Author Topic: [GB] GMK Gladiator : LIVE | April 15th - May 16th  (Read 161247 times)
Offline SxM Designs
  • https://sxmdesigns.com
    • Website
« on: Thu, 14 April 2022, 05:00:26 »
"What we do in life echoes in eternity!​"
GB DATE : April 15th - May 16th
ETA delivery Q4 2023
Updates
Update June
No updates
Update June
No updates
Update July
No updates
Update August
No updates
Update September
No updates
Update October
R1 Color samples accepted. Production render confirmed. Banderole design submitted. Waiting on production slot from GMK.
Update November
No updates
Update December
No updates
Update January 23
No updates
Update February 23
GMK ETA for production complete is Q3.
This set has been inspired by the legends of the ancient Gladiators fighting for their honor and freedom!
[/size][/b]
Click on your regional vendor to be redirected to the buy page!
EU        : Mykeyboard.eu
UK        : Protozoa
US        : Mechs & Co
WORLD     : KBDFans
CANADA    : Deskhero.ca
OCEANIA   : Daily Clack
SEA       : Ilumkb
KOREA     : Swagkeys
JAPAN     : Yushakobo
S.AMERICA : Fancy Customs
  Price List
For updates to our current projects and future ones, please join our discord and follow us over Instagram at the links below.
The base set contain 13 new Roman numerals molds. These are R1 1u and hence can be used either in the Numrow or in the F Rows. The Macros introduce Roman numeral macros plus traditional dual colored F Row mods.
Rudis aka Base kit                                                     Spectacula aka Novelties Kit
Columna aka Spacebars                                                        International Kit
Numeri aka Numpad kit                                                      Armature aka Macros Kit
The Forgotten                                                     The Gladiator
Meandros
Disclaimer : The keyboards are for visual purposes and are not included in the set. Colors in the final product may vary since renders are done under idealistic artificial lighting.
Dalco 956 by Hand Engineering
Maja by Vulcan
KBD8X MKII by Kbdfans
Nemui by Bachoo
Rotor by PopSmoke
Presenting our first collabs with KeyRelic - > The Corinthian | The Emperor - Solid Bronze Keycap
Hibi X GMK Gladiator (Gold anodised alu)
Prototypes are being made by HIBI and pics will be posted whenever they are done and delivered to HIBI! Hopefully Soon!
Cables will be provided by Keebstuff Kabelmanufaktur and CableMods.
CableMods Cables!
If you want to support this project please add this signature and spread the word. Thanks  :thumb:
To add a signature go to Profile -> Modify Profile -> Forum Profile -> Signature
Code: [Select]
[url=https://geekhack.org/index.php?topic=115551.0][img width=600 height=120]https://i.imgur.com/q2J7C9q.jpg[/img][/url]
« Last Edit: Wed, 22 February 2023, 09:57:05 by SxM Designs »
Offline SxM Designs
    • Website
Re: [GB] GMK Gladiator : April 15th - May 16th
« Reply #1 on: Thu, 14 April 2022, 05:00:53 »
Reserved
Offline Fraaaan
« Reply #2 on: Thu, 14 April 2022, 07:36:05 »
Why are regular and roman F13 different colors?
Offline nvh2092
« Reply #3 on: Thu, 14 April 2022, 08:12:46 »
Because the roman row in base kit is only meant for num row. You can still use those keys for F row but colors wont be conventional. If you care about correct conventional color => macro kit for accurate color.
« Last Edit: Thu, 14 April 2022, 08:14:53 by nvh2092 »
Offline SxM Designs
    • Website
« Reply #4 on: Thu, 14 April 2022, 08:32:37 »
Yeah thats right  :thumb:
Offline Neely_12
« Reply #5 on: Thu, 14 April 2022, 10:40:55 »
Would much rather have:
caps
lock
instead of:
caps
Offline Fraaaan
« Reply #6 on: Thu, 14 April 2022, 11:05:39 »
Where exactly on the numrow would I put it?
Offline SxM Designs
    • Website
« Reply #7 on: Thu, 14 April 2022, 11:06:49 »
caps
lock
instead of:
caps
I appreciate your choices. Personally, I feel its more cleaner with caps on the stepped key.
Offline ZAND4
« Reply #8 on: Thu, 14 April 2022, 11:07:29 »
Hawt!
Offline SxM Designs
    • Website
« Reply #9 on: Thu, 14 April 2022, 11:08:09 »
You mean the XIII?
