Author Topic: [Shipping] Stainless Steel Poker Plate  (Read 183631 times)
Offline The_Beast
  • I like wood ಠ_๏
Re: [4 Days Left] Stainless Steel Poker Plate - Sample on Pg 6
« Reply #200 on: Sun, 21 October 2012, 17:25:13 »
So we won't be able to open switches for Backspace, left/right shift and Enter, unless we desolder? :/
It sucks but it's only 4 switches vs all of them with a different plate design.
For those of you that want to have all your switches openable with the plate, get yourself a file.  Look at the image of the plate, there's really not much material that would need removing.  There's always the chance that you won't keep Cherry plate mount stab compatibility doing this.
Beast, you might ping Litster he's the closest up the food chain still posting that dealt with Phantom proto's.
And here's a picture :)
snip
I do have a dwg of a phantom plate. I'll be using that as a reference on these 4 switches. The red part of your post is why I'm reluctant to change/remove them
So, if I understand this right, you just have to shave off a little where I marked it red?
The space bar switch has the least support, right? (judging from the plate design)
Do you, Beast, feel a difference between space bar switch and any other switch when pressed? If not, why not redesign the plate?
The spacebar is the least supported but that doesn't mean it's weak by any means.
Well, the spot that would need shaving for the best results are the vertical lines to the left and right of the switch.  Trim them so that you are widening the switch hole.  The only support the switch gets at this point is from the top and bottom edges of the plate hole.  I MIGHT be able to figure out how to do this with a pic...
snip
That's what  I was planning to do, but with the switch only being supported by the top, it isn't ideal.
How much material would sanding both sides of the finished plate remove? Not enough to fit costar stabilizers without further sanding right?
The plate is .0625" thick, costar requires .060" +/- .005  thick plate (if I recall correctly). I can ask if he can sand them closer to .060" but it might increase the cost.
Offline Loligagger
« Reply #201 on: Sun, 21 October 2012, 17:49:10 »
If it could be sanded to .060" without increasing cost that'd be great, but otherwise I don't mind just sanding it myself. There are only five switches that need stabilizers anyway.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #202 on: Sun, 21 October 2012, 21:04:28 »
I'll be sending him an email asking a couple questions, that will be one of them.
Offline salmo
    • messmore.org
« Reply #203 on: Sun, 21 October 2012, 22:31:05 »
Added my order.  I even used some restraint and just got one.
Offline BossBorot
« Reply #204 on: Sun, 21 October 2012, 23:53:17 »
this is ****en awesome thanks for doing this
Offline TheQsanity
  • SmallFry Lovin'
Re: [3 Days Left] Stainless Steel Poker Plate - Sample on Pg 6
« Reply #205 on: Mon, 22 October 2012, 00:22:04 »
Which is the better plate? the Poker Suit or standard? How do we order the tool?
When we add this to our board will it be as easy as a PBC board to take off and put on switches?
SmallFry! <3
Offline The_Beast
  • I like wood ಠ_๏
« Reply #206 on: Mon, 22 October 2012, 00:53:17 »
The blank and poker suit plate are 100% the same except that the poker suit one will have the four poker suits cut out above the spacebar. You can order the tool, I'll be buying a bunch of sets and selling them during the same time as shipping the plates.
All the keys will still be open-able except those 4 stabilized keys I was talking about on this page.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #207 on: Mon, 22 October 2012, 01:03:28 »
Good to know we wouldn't have to pay for shipping twice.
So we are able to use both Co-star style and Cherry style stabilizers?
How do we put on the plate? Is soldering required?
SmallFry! <3
Offline The_Beast
  • I like wood ಠ_๏
« Reply #208 on: Mon, 22 October 2012, 01:16:09 »
The designs supports cherry and costar but the plate is too thick to use costar on unless you sand it yourself. The plates we're ordering are .0625" thick and costar requires .060" +/- .005"
To put  on this plate requires you to desolder all the switches, attach them to the plate then resolder everything back onto the PCB
Offline The_Beast
  • I like wood ಠ_๏
« Reply #209 on: Mon, 22 October 2012, 08:38:08 »
I looked at the poker plate and one of the litster plate dwgs I have, the stabilized key cutouts are identical. Did he have problems opening those switches? I guess not being able to open 4 switches isn't terrible considering other plate designs don't allow you to open any of them at all.
