Author Topic: Aluminum 60% case - GH60, Poker, Pure  (Read 123564 times)
Offline Strelok
Re: Aluminum 60% case - GH60, Poker, Pure
« Reply #150 on: Wed, 20 March 2013, 00:13:50 »
The large hole diameter is 2" (+tolerance factored in) for the large disc, and 1.30" for the smaller disc. They're all 1/4" thick. Hopefully you can make use of that space. I can increase the diameter more, but that would mean it can't be as deep because the bottom edge will be milled through the angled case.
6mm should be enough Z height depending on what surface mount components we end up needing.
I don't feel like doing the calculus to figure out the size of the rectangle we can fit inside a 2" diameter circle, but it will most likely give us enough room to work.
Offline cobraj
« Reply #151 on: Wed, 20 March 2013, 00:30:19 »
Just draw it and measure it with a ruler :P
Offline CommunistWitchDr
  • >implying keyboards
« Reply #152 on: Wed, 20 March 2013, 00:54:37 »
Case looks awesome.
A custom programmed GH60 and GPAD with these cases (anodized in black) with my thick imsto caps is now my ideal board. Tenkeylesses feel huge and some parts of the fn layer is dumb on poker/pure.
Not really sure of the switch. Blue, green, or white.
Also slow change rainbow leds because that's ballin.
http://www.youtube.com/watch?feature=player_embedded&v=06Oaj2cKCwE
Offline TheQsanity
  • SmallFry Lovin'
« Reply #153 on: Wed, 20 March 2013, 02:29:09 »
Will the case and ghpad be synchronized with the new Bluetooth/led/usbport/etc?
It would seem quite innovative if we could incorporate ghpad with Bluetooth connection to gh60 or something.
SmallFry! <3
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
« Reply #154 on: Wed, 20 March 2013, 09:11:12 »
We didn't thought about the gh60 and ghpad integration yet.
Worst case scenario, assuming that we do have room inside the ghpad case, we can have two bluetooth keyboards.
Any other idea?
Offline komar007
    • komar's blog
« Reply #155 on: Wed, 20 March 2013, 09:28:08 »
The GHPad will be designed in such a way, that it won't require any electronics (except switches and diodes) if connected as an extension to GH60.
However this requires the expansion pins, which are also used to talk to the BT module.
But it should be possible to communicate with BT between matrix scans. Electrically there's no problem. If the BT module doesn't send anything without notice, everything should be ok.
Offline agodinhost
    • Dr Ian O Xaman
« Reply #156 on: Wed, 20 March 2013, 09:37:30 »
Hmmm, don't know ...
And IF I wanna use ONLY the gpad?
Offline komar007
    • komar's blog
« Reply #157 on: Wed, 20 March 2013, 09:46:40 »
Then you solder the controller and everything and you use it.
Offline agodinhost
    • Dr Ian O Xaman
« Reply #158 on: Wed, 20 March 2013, 17:51:58 »
It works, sure.
So are we going to have two versions of the GHPad PCB?
Offline komar007
    • komar's blog
« Reply #159 on: Wed, 20 March 2013, 18:20:38 »
No, I don't think so. It shouldn't be necessary.
Offline pix3l_fodder
« Reply #160 on: Thu, 21 March 2013, 11:29:56 »
WhiteFire, how likely is it that I could get an un-anodized case, have it powder coated and the brass disks still fit? Are the disks a snug fit?
ignore, i got confused between this and another GH60 case. Any idea on the finishes yet?
« Last Edit: Thu, 21 March 2013, 14:27:02 by pix3l_fodder »
« Reply #161 on: Thu, 21 March 2013, 12:35:17 »
Am I the only one who wants the case done in the colours from the OP? Light blue bottom, red plate and purple top? :D
Oh, and I didn't see anywhere in the thread. Do you have an HHKB plate design with the split backspace?
« Last Edit: Thu, 21 March 2013, 12:38:58 by Halverson »
Offline Dubsgalore
« Reply #162 on: Thu, 21 March 2013, 13:24:21 »
Is there a price range for this? Also any idea on when these will be ready to order?
Offline Loligagger
« Reply #163 on: Thu, 21 March 2013, 20:04:51 »
Would it be possible for the case have a flat bottom like this?
