Author Topic: [IC] K-III  (Read 15014 times)
Offline masje
  • Your neighborhood keyboard designer.
    • masjewerke
[IC] K-III
« on: Wed, 15 January 2025, 10:21:27 »
A comfy, fun-to-type-on plateless TKL.
DISCORD IC FORM
Inspiration
I am a fan of plateless boards.
Ever since I got a neo65 and built in in a plateless config,
I found myself typing on it a ton.
And, I also like old cherry boards, which have just the right "reverby" sound when you type on it,
and I tried to replicate it on a modern TKL.
Mounting & Specifications
- double hotdog mount (similar to F1)
- 9 deg typing angle
- 2.1kgs built
- 19.35 adjusted front height
Internal PC weight.
I've tested both PC and brass weights in the proto run,
but decided PC sounded better!
Back profile, with PC DB cover
PCB Layout
Designed by my good friend Bloodyez, solderable 1.6mm.
Sales & Pricing
- February 2025 GB (same time as 818)
- Maybe 10 units(???)
- Three colors: Dark Grey (Powder coat) / Silver Ano / Pink Ano (DDS-E)
- Aiming for $400 - $420, incl. hard case/PCB
- Made by your favorite (overpriced) manufacturer
Here's a real life sample of the pink color. Thanks mandowo!
Gallery
Dark Grey Powder Coat
Silver Ano
Pink Ano
R0 Soundtest
Here you go, based-af 3 hour  s o u n d t e s t
We used a different manu for R0, so the pink is different
Thanks
Thanks to all my friends who joined the R0 run!!! & Hugh for making based video  :thumb:
Also thanks to Bloodyez for making based PCB :nut:
Offline HubertThemad
  • * St. Jude Supporter
    • Podcast Links
Re: [IC] K-III
« Reply #1 on: Wed, 15 January 2025, 10:39:09 »
BIG NUT
Edit: I will say that even though the majority of the configurations were of the brass inner weight, the PC inner weight does increase the "roomy"/"booming" sound that James was going for, much more than the brass internal weight.
I think you can compare the differences between the config or the internal PC and internal brass portions of the sound test and come to that conclusion yourselves, however!
And for those that want a variation of sound test that sticks with one mic before switching versus the one above that stays with one config, but switches mics, feel free to check this out. And the review video of the proto units (keep on mind that since it was a proto run, there are design changes with those units versus these IC units).
For example, no PC plate, so those recordings don't really apply to this public run (and no top mount or course, but imo, not a huge loss at all since the board seems to really be tuned for gasket mount).
Mic Method Sound Test Compilation:
YouTube Video Review (Proto unit, so there have been changes):
« Last Edit: Wed, 15 January 2025, 12:12:15 by HubertThemad »
Offline 51p50x
Re: [IC] K-III
« Reply #2 on: Wed, 15 January 2025, 10:43:05 »
rush rush
Offline Gtour
  • Just a random guy passionate about keyboards.
Re: [IC] K-III
« Reply #3 on: Wed, 15 January 2025, 10:45:20 »
PC weight new meta? Cool
Offline Stringer Bell
Re: [IC] K-III
« Reply #4 on: Wed, 15 January 2025, 10:59:19 »
Rush rush. Your favorite designer's favorite designer.
Offline LogolicusZ
  • Location: Land of Cheese with many holes and Tall Mountains with chocolate
Re: [IC] K-III
« Reply #5 on: Wed, 15 January 2025, 11:56:03 »
GLWIC
Offline LMarci
Re: [IC] K-III
« Reply #6 on: Wed, 15 January 2025, 12:02:28 »
I think i like this one :thumb:
Offline xLeHoy
  • weeb board enjoyer
Re: [IC] K-III
« Reply #7 on: Wed, 15 January 2025, 12:03:16 »
This too is looking really nice :beigeChamp:
Offline mmayhem17
    • Steam profile
Re: [IC] K-III
« Reply #8 on: Wed, 15 January 2025, 12:05:51 »
nice project, nice people, nice price, nice, nice, nice.
Offline tanghus
  • BEIGE GUD
Re: [IC] K-III
« Reply #9 on: Wed, 15 January 2025, 12:27:27 »
冲冲冲
Offline amorino
Re: [IC] K-III
« Reply #10 on: Wed, 15 January 2025, 14:14:08 »
This is it!
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: [IC] K-III
« Reply #11 on: Wed, 15 January 2025, 14:45:20 »
James trying to drain my wallet.... :p
Offline Saurov
Re: [IC] K-III
« Reply #12 on: Wed, 15 January 2025, 16:26:44 »
Looks great, always down for a comfy board  :thumb:
Offline EdgeOfInfinity
Re: [IC] K-III
« Reply #13 on: Tue, 28 January 2025, 18:42:01 »
i don't know how to feel about the daughterboard access cover thing
Offline Kokaloo
  • 🤘(• ω •)🤙
Re: [IC] K-III
« Reply #14 on: Tue, 28 January 2025, 19:28:00 »
glad only ten of these might exist
Offline sirieous
  • help
Re: [IC] K-III
« Reply #15 on: Tue, 28 January 2025, 20:41:09 »
Will keep an eye out for this. Board sounds lovely. GLWIC
Offline masje
    • masjewerke
Re: [IC] K-III
« Reply #16 on: Wed, 29 January 2025, 21:13:12 »
a compliment from someone like you  :p
« Last Edit: Wed, 29 January 2025, 21:17:00 by masje »
Offline Moods
Re: [IC] K-III
« Reply #17 on: Wed, 19 February 2025, 17:26:42 »
i would like one tenth of the population  :cool:
