Author Topic: What did you get in the mail today?  (Read 25499272 times)
0 Members and 20 Guests are viewing this topic.
« Reply #15550 on: Fri, 20 December 2013, 20:53:02 »
but it's in LA!!! it has been in LA since yesterday. but noooooooo i have to wait until tomorrow :(
anyway, looks awesome! congrats!
Offline Dubsgalore
« Reply #15551 on: Fri, 20 December 2013, 21:13:20 »
ayy gurl
I won't have to plug my phone into the wall ever again! Hooray for convenience.
niceeeeee get bro  ^-^
Offline calavera
« Reply #15552 on: Fri, 20 December 2013, 21:14:15 »
55g gold springs.
« Reply #15553 on: Sat, 21 December 2013, 00:16:12 »
OK, one complaint. Layout is PERFECT, but this character -> "ž" is way out of the normal slovenian layout. This will take some serious time to get used to, actually. Luckily I do 99% of my work in English but I do have to write my phd in slovenian so dayumn...
Also, can somebody tell me how I should set this baby up so my backspace would have delete under FN? Right now it's backspace all the time and I can't see the DIP settings to make it alt from backspace to delete?
Switch 3 I believe, Also I use Autohotkey
That's what I thought as well, but it isn't working. Previous reply said it's not possible. Oh well, it's not a big issue.
Did you unplug and replug the keyboard after changing the switch?  Apparently it does not work if you just flick a switch while the keyboard stays connected to the computer.
This guy:
Different lighting angles make him look lighter or darker:
I'm gonna need a stronger Esc key spring in this Das... ;D
Either way looks fantastic!
« Reply #15554 on: Sat, 21 December 2013, 05:18:05 »
Steel Brobot V2 came today.
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #15555 on: Sat, 21 December 2013, 08:12:16 »
kishsaver
ill get some pics up once im done cleaning it
« Reply #15556 on: Sat, 21 December 2013, 08:31:41 »
kishsaver
is THAT your endgame item?
I really wanna knowwwww
Offline BunnyLake
  • X
« Reply #15557 on: Sat, 21 December 2013, 08:33:00 »
kishsaver
nope
« Reply #15558 on: Sat, 21 December 2013, 08:35:18 »
kishsaver
nope
GAAHHHHHH
when will I get to know?
Offline deepthawt
  • ︻̷̿┻̿═━一
    • my programming hobby site, interactive jigsaws, photos &c
« Reply #15559 on: Sat, 21 December 2013, 10:40:05 »
4 Conti winter tires, mounted and balanced on rims, with lug nuts and wheel covers for my Forester.
Ordered it from tirerack on Sunday evening and they arrived by UPS Tuesday afternoon.
let it snow! let it snow! let it snow!
[| Ducky Shine II 9087 Yellow LED/BlueMX  |  Saitek Eclipse II  |  IBM Model M 1391401  | Cherry G80-5000  |  Logitech diNovo Mini  |  Microsoft Natural Ergonomic 4000  |  Matias Quiet Pro PC  |  Dell TH836  |  NEC KB-6923  |  Fujitsu FKB4700  |  GearHead Mini USB  KB1700U (89 key) | Filco Majestouch-2 ninja/blues  |   Matias Mini Quiet Pro PC | Ducky Shine 4/Clear MX | E Element RGB Silver/Black Outemu |]
« Reply #15560 on: Sat, 21 December 2013, 13:14:15 »
Cool, another Wisconsinite!  Good thing you picked those up, we're supposed to get quite a bit of snow this weekend!   :p
Edit: Wow, you've been here a long time.  I assumed you were newer.   :))
« Last Edit: Sat, 21 December 2013, 13:16:54 by HoffmanMyster »
Offline epzy
  • HHKB Fiend
  • ded
« Reply #15561 on: Sat, 21 December 2013, 13:18:49 »
Some cheap pbt caps and some translucent wasd/arrow caps :)
Offline MKULTRA
  • telling it how it is
« Reply #15562 on: Sat, 21 December 2013, 13:57:05 »
« Reply #15563 on: Sat, 21 December 2013, 15:07:50 »
Another brobot, checking in.
