Author Topic: [IC] GMK Tuzi  (Read 310173 times)
Offline LightningXI
  • PPD
    • ArtisanMacro
Re: [IC] GMK Tuzi
« Reply #150 on: Fri, 06 November 2020, 03:51:50 »
Added F13 in Base Kit. Color is subject to change or can offer both Alpha colored and mod colored F13.
IMO F13 should always be mod colored so that the alternating color pattern is symmetric across the alpha block between Esc and F13. After all, a big argument for adding the F13 in the first place is symmetry.
+100 for mod colored F13.
Can't emphasize this more.
Offline konstantin
  • Formerly constexpr
Re: [IC] GMK Tuzi
« Reply #151 on: Fri, 06 November 2020, 09:34:06 »
Agreed. There's not much sense to alpha-colored F13, imo.
Offline SenseiJia
  • Hey you.
Re: [IC] GMK Tuzi
« Reply #152 on: Sat, 07 November 2020, 15:22:14 »
Alright will make the switch over! Thanks for the input!
Offline AnotherAsian
Re: [IC] GMK Tuzi
« Reply #153 on: Sun, 08 November 2020, 00:06:34 »
Please happen! This set is super cute! ^_^
Offline SenseiJia
  • Hey you.
Re: [IC] GMK Tuzi
« Reply #154 on: Sun, 15 November 2020, 12:21:22 »
Minor Update!
11/15 - As per suggestions from IC and comments. Changed F13 to Mod Color. Moved one R3 1U Novelty to R4 so you can have a full vertical row with bunnies. Moved B Key from Spacebar kit to Base kit.
Offline typezero
Re: [IC] GMK Tuzi
« Reply #155 on: Thu, 19 November 2020, 23:58:07 »
Loving the theme and color, can't wait for the GB
Offline kidpid
Re: [IC] GMK Tuzi
« Reply #156 on: Sat, 21 November 2020, 16:07:51 »
+1 to a 40s kit
Offline kt1928
  • Kappy
Re: [IC] GMK Tuzi
« Reply #157 on: Sun, 22 November 2020, 13:57:41 »
Cant wait for the GB!!
Offline bkrownd
Re: [IC] GMK Tuzi
« Reply #158 on: Sun, 22 November 2020, 21:43:00 »
So cute   :D
Offline konstantin
Re: [IC] GMK Tuzi
« Reply #159 on: Mon, 23 November 2020, 08:41:58 »
I don't think this was particularly necessary, as it's still not possible to cover all Alice setups with just the base kit due to the lack of a 2u Shift (using numpad 2u 0 looks quite bad). Keep in mind that (2.25u+1u) and (2u+1.25u) setups are about equally as common.
Although, it has to be said that not having any doubleshot keys in the spacebars kit does reduce the price by a bit; however, from what I've seen/heard recently, it's not by much.
That being said, regardless of whether you decide to move the second B back to the spacebars kit or not, would you please consider adding at least a 1.25u space and, ideally, a 1u space as well to the spacebars kit? This will allow multiple layouts to be covered with spacekeys, including:
  • standard split 6.25u space — (2.75u+1.25u+2.25u) and (2.25u+1.25u+2.75u) configurations;
  • Alice — (2u+1.25u) and (2.25u+1u) left space configurations.
On a different note, have you considered using single-line Caps instead of Caps↲Lock for the stepped key? It looks a bit cleaner imo, and fits in better with the rest of the single-line legends in the set.
Edit: formatting
« Last Edit: Mon, 23 November 2020, 08:52:16 by konstantin »
Offline donny_pete
Re: [IC] GMK Tuzi
« Reply #160 on: Mon, 23 November 2020, 11:47:58 »
this might have to be a cop for 2021
Offline Poesjuh
Re: [IC] GMK Tuzi
« Reply #161 on: Mon, 23 November 2020, 17:23:18 »
Good suggestion on the 1.25u and 1u alpha colored spacebars. Using mod colored keys between two alpha colored spacebars is horrible.
Offline SenseiJia
  • Hey you.
Re: [IC] GMK Tuzi
« Reply #162 on: Wed, 25 November 2020, 09:49:50 »
Edit: formatting
Thanks for the suggestions!
I will definitely look to have 1.25u and 1u space in the spacebar kit. Was wondering if I should offer Accent Alice bars in the kit as well.
