Author Topic: [IC] KKB Skidata neo  (Read 46200 times)
Offline masje
  • Your neighborhood keyboard designer.
    • masjewerke
« on: Wed, 29 November 2023, 01:45:38 »
304437-0
It's skiing season. Time to remake another classic.
DISCORD IC FORM
K I T T I N G
304439-1
Base kit. Includes support for alice, limited 40s, HHKB, etc. I made a mistake, there's an extra ansi enter.
304441-2
Nordeuk kit. Get this for that authentic skidata look. Though who are we kidding, this kit will not be made.
304443-3
Alert kit, with cooooolllll translucent keycaps :cool:
304445-4
R5 kit. Will consider adding this to base to replace R4.
304447-5
Relegendables kit. Includes front print from ESC to F12 and 10 blanks.
C O L O R S
Colors will be matched to GMK N9/V2.
P R I C I N G
Aiming for
- $95 for Base kit
- $35 for Nordeuk kit
- $20 for Relegendables kit
- $30 for Alert kit
- $25 for R5 kit
V E N D O R S
TBD
R E N D E R S
304449-6 304451-7
21xx by Pontus
304453-8 304456-9
F2-84 and Frog by Geon
304458-10
JEBAETED by yours truly
T H A N K S
Thanks to Pontus for the render model & render help  :thumb:
Thanks to Jampot for kitting suggestions  ;D
Thanks to Geon for providing the models on his site
Thanks to all my discord server members
S I G N A T U R E
Code: [Select]
[url=https://geekhack.org/index.php?topic=121987.0][img width=358 height=120]https://i.imgur.com/RLr0Dzl.png[/img][/url]
T O - D O
Reach out to vendors. Please shout to your local vendors if you want this set run  ;D
Organize received feedback and make changes to the kitting
Get color chip samples + translucent samples from KKB
F E E D B A C K
( 1 ) Reverse colored accent keys. I know previous sets ran with them, but i dont like the look personally. Will look into it if there's demand, but also need to figure out which child kit to put them into (base already pretty cramped)
( 2 ) Macro expansion keys. I would love row correct macro column with F1-F10, but it will likely depend on demand.
( 3 ) Second 2.2u shift key & 2u shift. Should be ok to add to base kit. No promises though.
( 4 ) Second B. Important addition to base kit.
( 5 ) Redundant ANSI enter. Will be removed.
( 6 ) Considering R5 in base. I dont think it'll make it as a separate child kit.
( 7 ) 10u? Will ask KKB if they have molds. Likely will be an add-on.
( 8 ) Windowed Scroll Lock. Wasn't in original Skidata keyboard. But i understand it might be weird if we have other windowed keys. Will include if not too expensive.
( 9 ) 1u Spacebar. Should be ok to add to base kit. No promises though.
( 10 ) R1 backspace in Alert kit. Should be ok to add.
( 11 ) 1u Alt Gr in base kit will be changed to 1u Alt. It's too cramped for me as well.
( 12 ) R2 |\ will be removed in favor of R1 |\ in alert kit.
( 13 ) Orange relegendables? Think it's a hard sell, might be a pass on this one.  :(
( 14 ) Thinking of ways to make Nordeuk work. Am considering buying out MOQ.
« Last Edit: Thu, 30 November 2023, 01:22:54 by masje »
Offline Jampot_298
Re: [IC] KKB Skidata neo
« Reply #1 on: Wed, 29 November 2023, 01:55:35 »
Yes yes yes. This is hot and I need it...
Offline Fraaaan
« Reply #2 on: Wed, 29 November 2023, 02:01:17 »
Finally a Skidata rerun... GLWIC!
Offline Moods
« Reply #3 on: Wed, 29 November 2023, 02:30:02 »
Another killer looking project Masje. Count me in  :cool: :cool:
Offline VXQN
« Reply #4 on: Wed, 29 November 2023, 02:48:13 »
This is excellent. I'd like to see accent enter and esc, and I'd love to see sculpted macro or F keys!
Offline ph4nt0m
« Reply #5 on: Wed, 29 November 2023, 03:43:31 »
Please consider adding a second 2.25u shift key for proper Type-K support. You could replace the redundant enter key. ;)
Offline tactilesbad
« Reply #6 on: Wed, 29 November 2023, 04:01:33 »
HELL YEA
Offline aa212121
« Reply #7 on: Wed, 29 November 2023, 04:43:34 »
Clean! nice work!
Offline jiminojimi
« Reply #8 on: Wed, 29 November 2023, 07:01:46 »
Wow, just wow.... Like you have my full attention.
