Author Topic: [IC] Project Affogato Wrist Rest (Wood & Alu) Updated 11 Aug.  (Read 27790 times)
Offline KeepCalm27
Hey everyone, this is KeepCalm27. People have been seeing a lot of keyboards and keycaps interest check, but today I will present to you something equally important, the Wrist Rest.
For the first round, it will be only available for 65% size (315.5mm Length).
IN STOCK SALE on DEC 22
GB Link: https://geekhack.org/index.php?topic=115690.msg3100549#msg3100549
IC Form:https://forms.gle/pv8HiWrXt7schQQ86
Thank you for your patient to fill it out. Every suggestion means a lot.
Update December 9, 2021
Louis and I have been working on international transport for a long time. Finally we are close to in-stock sale, probably in 1-3 weeks.
Forged carbon fiber panels are also in-stock, but limited number.
QC are 95% done at iLumkb.
Sent to streamer, build und use guide on the way!
Update September 14, 2021
All Manufacturing was finished on August 27, and was sent to vendors. EU vendor is Oblotzky. Still need some time for vendors to QC all units themselves.
Another new panel material is decided, which is forged carbon fiber. And leather panel is waiting for prototypes. I will post some photos of forged carbon fiber panel by the end of this month.
Update August 10, 2021
Prototype II works well and also looks well. I finally choose Equalz as my alu part manu, they get pretty good quality control.
All the cushion layers are silicone now, which is easy to install.
Some people ask me about the magnetic connection. Actually it makes changing the top panel of wrist rest easier, which means the top panel is not glued onto the alu base. I tested several magnet combinations and finally makes sure when the panel is lifted, the base won't be lifted together, and when holding the wrist rest upside down, the panel won't drop. There will be other panels availble in the future. I have already ordered some forged carbon fiber panels from several suppliers.
Here are some photos of the second prototype.
Original Walnut, this panel isn't the final version, which is made by hand & CNC. It will be more accurate in the mass production.
With some wax (You can apply some was if you want)
Base and top panel
Magnetic connection
With Percent Canoe Gen2 (this board is a little bit wider than normal 65% keyboards)
Packaging was designed, and sample was made and still on the way to my house.
Update August 2, 2021
Just got my alu part of prototype II, new manu is better than previous one. Soon I will post some new photos of it.
Wood part of prototype II is not reaching my standard, so it needs a few more days to re-make.
Features:
8-degree angle
Aluminum base & wood top panel (optional forged carbon fiber panel)
Magnetic connection with Silicone cushioning layer
Silicone protection layer between wrist rest & keyboard
Structure:
Prototype I Photos:
Dimension:
Front height: 4mm, Rear height 16mm (Lower profile makes typing more comfortable)
Length: 315.5mm, which perfectly matches 65% keyboards, eg: Keycult No.2/65, Aurora Input Series 65, etc.
Width: 85mm
Colors:
R1 will be limited to Black Anode / Dark Walnut. Forged carbon fiber panels are provided as an option.
Vendors:
Asia: iLumkb
EU: Oblotzky Industires
Pricing and In-stock Quantity:
Price: to be determined
In-stock Quantity: 160 Units for R1 (R2 depends on the demand)
To-do:
Get prototype I (without magnetic connection, tested)
Get prototype II (with magnetic connection)
Design the outer packaging (Probably carton with EVA)
Finalize selling details (In-stock quantity, colors, pricing)
« Last Edit: Mon, 20 December 2021, 05:04:00 by KeepCalm27 »
Offline KeepCalm27
Re: [IC] Project Affogato Wrist Rest (Wood & Alu)
« Reply #1 on: Tue, 27 July 2021, 02:33:25 »
Reserved ;D
Offline Lya
« Reply #2 on: Tue, 27 July 2021, 02:40:35 »
冷静哥 YYDS, i want this ASAP
Offline Caseybb
« Reply #3 on: Tue, 27 July 2021, 02:53:12 »
GLWIC!
Offline Crushader
« Reply #4 on: Tue, 27 July 2021, 03:26:28 »
I'm really interested if there's a 96%/1800 size, white color and lighter wood like maple/pine, etc
Offline Altain
  • Formerly zungzangbi
« Reply #5 on: Tue, 27 July 2021, 03:54:19 »
Insta buy 100% (please more production units!) also I'm pretty sure the success of first couple of rounds will eventually and definitely move on to the product lineup expansion, so definitely joining.
