Author Topic: [Shipping Starting] LZ-GH Keyboard (taking LED options...)  (Read 362393 times)
Re: [Shipping Starting] LZ-GH Keyboard (taking LED options...)
« Reply #1450 on: Sun, 16 June 2013, 17:55:11 »
Pretty sure we're good via PM.
K awesome. Thanks again for all the help! :)
Yea we will be good to go. I messed up by thinking all "like-colored" LEDs shared the same voltage (i.e. one red is the same foreword voltage as any other red) I now know I was wrong and need 1kOhm resistors for our particular red LEDs and our 5000 732Ohm resistors are no good for us....For now...
They're good for the lower colours!!
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1451 on: Mon, 17 June 2013, 13:01:41 »
Got mine, looks intact
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #1452 on: Mon, 17 June 2013, 13:07:06 »
-Enzo Ferrari
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #1453 on: Mon, 17 June 2013, 13:25:11 »
So I have some 7000MCD Cyan @  4.2-4.6V LEDs, what resistors would I need? Is it even possible to give that much voltage to an LED on an LZ-GH?
Edit: Just found a calculator but need some information. What would the source voltage be, diode forward voltage, and diode forward current be?
« Last Edit: Mon, 17 June 2013, 13:27:36 by danielucf »
Offline alaricljs
  • I be WOT'ing all day...
« Reply #1454 on: Mon, 17 June 2013, 13:35:02 »
your LED provides the diode forward voltage and current.  5v is the supply voltage and 3.4mA is the absolute max supply current per LED.  I recommend aiming for 3.2mA
Filco w/ Imsto thick PBT
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #1455 on: Mon, 17 June 2013, 13:45:15 »
So here is what I plugged in:
Source Voltage - 5v
diode forward voltage - 4.2-4.6
diode forward current  (mA) - 3.2
then for my resistor I get 270-150 ohm depending on the voltage I want. 4.2v 270 ohm, 4.3v 220 ohm, 4.4v 220ohm, 4.5v 180 ohm, and 4.6v 150 ohm.
Any advice on which resistor I should shoot for? These LEDs are Green around @ 3.2-3.6V which is normal keyboard LED voltage I imagine *shrug*
Offline alaricljs
« Reply #1456 on: Mon, 17 June 2013, 14:05:02 »
What?  First you say you have cyan 4.2-4.6v leds.... now they're green and 3.2-3.6v ?
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #1457 on: Mon, 17 June 2013, 14:12:43 »
I was under the impression that depending on what resistor you put in they would be different colors. At least that is what the Chinese seller on ebay said.
For exampe:
680 ohm resistor giving 3.2V at the LED = visibly green
180 ohm resisotr giving 4.5V at the LED = visibly cyan
Offline alaricljs
« Reply #1458 on: Mon, 17 June 2013, 14:39:32 »
I've only ever seen ~.5v variance (ie: 3.0-3.4v) and going outside that cooking the LED.  I've got a few LEDs I could burn up, might be interesting.  Also, if it doesn't burn up it undoubtedly shortens the life span.
Ok, the color changed just slightly... right before it flickered and burnt at ~3.95v.
« Last Edit: Mon, 17 June 2013, 14:44:48 by alaricljs »
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #1459 on: Mon, 17 June 2013, 14:43:59 »
Maybe they are designed for 4.2-4.6V and when you undervolt them they are green instead of Cyan. I'll test it out and see I guess, as long as it won't kill the PCB or anything that isn't easy to replace like LEDs.
Offline alaricljs
« Reply #1460 on: Mon, 17 June 2013, 14:45:09 »
Put a DMM in-line and find out how much current is passing.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #1461 on: Mon, 17 June 2013, 14:54:52 »
Where is a good place to buy one?
Offline alaricljs
« Reply #1462 on: Mon, 17 June 2013, 15:58:14 »
A reasonably cheap Craftsman has been my DMM for years now.  Sears (no longer available)
Honestly Harbor Freight or HD or Lowes should have something *good enough*
« Reply #1463 on: Mon, 17 June 2013, 16:15:30 »
Yeah, you can get the cheap one at Harbor Freight on sale for $1.99. Works well enough for me.
Offline WhiteFireDragon
    • youtube
« Reply #1464 on: Mon, 17 June 2013, 16:39:28 »
Haha DMM for $2? And it actually works?