Pic is penoulum's 356 mini:
Offline DavinDidIt
« Reply #164 on: Thu, 21 March 2013, 21:06:00 »
4) modular top cover - The top cover has 3 different designs, allows you to choose a winkeyless cover, HHKB style, or standard full keys
Would be awesome if this can fit the topre HHKB....
If so, I'd definitely be in
KMAC 2, HHKB
Offline Dubsgalore
« Reply #165 on: Thu, 21 March 2013, 21:21:58 »
this will be the case for my gh60. i want the hhkb layout and this looks the best for the gh60 hhkb layout. really excited...just want to know when we will ordering here. also...if we can pick colors..i think a white case would be sexy. i can just imagine my gh60 now...white on white pbt keycaps on a white aluminum case..gonna be awesome
Offline L4yercake
« Reply #166 on: Thu, 21 March 2013, 21:35:08 »
Not possible as the top of the HHKB is also part of the switch housing.
« Reply #167 on: Fri, 22 March 2013, 04:04:45 »
Yeah not a fan of the colours you've picked(red and grey? - i think), no chance for all black or just a raw milled case for we can get it painted ourselves?
Offline longweight
  • philanthropist
« Reply #168 on: Fri, 22 March 2013, 04:28:02 »
Those are indicative renderings.....
« Reply #169 on: Fri, 22 March 2013, 04:53:16 »
I thought that to, but reading post http://geekhack.org/index.php?topic=39599.msg818891#msg818891
says otherwise. I mean I don't mind Titanium look but I would want the plate to be the same colour (although the GH60 comes with a plate so this might not be a problem), just would prefer a black option.
Offline Dubsgalore
« Reply #170 on: Fri, 22 March 2013, 07:59:25 »
i think when the group buy comes out for this (hopefully soon) i bet there are going to be more colors
Offline Kaysa
« Reply #171 on: Sat, 23 March 2013, 05:00:17 »
What is the estimated price for a case for HHKB Pro2 ansi layout with the GH60 PCB, switches, Plate, Switches Lube, Stabilizer Lube and etc.?
May I have  a quotation for all the above? and the estimated price to finish all stated above?
Currently Using:
HHKB Pro2 Black with Pink blank keycaps
Topre Realforce 10th Anniversary 2nd Batch "Silent" Varied Weight force.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #172 on: Sat, 23 March 2013, 18:04:35 »
A semi-wild guess:
$140 for the GH60
$200-$250 for the case
Offline Dubsgalore
« Reply #173 on: Sat, 23 March 2013, 18:07:24 »
A semi-wild guess:
$140 for the GH60
 :eek:
« Reply #174 on: Sat, 23 March 2013, 18:10:08 »
Welcome to WalletHack
Offline The_Beast
  • I like wood ಠ_๏
« Reply #175 on: Sat, 23 March 2013, 18:10:32 »
A semi-wild guess:
$140 for the GH60
 :eek:
It's a custom milled case
Offline Dubsgalore
« Reply #176 on: Sat, 23 March 2013, 19:50:12 »
A semi-wild guess:
$140 for the GH60
 :eek:
 :confused: $200
ok now that we have a price range, any known time this will be ready for GB?
Offline Index
« Reply #177 on: Sun, 24 March 2013, 15:22:52 »
Im ready to drop the monies for 2 cases.
Gaming Keyboard: Leopold FC200RT/ABN
Work Keyboard: HHKB Pro 2 PD-KB400B
Offline Dubsgalore
« Reply #178 on: Sun, 24 March 2013, 15:27:28 »
i want to hear when this will be ready to order :)
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #179 on: Mon, 25 March 2013, 02:03:53 »
Give the man time before before jumping him with these questions; these things take time. Also consider that the GH60 wont be ready until summer (hopefully).
I honestly feel bad i'm not contributing to these projects. WFD and GH60 team are heros.
Offline ishumprod
« Reply #180 on: Mon, 25 March 2013, 03:03:55 »
ktf bro
home-made TKL rubber dome keyboard !
Offline Sai
« Reply #181 on: Wed, 27 March 2013, 22:56:37 »
hmm , i am just curious. will it be possible for the case to have blockers like KMAC Happy? so it would be easy to go between ANSI 1.5 and HHKB style. :D
Offline tradet
« Reply #182 on: Fri, 29 March 2013, 16:30:09 »
This looks so good. I'm very interested!
