Author Topic: [IC] EPBT Less But Better [UPDATED DEC.3]  (Read 90141 times)
Offline Charks!
Re: [IC] EPBT Less But Better [UPDATED DEC.2]
« Reply #50 on: Wed, 02 December 2020, 02:51:12 »
I think there's some jumble up on the R1,R2 etc indicator in Base kit picture...can you double confirm?
Offline openkeydesign
« Reply #51 on: Wed, 02 December 2020, 09:35:33 »
Yes. Thank you. We will make it right in the next version.
Offline Techlet
« Reply #52 on: Wed, 02 December 2020, 12:41:06 »
I like the overall looks of this set. However, none of the text only mod keys are horizontally/vertically centered where you would normally expect them to be. For example, escape and the R4 mods in the base kit all sit low; and R1 delete, end, page down all sit high and to the right.
Is this an issue with the renders or are the keys meant to be like this?
« Reply #53 on: Wed, 02 December 2020, 23:06:37 »
No EU vendors? :(
Kbdfans could accept orders from EU I think.
Offline bansheetango
Re: [IC] EPBT Less But Better [UPDATED DEC.3]
« Reply #54 on: Thu, 03 December 2020, 04:05:00 »
They do, import is a hassle though.
Offline spamnyams
  • Potato
« Reply #55 on: Thu, 03 December 2020, 10:02:04 »
Ooooooo  :thumb:
Offline Prestley
    • Twitch
« Reply #56 on: Thu, 03 December 2020, 22:29:35 »
Really dig this set. Just ordered from kbdfans too so I could get a few dollars off when this goes up!
Offline Convergence
« Reply #57 on: Fri, 04 December 2020, 20:06:40 »
Very clean, the only thing that would made this perfect for me is purple accents in the color dots kit and a 1.5u fn in the base kit.
I do share the sentiment that an EU vendor would be much appreciated, importing can be a nightmare.
« Last Edit: Fri, 04 December 2020, 20:41:24 by Convergence »
Offline whirlwind
« Reply #58 on: Fri, 04 December 2020, 23:47:08 »
No EU vendors? :(
What do you mean "you think"?
Did you not try to find any EU vendors for us and by assuming that we can order from KBDfans that will magically solve your problem? Are you aware we pay import tax from vendors such as KBDfans?
If that's the case, I'm voting with my wallet and I will not buy this set I think.
Sent from my XQ-AS52 using Tapatalk
Offline Ry0t@
« Reply #59 on: Sun, 06 December 2020, 08:09:53 »
That looks amazing! I'd be 100 percent in, if only it had a NorDe kit! No plans for that?
Offline clackeys
    • Clackeys
« Reply #60 on: Sun, 06 December 2020, 17:32:41 »
Very excited for how clean this is looking, belongs on one of our white boards.
Offline dibkib
« Reply #61 on: Thu, 10 December 2020, 02:37:26 »
I really like this, but as discussed by others, I'd really appreciate an EU vendor.
Offline PHYLO
« Reply #62 on: Wed, 16 December 2020, 10:07:00 »
I genuinely wish more keycap sets tried out different typefaces/fonts for the legends. These are the best ones I've seen so far.
Offline Cubic // esc lab
  • Formerly 'esclab'
    • esc lab
« Reply #63 on: Wed, 16 December 2020, 12:28:54 »
I had some other thoughts last night. Very excited with the idea and a lot of good stuff here. But a few more ideas...Dieter rams was very against using anything that was not needed aka less is more. One of his ten design principles is that it uses as little design as possible. I understand the novelties and less kits are inspired by his other designs but are they betraying his design ethos? For example I don’t think putting a speaker design on a key would be something he would do because it does not involve the function. I also think it would be very unlikely that he would put a quote like “less is more on keys”. I think the idea of novelties in general to dieter would be frowned upon. So I think the less and novelties kits are not in line with his design philosophies if that is your aim. But I see what you were doing by taking his design ideas for things like speakers and putting them on keys. So it depends on what direction you want to go. Finally if you get rid of the novelties(less/novelties) then I think with the other kits capital alphas would seem quite strange as the mods are lower case and I love the the lower case look very cool. Just some more ideas... really excited for this.
