probably spray lubed around 500 switches so far. The longest has been around for 6 months with zero negative effects so far.
Results:
- The tactility of tactile switches is still there after spray lubing. However, it is decreased, but it's definitely still there and nowhere close to feeling exactly like a linear.
- Some switches did get ruined, meaning if I mount them, the key presses would no longer be detected by the PCB. However, I would say this occurred mainly at the beginning when I first tried to spray lubing. Even then, it would be around 2 switches that go bad per batch of 50 switches.
- DO NOT spray lube switches that are soldered onto the PCB already. This was by far the worst result and per what many people said above, ruined the board and switches.
- The best results were for linear switches. I could spray lube around a batch of 50 switches in around 10 mins or so while watching T.V with my wife. I get around 70-80% of the acoustic and feel the benefit of hand lubing with Krytox, but for significantly less time. With a full-time job, the efficiency of spending 20 active mins vs a few active hours hand lubing seems like a good tradeoff for me. (Yes, you have to leave the switches around for a few days to dry, but those are not active time spent, so it's ok for me).
My personal conclusion so far:
- I will likely continue to experiment with this to gather more data and see if a significant number of batches can continue to function well after a few years. The reason is that many people recommend us to never spray lube because it will damage the switches and make them worse or even break them. However, if you continuously do it for thousands of switches and the vast majority of them work perfectly fine after years, then clearly something interesting is going on. I personally always subscribe to the motto "trust, but verify".
- I would never spray lube a soldered board for modding purposes even if you just want to experiment as I did. It will MOST LIKELY just ruin the board.
- If you have a lot of spare parts and are ok losing them, I would recommend you try it if you're curious. However, if you only have 1 board or 1 set of switches you normally use, do not try it!
ID80, Rama M65-A, Black Inks V2