Offline SxM Designs
    • Website
« Reply #10 on: Thu, 14 April 2022, 11:08:45 »
Offline Psyquack
« Reply #11 on: Thu, 14 April 2022, 11:14:25 »
I might be wrong about this, but I think it’s so you could also use the Roman numerals on the f row. This is what I gather from the first KBDFANS MXII render at least. That explains the additional, more standard number row included in the base kit.
With regards to the set, I like the colors. That said, the kitting decisions that you made in the base kit make this a very expensive proposition for anyone who wants to have a proper numpad or full accent support. Good luck with the group buy regardless.
« Last Edit: Thu, 14 April 2022, 15:44:03 by Psyquack »
Offline SxM Designs
    • Website
« Reply #12 on: Thu, 14 April 2022, 11:35:30 »
With regards to the set, I like the colors and everything. That said, the kitting decisions that you made in the base kit make this a very expensive proposition for anyone who wants to have a proper numpad or full accent support. Good luck with the group buy regardless.
Yeah thats right. These are R1 1u. So can be used as an unconventional F row as well. For a more traditional dual colored F rows, you would need the Macro support.
Yeah having everything would be expensive. I agree. The goal was to minimize cost for most people who dont need numpad support. This is always been an issue for any TKL bases.
The base kit at $129 is very competitive imo comparing to other sets running / ran.
Again, thanks for the kind words and support! I appreciate it a lot!
Offline rookb
« Reply #13 on: Thu, 14 April 2022, 15:24:08 »
€140 for a tkl base with an ugly novelty numrow instead of numpad lol
Offline Fraaaan
« Reply #14 on: Thu, 14 April 2022, 15:27:51 »
You mean the XIII?
Yes? Is that not what we've been talking about this entire time?
Offline max.clacks
« Reply #15 on: Thu, 14 April 2022, 15:37:34 »
You mean the XIII?
It seems that the intent of the alpha colored 'XIII' is intended for if someone would like to use the Roman numerals on the function row, as the Roman numerals in the base kit are only alpha colored.
If someone was going to use the Roman numerals on the num row, there wouldn't be a conventional place for it, however, if someone did choose to use split bs, then that would enable the use of the 'XIII'.
I'm not a fan of the Roman numerals in the base kit, but this is my understanding.
Offline nvh2092
« Reply #16 on: Thu, 14 April 2022, 16:37:45 »
You mean the XIII?
Based on base kit render, that  alpha "~`" key can still be replaced with a roman key.
Offline okidna
« Reply #17 on: Thu, 14 April 2022, 17:16:57 »
Nice, a darker Blue Samurai with a darker Red Samurai accent  ;D
Offline SxM Designs
    • Website
« Reply #18 on: Thu, 14 April 2022, 19:47:43 »
EU prices will be higher across the board for every set running due to the Euro losing its value.
There is nothing anyone can do regarding this.
Offline SxM Designs
    • Website
« Reply #19 on: Thu, 14 April 2022, 19:48:49 »
more greenish blue. Most uncalibrated screens would show otherwise and hence I can understand!
Offline SxM Designs
    • Website
« Reply #20 on: Thu, 14 April 2022, 19:49:37 »
You mean the XIII?
Split BS is more conventional but this would work as well.
Offline Mecxs
« Reply #21 on: Thu, 14 April 2022, 20:10:44 »
:D :D :D :D :D :D :D
Offline nvh2092
« Reply #22 on: Fri, 15 April 2022, 00:22:18 »
You don't have any idea about how moq, custom color and custom mold affect the final price, do you?
« Last Edit: Fri, 15 April 2022, 00:24:10 by nvh2092 »
Offline Fraaaan
« Reply #23 on: Fri, 15 April 2022, 04:45:26 »
You mean the XIII?
If you're splitting BS then you have 2 more spaces to fill so why not have a roman 14 as well if this is how you envisioned it? What's the point of going from 1 to 13 and then having pipe?
Offline SxM Designs
    • Website
« Reply #24 on: Sat, 16 April 2022, 04:27:01 »
You mean the XIII?
1-13 --> reusability in F row. 14 could have been also added but no one wanted / mentioned it during the IC phase.
« Last Edit: Sat, 16 April 2022, 11:43:10 by SxM Designs »
Offline SxM Designs
    • Website
Re: [GB] GMK Gladiator : LIVE | April 15th - May 16th
« Reply #25 on: Sat, 16 April 2022, 11:42:11 »
[/size][/b]
EU        : Mykeyboard.eu
UK        : Protozoa
US        : Mechs & Co
WORLD     : KBDFans
SEA       : Ilumkb
KOREA     : Swagkeys
JAPAN     : Yushakobo
Offline acerb
« Reply #26 on: Sat, 16 April 2022, 12:22:14 »
It's still crazy when you think GMK sets are produced in Europe (Germany)! It should be cheaper locally than after the oversee trip!