Edit:
I emailed the laser guy asking for final cost of the plates, invoicing should start soon and I might close a few days early to give you guys time to pay. I also asked about having him sand both sides, no. He said he could with one plate but the machine he has just isn't build for precision like that and it wears his machine pretty quickly. He said he could try to find precision thickness sheets but that's big $$$$ and would increase the cost quite a bit.
Edit #2:
I was poking around the phantom build thread and those 4 switches aren't open-able either on the phantom plate
« Last Edit: Mon, 22 October 2012, 14:11:29 by The_Beast »
Offline The_Beast
  • I like wood ಠ_๏
Re: [Closing tomorrow] Stainless Steel Poker Plate - Sample on Pg 6
« Reply #210 on: Mon, 22 October 2012, 17:02:36 »
Final quote will be in tomorrow, invoicing will start when I wake up/get the quote in. First round of invoices will be for the plate only. I'll order the plate, wait for them to be produced, get them around thanksgiving, pack them up and send a 2nd invoice (or mass PM) for shipping money.
Offline alixinhzai
« Reply #211 on: Mon, 22 October 2012, 23:25:55 »
ordered  :) cutting technology is better than my country :( that very nice :D
Offline The_Beast
  • I like wood ಠ_๏
Re: [Closing Today @ 11:59CST] Stainless Steel Poker Plate - Sample on Pg 6
« Reply #212 on: Tue, 23 October 2012, 01:45:57 »
closing in ~10 hours
Offline TheQsanity
  • SmallFry Lovin'
« Reply #213 on: Tue, 23 October 2012, 02:38:02 »
That deadline is plate only? What about the tool?
SmallFry! <3
Offline The_Beast
  • I like wood ಠ_๏
« Reply #214 on: Tue, 23 October 2012, 02:55:51 »
I'm fronting the money for the tool
« Reply #215 on: Tue, 23 October 2012, 02:58:48 »
Hey Beast, do you think these plates will be shipped out by say mid-November? If so I can actually send these to a US address if international shipping for 3 plates is too much of a difference.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #216 on: Tue, 23 October 2012, 03:00:37 »
I should start shipping 11/26
Shipping doesn't really matter all that much since I'll be sending one invoice for the plates and another for shipping.
« Reply #217 on: Tue, 23 October 2012, 03:07:05 »
Yea I was just wondering if I'd be around the states when you're shipping out. But I'll be home most likely by the time those arrive. Cool cool, good to know Pinky P---errr Beast.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #218 on: Tue, 23 October 2012, 03:11:19 »
My friends call my pinkie pie, since your not my friend you may address me as Miss Pinkamena Diane Pie
ಠ_ಠ
« Reply #219 on: Tue, 23 October 2012, 03:14:55 »
ಠ_ಠ
Not your friend? *Goes and cries in a corner*
SO MEAN Miss Pinkamena Diane Pie! More like....Miss PinkaMEANIE Diane Pie! :'(
Offline The_Beast
  • I like wood ಠ_๏
« Reply #220 on: Tue, 23 October 2012, 03:31:28 »
ಠ_ಠ
lol, I love saying up till 3am to laugh at dumb jokes ^___^
« Reply #221 on: Tue, 23 October 2012, 03:40:10 »
^ Gogo late nighters! LETS PARTY BRO!
Offline The_Beast
  • I like wood ಠ_๏
« Reply #222 on: Tue, 23 October 2012, 03:42:54 »
Yea until you start to have 8am classes
« Reply #223 on: Tue, 23 October 2012, 03:46:25 »
Bust out the coffee...ALL NIGHTER TIME!
Offline feng
« Reply #224 on: Tue, 23 October 2012, 07:33:27 »
Order sent.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #225 on: Tue, 23 October 2012, 09:25:36 »
9:30 now, closing in 2 1/2 hours
I'm starting to invoice now
Offline The_Beast
  • I like wood ಠ_๏
« Reply #226 on: Tue, 23 October 2012, 10:13:02 »
All ConUS invoices have been send. I'll do international and any new orders tonight
Check here for most up to date info
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #227 on: Tue, 23 October 2012, 10:14:46 »
Paid
Offline MMB
« Reply #228 on: Tue, 23 October 2012, 10:24:37 »
$PIZZAID!$
Offline xavierblak
« Reply #229 on: Tue, 23 October 2012, 10:31:52 »
Paid! :cool:
Offline modulor
« Reply #230 on: Tue, 23 October 2012, 10:39:32 »
Payment sent!