For the Capslock to Caps on stepped. I think it's fine the way it is since I was going for the standard Text+Icons mods anyways and it has some sort of uniformity with keys that have 2 lines of characters/icons like Tab, "`~" "\|", etc. At least imo.
I will think about the B key placement still. I'm still wondering if there's enough demands for a 40s kit so I make kits based on already existing sets with great kitting like Taro R2 by Pwad3. Else moving the B key back to Spacebar kits seems to be the best.
« Last Edit: Wed, 25 November 2020, 09:53:07 by SenseiJia »
Offline yicaoyimu
Re: [IC] GMK Tuzi
« Reply #163 on: Wed, 25 November 2020, 10:21:10 »
Any update on vendor or GB date? The kits look pretty much finalized by now.
Offline SenseiJia
  • Hey you.
Re: [IC] GMK Tuzi
« Reply #164 on: Thu, 26 November 2020, 14:53:32 »
Hopefully soon! Fingers crossed!
Offline SxM Designs
  • https://sxmdesigns.com
    • Website
Re: [IC] GMK Tuzi
« Reply #165 on: Thu, 26 November 2020, 15:00:24 »
Cant wait. Lovely colors!
Offline Hyphen
Re: [IC] GMK Tuzi
« Reply #166 on: Fri, 27 November 2020, 09:00:39 »
I'll just be over here crossing my fingers for a Canadian vendor.
Offline Firebear31
Re: [IC] GMK Tuzi
« Reply #167 on: Fri, 27 November 2020, 15:57:58 »
omggg the novelties are so cute :DDD
Offline manic#1447
Re: [IC] GMK Tuzi
« Reply #168 on: Mon, 30 November 2020, 19:13:26 »
looks nice! now i wanna get it to got with lilac tsukuyomi
Offline Yukinon
Re: [IC] GMK Tuzi
« Reply #169 on: Mon, 30 November 2020, 20:26:37 »
Looks great. Can't wait for group buy.
Offline eggero
Re: [IC] GMK Tuzi
« Reply #170 on: Sat, 05 December 2020, 23:40:42 »
can't wait!
Offline clackeys
    • Clackeys
Re: [IC] GMK Tuzi
« Reply #171 on: Sun, 06 December 2020, 17:50:35 »
This is a cute set!
Offline iinko_mk
  • Status: broke
Re: [IC] GMK Tuzi
« Reply #172 on: Sun, 06 December 2020, 22:45:15 »
I love the purple man, sooooooo clean and cute!
Offline Galakc
Re: [IC] GMK Tuzi
« Reply #173 on: Mon, 07 December 2020, 14:47:47 »
Have to say this is a beautiful set!
Offline Kiggen
Re: [IC] GMK Tuzi
« Reply #174 on: Tue, 08 December 2020, 21:37:11 »
Would love to see another 1U R4 bunny in the Novelties Kit.
Offline boyjun
Re: [IC] GMK Tuzi
« Reply #175 on: Fri, 18 December 2020, 05:45:31 »
Hoping for a canadian proxy
Offline Daomington
Re: [IC] GMK Tuzi
« Reply #176 on: Mon, 21 December 2020, 10:40:46 »
Reserved!
Offline NoThankYou
Re: [IC] GMK Tuzi
« Reply #177 on: Fri, 25 December 2020, 18:56:17 »
Sign me up!
Offline dinosarrr
Re: [IC] GMK Tuzi
« Reply #178 on: Fri, 25 December 2020, 20:06:45 »
Uber cute. UwU
Offline Viriid
Re: [IC] GMK Tuzi
« Reply #179 on: Sat, 02 January 2021, 09:18:24 »
Cannot wait for the GB!
Offline wunderninja
Re: [IC] GMK Tuzi
« Reply #180 on: Thu, 14 January 2021, 23:45:59 »
Now this is heat.
Offline water-fairy
Re: [IC] GMK Tuzi
« Reply #181 on: Fri, 15 January 2021, 17:58:26 »
I can't wait for the group buy! This looks perfect!! <3
Offline Gnome
Re: [IC] GMK Tuzi
« Reply #182 on: Fri, 15 January 2021, 19:53:51 »
So excited for this set. I love everything about it, Soft and subtle colors, cute and expressive novelties, the story behind it, EVERYTHING!
Will definitely buy this set and deskmat the same day it enters Group buy.