I love the intention of this set as a fellow Dieter fan, but I agree that this could use improvements in terms of aligning with his 10 principles.
I'll offer some thoughts once I grab some coffee..
Offline nettik
« Reply #64 on: Wed, 16 December 2020, 13:59:09 »
I really like the theme behind this set, but a few things to think about:
Do you really need capitalized alphas if everything else is lowercase? I get some people might want all caps, but if literally all the mods are lowercase, the contrast is not going to look nice.
The novelty with six lines (I'm assuming that's a speaker grill or something?) is way too heavy in comparison to the rest of the set. Best example of what I mean is that first picture in your post - if you look at it from a glance, everything else looks the same uniform and pleasing weight except for those caps. It draws too much of your attention. Also the fact that I can't tell what it is tells you it's not a good idea for a novelty. I'm also not personally into the novelties (I keep misreading the 'but better' keycap as butter for some reason) but that might change with more renders.
Are you sure EPBT is the best choice for this set? EPBT caps can be blurry and I don't think it will work well for this font.
  • Formerly 'esclab'
    • esc lab
« Reply #65 on: Wed, 16 December 2020, 20:32:36 »
First of all, kudos for all the effort you put into both the keycap set design + the IC. Lots of attention to detail and illustration efforts.
I do want to preface that I understand this is your interpretation of Dieter Ram's design principles -- it's your creative direction to do it however way you like. There's no right answer, so only take what I say as suggestions. His principles are guidelines, not rules. Great designers break them every day. Design would be boring as hell if there was only one way to do things.
But let's get get to the feedback.
1. Legibility
I think this is the biggest issue with your set right now. I understand the intent to use what I am guessing is Helvetica Neue Light (or even Ultralight) in your legends. But the legibility is incredibly low, even after I expand the image. I'm not a fan of lower case fonts for legends. If you look at the Magic Keyboard from Apple (which is heavily inspired by Rams' work, and also a keyboard I own), they use all-caps + centered legends for alphas. The font weight is also higher, although not as thick as default GMK fonts.
While Helvetica Neue Light/UL is a very aesthetically pleasing weight, it was never intended for great legibility. You'll rarely see it used in places where readability matters (and in legends, it matters). It's often used as an accent font, or in large illustrations.
Suggestion: Capitalize the legends (to increase consistency of legibility) + increase the font weight.
2. Attention to detail
From my cursory look into all your individual sets, I found a few instances where legends aren't properly horizontally and vertically centered. This is something you must fix. For a set inspired by Rams, you really shouldn't be violating "design is thorough down to the last detail".
3. Novelties
I can see you spent a lot of time on the novelties and they look beautiful.
However, I'm personally not a fan of novelties. One of Dieter's design principles (of the 10) is that "design makes a product useful", "design makes a product understandable", and "is unobtrusive". I see that you are borrowing details from some of his most popular products as an homage to his iconic designs, but in doing so, violates those principles because they don't add anything to the design other than as an aesthetic homage. Rams aims not to add design for just the sake of design (such as purely aesthetic choices). There's few reasons to have those design details in the novelties.
Suggestion: Dig deeper into the 10 design principles, and really explore what would make sense as novelties.
4. Color dots
As an opposite, I think the color dots makes sense - they are both aesthetically pleasing and useful. The dots will replace keys that have axillary uses that aren't labeled. They let the user define the utility. It's both aesthetically pleasing and serves as a function. I love them. Good work here.
5. less
This is the one group that I am really not a fan of. The text "less, but better" serves as a complete anti-thesis to what the text itself is trying to say. By adding that text, you aren't introducing less, nor are you adding anything better to the design. Dieter himself would never add text like this into his designs. Never.
Suggestion: Remove this.
6. Manufacturing
Let's say you do choose to go ahead with manufacturing (and it seems like you have, considering you've already chose ePBT), the legibility will be my biggest concern. ePBT is quite flexible when it comes to the type of designs + fonts, so it'll be better for you, but I would order samples of the Helvetica Neue Thin/Ultrathin to make sure the print does not bleed, and/or is legible.