I would love to see more of the Alert kit ... Ie expanded into alpha chars
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #9 on: Wed, 29 November 2023, 08:32:27 »
I already have this set in GMK, but with R5, I'll consider it.
Offline farlig
  • * St. Jude Supporter
« Reply #10 on: Wed, 29 November 2023, 08:34:00 »
Count me in, especially if you go for R5 in base.
Offline HubertThemad
    • Podcast Links
« Reply #11 on: Wed, 29 November 2023, 09:32:36 »
I wasn't in the hobby to partake in GMK Skidata at non-aftermarket prices, and didn't want to buy DCX Skidata, so I shall partake in KKB Skidata. GLWIC
Offline Rhienfo
  • GOTHETIGES
« Reply #12 on: Wed, 29 November 2023, 09:52:44 »
This is just great to see. Will probably pick up most of the kits.
Do KKB do custom moulds, cause I think it would be really cool to see 10u or BAE or something like that if that's possible.
GLWIC
Offline vhaarr
« Reply #13 on: Wed, 29 November 2023, 10:10:15 »
AltGr in base? That's the most based thing I've seen this week. Also nordeuk?!
And 2x 3u space in base? Wow.
And here I was thinking I definitely didn't need another dark set. Turns out I do. I need to show my support for this kind of kitting.
That said I don't understand the extra Q and M keys at all :-P
Also I don't get the transparency thing. I'd rather have an accept set with reversed colors.
Let the Holy Handgrenades rain.
Hammering on an old Happy Hacking Pro 2. Still going strong!
Offline CoolPenguin1
« Reply #14 on: Wed, 29 November 2023, 10:36:02 »
Amazing kitting and prices. Definitely picking this up when it runs.
They do but it's extremely expensive. There have been a few attempts at getting them to make a BAE but I'm pretty sure it's not really getting anywhere due to cost.
Offline Thebloodyez
  • Just a random keyboard builder.
« Reply #15 on: Wed, 29 November 2023, 11:22:38 »
Skidata R5 and good kitting :eek: . Another masje banger. GLWIC :thumb: .
Offline iwobobul
« Reply #16 on: Wed, 29 November 2023, 14:55:01 »
Yes please!
Offline Flybeck
« Reply #17 on: Wed, 29 November 2023, 14:55:55 »
EXCELLENT
Offline Meepergon
« Reply #18 on: Wed, 29 November 2023, 15:02:51 »
i need this now. shinethrough in base kit? alert kit? absolutely ****ing BASED. i don't really like KKB texture but i will most definitely be picking this up.
Offline aicyborg
« Reply #19 on: Wed, 29 November 2023, 16:41:25 »
If Nordeuk kit doesn't make it, would you be open to adding ISO-UK to base? This is quite common for KKB, I don't think it adds much cost and gets at least for me what I want.
Offline ankit
  • Formerly ankit-sachdeva
« Reply #20 on: Wed, 29 November 2023, 20:57:55 »
I'm so in.
One suggestion is that I think the 1u Alt Gr key looks too cramped on previous sets (including my own lol). Any chance of replacing it with just a second 1u Alt?
Offline Rhienfo
  • GOTHETIGES
« Reply #21 on: Thu, 30 November 2023, 03:57:12 »
Ah that's a shame, thanks for telling me :)
Offline masje
    • masjewerke
« Reply #22 on: Fri, 01 December 2023, 03:12:37 »
Yes! My original thought is to push for nordeuk sales by putting UK ISO here, but depending on how the IC goes, will either put them in base or consider buying out nordeuk kits.
Offline masje
    • masjewerke
« Reply #23 on: Fri, 01 December 2023, 03:13:31 »
I'm so in.
Ah yes, was perhaps a oversight on my part... will have an extra 1u 'alt' instead.
Offline 51p50x
« Reply #24 on: Tue, 05 December 2023, 20:57:00 »
Good kitting and price.
GLWIC
Offline Surefoot
« Reply #25 on: Wed, 06 December 2023, 02:41:26 »
Is it ABS or PBT ?
Offline masje
    • masjewerke
« Reply #26 on: Thu, 07 December 2023, 01:30:10 »
Is it ABS or PBT ?
Hello! This set will be double-shot ABS  :thumb:
Offline ppatches24
« Reply #27 on: Sat, 16 December 2023, 02:38:21 »
Pleas gib now, k thanks. Alert KIT IS HOT.