NP-R (soon) | 21XX | Leggera-G Acrylic | Classic TKL | Frog TKL 8K | GH60revC | R1 86U 45g | G80-2100HDU | G80-3000HAU | G80-3700HAU | QFR V1 | FC200R | Poker X | G80-11900LUMEU
Offline yuiop
« Reply #231 on: Tue, 23 October 2012, 11:28:25 »
Last minute order sent!
Offline The_Beast
  • I like wood ಠ_๏
« Reply #232 on: Tue, 23 October 2012, 13:05:06 »
CCCC-CCCC-CLOSED
More invoicing tonight or tomorrow
Offline nebo
Re: [Invoicing] Stainless Steel Poker Plate - See Post #2 For Order Status
« Reply #233 on: Tue, 23 October 2012, 13:38:05 »
While I'm no longer in this GB, is there a good guide for modding from PCB to plate mounting? It's been forever since I soldered anything and if it's simple enough I'd rather just do it myself.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #234 on: Tue, 23 October 2012, 13:41:18 »
If I have time I can try, but I make no promises
Offline nebo
« Reply #235 on: Tue, 23 October 2012, 13:49:01 »
No promises needed, I remember school and 8AM classes, sleep when you can. It's far more important.
Offline tipo33
  • "Ski"
« Reply #236 on: Tue, 23 October 2012, 16:02:25 »
PAID!  I'm really exited for a platemounted poker.  I should probably pull out the soldering iron, blow the dust off, and practice on something cheap before it arrives...
KM4COL    R.I.P.  SmallFry
Offline The_Beast
  • I like wood ಠ_๏
« Reply #237 on: Tue, 23 October 2012, 18:50:57 »
ALL invoices have been sent, you can wait a bit before paying (to spread payments out) but just don't forget   ^___^
« Reply #238 on: Tue, 23 October 2012, 18:54:24 »
Paid and sent you a pm
Offline skeaono
« Reply #239 on: Tue, 23 October 2012, 19:13:15 »
Paid!
Offline CKTofu
  • I don't even...
« Reply #240 on: Tue, 23 October 2012, 19:40:58 »
Paid!
Ducky Shine 2 - MX Red with Red LEDs
Offline salmo
    • messmore.org
« Reply #241 on: Tue, 23 October 2012, 19:47:25 »
paid!  Can't wait... (but will :) )
Offline The_Beast
  • I like wood ಠ_๏
« Reply #242 on: Tue, 23 October 2012, 19:48:43 »
Don't worry about the note section. I thought you could put you can't, I only needed it so I could find your user names more easily. But google spreadsheets have a search function (google and search, iknowright?) so it's no big deal
Offline hasu
  • @tmk
« Reply #243 on: Tue, 23 October 2012, 21:46:30 »
Paid. String Yen kills our domestic industries but it is nice when buying from oversea :D
Offline mehkat1974
« Reply #244 on: Tue, 23 October 2012, 22:51:51 »
Paid. Sorry about the delay (if there was one) these days seems like everyone is doing the invoicing via pm, I hadn't been in my pp account for a while
HHKB Type-S / KBC Poker with reds
Offline The_Beast
  • I like wood ಠ_๏
« Reply #245 on: Tue, 23 October 2012, 22:53:11 »
It's the first day, I wasn't even expecting to get this many payments
Offline mehkat1974
« Reply #246 on: Tue, 23 October 2012, 22:55:14 »
ffs I forgot to put my gh name in the notes
sorry about this I know it's a drag I will pm you
Offline mm87
« Reply #247 on: Tue, 23 October 2012, 23:26:43 »
Paid :]
Offline The_Beast
  • I like wood ಠ_๏
« Reply #248 on: Wed, 24 October 2012, 00:56:20 »
« Reply #249 on: Wed, 24 October 2012, 01:02:55 »
Can I get a refund and just send you apples instead? I feel that would be better for both of us :p
