Author Topic: Series 6.xx | 60xt Top Mount / Gummy  (Read 40064 times)
Offline paulgali
    • SKME
« on: Thu, 31 March 2022, 03:04:06 »
Hello Geekhack buddies!
GB Confirmed to start on October 2nd, available at SandKeys.ME
This is something I am very proud of. I hope you like it as much as my cat wants to steal it!
IC FORM
Specs
  • 6 degree, 60% with xt column
  • Adjusted front height of 19.1mm (see below)
  • 7.8mm plate to top case clearance
  • WK and WKL options available
  • MX + Alps compat (with mx stabs)
  • Stock Alu 5052 plate with 1.2mm pcbs
  • Currently testing  1.6mm pcbs with ABS plates. PC plates are too dead sounding for this.
  • Internal brass weight/sheet. This is interchangeable with PC bottoms - reasoning below
  • External Stainless Steel weight - upcoming protos to have polished SS instead of brushed GB edition will have clear coated brass external weight
  • Top mount standard, with optional gummy mount included. Uses 190x4mm orings
  • 1433g with current build (photo below)
No foam. With this much surface area covered in brass, its not needed.
The option of having a pc internal bottom was something I thought might be of interest. This piece replaces the internal brass
I love how PC sounds, but hate touching it - or my cat scratching it. It is something I will test when I get new protos, and update here.
Going forward I want to experiment with other materials in this fashion, so why not :D
Anodization options
I am testing another manufacturer. Each of the below are currently being tested with the anodizer, as there are several protos on the way.
I will remove what I do not like, or do not deem a high enough quality.
  • Red (current proto)
  • Navy
  • Green
  • Silver
  • Purple
  • Pink
Measured without feet as I am changing the feet being used. Measured from the inside edge of top case to external case floor.
PCB Support
Each unit comes with the necessary C3 Unified daughterboard + 150mm medusa cable.
There are SMD LEDs on caps lock, and the 2 top left keys (acting as layer indicators)
Prototype images
This unit came with some particularly poor anodization - something I am working on to improve. Note - I take horrible photos  :p
GMK Red Devils
Sides - i love corsa sides, but wanted something with a much "softer" aesthetic.
Back (yikes it was a sunny day)
External SS brushed. Is being updated to polished, but I like this. Will test regular sandblasting too!
Internal brass weight - can't take a photo right now, heres a screenshot from a previous build stream. Yeah, that's covering a large surface area.
The gap is present on the divider between the XT columns and main alpha/mod cluster, to affect sound as little as possible.
Note the USB port is also aligned along this divider.
Soundtests
I'll post some more when I sit down to record a few. Remember, soundtests are a meme  :thumb:
DCS WOB, Jwicks and Alu Plate in Gummy
Gummy Mounted SP Stars, 1.2mm pcb + alu plate, GMK Metropolis
Pricing / Vendors / Unit allocation
6xx GB will go live on Sunday October 2nd, 6pm UAE Time. FCFS. MOQ & capped @ 150 units.
Price: $420
Shipping: DHL Express with a fixed cost of $35 [read after this] for international sales. Fuel surcharges are currently higher and DHL have told us next month will be closer to 40. We will fix the price based on Septembers fuel surcharges..
Vendors: Sandkeys only. So the process can be sped up 🙂
Timeline: 4 months production timeline, lets say 6ish months including QC. ETA Q1-2 2023
----Base Kit includes----
Top WK, WKL - A6063
Bottom  - A6063
Internal Brass Sheet
External brass weight
Alu plate - A5052. Colormatch with case unless stated otherwise
1.2mm PCB  + JST + AI03 C3 DB
Orings - to confirm final size
Each unit ships with hard cases, and a plain cardboard box around it. Recycle that box, I'm not wasting your GB money on fancy packaging.
----Optional Extras----
1.6mm pcbs, 1.2mm PCB
Plates - A5052, black ABS MX, Alps Alu plates
Internal sheet addons - i will give you access to the file instead to cut / 3d print your own.
Midnight blue (aka very dark fkn blue), Bright Red, Silver (red plate), Purple, Green, Pink
Credits
Maelk - the phenomenal PCB work. Highly recommend!
The MENA community - always have my back
Boyos - you know who you are, thank you for the constant encouragement
Discord
Don't let memes be dreams
« Last Edit: Sat, 01 October 2022, 10:38:21 by paulgali »
Offline paulgali
    • SKME
Re: Series 6.xx | 60xt Top Mount / Gummy
« Reply #1 on: Thu, 31 March 2022, 03:04:17 »
Reserved
15/7/2022 - V2 units have shipped. Sound and feel is there, but the factory has screwed me over with finishing and ano. This project is being moved to the same factory making Safa - meaning cost is going up, and unit cap will have to increase to compensate for the target price. Seems like I can only trust this place to not let me down.
26/07/2022: GB details confirmed. Change of manu means a slightly higher cost than anticipated but the quality on the finish will be worth it.
