Author Topic: [IC] IRON160 by Smith + Rune (All info avail! Hotswap is now a kit option!)  (Read 85930 times)
Offline voxkey
Okay community you've won, we finally made a 60...
Smith + Rune Website
Join Smith + Rune Discord
Follow us on Instagram
We've taken the IRON165r2 and chopped off a row of keys! Well we did a bit more than that, making small changes and tweaks along the way to further improve the IRON design, but it sounds a lot more fun describing it that way.
Oh, and we brought plum back!
YouTube Videos and Typing Tests
Interest Check Forms - Please Fill These Out
IRON160 General Questions and Feedback #1
IRON160 Plate and PCB Questions and Feedback
Timeline, Vendors, and Quantities
Group Buy Start Time
The group buy will go live April 30th, 2022 at 10 AM EDT worldwide!
Vendors, Pricing and Quantities
We're once again partnering up with CannonKeys in the US, DeskHero in Canada, MyKeyboard in the EU, and iLumkb in the SEA market to handle sales once again.
If you are unsure which vendor covers the country you live in, please reach out to the vendors directly to confirm.
Limit 1 per order.
Vendor Links and Pricing
Choosing the copper bottom replaces the standard aluminum bottom, you will not receive both.
CannonKeys - North/Central/South America Vendor (excluding Canada)
1000 boards, CannonKeys hybrid FCFS/raffle checkout
$479 USD w/black anodized aluminum bottom
$699 USD w/full copper bottom (sandblasted, matte finish, not brushed)
DeskHero - Canadian Vendor
$649 CAD w/black anodized aluminum bottom
$945 CAD w/full copper bottom (sandblasted, matte finish, not brushed)
200 boards, custom raffle/queue checkout
MyKeyboard EU - European Vendor
300 boards, FCFS
€509 inc VAT (€421 wo/VAT) w/black anodized aluminum bottom
€739 inc VAT (€611 wo/VAT) w/full copper bottom (sandblasted, matte finish, not brushed)
iLumkb - AP Vendor
500 boards, FCFS
$689 SGD inc GST w/black anodized aluminum bottom
$1009 SGD inc GST w/full copper bottom (sandblasted, matte finish, not brushed)
Iron160 Features
  • Choice of WK, WKL, or MX HHKB top
  • 7 Degree Typing Angle
  • Full Gasket Isolation Mount
  • Bottom Accent Plate w/exposed rune logo
  • Low-Profile Front Height (less than 17.25mm)
  • Seamless Case Design
  • QMK/VIA compatible PCB, designed in collaboration with Gondolindrim, choice of hotswap or solderable
  • Unified C3 USB-C daughterboard (centered on case)
  • Optimized plate for consistency on every key press (see analysis below)
Iron160 Colors
Each board comes with a black anodized aluminum base and contrasting aluminum accent "weight". Please refer to the prototype photos and renders for a visual depiction.
  • Black
  • Plum
  • Rosewater
Add-ons and Extras (All prices listed in EUR include VAT, all prices listed in SGD include GST)
  • Hotswap PCB w/daughterboard and JST cable - $60 USD / €65 EUR / $89 SGD / $82 CAD
  • Solderable PCB w/daughterboard and JST cable - $60 USD / €65 EUR / $89 SGD / $82 CAD
  • Copper plate - $50 USD / €55 EUR / $74 SGD / $68 CAD
  • Forged carbon plate - $50 USD / €55 EUR / $74 SGD / $68 CAD
  • FR4 plate - $30 USD / €35 EUR / $44 SGD / $41 CAD
  • Polypropylene plate - $40 USD / €45 EUR / $59 SGD / $54 CAD
  • Polycarbonate plate - $40 USD / €45 EUR / $59 SGD / $54 CAD
  • Aluminum plate - $40 USD / €45 EUR / $59 SGD / $54 CAD
  • Brushed brass accent weight (compatible with IRON165r2) - $60 USD / €65 EUR / $89 SGD / $82 CAD
  • Brushed copper accent weight (compatible with IRON165r2) - $65 USD / €70 EUR / $95 SGD / $88 CAD
  • Brushed stainless steel accent weight (compatible with IRON165r2) - $90 USD / €95 EUR / $132 SGD / $122 CAD
  • Salvun copper artisan keycap - $60 USD / €60 EUR / $89 SGD / $82 CAD
  • Smith + Rune artisan keycaps available in all three colors (anodized aluminum) - $38 USD / €42 EUR / $56 SGD / $52 CAD
  • Extra gasket set - $8 USD / €10 EUR / $12 SGD / $11 CAD
Supported Layouts
There will be three plate layout options, semi-fixed. All plates support split backspace and stepped caps. ISO plates may not be available from all vendors.
  • Tsangan (7u bottom row)
  • ANSI (6.25u bottom row)
  • ISO
  • If a hotswap PCB is chosen, your kit will come with a Tsangan plate which is the ONLY compatible plate with a hotswap PCB.
  • Due to physical key compatibility with the case, an ANSI plate is only an option when choosing a WK top.
  • Due to physical key compatibility with the case, WKL and MX HHKB tops will come with a Tsangan or ISO plate, both of which are compatible options.
  • ISO only supports a 7u bottom row, but is compatible with all three top options.
  • There is no ISO or 6.25u bottom row option for the hotswap PCB. Please refer to the PCB layouts below.
Solderable PCB Supported Layouts
Hotswap PCB Supported Layouts
Optimized Plate, the Process, and FEA analysis
Using FEA (finite element analysis) we were able to measure the simulated force on each switch plate hole to see how the plate would react to this force. The maximum displacement was recorded for every switch plate hole and relief cuts were added to the plate (iteratively) to try and make the displacement equal across all switch holes.  The results are measured in max displacement in mm 10^-2.  See the original IRON165 IC for details on how we went through testing methods.
What's In The Box
  • Iron160 Keyboard
  • Aluminum Plate
  • PCB, USB-C Daughterboard, and JST cable, choice of either Hotswap or Solderable
  • Gaskets and all mounting hardware
  • Custom screws for flush-mount look
  • New custom carrying hard case w/CNC foam inserts
I have a question about something that isn’t covered here!
This interest check is legitimately that and not everything has been figured out. It's possible the reason your question isn't covered is because we're still relying on feedback to make a decision. Please please please fill out the forms at the top of the IC. They will help us out immensely.
Or you could shoot us an email, visit our instagram, or join our Discord. Definitely, definitely join our Discord.
Links are at the top.
How do I stay up to date on this project?
You can follow along here, on Instagram, and Discord. You can also join our newsletter via our site. Links at the top.
Black Prototype (not renders)
Plum Prototype (not renders)
Rosewater Prototype (not renders)
Renders
Interest Check Disclaimer
Keep in mind this is an interest check. Nothing, including options, pricing, etc, is final until the GB starts. This IC represents the most correct, up-to-date information we have regarding the IRON160 at this time. Some things may change.
We will be announcing any changes, if any, here first, and on Discord as well.
Special Thanks
  • lbaron, boneandbee, and the rest of S+R staff, best team ever!
  • The entire Smith + Rune community, a bright light in a sometimes very dark world.
  • Everyone who has supported us along the way. We couldn't have got to this point without you!
« Last Edit: Fri, 29 April 2022, 11:05:32 by voxkey »
Offline voxkey
Re: [IC] IRON160 by Smith + Rune
« Reply #1 on: Thu, 17 March 2022, 21:33:38 »
Updates - April 28th, 2022
  • Pricing and sale formats has been updated for ALL regions.
  • Hotswap can now be chosen as on option with the kit. No need to purchase it separately. This decision was largely based on feedback from you, the community.
  • Necessary info has been added to the supported layouts section regarding plate and PCB options.
Updates - April 18th, 2022
  • We finally have pricing!
  • Custom screws will now be standard. We liked how all screws sat flush on the IRON180 so much that we've decided to continue this evolution by having custom screws made with the spacer built in.
  • We're revisiting the carrying case and making improvements. We're ditching the old foam for CNC'd foam and making a few more updates without sacrificing the protection the case provides.
  • An upgraded copper bottom will be offered. The feedback overwhelmingly pointed towards copper.
Updates - April 8th, 2022
  • Group buy date have been announced.
  • Vendors and quantities available have been announced.
  • Hotswap PCB will be available as an addon at the time of the group buy. Each IRON160 will come standard with a solderable PCB. This way we can still continue to support all layouts.
  • Polycarbonate and polypropylene plates will be available in addition to the forged carbon and aluminum plates.
  • Salvun artisan keycaps will be returning.
  • Smith + Rune artisan keycaps will also be available in all three board colors (like the ones offered with IRON180).
  • Brushed finish has been chosen for the brass, copper, and stainless steel accent weights.
  • Solid brass OR copper upgraded bottom, similar to what we offered on the 180. Please fill out the IC form and let us know what you prefer!
Updates - April 3rd, 2022
Upcoming additions to the group buy. We're hoping to finalize many of these options this week.
  • Hotswap PCB - we're not sure on layouts or how this will be offered, but we are 100% sure you'll be able to get one at group buy along with your IRON160!