Suggestion: Order samples and make sure readability is emphasized.
7. IC post suggestion
Due to the small font weight + lots of whitespace in your renders -- I found it quite hard to get a read of your keycap set in general. I would reduce the whitespace in your renders more, so people don't have to zoom into each picture as much.
Your hero shot (the first image with all the renders at once) is essentially unreadable even while the image is expanded.
I would personally also take out the "less, but better" in every render. I understand this is the name of your keycap set, but it's a little redundant and even stretches into corniness when overused.
I would also start both a Discord and Instagram account. The former helps you build your community and provide instant updates to your supporters. Instagram helps you build an audience for your set. A design language like this will get you quite a good number of followers if you keep your posts consistent.
Suggestions: Reduce the white space in your renders so us readers can quickly scan your IC post with minimal interaction. Start a community via Discord and IG.
All in all, I think your IC is very very polished. My feedback does not take away the effort + heart you put into this design.
I actually tend to write a lot when I see something that has a lot of potential but can use a bit of a push to become even better. I especially love the small Rams details you included in the IC such as the radio dial-type design details that is signature to his style.
Rams' design principles are like he says.. principles. They're not rules. Some of the best design in the world may not even follow close to Rams' work. It is up to you, the designer, to make these design choices. But since you said you are designing something inspired by Rams, I applied my feedback through the lens of his principles.
Really looking forward to what you do moving forward and any further updates.
GLWIC.
loop @ esc lab
« Last Edit: Wed, 16 December 2020, 21:08:00 by esclab »
Offline Jefff
    • jlabs.co
« Reply #66 on: Wed, 16 December 2020, 21:06:26 »
I do want to preface by me understanding this is your interpretation of Dieter Ram's design principles -- it's your creative direction to do it however way you like. There's no right answer, so only take what I say as suggestions.
1. Legibility
3. Novelties
4. Color dots
5. less
6. Manufacturing
GLWIC.
loop @ esc lab
Great feedback!
Offline _rubik
« Reply #67 on: Wed, 16 December 2020, 22:25:37 »
The type isn't quite to my taste, but I _love_ those novelties. Super cool  :thumb:
Offline ryukomatoi
« Reply #68 on: Mon, 21 December 2020, 15:08:19 »
I see a potentially great product and the community has some pretty good feedbacks.
I will agree that it may not be easy for ePBT to implement the thin fonts. If it can be executed, then great. If not, I honestly wouldn't mind the legends to be bolder.
I do appreciate the "less but better" concept, however I feel that the design aesthetic doesn't completely follow. My only gripe is the modifiers. When modifiers have both symbols and legends, it just looks too busy in my opinion. To respect the less-but-better concept, I feel that it should only have one or the other, not both. A nice example would be to take a look at ePBT's GoK x BoW keycap set.
Regardless, I look forward to see new renders and sample keycaps. Having mentioned the GoK x BoW set, you can already tell that I'm a sucker for a WS2 white keycaps with CR legends, especially made by ePBT.
Offline Jacki
« Reply #69 on: Mon, 21 December 2020, 15:12:19 »
I wish the Font was bigger and darker so it's more visible
[img width=267 height=120]https://i.imgur.com/in3VqH2.jpg[/img
Offline mrvco
« Reply #70 on: Sun, 27 December 2020, 14:57:18 »
Text + Icons on the mods is a bit much, one or the other would be my preference.  I'm not a fan of the 'Less' kit (way too busy) and some of the 'Novelties' are ok (the horizontal line keys are a bit overwrought for my tastes), but I do like the 'Dots' kit.  All that being said, it would be good to hear some feedback on your confidence that ePBT can pull off these legends as PBT dyesub.
Offline geveent
« Reply #71 on: Sun, 27 December 2020, 19:19:01 »
I want it now. Please start selling the keycaps. The keycaps are perfect. You don't have to change anything.