48667-0
« Reply #15564 on: Sat, 21 December 2013, 15:20:45 »
I want a brobot :(
Offline yjfknt
« Reply #15565 on: Sat, 21 December 2013, 16:09:17 »
the colorful ones are coming soon :)
« Reply #15566 on: Sat, 21 December 2013, 16:55:32 »
Didn't get it in the mail, but I wanted to share it nonetheless.
I found it for a good price at a local swap meet/flea market/giant garage sale type thing.  The $200+ prices on eBay and Craigslist were a little daunting.  Now I just have to set it up and I can start casting translucent caps and get rid of the bubbles in some of my other designs.
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #15567 on: Sat, 21 December 2013, 17:22:35 »
please be the first to make emerald translucent :D
Offline do_Og@n
« Reply #15568 on: Sat, 21 December 2013, 17:38:09 »
IBM Model M
FK-2001 with windows keys
Northgate OmniKey Ultra
I've never had a Northgate board before.....that thing is HEAVY!!!
Offline Photoelectric
« Reply #15569 on: Sat, 21 December 2013, 17:40:53 »
It looks scary...  I hope you'll be  very careful with it!
« Reply #15570 on: Sat, 21 December 2013, 17:57:49 »
And so it begins-
« Reply #15571 on: Sat, 21 December 2013, 18:05:53 »
I definitely will be.  The last thing I want to do is kill myself with it.  I'll be doing incremental pressure increases and will see if I can do them from a distance.  I plan on starting with 20-30 PSI and seeing if there are any leaks anywhere.  From there, I'll do 5-10 PSI increases up to 65 or 70 PSI (max safe for the pot is 80 PSI) and see how it holds up.  Most my casting should be in the 45-70 PSI range, depending on the casting material.
And so it begins-
Well, it had been going, but now I can finally do some good and proper casting and should be getting higher quality caps out of it.  It will also let me make some acrylic pen blanks and stabilized blanks for cheaper too.  I've been doing some pens for a while, but have avoided acrylic/resin due to cost.
« Last Edit: Sat, 21 December 2013, 18:07:44 by nubbinator »
Offline MJ45
  • HHKB Pro
« Reply #15572 on: Sat, 21 December 2013, 18:52:38 »
And so it begins-
Good Luck, I can't wait to see some of your Pressure Casted Items.
Offline RabRhee
« Reply #15573 on: Sat, 21 December 2013, 19:02:59 »
I got an early present today, a rather cool board came called Twilight Struggle. Fortunately nothing to do with glittery vampires at all.
And some cheap Draper storage boxes (4 for £10 posted) to stick keys and other junk in. The two small boxes each hold a couple of Taihao sets without spacebars, and then theres two double that size in the set.
48680-0
« Last Edit: Sat, 21 December 2013, 19:04:34 by RabRhee »
-Life is good-          Crafting: |  Keychains |  More.   .Keychains | Crowdsource Key | Budget Keycap Board |
« Reply #15574 on: Sat, 21 December 2013, 21:08:19 »
it so beautiful. im even more excited for what's to come from brocaps!
Offline moogle
« Reply #15575 on: Sat, 21 December 2013, 21:34:31 »
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #15576 on: Sat, 21 December 2013, 22:02:58 »
lol, that's exactly what i said. the manufacturer is high quality though; i suspect it only looks scary because the previous owners just didn't care to clean it all that often (ie, ever ;)). it'll probably look pretty darn sweet after a good clean and coat.
Offline zenuty
« Reply #15577 on: Sat, 21 December 2013, 22:08:53 »
Wow Nice BroCaps V2
Metoo wants it  :cool:
LINE ID : zenuty
Skype ID : zenuty
www.facebook.com/zenuty
Offline HipsterPunks
  • Gangnamember
« Reply #15578 on: Sat, 21 December 2013, 23:34:54 »
Dibs on trans green derp cap :) read your wax casting guide last night, gave me an itch to try it out
sell ass and eat out
Offline dragonxx21
« Reply #15579 on: Sun, 22 December 2013, 00:12:20 »
secret santa gift. I CANT OPEN IT THOUGH
Keyboards Owned:
Realforce Topre 91 Key JIS Profile - Main
CM Quickfire Rapid Blue Switches
IBM Model M in Industrial Shell
Offline Pacifist
  • on hiatus
« Reply #15580 on: Sun, 22 December 2013, 00:25:48 »
you can open but not tell anyone
« Reply #15581 on: Sun, 22 December 2013, 09:15:12 »
I mean
The rule was not to open it until Christmas
Offline HendyZone
  • HHKB Elite
    • MechanicalKeyboards.co.id
« Reply #15582 on: Sun, 22 December 2013, 11:39:26 »
Got this case for travelling :p
« Reply #15583 on: Sun, 22 December 2013, 11:50:17 »
Is that a 3d printed poker case?