  • Brass, copper, and stainless steel accent weights will be returning for this group buy as well. Still deciding on finish options. These will be compatible with IRON165r2 and vice versa.
  • Forged carbon plates will be offered as an addon. We're on the fence about offering a second option like PC so make sure to fill out those forms.
  • A ton of people want to see an upgraded alternate base option like we offered on the IRON180. Maybe brass or copper? Make sure to fill out the forms.
« Last Edit: Thu, 28 April 2022, 14:07:54 by voxkey »
Offline Rik.caffeinated
« Reply #2 on: Thu, 17 March 2022, 21:34:45 »
PLUM IS BACK BABY!
Offline Chippy
  • sus chef
« Reply #3 on: Thu, 17 March 2022, 21:37:47 »
Kinda cute.
1.2og | Buddy 6xx | Le Fishe V1 Proto | xyz60 Rev2 | Quartermaster | Chimera65 | Satisfaction75 | Realforce 84u | Zenith Z-150 | Realforce 86u | 378
This and the swiss cheese keyboard is the next generation of keyboards
Offline yoniwolf1202
« Reply #4 on: Thu, 17 March 2022, 21:37:58 »
Woooooo
Offline hover0423
« Reply #5 on: Thu, 17 March 2022, 21:38:08 »
Nice color~
Offline ThePanduuh
  • Discord @thepanduuh
« Reply #6 on: Thu, 17 March 2022, 21:38:28 »
Plum
I have some keyboards, mostly resin.
I like CAD. Making things is fun. [W] Projects
Offline vheissu
  • Pragmatic Geometrist
« Reply #7 on: Thu, 17 March 2022, 21:38:36 »
Offline Visionaire
« Reply #8 on: Thu, 17 March 2022, 21:38:40 »
PLUM IS BACK BABY!
Man, Rik first. He's on it.
Offline mixistor
« Reply #9 on: Thu, 17 March 2022, 21:39:00 »
Sheeeeeesh, plum is amazing :eek:
Offline boyjun
« Reply #10 on: Thu, 17 March 2022, 21:39:04 »
very nice
Offline novelflyer
« Reply #11 on: Thu, 17 March 2022, 21:40:09 »
Rosewater looks really nice
Offline totalemon
  • good morning :)
« Reply #12 on: Thu, 17 March 2022, 21:41:47 »
60s aren't my thing but this looks fantastic. best of luck luke and vox <3
Offline dRnRcRr
« Reply #13 on: Thu, 17 March 2022, 21:42:27 »
60 so good.
Sent from my SM-S908W using Tapatalk
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #14 on: Thu, 17 March 2022, 21:42:30 »
will you be addressing the wkl blockers
Offline misswaffle
« Reply #15 on: Thu, 17 March 2022, 21:42:45 »
So happy to see plum return!
Offline MrMar
    • Instagram
« Reply #16 on: Thu, 17 March 2022, 21:44:29 »
Yep.
Offline KneeDeep
« Reply #17 on: Thu, 17 March 2022, 21:45:58 »
Been super stoked for this announcement, congrats guys!
Offline h40
    • h40.io
« Reply #18 on: Thu, 17 March 2022, 21:46:31 »
I'm in for plum for sure.
Offline marshmellohs
« Reply #19 on: Thu, 17 March 2022, 21:47:22 »
rosewater good
Offline MOON
« Reply #20 on: Thu, 17 March 2022, 21:47:37 »
Does it have RGB and work with my DZ60 PCB?
Offline Easonic
« Reply #21 on: Thu, 17 March 2022, 21:48:24 »
boring
Offline lbaron
« Reply #22 on: Thu, 17 March 2022, 21:48:51 »
We listened too what the community wants and addressed it for this board.
Offline Xanira
  • Where am I? Who am I?
« Reply #23 on: Thu, 17 March 2022, 21:53:46 »
can i have one pls
Offline darthcapn
« Reply #24 on: Thu, 17 March 2022, 21:57:30 »
I want this right now. Not a year from now. Right now.
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline Lysol_
« Reply #25 on: Thu, 17 March 2022, 21:59:39 »
hopefully, blockers are fine this time. :)
Offline Dianoda
« Reply #26 on: Thu, 17 March 2022, 22:06:57 »
Got to go hands on with a few of the (unbuilt) protos at a recent meetup, very nice in person and the maroon HHKB was a beaut.  Very much looking forward to this one!