« Last Edit: Tue, 26 July 2022, 13:27:53 by paulgali »
Offline Sup
« Reply #2 on: Thu, 31 March 2022, 03:04:49 »
This Keyboard is awesome! PogChamp / [̲̅$̲̅(̲̅5̲̅)̲̅$̲̅] ( 5 dollars have been added to your PayPal.)
For real though it looks noice. Like the side profile.
current
Coming soon
Offline whirlwind
« Reply #3 on: Thu, 31 March 2022, 03:05:04 »
POGGERS
Offline spedywin
  • Formerly spedywin
« Reply #4 on: Thu, 31 March 2022, 03:05:26 »
thank u paul baul man very nice
Offline $W4GK!NG
  • Cars/Racing/Keyboards/Watches Enthusiast
    • Linktree
« Reply #5 on: Thu, 31 March 2022, 03:05:57 »
buddy....
Offline P103
« Reply #6 on: Thu, 31 March 2022, 03:08:17 »
Big shill for beats by baul
Offline TibtibThePrincess
  • Look but don't buy
« Reply #7 on: Thu, 31 March 2022, 03:10:11 »
Internal AND external weight?? Looks super nice glwic
Sent from my CLT-L29 using Tapatalk
Offline blacksimon
  • illuminati.works
    • illuminati.works
« Reply #8 on: Thu, 31 March 2022, 03:11:05 »
is this a xerox feline?
Offline ephemeral25
« Reply #9 on: Thu, 31 March 2022, 03:12:58 »
Very excited for the prototyping results  :thumb:
Nice project, looks good and well thoughts.
Offline cwaaar
« Reply #10 on: Thu, 31 March 2022, 03:14:37 »
Love this one, Paul  :thumb:
Offline el_lento
« Reply #11 on: Thu, 31 March 2022, 03:15:07 »
Love to see alps compat in base, although mention that it is alps compat with mx stabs for modern DCS sets.
Keep up the good work.
Offline Zyrophr
  • https://zyrophr.com
    • zyrophr.com
« Reply #12 on: Thu, 31 March 2022, 03:18:49 »
Cool stuff
French keyboard streamer
Offline HalfScrim
  • no fun. not ever.
« Reply #13 on: Thu, 31 March 2022, 03:22:23 »
looking real good
Offline victorpre
« Reply #14 on: Thu, 31 March 2022, 03:29:59 »
lovely, nothing else to say. I'm already in  ;)
Offline Nonnegaard
« Reply #15 on: Thu, 31 March 2022, 03:32:37 »
nothing like a 60 xt to really get my morning wood going. this is stunning.
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline Toscoe
« Reply #16 on: Thu, 31 March 2022, 03:35:56 »
Awesome! This looks freaking nice. +1000 for XT Columns.
Offline paulgali
    • SKME
« Reply #17 on: Thu, 31 March 2022, 03:38:11 »
Added that stipulation. Thanks for reminding <3
Offline Juan.
« Reply #18 on: Thu, 31 March 2022, 03:41:22 »
I touched and I liked
rubber cup
Offline Moods
« Reply #19 on: Thu, 31 March 2022, 03:47:27 »
cool cool
Offline hpetrovski
  • Osum
« Reply #20 on: Thu, 31 March 2022, 04:05:14 »
Another banger, buddy.
Offline rookb
« Reply #21 on: Thu, 31 March 2022, 04:06:22 »
Love it baul
Offline Klyback
« Reply #22 on: Thu, 31 March 2022, 04:16:10 »
side profile looks nice. I don't have any xt keyboard so I am tempted to get my hands on one. GLWIC :thumb:
Offline mmayhem17
    • Steam profile
« Reply #23 on: Thu, 31 March 2022, 05:18:56 »
This have a weight.
Offline infectedqt
« Reply #24 on: Thu, 31 March 2022, 05:31:35 »
pretty nice, where board tho
Offline Pyroo
« Reply #25 on: Thu, 31 March 2022, 05:48:27 »
Murphy approved, absolute must have
Bunny enthusiast
Offline Sicowa
« Reply #26 on: Thu, 31 March 2022, 06:48:48 »
Looks sick
Collection: Khajit 60, Leopold FC980C, Pepper, Ex. Visa, Daedalus
pfp:https://twitter.com/kuroseP/status/1305179874429079553?s=19
Offline Baka Bot
« Reply #27 on: Thu, 31 March 2022, 08:17:21 »
OMG there is brass inside  :eek:
Offline chorb
« Reply #28 on: Thu, 31 March 2022, 08:51:51 »
Very cool rectangle, very nice. GLWIC  :thumb:
also brassinside
Offline kyuut
  • i just learned a new dance
« Reply #29 on: Thu, 31 March 2022, 09:06:02 »
absolute banger. if murphy approves i buy ;D
TGR Jane v2 | TGR Jane v2 CE | TGR x SINGAKBD Unikorn 2.2 | SINGAKBD Kohaku R2 Prototype | HHKB Professional 2
Offline ubmit
« Reply #30 on: Thu, 31 March 2022, 09:22:07 »
based
Lyn Whale | KFE CE | Frog | Singa | Dolice | Haus | Kei | Polaris | Prophet | Bongoneko
Offline mrvpixel
« Reply #31 on: Thu, 31 March 2022, 09:22:24 »
Baul with another banger
Verstuurd vanaf mijn AC2003 met Tapatalk
Offline herbologist
  • beige enjoyer. send help.