Offline HendyZone
  • HHKB Elite
« Reply #15584 on: Sun, 22 December 2013, 11:52:48 »
Offline Pacifist
  • on hiatus
« Reply #15585 on: Sun, 22 December 2013, 14:27:27 »
« Reply #15586 on: Sun, 22 December 2013, 14:29:18 »
love that keyset..  :thumb: greeen and creme cheese heh
« Reply #15587 on: Sun, 22 December 2013, 19:50:29 »
Woo I got something!  Totally forgot about these, I'm so silly :))
Thanks nubbs! :)
48748-0
48750-1
48752-2
48754-3
« Reply #15588 on: Sun, 22 December 2013, 19:51:24 »
Whoah!!  Those are pretty cool.  The red one shall be named "the bubble man" or alternatively "strawberry jelly man".  It looks like you can eat it.  I like the translucent teal.
« Reply #15589 on: Sun, 22 December 2013, 19:52:14 »
Thanks nubbs! :)
Hes doing transparent now! sickk
« Reply #15590 on: Sun, 22 December 2013, 20:12:23 »
Thanks nubbs! :)
Not really, not yet. Those were, OMG, what monstrosities are these?!?!? caps that I gave away in the free stuff thread.  Now that I have a pressure pot, I should be able to make some good translucents.
Good to see those made it to you already rowdy.  The post is killing it.
« Reply #15591 on: Sun, 22 December 2013, 20:14:48 »
Thanks nubbs! :)
oh cool ;p
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #15592 on: Sun, 22 December 2013, 20:18:48 »
You're not kidding. I was sitting around watching football yesterday when I got a knock on the door, it was the Australia Post man with my SSK! Don't think I've EVER had a parcel delivered on a weekend before, they must be stepping up for Christmas.
« Reply #15593 on: Sun, 22 December 2013, 20:21:07 »
Thanks nubbs! :)
Heh yeah :)
The red one looks like a couple of little bits were snapped off the underneath - there are two shiny smooth curved bits whereas the rest of it is all bubbly.  Nothing rattling around loose in the bag.
The Cyclops one is a really deep aqua.
Both are resisting my attempts to take good photos :))
« Reply #15594 on: Sun, 22 December 2013, 20:37:06 »
Nope, nothing snapped off, I just derped and put too little resin in the mold...hence that look.
Offline HendyZone
  • HHKB Elite
« Reply #15595 on: Sun, 22 December 2013, 23:18:28 »
No sir, actually it's for tkl board lol :))
got from this -> http://www.ebay.com/itm/Keyboard-Carry-BAG-for-Tenkeyless-87-key-or-small-keyboards-Black-and-Gray-color/281214409996
ts is talking about the case for the poker not the bag
ah sorry then, the poker case is acrylic case from alixinhzai
 :thumb:  :thumb:
Offline yasuo
  • spanengan puyeng newbie
« Reply #15596 on: Sun, 22 December 2013, 23:36:45 »
mantap ui casenya :p masih nyimpen poker lama juga ui ;D
Logitech MK220 Colemak DH
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #15597 on: Mon, 23 December 2013, 00:06:17 »
Just got home from a small vacation and I received my steel Brobut and Samsung EVO SSD for my laptop. I just installed Win7 on it and it is grrrreat.
Offline YoungMichael88
  • HHKB Wannabe
« Reply #15598 on: Mon, 23 December 2013, 00:13:54 »
Thanks nubbs! :)
A bubble trans blank would look pretty incredible in that orange-ish color.
« Reply #15599 on: Mon, 23 December 2013, 01:47:38 »
Sweet :)
What kinda surprised me is that they both fit on a MX switch easily!  Not tight, not loose, a perfect fit.