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #28 on: Sun, 17 December 2023, 08:37:20 »
Love this & would be totally down to grab a set if you go with R5 in the base (I already have SkIIdata). Also how comes no extra B for Alice layout? You get the extra bars in the base, might as well add the extra B in.
Offline patricklau
« Reply #29 on: Thu, 21 December 2023, 03:47:47 »
Sooo Gooood. I've the whole layout! GLWIC :cool:
Offline offbrandbiscuit
« Reply #30 on: Thu, 21 December 2023, 09:10:48 »
You're an absolute legend for running this set again. Please do consider adding the orange accents to the base kit though, otherwise I feel it's pointless to offer two 2.25u enters if they both look the same. The semi-translucent accent row kit is an interesting idea, will have to see how it pans out. Definitely interested in this one
i like fire trucks and moster trucks
Offline Nebulonix
« Reply #31 on: Fri, 22 December 2023, 00:48:56 »
Great work on the kits! :)
Offline involuntarysoul
« Reply #32 on: Fri, 22 December 2023, 02:25:31 »
cherry r5 is terrible with the standard spacebar
Offline zlobin356
  • Hi! My name is zlobin!
« Reply #33 on: Fri, 22 December 2023, 10:54:24 »
very interesting! i believe i would like to order them.
Collection state: OTD The Cheat, Tofu60 v1, Hal.6
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #34 on: Fri, 22 December 2023, 15:45:30 »
Do you know if there is a Cherry manufacture that does R5 spacebars? Last I heard GMK only has R4, but that doesn't mean R5 isn't out there somewhere.
« Reply #35 on: Fri, 22 December 2023, 18:34:46 »
dcs spacebar is very close to cherry R5
Offline chigi22
« Reply #36 on: Sat, 23 December 2023, 22:07:36 »
Would strongly prefer to keep  R4 bottom row in base
Offline jiminojimi
« Reply #37 on: Wed, 24 January 2024, 14:54:22 »
Any updates on this?
Offline Dmitri
« Reply #38 on: Wed, 24 January 2024, 17:02:08 »
R4 for me
Offline tactilesbad
« Reply #39 on: Thu, 25 January 2024, 03:37:19 »
no it's not, it's ergonomic and looks cool AF
+1 for R5, KKB does have the molds so don't lose the opportunity to make this set stand out from the average.
Offline iwobobul
« Reply #40 on: Sat, 27 January 2024, 03:30:25 »
Is this going to happen (pretty please)?
Offline QWER|key
« Reply #41 on: Sat, 27 January 2024, 04:49:31 »
Build it, and they will come :)
Offline mathiasn
« Reply #42 on: Sat, 27 January 2024, 05:37:04 »
Want, want, want.
(one kit, not three ;D)
Was going to add suggestions, but found they're there (6,8,1 in particular).
Offline masje
    • masjewerke
« Reply #43 on: Sat, 27 January 2024, 07:28:49 »
Yup it is! Working on it...
Offline masje
    • masjewerke
« Reply #44 on: Sat, 27 January 2024, 07:29:25 »
Currently looking for vendors & some kitting fixes!
Offline dvorcol
« Reply #45 on: Sat, 27 January 2024, 21:02:25 »
Three previous three sets I know of are Skiidata with two i's. Why are you using only one?
From KeycapLendar:
Offline konstantin
  • Formerly constexpr
« Reply #46 on: Sun, 28 January 2024, 01:44:08 »
From KeycapLendar:
I would assume the II comes from GMK SkIIdata being the second run of this colorway that was manufactured by GMK. Drop probably took that name not knowing any better (or they were looking to avoid potential trademark issues). The Austrian company that the original Cherry orange-on-black keyboard/keyset was made for is called Skidata, with one I.
« Last Edit: Sun, 28 January 2024, 01:49:36 by konstantin »
Offline masje
    • masjewerke
« Reply #47 on: Sun, 28 January 2024, 05:09:33 »
From KeycapLendar:
Yup. Skiidata with two ‘I’s I believe was the name TKC gave this set when they ran it as a R2 of this N9/V2 colorway. The DCX project was an extension of this GMK project afaik, so the name stuck.
Skidata with one ‘I’ is the original, I think.
Offline hottrout
  • I'd Hit Dat Key
« Reply #48 on: Mon, 29 January 2024, 03:13:05 »
I have GMK but I like the Alert Kit and R5, might just pick up a full set.  Nice to see it back.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline DennisBytes
« Reply #49 on: Thu, 15 February 2024, 21:03:08 »
I've been waiting for a proper Skidata re-run for awhile. Excited for R5 support too. I am in.