Btw where can I get those aqua-marine or cyan LEDs? Do they also come in SMD?
« Reply #1465 on: Mon, 17 June 2013, 16:42:07 »
Okay, it was $3.99 actually.
http://www.harborfreight.com/7-function-digital-multimeter-69096.html
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #1466 on: Mon, 17 June 2013, 17:13:44 »
I was selling them awhile ago, got 1000 of them on ebay from a Chinese seller and I can not find any more for sale. I think I only saved enough for LZ-GH.
Offline Dianoda
« Reply #1467 on: Mon, 17 June 2013, 17:24:54 »
Try ebay.  If you can't find any, well, I have a 100ct set of these SMD cyan leds, could maybe spare a few:
http://www.ebay.com/itm/190830790646?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Haven't had a chance to test them out yet, but soon...
Offline rknize
    • metaruss
« Reply #1468 on: Tue, 18 June 2013, 13:39:12 »
It arrived today and looks to be in good condition.
Russ
Offline codyeatworld
« Reply #1469 on: Tue, 18 June 2013, 13:42:04 »
Mine came yesterday and I love it, very glad I had you solder the resistors for me alaricljs! :P
Gotta get my hakko outta storage and while I wait for my switches :D
« Reply #1470 on: Tue, 18 June 2013, 13:56:01 »
Phantom today...LZ tomorrow...MY BODY IS NOT READY! :D
Offline alaricljs
« Reply #1471 on: Tue, 18 June 2013, 15:08:52 »
If you get your board and the LEDs are super dim... unplug it, hold down the Esc key and plug it in (hold Esc for 5 seconds).
Problem solved.
Offline jcrouse
« Reply #1472 on: Tue, 18 June 2013, 17:08:53 »
If anyone ordered a metal grey or black, preferably metal grey, in 84 key and is interested in trading for a red send me a PM. It is in perfect condition without and marks or flaws.
Thanks,
John
Offline alaricljs
« Reply #1473 on: Tue, 18 June 2013, 17:18:40 »
BTW - I also just learned that this sort of reset of the LEDs also will default the KB to an 87key layout (messes up the alt/win/ctrl on the right side)
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #1474 on: Tue, 18 June 2013, 17:26:29 »
Mine arrived yesterday but I didn't get to dig in until today. Looks really amazing so far and I can't wait to put it all together, now I just need to decide if I want stickered/lubed vintage blacks, or 62g whites with stickers. Also need to decide if I'm going to dremel my top housings so they can be removed with LEDs still installed.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #1475 on: Tue, 18 June 2013, 21:28:28 »
So he has already fitted all your switches for you?  Have no idea what deal you have had with alaricljs.
I did get a request for shipping but nothing else.  Would it be extremely rude if I kindly ask here, has the keyboard been completed already and if so, can I get some pics of it?
So far I have no information about it's assembly nor any info about the Korean Cherry Clears that were sent to him.  Just need to ask questions and see if there are any answers (has been like dealing with your Pentagon, many questions but still no answers whatsoever).
So far have not gotten any info aside from wanting money for shipping.  Would appreciate knowing what else has been done?
« Last Edit: Tue, 18 June 2013, 21:33:39 by Elrick »
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #1476 on: Tue, 18 June 2013, 21:50:29 »
rknize didn't get it assembled :P
-Enzo Ferrari
Offline Elrick
  • Hype Master
« Reply #1477 on: Tue, 18 June 2013, 22:32:13 »
rknize didn't get it assembled :p
That's alright.  I just got the PM from the "Keyboard Master" and he says everything has been completed.
And that is all I was after.
Offline Elrick
  • Hype Master
« Reply #1478 on: Tue, 18 June 2013, 22:40:41 »
Payment has been sent.
Thank you for putting this keyboard together for me, much appreciated.
Offline rknize
    • metaruss
« Reply #1479 on: Tue, 18 June 2013, 23:20:15 »
Yup, just parts:
Russ
Offline Elrick
  • Hype Master
« Reply #1480 on: Tue, 18 June 2013, 23:45:57 »
Yup, just parts:
Definitely beautiful.  You've got the same colour as mine.