Would've liked to see a cute bunny on an ISO enter key aswell. Thanks for making this set and i hope it enters Group buy ASAP!
Offline kibou store
Re: [IC] GMK Tuzi
« Reply #183 on: Sat, 16 January 2021, 16:18:38 »
This purple so lit
Offline SenseiJia
  • Hey you.
Re: [IC] GMK Tuzi
« Reply #184 on: Wed, 20 January 2021, 23:44:26 »
After some thoughts and talk. I decided to make some changes to the kits and add in a 40s/Extensions Kit.
Changes:
Base Kit: Moved extra B to extensions kit. Removed 00 Key. Moved Accent arrows to Spacebar Kit.
Spacebar Kit: Added Accent Bars. More of an accent add-on kit now.
This change might not be liked by some but I hope I can at least include more people into this group buy while keeping everybody reasonably happy~
~Will fix the space between PgUp/PgDn (Right now it's Pg Up Pg Dn, doh) and Extension's Kit 1.75 Backspace not being Text+Icon in the renders.
« Last Edit: Wed, 20 January 2021, 23:53:35 by SenseiJia »
Offline SenseiJia
  • Hey you.
Re: [IC] GMK Tuzi | Groupbuy Feburary 1st!
« Reply #185 on: Thu, 21 January 2021, 12:38:50 »
Hey everyone!
GMK Tuzi group buy will run from February 1st to February 28th.
Vendors:
US: Omnitype
CA: DeskHero
EU: MKB.eu
SEA: iLumkb
AU: DailyClack
New! Banderole
« Last Edit: Thu, 21 January 2021, 12:42:06 by SenseiJia »
Offline ponyo
« Reply #186 on: Thu, 21 January 2021, 12:46:41 »
This looks lovely - I can't wait. With Brexit potentially causing headaches with EU vendors shipping to the UK, is there any chance of a UK vendor (Prototypist maybe?) ?
Offline ogp3
« Reply #187 on: Thu, 21 January 2021, 12:49:56 »
Thrilled to see a 40s kit get added to this set - really looking forward to the groupbuy!!
Offline bkrownd
« Reply #188 on: Thu, 21 January 2021, 14:44:12 »
byebye paycheck, hello cute little bunny-critters
Offline misononyan
« Reply #189 on: Thu, 21 January 2021, 17:42:54 »
Ohhhhhhh my god. This is going to be my first GMK set, I can feel it
Offline sup3r170va
« Reply #190 on: Thu, 21 January 2021, 18:23:28 »
Looks good. Can I ask if any of the colours are standard colours? Eg for the white, is it WS1 or CP or some other colour?
Also, hoping for some tuzi rama caps :)
Offline scrubbiecris
« Reply #191 on: Thu, 21 January 2021, 19:08:19 »
So excited for gb, such a cute set!
Offline 2QT2BSTR8
« Reply #192 on: Thu, 21 January 2021, 20:02:05 »
It's in the first post, they're custom colours.
Offline HungHingDaiLo
  • 無間道
« Reply #193 on: Thu, 21 January 2021, 22:10:23 »
GLWGB!
Any chance for EN zFrontier as Asia proxy?
IG: @rayhhdailo
Offline vocal118
Re: [IC] GMK Tuzi | Groupbuy February 1st!
« Reply #194 on: Thu, 21 January 2021, 23:10:08 »
zf?
Offline water-fairy
« Reply #195 on: Fri, 22 January 2021, 01:31:16 »
oh no! EU vendor doesn’t send to UK!  :(
Offline Poesjuh
« Reply #196 on: Fri, 22 January 2021, 06:04:04 »
Yes we do.
Offline VXQN
« Reply #197 on: Thu, 28 January 2021, 13:10:47 »
Yes we do.
I believe water-fairy was referring to this on the mykeyboard.eu homepage?
260698-0
Offline Poesjuh
« Reply #198 on: Thu, 28 January 2021, 14:05:57 »
I understand. And there are still some challenges with shipping to UK. But we are shipping to the UK again slowly and keep in mind that Tuzi won’t ship for 9-12 ? months.
So it’s save as a UK buyer to join, we’ll make it work.
Offline ryukomatoi
« Reply #199 on: Thu, 28 January 2021, 21:26:32 »
Looks like SNES theme but cleaner. I'm interested.
