Author Topic: Signature Plastics New Site  (Read 13721 times)
Offline AKIMbO
  • HHKBro
« on: Thu, 31 January 2013, 11:55:35 »
Looks like SP updated their marketplace site.  They revamped the marketplace and pimpmykeyboard.  New stuff like keycaps display racks, stoner keys, metallic keys, rubber keys, etc.
http://www.keycapsdirect.com/marketplace.php
http://www.pimpmykeyboard.com/
| KBD75 (box reds)
Offline phetto
  • HHKB JP
Re: Signature Plastics New Site
« Reply #1 on: Thu, 31 January 2013, 12:01:03 »
Some nice things over there. Damn budget..
Offline inteli722
« Reply #2 on: Thu, 31 January 2013, 12:02:03 »
Looks much nicer than the old site... I'm pretty sure that someone's going to get a bunch of clacks and a display shelf to brag to their friends about how many caps they bought for 300% actual value (assuming they bought secondhand. Not insulting CC's prices).
I spot a couple internet-related caps that would be fun.
Waiting for: Phantom Plate
Offline The_Beast
  • I like wood ಠ_๏
« Reply #3 on: Thu, 31 January 2013, 12:12:35 »
Looks sweet. I might order some of the white display thingys and do a hardwood display panel
« Reply #4 on: Thu, 31 January 2013, 12:18:47 »
Those faded function and number sets are PIMP!
Flat keys! Just what I need for my 86-key ANSI150 Phantom layout and GH60 layout. Illusion of blocks, but a usable winkey/fn switch, if needed. :)
Spherical stoner keys? Yes!
Nice work, SP. Bravo. :D
Offline alaricljs
  • I be WOT'ing all day...
« Reply #5 on: Thu, 31 January 2013, 12:27:33 »
Thinking of getting flat keys for custom PC case power/reset...
Filco w/ Imsto thick PBT
« Reply #6 on: Thu, 31 January 2013, 12:46:09 »
Beast, I'd be interested in this. Let me know if you end up doing this.
Offline whiskytango
  • Don't touch the trim
« Reply #7 on: Thu, 31 January 2013, 13:27:44 »
so does anyone know if the caps on http://www.pimpmykeyboard.com/ are double shot or what?
And can anyone elaborate on the TPU (rubber) and POM (acetal) material choices for the Custom Ctrl Set?
Offline inteli722
« Reply #8 on: Thu, 31 January 2013, 13:28:55 »
They should all be either Doubleshot or DyeSub (for instance, the Nyan Cat key HAS to be DyeSub) considering they're from SP.
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #9 on: Thu, 31 January 2013, 13:42:25 »
I like the key lock-outs.  I also spy a PBT modifier set in addition to the PBT arrows.  I like where this is heading.. :)
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #10 on: Thu, 31 January 2013, 13:51:42 »
Too bad that set does not contain matching blanks for the winkey spots.
Also, RUBBER keycaps?
 - Ron | samwisekoi
Offline inteli722
« Reply #11 on: Thu, 31 January 2013, 16:43:22 »
 - Ron | samwisekoi
Same thing as rubber Lego guns. that would be VERY cool. Not sure how practical, maybe if you type on a mechanical keyboard in the car (provided you aren't driving)...
Offline quake4mhg
« Reply #12 on: Thu, 31 January 2013, 18:49:10 »
Sorry for my noobish. What's the key lockouts for? Thank you 😅
Offline sth
  • 2 girls 1 cuprubber
« Reply #13 on: Thu, 31 January 2013, 18:51:59 »
I'm REALLY curious to know if they are within their rights to reproduce keys with custom legends like Dan's stoner key or any number of the techkeys products.
Ah whoops I see those ones aren't for sale.
« Last Edit: Thu, 31 January 2013, 18:54:06 by sth »
Offline AKIMbO
  • HHKBro
« Reply #14 on: Thu, 31 January 2013, 18:57:28 »
It looks like plastic inserts which prevent you from being able to depress the switch.  Seems like its' the same size as a keycap...so the keycap would be hitting the key lockout plastic thingamajigs and not be able to be fully depressed (ie. you can't activate the switch).
But that's just my educated guess.
| KBD75 (box reds)
Offline SmallFry
« Reply #15 on: Thu, 31 January 2013, 19:07:43 »
The keylockouts and the flat keycaps would be nice for a phantom to go from 84 to 86 in a snap, IMO.
Offline lazerpointer
  • ya gotta stay phresh
« Reply #16 on: Thu, 31 January 2013, 19:20:08 »
I don't see where the rubber key caps are. I've wanted to try something like that
i type, therefore i geekhack
« Reply #17 on: Thu, 31 January 2013, 19:24:30 »
The problem with the key lockouts, they only work for pcb mounted boards. They clip right over the switch, and with a plate it just doesn't work. Nor do they work on topre.