Offline Gondolindrim
    • My GitHub
« Reply #27 on: Thu, 17 March 2022, 22:08:40 »
lets gooooo
A pessimist will tell you the cup is half empty. An optimist will tell you the cup is half full. An engineer will tell you it's exactly twice the size it needs to be.
Offline tsukune1349
« Reply #28 on: Thu, 17 March 2022, 22:13:06 »
Listen up people, you'll be allowed to purchase yours once my Rose Water is secured in cart and successfully checked out.
« Last Edit: Thu, 17 March 2022, 22:15:02 by tsukune1349 »
Offline hali
  • OHHHH MY GODDDDDD
    • hali.studio
« Reply #29 on: Thu, 17 March 2022, 22:31:02 »
what was the content of the message exactly? i feel like something as important as that should be in the main post too, considering some of the other comments i've seen
Offline shima
  • keeb weeb
« Reply #30 on: Thu, 17 March 2022, 22:33:44 »
is there finally no chode
boards: anura
Offline meawto
« Reply #31 on: Thu, 17 March 2022, 22:39:22 »
Offline Nurseh
  • Sorry for always apologizing
« Reply #32 on: Thu, 17 March 2022, 22:44:08 »
Nice to see. Brass bottom and possibly a white would pique my interest.
Offline HelloThisIsDog
« Reply #33 on: Thu, 17 March 2022, 22:46:54 »
This will be all alu only, no brass options?
Offline city
    • twitch
« Reply #34 on: Thu, 17 March 2022, 22:59:11 »
Definitely in for an HHKB.
Offline Vaiur
« Reply #35 on: Thu, 17 March 2022, 23:00:08 »
Iron, so hot right now.
CB87:Sakabato Black/Red/Brass | Think6.5v2 Deep Ocean 1u | Alpine65 eWhite | Vega Grey | RAMA u80a SEQ2 Sage | Iron165 r2 Graphite | Mode80 Lotus | Geon Frog F12 Black | Keycult 2/65 Purple Unfinish | Geon F2-84 Black | JJW Cloudline Navy/Silver | Iron165 r2 PC Atomic Purple
Offline kabocha
« Reply #36 on: Thu, 17 March 2022, 23:11:17 »
The mad lads at SR has finally answered the call. 60% with the option of HHKB blockers. Bless up and also PLUM!
Offline scoopbb
« Reply #37 on: Thu, 17 March 2022, 23:16:43 »
will plate files be available?
Offline IOVERCALLHISTIOCYTES
« Reply #38 on: Thu, 17 March 2022, 23:20:25 »
+1 for brass bottom, but maybe that’s too many SKUs. Thanks for my 180, nice work as always.
Offline roseedge
« Reply #39 on: Thu, 17 March 2022, 23:34:17 »
I NEED THIS IN PLUM PLZZZZ! ;D ;D
Offline lbaron
« Reply #40 on: Thu, 17 March 2022, 23:34:41 »
After GB fulfillment we will release plate files
Offline lbaron
« Reply #41 on: Thu, 17 March 2022, 23:36:53 »
We’ll be launching a IC form soon to gather feedback about things like Hotswap PCB interest, additional weights for the bottom (brass, copper, stainless) and finishes for them. While a solid brass bottom is most likely not in the works, weights like Iron165 r2 are being discussed.
Offline ankit
  • Formerly ankit-sachdeva
« Reply #42 on: Thu, 17 March 2022, 23:40:22 »
Really happy to see hhkb here.
Offline whirlwind
« Reply #43 on: Fri, 18 March 2022, 01:06:06 »
WK stonks
Offline Koniotaur
« Reply #44 on: Fri, 18 March 2022, 01:10:58 »
Bump, I'd like to know as well.
Offline Andertheker
« Reply #45 on: Fri, 18 March 2022, 02:51:20 »
Very nice :thumb:
Offline samuelcc
« Reply #46 on: Fri, 18 March 2022, 02:54:39 »
Will the wkl blocker the same as the other boards or there will be IRON design choices taken in it?
Besides that, is there anything people should know about for this board that's different from other board? Ya know, there's no "standard" in keyboards and anything can be cut off 1mm for "design".
Offline lakeboredom
« Reply #47 on: Fri, 18 March 2022, 03:02:38 »
 want bigger bumpons
Sent from my MotoG3 using Tapatalk
Offline Carcha
« Reply #48 on: Fri, 18 March 2022, 03:29:38 »
Oh my. Oh my!
Offline borgirrrrr
« Reply #49 on: Fri, 18 March 2022, 03:29:46 »
Missing your smith and rune logo! It was definitely a nice touch, what if you guys input it somewhere on the left or right lower part of the board? Still nice regardless though, will definitely cop