Offline kuro0renji
« Reply #6 on: Tue, 27 July 2021, 04:12:49 »
Looks beautifully crafted.
Offline Slayer77
« Reply #7 on: Tue, 27 July 2021, 05:45:34 »
Most keyboards are 5-7 degree, why have you gone with an 8 deg angle? Do you have a specific board in mind?
Sent from my GM1911 using Tapatalk
Offline KeepCalm27
« Reply #8 on: Tue, 27 July 2021, 06:40:26 »
8-degree works well with 5-7-degree boards as well, more important is the lower profile. Actually this angle doesn't makes much difference, but the width does. My Keycult No.2/65 and Aurora Input Series 65 are both 8 degree, and it also works great with my E6.5.
Offline dudewth
« Reply #9 on: Tue, 27 July 2021, 08:03:50 »
looks nice - definitely interested
Offline dexie
« Reply #10 on: Tue, 27 July 2021, 08:15:46 »
Looks really neat. Will buy one if shipping to europe is not very expensive.
ISO Life
Offline KeepCalm27
« Reply #11 on: Tue, 27 July 2021, 09:14:13 »
Hope it won't be too expensive, or maybe consider finding a EU vendor?
Offline Visionaire
« Reply #12 on: Tue, 27 July 2021, 09:23:07 »
Stunning design and love the combination of materials. I hope to see a lot more of this in the future.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #13 on: Tue, 27 July 2021, 10:13:44 »
Saw this over at the Keycult server gallery. Stunning work. Will be interested if the price is hopefully not too high.
Great stuff.
Offline KeepCalm27
« Reply #14 on: Tue, 27 July 2021, 10:24:03 »
Great stuff.
Thank you! I hope it won't become to expensive, but CNC machining the both part accurately is kind of costy. I'm still trying to negotiate with the both manu, hopefully lower the price.
Offline brunosan_.
« Reply #15 on: Tue, 27 July 2021, 12:48:52 »
I really like the design of it. GLWIC.  :thumb:
Offline Slayer77
« Reply #16 on: Tue, 27 July 2021, 12:52:30 »
Thanks for the reply, appreciate the response! hope you make a tkl one after this :)
Offline darthcapn
« Reply #17 on: Tue, 27 July 2021, 12:54:34 »
I like the design aesthetic of this. A must buy!
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline Techlet
« Reply #18 on: Tue, 27 July 2021, 14:15:58 »
This but TKL size please.
Offline Yuinth
« Reply #19 on: Tue, 27 July 2021, 16:12:09 »
Love the design and the colors chosen for the first round. Will try to get one for sure.
Hopefully there's enought demand for more rounds with more colors and sizes.
GLWIC & GB
« Reply #20 on: Tue, 27 July 2021, 19:22:32 »
I will 100% buy this for my Jelly Epoch. great job
Offline wowaweewa
« Reply #21 on: Wed, 28 July 2021, 09:29:05 »
Very nice, although I think this wouldn't really fit my Hello M0110 keyboard, since the case has rounded edges... Ah well, could just buy a new 65% instead!
Offline DuellM
  • Keyboard Fatty
« Reply #22 on: Wed, 28 July 2021, 09:32:22 »
This in E-White with Oiled Maple would look Fantastic  ^-^
Offline KeepCalm27
« Reply #23 on: Wed, 28 July 2021, 13:02:23 »
I just order a new prototype from manu, which is silver+cherry. I will try to figure out a light color combination, thanks for your advice!
Offline KeepCalm27
« Reply #24 on: Wed, 28 July 2021, 13:27:25 »
I'm still considering TKL version, but according to the way we use TKL, it might be asymmetric. But I'm sure 60% & TKL will be made in the future.
Offline hottrout
  • I'd Hit Dat Key
« Reply #25 on: Wed, 28 July 2021, 14:31:35 »
Take my money.  Then take it again for a TKL version.  Then take it again and again for a Bear version and a NAUS version.  Keep bringing more versions out and I will keep buying them.  Love the initial design and would love to see someone really go to town on good wrist rest designs.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline KeepCalm27
« Reply #26 on: Thu, 29 July 2021, 02:39:27 »
Thanks for supporting! I will bring up 60% & TKL soon after I finish 65%. I still have some new design in my head, some of them are already in my computer. I will still focus on Wrist Rest, cuz I think it really helps while using keyboards.
Offline hottrout
  • I'd Hit Dat Key
« Reply #27 on: Thu, 29 July 2021, 04:09:27 »
Good fitting wrist rest is essential to any Alice style board and is often overlooked by the board designers.  I have many boards that need a fitted rest.  You make them and I will buy them.
Systems -
  Keyboards -
Offline Xherion
« Reply #28 on: Thu, 29 July 2021, 06:34:24 »
Very nice design, filled up the IC
Offline KeepCalm27
« Reply #29 on: Thu, 29 July 2021, 08:19:52 »
Offline cadrev
« Reply #30 on: Fri, 30 July 2021, 18:07:41 »
Insta-buy for me, just hope the price is manageable!  :thumb:
Offline KeepCalm27
« Reply #31 on: Sat, 31 July 2021, 02:21:13 »
still checking details and pricing with manu, i'm sure it won't be too high. And it is pretty sure worthy.
Offline vheissu
  • Pragmatic Geometrist
« Reply #32 on: Sat, 31 July 2021, 02:27:57 »
I know you are still checking details with your manu about pricing, but do you have any estimate? Your design is stunning btw I really dig it :thumb:
Offline KeepCalm27
« Reply #33 on: Sat, 31 July 2021, 02:39:32 »
black ano / dark walnut will be like $100-130, i think. I'm still not sure, cuz Prototype II has not been checked yet.
Offline General_Pretzel
« Reply #34 on: Sun, 01 August 2021, 21:55:58 »
By far the coolest looking wrist rest I've ever seen! Would definitely pick up a few different sizes!
Offline HappyB0T
  • I'm a Piggie
« Reply #35 on: Sun, 01 August 2021, 22:51:26 »
+1 Looking fantastic!
Offline PokeH
« Reply #36 on: Sun, 01 August 2021, 23:04:02 »
Looks so good. Hope it goes on GB soon so I can pick it up.
Offline KeepCalm27
« Reply #37 on: Mon, 02 August 2021, 09:46:12 »
Thanks for supporting! I will keep on working to bring you guys better wrist rest!
Offline Tree_
« Reply #38 on: Tue, 03 August 2021, 03:30:20 »
Would be super keen if I could get a rose gold to match my Vega,  ;D
Offline KeepCalm27
« Reply #39 on: Tue, 03 August 2021, 03:43:49 »
Fill up the form and I will see if it is possible to bring up different color in next round.
Offline KeepCalm27
Re: [IC] Project Affogato Wrist Rest (Wood & Alu) Updated 11 Aug.
« Reply #40 on: Wed, 11 August 2021, 01:33:16 »
Prototype II updated, move on to manufacture process.
Offline darthcapn
« Reply #41 on: Wed, 11 August 2021, 11:22:02 »
Any proxy for the US? Are you looking for vendors?
Offline KeepCalm27
« Reply #42 on: Thu, 12 August 2021, 02:58:47 »
For the first round, which has already begun manufacturing, likely only iLumkb. But iLumkb told me about shipping fee to US, it will be around 25 USD with DHL within 5 days.
If you guys like this design and my future design of wrist rest, yes, I will reach out to US vendors.
Offline darthcapn
« Reply #43 on: Thu, 12 August 2021, 08:13:25 »
Makes sense! Glwgb!
Offline LONGZILLA
  • ヽ(`Д´)ノ rawr
« Reply #44 on: Wed, 18 August 2021, 17:03:43 »
The prototype with additional wood finish turned out amazing.
« Reply #45 on: Wed, 18 August 2021, 22:31:17 »
Wow - the second proto looks incredible! Will definitely be picking one up! Very exciting!
Is there another place we can follow along the project (Discord), or will everything just be posted on GH?
Offline KeepCalm27
« Reply #46 on: Thu, 19 August 2021, 09:20:34 »
In iLumkb Discord, Louis will post the update there. Round 1 nearly finish manufacture and when I finish QC and send them to iLumkb, they will annouce the selling detail in discord channel.
Offline kenstvr
« Reply #47 on: Sun, 22 August 2021, 03:47:33 »
Super keen for this!! Have been looking for a good wrist wrest and i really like this design.
Offline keguira
« Reply #48 on: Mon, 23 August 2021, 04:43:04 »
already asked in the form but maybe i'm not the only one wondering : where will the wood come from ? Upcycling ? if not, will it have some certification to avoid some sh**** wood mafia ?
Offline MOO·OON
« Reply #49 on: Mon, 23 August 2021, 21:57:27 »
 :thumb: nice work.