Offline Casserole
« Reply #72 on: Sun, 27 December 2020, 21:13:09 »
really digging this set. Love the novelties! Share the concern with others about how thin characters are on the set. Hope to see it soon!
« Reply #73 on: Sun, 27 December 2020, 22:10:00 »
I have to say, I am still concerned by the thin legends. I am not sure if ePBT will be able to do this level of detail considering their previous issues with regular thickness legends. Regardless, I will be pleasantly surprised if it does actually come out properly. good luck!
Offline Sandy
  • Formerly cogitoergofemme
  • Sandy - Peach Tray Maker
    • the peach · studio
« Reply #74 on: Wed, 30 December 2020, 22:00:33 »
This is really well executed!
🍑C11🍑KWA.6🍑GPK60 47-GR1RE🍑Vast60🍑Rose60🍑EHKB🍑Viktus Sinne🍑Boop65🍑Jelly60 Pro🍑Fuji65🍑Ginkgo 65🍑S7.7🍑Treasure Type-9 II🍑Thermal R2🍑Jelly 60🍑
Offline santela
« Reply #75 on: Thu, 31 December 2020, 00:59:22 »
Same. Given how thin these lines are, I am pretty doubtful.
Offline Corruto
« Reply #76 on: Thu, 14 January 2021, 04:36:57 »
I would love an International Kit. Really want this!
Offline apophene
« Reply #77 on: Thu, 25 February 2021, 08:59:33 »
Love, love, love this. Can't wait to give you my money. Am building a Sinc right now with an acrylic/plywood case...this will be perfect.
Offline Capone1423
« Reply #78 on: Sun, 28 February 2021, 12:52:34 »
is there any chance for an international kit?
Offline Extra Fox
  • quis qui sais
« Reply #79 on: Sun, 28 February 2021, 16:14:13 »
I really enjoy Dieter Rams' aesthetic and this set is really fantastic.
I think Loop did a great job with his suggestions. So the only suggestion I have would be to echo others and say I'd like the letters to be center-center on the keys.
Personally, while I fully appreciate Dieter Rams principles, I do like the novelties.
A-a-ron
Offline kchlam
« Reply #80 on: Sun, 28 February 2021, 19:16:18 »
Hmm interesting, very neat to see lowercase on the alphas
Offline apophene
« Reply #81 on: Fri, 05 March 2021, 13:28:03 »
Am seeing [Coming Soon] instead of [IC] now on KBD Fans... and a date of 15 March. Hype!   :cool:
  • Formerly 'esclab'
    • esc lab
« Reply #82 on: Fri, 05 March 2021, 20:12:07 »
Looks like there will be no changes made from the feedback that folks have given?
Offline yotasan
    • ARCANE - PHOTOGRAPHY ARCHIVE
« Reply #83 on: Fri, 05 March 2021, 20:49:53 »
i love how simplistic these keycaps are, i love the novelties too.
Offline -Jerry-
  • OR '1'='1'
    • Jerry Talks Tech
« Reply #84 on: Sun, 07 March 2021, 16:14:38 »
These are so clean and beautiful - so tempting!
"Romeo"     "Split75"   "Melody96"     "KBD8X MKII"     "Womier K87"
Offline elmo
  • Hello I like keyboards
    • Elmo's keyboards
« Reply #85 on: Mon, 08 March 2021, 07:32:29 »
Will continue to update renderings
can you perhaps use a decent image hoster?
this right here is a bit weird...
  • Formerly 'esclab'
    • esc lab
« Reply #86 on: Wed, 10 March 2021, 03:26:36 »
Seems like this set is going into GB with vendors with no changes/response from OP on the feedback
Offline hottrout
  • I'd Hit Dat Key
« Reply #87 on: Wed, 10 March 2021, 15:46:11 »
My thoughts as well. If you don't want your customers opinions, don't bother to ask.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline LordHaveMercy
« Reply #88 on: Wed, 10 March 2021, 19:22:49 »
I got a feeling that Killer is not exactly the one in charge of this layout. That might be why they're not too responsive at this point. Also, I have this general 'feeling' that there might be a slight language barrier with OP, too.