« Reply #32 on: Thu, 31 March 2022, 09:30:10 »
Buddy.... Looks incredible. Gib
Sent from my Pixel 6 Pro using Tapatalk
Offline sagarpruthi
« Reply #33 on: Thu, 31 March 2022, 09:31:45 »
This is sick! Can't wait for this to go into GB.
Offline puggo69
« Reply #34 on: Thu, 31 March 2022, 10:02:53 »
i like this
Offline sirieous
  • help
« Reply #35 on: Thu, 31 March 2022, 10:32:25 »
Looks very promising. GLWIC
Offline ankit
  • Formerly ankit-sachdeva
« Reply #36 on: Thu, 31 March 2022, 10:45:14 »
looks pretty thoccccy baul
Offline linell
« Reply #37 on: Thu, 31 March 2022, 11:13:04 »
yay it's out  ;D
bro this a **** set, just be thankful you even getting 1 base running fr
Offline TyPo.mk
« Reply #38 on: Thu, 31 March 2022, 11:17:55 »
Scroll through this thread and count the safa signatures
Offline Bub
    • big bub's beepers
« Reply #39 on: Thu, 31 March 2022, 11:21:40 »
enjoyed watching your streams building (and rebuilding) this board. glwic! i hope to get an xt board this year so might be in.
Offline MK47
  • Don't talk to me
« Reply #40 on: Thu, 31 March 2022, 11:39:16 »
A very slick board designed by an awesome guy. 6.xx so lit
Offline Chippy
  • sus chef
« Reply #41 on: Thu, 31 March 2022, 11:49:21 »
Will this pair good with a modi/magni stack?
Top mount good, can't wait for this!
1.2og | Buddy 6xx | Le Fishe V1 Proto | xyz60 Rev2 | Quartermaster | Chimera65 | Satisfaction75 | Realforce 84u | Zenith Z-150 | Realforce 86u | 378
This and the swiss cheese keyboard is the next generation of keyboards
Offline YayItsKate
« Reply #42 on: Thu, 31 March 2022, 12:03:06 »
yaaaaaaaaaaaaaay Baul and Maelk!!!  :)
Offline elvenmonster
« Reply #43 on: Thu, 31 March 2022, 13:01:32 »
Take my money and run away.
Offline Udyrstruidor
  • uga uga
« Reply #44 on: Thu, 31 March 2022, 13:13:42 »
You are making great stuff
Poseidon60 | GrayStudio Space65 R1 | Ikki68 Aurora | CannonKeys Bakeneko60 | Gok 7V | NotFromSam Samice | CableCarDesigns Prophet | Geonworks Frog TKL | FancyAlice | Aeboards Praxis R2 | HHKB Pro BT | Geonworks F2-84 | UTD 360C | Elongate | Realforce 87u | GrayStudio Space65 R3 | TGR Jane v2 ME | TGR x Singa Unikorn R2.2 | Singa Kohaku65 R1 | Cherry G80-1824HBU | Matrix 8xv 3.0 | CableCarDesigns Prophet | Daji Seis Cero | Matrix 8xv 2.0add Xmas | TGR Jane v2 CE | Baionlenja Bias R2 | Merisi Ottantaquattro | TGR Jane v2
« Reply #45 on: Thu, 31 March 2022, 13:32:43 »
hhkb version pls
Offline LaserCrafter
  • reeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
« Reply #46 on: Thu, 31 March 2022, 14:25:42 »
i love you baul
Keyboard Collection: Unikorn, Orion v1, Orion v3, Realforce 87u, Das II, 356mini, Wang 325-3770, Lightpad v2, Deko Fast Action
Keyset Collection: OG Doubleshots x2, CRP 2551 R4, Muted 2, Cyan R1, WoB, DCS Wyse, ISO OG POM, ePBT Blanks, BSP Blanks, BoW + Gigachild, Minimal R1, SAD Dyesubs,
Offline carlfink
  • metal rectangle enjoyer, @carl.#1208 on discord
« Reply #47 on: Thu, 31 March 2022, 14:37:37 »
i need this in my life please baul!
Offline Lysol_
« Reply #48 on: Thu, 31 March 2022, 20:06:47 »
ayy let's go.  I probably won't be able to join but happy to see this with an IC now.
Offline catamscott
« Reply #49 on: Thu, 31 March 2022, 20:42:04 »
holy crap that internal weight is chonky. looks ****ing killer though, target price is great. interested to see how the abs plate turns out, acrylic is pretty pog too imo