Offline rurushu
« Reply #183 on: Sat, 30 March 2013, 12:18:15 »
this case is really nice, although it does strike some similarity to Duck Poker case when i first saw it, but the overall design + the compatibility it provides with other 60% keyboard justifies its design as an ideal design!
cant wait for the pricing as might be getting the GH60 depending on the progress of this awesome WFD casing....
oh by the way, WFD, have you thought up of a name for your case? or is it just going to be called WhiteFireDragon Case? (The name sounds impressive though)  :p
Offline tricheboars
  • Keyboards are Important!
« Reply #184 on: Sat, 30 March 2013, 15:57:22 »
i agree this bad boy needs a name. something with some panache?
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #185 on: Sat, 30 March 2013, 16:04:23 »
Well the Duck Poker Case is called that because Duck0113 designed it/ran the GB. So by that rationale, would that make this the WFD 60?
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #186 on: Sun, 31 March 2013, 00:44:47 »
WFD60 looks good to me unless he has a more elaborate name in the works.
Offline WhiteFireDragon
    • youtube
« Reply #187 on: Sun, 31 March 2013, 01:08:26 »
I would prefer not to name things after myself. I don't need THAT much credit. I'm open to suggestions, but here are some of my own:
- Magnus 60
- Esprit 60
- Aldebaran 60
- Legend 60
For those waiting and still PMing me about details of this case, this is not completely on hold, but there are just other priorities, like finishing up the phantom parts. I scrapped the current drawings of this case and started from scratch again during the past few weeks. The angle before was a 5° tilt, I increased it to 6.25°. For reference, stock poker is 6°, and Filco with the extended feet I measured at 10°. I also had to slightly increase the thickness of the front and back wall so that the screw head does not show through. And the current height was designed for 0.15" standoffs, which does not exist so I had to change to total gap between the case and PCB.
Offline Nask
« Reply #188 on: Sun, 31 March 2013, 01:12:39 »
- Magnus 60
- Esprit 60
- Aldebaran 60
- Legend 60
I think Magnus really better and my favorite is Legend 60.
You should make a quick poll.
Keyboards: IBM SSK | Noppoo Choc Mini MX-Blue | PLU ML-87 MX-Brown | CM QFR Mx-Red | CM Novatouch
« Reply #189 on: Sun, 31 March 2013, 01:13:58 »
My votes for Legend 60 :D
Offline Jocelyn
  • 조셀린
Re: Re: Aluminum 60% case - GH60, Poker, Pure
« Reply #190 on: Sun, 31 March 2013, 01:15:11 »
Stop allowing WFD to be so modest lol
Make him keep it WFD60 imo :)
« Last Edit: Sun, 31 March 2013, 01:16:49 by Jocelyn »
« Reply #191 on: Sun, 31 March 2013, 01:20:43 »
Don't even act like we won't call it that anyways. Of course we're going to call it that regardless of what the OP title is :P
Offline Nask
« Reply #192 on: Sun, 31 March 2013, 01:42:10 »
You only said that because he has a cool nickname, WFD60 is as cool as Legend60. :D
Offline gameaholic
« Reply #193 on: Sun, 31 March 2013, 02:02:59 »
Would an orange LED color be possible for the Caps Lock LED? oop meant to post in GH60 group buy thread, and oops there is an option for amber LED in the poll
« Last Edit: Sun, 31 March 2013, 02:08:11 by gameaholic »
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Offline rurushu
« Reply #194 on: Sun, 31 March 2013, 08:51:39 »
i also agreed to the name WFD60, not saying that it gives too much credit to the designer (although i think the designer deserved it),
but partly the name also sounds nicer....
so i vote for WFD60
Offline mashby
    • Mashby
« Reply #195 on: Sun, 31 March 2013, 09:30:42 »
Dragon 60?
White Fire 60?
Offline Moosecraft
  • HHKB Pro
« Reply #196 on: Sun, 31 March 2013, 10:18:04 »
WhiteDragonOfAwesome60?
Offline tricheboars
« Reply #197 on: Sun, 31 March 2013, 11:16:51 »
So 'Magnus the God Cleaver' it is.
« Reply #198 on: Sun, 31 March 2013, 11:16:56 »
I think WFD60 would be good. I'm going to call my case the TEK-80 - I think short version of username+size in percent is a good format.
Offline Dubsgalore
« Reply #199 on: Sun, 31 March 2013, 12:28:06 »
voting for WFD60
if not, then Legend60