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
« Reply #89 on: Thu, 11 March 2021, 06:59:37 »
clean
  • Formerly 'esclab'
    • esc lab
« Reply #90 on: Mon, 15 March 2021, 15:36:47 »
Looks like this went into GB officially today. Granted I still think it's a good looking set, but OP just drive-by ICing (which makes it look like an ad) and not responding/listening to all the constructive and good feedback people provided is fairly disappointing.
I was originally quite intrigued by the set but I'll be voting with my wallet that this isn't good behavior.
Good luck with GB nonetheless.
EDIT:
I'm confused. Looking at the non-render layout photos in the GB pages, the legends look like they're not using the Helvetica Light Neue weight, while the renders look like they are.
So which one is it?
Additionally, have you checked if you're allowed to use the "Less, but better" quote without needing to consult Dieter Rams? Not sure if this is trademarked or not.
« Last Edit: Mon, 15 March 2021, 15:41:35 by loop | esc lab »
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #91 on: Wed, 17 March 2021, 00:52:13 »
In addition to the distasteful "drive-by IC" and lack of response to constructive criticism, I'm specifically concerned about the very thin text in some of the legends.
This one is all but guaranteed to run way behind schedule and/or deliver a sub-par product in the end.
Great idea, but unfortunately I am not willing to tie up anhy more money in risky GBs. Good luck to anyone who wants to join.
Offline RickHoen
« Reply #92 on: Wed, 17 March 2021, 07:44:07 »
I see people asking about an EU vendor, but there is one right?
Not sure why this is not mentioned anywhere: https://candykeys.com/group-buys/epbt-lessbutbetter
Offline DwieDave
« Reply #93 on: Fri, 19 March 2021, 11:47:38 »
Greetings, Humans!
Now that the Group buy has started:
Is there an official [GB] Thread?
Offline glibber
« Reply #94 on: Wed, 31 March 2021, 04:30:36 »
Since this is in GB now, just a heads up for anyone looking to build a DE layout (or possibly other international layouts too):
The labelling on the international kit isn't entirely correct in the renders, not sure if it's going into production like that. See my original post here.
I have tried to contact the OP about this, but haven't received an answer yet (and don't think I will).
Really sad to see how this thread went in general, I think it's a great looking set.
Offline gh_pp
« Reply #95 on: Tue, 13 April 2021, 23:56:41 »
5. less
I agreed with this 100%.
I think the "less" set with the color accent is essential to make a unique and stand out look to any board, but the "less, but better" text is just completely anti "less, but better". I do like the black novelty included in the "less" set, it is a great addition to complement any design.
Initially I have base + extra + novelty + dots + space bar in my cart.
But I already have a lot of black on white pbt sets, so in the end I just pre-ordered the novelty + dots. (would love the black novelty but can't justify having all the colored keys with text that I won't be using)
I think these two sets are super flexible and can complement any BoW set, I especially like the 2.75 + 2.25 novelty, super useful for split spacebar user !
Looking forward to production and hopefully epbt can overcome the thin font concerns mentioned by others.
QFR brown x2, Realforce 45G, Type-S, Keycool 22 blue
Previous keyboards: 55G, IBM Model M, Dell AT101W, Fujitsu FKB4725, G80-3000 clear, QFS green, QFS blue
[WTB] Custom keyboard build
Offline ClerklyTexas
« Reply #96 on: Thu, 22 April 2021, 09:34:28 »
Now that the group buy is over, where can we look for updates on production?
Offline Extra Fox
  • quis qui sais
« Reply #97 on: Thu, 22 April 2021, 10:54:03 »
The starter of this IC/GB 'openkeydesign' last visited 2021-02-04.
I can't be certain, but I'm not hopeful there will be updates.
A-a-ron
  • Formerly 'esclab'
    • esc lab
« Reply #98 on: Thu, 22 April 2021, 11:51:07 »
Your best bet is probably look for vendor updates instead of designer updates
Offline LordLootus
« Reply #99 on: Fri, 03 September 2021, 12:19:49 »
Anyone seen any updates on this? I haven't seen any vendor updates at all on what is happening.