Can't wait to fit it out with some Dolchs when it gets here......although haven't seen the Dolch's quite yet.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #1481 on: Wed, 19 June 2013, 00:01:14 »
People building these, don't forget to put your PCB mount stabilizers on the PCB before you start soldering on switches.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #1482 on: Wed, 19 June 2013, 01:27:43 »
Oooooh boy, got this bad boy put together. Went with Tribolube 71 lubed vintage blacks with orange stickers. Typing on this is pretty awesome, had to christen it with dolch and RGB with white text, will have to post pictures tomorrow. Getting LEDs to work will come later.
Offline jcrouse
« Reply #1483 on: Wed, 19 June 2013, 06:50:11 »
Yeah, ya only ever do that once. I did it a few months ago. Fortunately caught it after 3 or 4 switchhes were soldered. Another best practice is to use a meter and verify every diode. I built a high quality korean board once only to find two diodes on backwards, was NOT happy.
John
Offline jcrouse
« Reply #1484 on: Wed, 19 June 2013, 06:53:39 »
25783-0
First day of use.
Enjoy,
John
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #1485 on: Wed, 19 June 2013, 08:17:37 »
-Enzo Ferrari
« Reply #1486 on: Wed, 19 June 2013, 09:18:28 »
^ haha, this.
Offline jcrouse
« Reply #1487 on: Wed, 19 June 2013, 10:02:21 »
First day of use.
Enjoy,
John
No cc on it :(
They are in the safety deposit box, errrrr, I mean, I wish I had CCs.
Offline AKIMbO
  • HHKBro
« Reply #1488 on: Thu, 20 June 2013, 21:20:35 »
Hey guys...I've got a really dumb question.  Does the LZ-GH PCB support both plate mount and pcb mount cherry mx switches....or just plate mount switches?
| KBD75 (box reds)
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #1489 on: Thu, 20 June 2013, 21:21:29 »
Both plate and pcb mount
-Enzo Ferrari
Offline AKIMbO
  • HHKBro
« Reply #1490 on: Thu, 20 June 2013, 21:22:19 »
Ooo nice...I scored some pcb mount clears so less work for me.  Off to alaricj these go!
| KBD75 (box reds)
Offline Kayliss
« Reply #1491 on: Fri, 21 June 2013, 03:59:30 »
My LZ-GH arrived safely today. Thank you to Boost and everyone else involved.  :D
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #1492 on: Fri, 21 June 2013, 16:16:25 »
Are you sure? It came with PCB mount, and when I tried to use my own plate mount the holes were too big and the stabilizers just wouldn't stay.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1493 on: Fri, 21 June 2013, 16:18:04 »
Note how that says switches, sir and not stabs...
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #1494 on: Fri, 21 June 2013, 16:22:05 »
Grah I'm an idiot. Good looking out. I blame 3 too many Mai Tai drinks last night :p
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1495 on: Fri, 21 June 2013, 16:44:12 »
Thems some tasty alcohols.  All is forgiven.
Offline Turkishrambo
« Reply #1496 on: Sun, 23 June 2013, 07:29:32 »
NEED HELP STAT!
I dropped a few resistors because im clumsy.. can someone link me to the ones i need to get? I only need like 5. lol\
 My local electronics store doesnt have these.. T.T
Wouldve been nice if we got a few extras! XD
Offline jcrouse
« Reply #1497 on: Sun, 23 June 2013, 11:25:03 »
Anyone get the programming figured out yet. I know Small Fry was close at one point. I can do most of the basic stuff but can't get the LEDs setup the way I want. There were posts asking for help but we keep getting told to go to the mfg's website. Personally, I don't do Korean too well. With this amount of money changing hands it certainly should not be too much to ask someone involved to take a couple of hours and give us an English manual. Am I wrong here?
The problem I am having, after soldering the LED resistors is dimness, as alaricljs mentioned in a post. I can hold down the ESC for 5 seconds while powering up to reset it and get the desired brightness but then I only have basic scroll lock / caps lock functioinality. I am attempting to illuminate the entire F row. I have tried all of the modes in the software but they are too dim. Also, they don't seem to save to the kbd properly, meaning when I unplug and replug they don't come back how they were before. Also, what if the F/W button in the software do?
John
« Last Edit: Sun, 23 June 2013, 12:28:43 by jcrouse »
Offline jcrouse
« Reply #1498 on: Fri, 28 June 2013, 07:22:06 »
Anyone? Any help out there?
John
Offline pasph
« Reply #1499 on: Fri, 28 June 2013, 07:49:09 »
John
Have you tried to PM DrugER?