« Reply #18 on: Thu, 31 January 2013, 19:35:35 »
They are on pimpmykeyboard, and it is one of the options for the custom control set.
« Reply #19 on: Thu, 31 January 2013, 19:36:21 »
Are you sure?  The photo seems to have it installed on a plate mount keyboard.
« Reply #20 on: Thu, 31 January 2013, 19:36:42 »
THIS
Offline inteli722
« Reply #21 on: Thu, 31 January 2013, 19:39:07 »
THIS
YES, THIS.
That would be great...just to find a set that would match the color of your case...
Offline SmallFry
« Reply #22 on: Thu, 31 January 2013, 19:39:33 »
Heh, I'll have to buy a set:)
Offline reaper
« Reply #23 on: Thu, 31 January 2013, 19:50:42 »
Ooh, new keycaps.  You know I'm in. lol
Din Eli
Offline limmy
« Reply #24 on: Thu, 31 January 2013, 20:06:55 »
A lot of interesting products!!
Offline inlikeflynn
  • file not found
« Reply #25 on: Thu, 31 January 2013, 21:21:54 »
umm,
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline alaricljs
« Reply #26 on: Thu, 31 January 2013, 21:23:23 »
That's interesting, wonder if they talked to Dan.
Offline SmallFry
« Reply #27 on: Thu, 31 January 2013, 21:24:29 »
It isn't his design, they don't need his approval, despite the obvious connection.
Offline sth
« Reply #28 on: Thu, 31 January 2013, 21:26:12 »
HMm yeah that's what I posted about originally after seeing their picture. Not sure about the legality but that's pretty weak; they could easily come up with their own designs...
« Reply #29 on: Thu, 31 January 2013, 23:47:05 »
Those doubleshot PBT arrowkeys are back! I also nite the "custom ctrl set" is also available in PBT. Is it doubleshot? Looks like it? I also notice it's available in POM. Maybe i will order both and see what the deal is.
« Reply #30 on: Fri, 01 February 2013, 04:35:53 »
An Oops! key to fit backspace would be perfect :))
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #31 on: Fri, 01 February 2013, 06:50:05 »
umm,
that smile is ugly compared to the one from DanGWanG...
« Reply #32 on: Fri, 01 February 2013, 07:53:44 »
It's the well-traveled design from the WWW.  Dan's is a bit different and presumably he did not give them access to his design.
Offline Lastpilot
  • Power stance
« Reply #33 on: Fri, 01 February 2013, 08:22:59 »
I wonder what a full flat keycap set would look like... :D
Offline TotalChaos
  • Indy Game Coder
« Reply #34 on: Fri, 01 February 2013, 10:57:54 »
I agree.  I would order one right now if they had one.  I am putting an order together.
Currently reading their FAQ, and all their profile .pdfs and stuff.  And finding bugs in their website.  They don't seem to have a vendor forum so I will try to send them an email if I remember.
Offline phetto
  • HHKB JP
« Reply #35 on: Fri, 01 February 2013, 11:19:13 »
Isnt that just a normal awesome face but in green?
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #36 on: Fri, 01 February 2013, 11:21:06 »
Yes.
Offline phetto
  • HHKB JP
« Reply #37 on: Fri, 01 February 2013, 11:23:52 »
Then why are people complaining? No one here came up with that smiley :P
Offline multipla
« Reply #38 on: Fri, 01 February 2013, 11:30:03 »
That big key in the stoner set, is that a replacement for the backspace key?
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #39 on: Fri, 01 February 2013, 11:34:20 »
Yes.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #40 on: Fri, 01 February 2013, 13:26:27 »
I bought the small pack of "Modular Display/Storage Kit" to see what that's all about.
Offline inteli722
« Reply #41 on: Fri, 01 February 2013, 13:40:07 »
It looks like a series of dummy stems that can be rearranged.
Offline alaricljs
« Reply #42 on: Fri, 01 February 2013, 13:40:40 »
This is what it's all about:  thread
Offline inteli722
« Reply #43 on: Fri, 01 February 2013, 13:45:21 »
file not found
Offline shadewolf
  • ಠ_ಠ
« Reply #44 on: Fri, 01 February 2013, 13:50:36 »
Offline inteli722
Offline llovro
« Reply #46 on: Sun, 03 February 2013, 05:42:08 »
stoner set is dope! :D
Offline TotalChaos
  • Indy Game Coder
Offline Sai
« Reply #48 on: Tue, 05 February 2013, 07:21:24 »
i like this idea !  ;)
Offline TheQsanity
  • SmallFry Lovin'
« Reply #49 on: Tue, 05 February 2013, 20:30:52 »
Cute site.
SmallFry! <3