Offline SxM Designs
    • Website
« Reply #27 on: Sat, 16 April 2022, 13:23:02 »
Yeah those are the taxes we must pay. It is what it is.
Living in EU, I have accepted the 20+ % markup + more taxes for anything I buy anywhere :/
Offline ZAND4
« Reply #28 on: Sun, 17 April 2022, 16:18:07 »
In for the base
Offline SxM Designs
    • Website
« Reply #29 on: Mon, 18 April 2022, 10:05:26 »
In for the base
Thanks for the support!!  :thumb:
Offline JohnYYZ
  • KanataKeys.co
« Reply #30 on: Mon, 18 April 2022, 14:18:08 »
Best of luck for the GB!!
Offline BasedCoper
« Reply #31 on: Mon, 18 April 2022, 16:46:54 »
looks solid. definitely a strong consideration but not having numpad in base and being forced to buy 2 styles of numbers hurts for value b/c you won't even use so many of the keys
Offline Luna
« Reply #32 on: Tue, 19 April 2022, 06:31:32 »
I'm in.  :thumb:
Offline SxM Designs
    • Website
« Reply #33 on: Wed, 20 April 2022, 11:52:41 »
Offline SxM Designs
    • Website
« Reply #34 on: Wed, 20 April 2022, 11:55:00 »
Glad you liked the set! The kitting in this has been tricky from the get go to get my vision across!
Offline SxM Designs
    • Website
« Reply #35 on: Wed, 20 April 2022, 11:55:19 »
I'm in.  :thumb:
Thanks for the support! Lets go!
Offline bkrownd
« Reply #36 on: Wed, 20 April 2022, 19:14:55 »
KeyRelic artisans are so perfect for this set
Offline SxM Designs
    • Website
« Reply #37 on: Thu, 21 April 2022, 03:59:02 »
Glad you liked them!!
Offline yangsiyin
  • Hello World~ Keebs
« Reply #38 on: Fri, 22 April 2022, 20:56:11 »
The Hibi one looks like Pantheon, doesn't it? :)
Offline SxM Designs
    • Website
« Reply #39 on: Fri, 22 April 2022, 21:30:52 »
You referencing Pantheon from LoL?
Well its a gladiator helmet so I can see why xD
Offline kapowaz
    • kapowaz industries
« Reply #40 on: Sat, 23 April 2022, 17:06:44 »
Not sure if it’s been pointed out before, but I’m pretty sure there’s a kitting error in the International Kit; the R4 key with : , (colon, comma) should be ; , (semi-colon, comma). I think this was an error that was propagated from a few other sets (I made the same mistake in one of my own).
Offline SxM Designs
    • Website
« Reply #41 on: Sun, 24 April 2022, 09:52:23 »
Yes you are correct.
We sent GMK the right renders But sadly, I uploaded the wrong file here :( . So no worries here!
I will correct this here asap!
Updated render!
« Last Edit: Wed, 27 April 2022, 02:16:17 by SxM Designs »
Offline PCov
« Reply #42 on: Tue, 26 April 2022, 08:34:34 »
These look amazing.  Wow.
Offline SxM Designs
    • Website
« Reply #43 on: Wed, 27 April 2022, 02:16:30 »
Thanks a lot!!
Offline SxM Designs
    • Website
« Reply #44 on: Wed, 27 April 2022, 02:23:33 »
Small Update incase people are wondering about numbers :
We are already way past the half way mark on numbers. So all kits should meet MOQ easily!
Sadly majority of the vendors have not yet updated any numbers so there is no point uploading something which is very old.
I would also encourage people who always need an international kit to check this set out! I am hopeful to see the international kit hit MOQ!!
Cheers! :thumb:
Offline SxM Designs
    • Website
« Reply #45 on: Wed, 27 April 2022, 10:55:50 »
Tonight we dine in HELL!
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #46 on: Sat, 30 April 2022, 15:30:15 »
Edit: corrected colors
« Last Edit: Sun, 01 May 2022, 00:46:16 by dvorcol »
Offline Luna
« Reply #47 on: Sat, 30 April 2022, 15:45:27 »
What are the white and red bars for?
Offline SxM Designs
    • Website
« Reply #48 on: Sat, 30 April 2022, 15:49:28 »
You mean in the graph?
Offline dvorcol
« Reply #49 on: Sat, 30 April 2022, 16:55:03 »
Just my way of showing the alternative colors offered in those two kits on the graph.
