Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6009943 times)
0 Members and 13 Guests are viewing this topic.
Offline nukec
  • that rug really tied the room together
« Reply #9000 on: Sat, 12 July 2014, 09:15:36 »
Hi I just got set of dcs blanks. Did i put wrong enter key? It is little bit higher?
« Last Edit: Sat, 12 July 2014, 12:10:35 by nukec »
HHKB Pro2, Poker2 Blue, KBPV60 Brown, DuckyShine3 Brown
Offline BlueBär
« Reply #9001 on: Sat, 12 July 2014, 09:52:36 »
Hi I just got set ob dcs blanks. Did i put wrong enter key? It is little bit higher?
Switch your left shift with the enter key.
Offline BlueBär
« Reply #9002 on: Sat, 12 July 2014, 09:54:05 »
What's the name of the springs used in HHKB Pro 2 spacebars?
Not sure what you mean by name. Do you mean "conical springs"?
Offline nukec
« Reply #9003 on: Sat, 12 July 2014, 10:25:06 »
Thanks it's perfect now!
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #9004 on: Sat, 12 July 2014, 11:54:42 »
Will 3 G81 sets fit in a small USPS priority box?
Offline Battou62
« Reply #9005 on: Sat, 12 July 2014, 12:19:55 »
I would say no to that. It would be an extremely tight fit.
Offline Battou62
« Reply #9006 on: Sat, 12 July 2014, 12:24:04 »
Would it be relatively easy to swap springs on a KMAC? I am trying to expand my chances of finding one :)
Offline frosty
  • jukebox hero
« Reply #9007 on: Sat, 12 July 2014, 12:30:33 »
where do i get filco cases? just barebone cases, with the filco logo on it and all. i saw a post where it directed me to a diatec website but i couldn't find replacement cases there. any help?
Offline yicaoyimu
« Reply #9008 on: Sat, 12 July 2014, 13:05:36 »
I just take a look at a picture of the plate. The holes for switches don't have the extra space for removing switch caps without desoldering, so no it won't be easier.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #9009 on: Sat, 12 July 2014, 13:09:08 »
70595-0
All the IBM jr's were RD, right?
Offline epzy
  • HHKB Fiend
  • ded
« Reply #9010 on: Sat, 12 July 2014, 13:13:40 »
I need one of these:
« Reply #9011 on: Sat, 12 July 2014, 13:43:37 »
Why am I not at keycon? is my question.
Offline BlueBär
« Reply #9012 on: Sat, 12 July 2014, 17:42:02 »
I don't think they have a special name. They usually just get called Topre Spacebar springs afaik.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #9013 on: Sat, 12 July 2014, 17:49:30 »
Well I need to find one. :/
Offline BlueBär
« Reply #9014 on: Sat, 12 July 2014, 17:53:43 »
Yep.
If you have the measurements you could try looking for one in online stores. I don't think you can buy replacements for them easily.
« Reply #9015 on: Sat, 12 July 2014, 17:54:37 »
wasn't the consensus that they feel better without it?
Offline BlueBär
« Reply #9016 on: Sat, 12 July 2014, 17:56:06 »
Yeah maybe somebody who doesn't use theirs can give one to you, epzy? Can't hurt asking in the free stuff thread for example.
Offline frosty
  • jukebox hero
« Reply #9017 on: Sat, 12 July 2014, 18:57:37 »
mini bumb (idk lol)
« Reply #9018 on: Sat, 12 July 2014, 19:10:24 »
you can't
those are full keyboards
Offline epzy
  • HHKB Fiend
  • ded
« Reply #9019 on: Sat, 12 July 2014, 19:12:53 »
Yeah, ComradeSniper is hooking me up. :)
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #9020 on: Sat, 12 July 2014, 20:10:37 »
Ask in the free stuff thread. I know some people don't like using that spring, so. Someone may have one they would give you.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #9021 on: Sun, 13 July 2014, 00:05:42 »
70660-0
Is this just some kind of slider over dome?
Offline frosty
  • jukebox hero
« Reply #9022 on: Sun, 13 July 2014, 02:56:47 »
it said replacement case in a section. but i just want a white tkl case T.T
Offline BlueBär
« Reply #9023 on: Sun, 13 July 2014, 05:27:56 »
I don't see where you can buy the case alone on their site. I only found a "case replacement service".
Key Tronic or Alphameric foam and foil.
Offline b7ad
  • ゆめうつつ
    • mechblog
« Reply #9024 on: Sun, 13 July 2014, 07:04:24 »
Anyone have experience with plastidipping plates? I'm pretty sure it will adhere to the steel plate with no problem, but I'm slightly worried about when it comes to soldering the switches in.
I plastidipped the top case of my Shine II.  I haven't tried it on a plate.
I think the plastidip would get scratches or peel if you accidentally hit it with a wire keycap puller while pulling keycaps off.  It may also peel when -- as you mentioned -- insert the switches.
If you do decide to experiment and have trouble peeling the plastidip off, spray some WD40 on it and brush it.  WD40 dissolves plastidip. ;)
Thanks for the input and apologies for the late response. It's glow in the dark plasti-dip and I believe it to be 'invisible' or close to it when it's not 'glowing' so maybe a bit coming off wouldn't matter so much kinda thing. Maybe it will be interesting to try anyway!
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #9025 on: Sun, 13 July 2014, 08:17:28 »
Whoa.  TIL that there's glow in the dark plastidip.  Excited to see how it turns out! :thumb:
Offline combataran
« Reply #9026 on: Sun, 13 July 2014, 09:57:31 »
What other keycap sets are out there that have coloring schemes like the OTD RA and CCNG?
Cherry G80-1000HFD | CM Storm Spawn | Keypuller.com - Key Caps News & Database
Offline Vitaly
« Reply #9027 on: Sun, 13 July 2014, 10:05:39 »
Originative or PimpMyKeyboard Dolch set, what is better, what's difference?
« Reply #9028 on: Sun, 13 July 2014, 10:20:15 »
Originative is Cherry Profile, which means it's thick, doubleshot ABS. Made by a company called GMK, who owns all the OG cherry tooling. You'll probably just lose all your money if you order from Originative, though.
PMK dolch is made by SP, and it's DSA profile, which IMO is the worst profile. It's thin ABS as well, which feels pretty lame. You'll actually get a keyset if you order from PMK, though.
Offline Vitaly
« Reply #9029 on: Sun, 13 July 2014, 10:54:30 »
Thanks.  I have two GMK keycaps, and they really good and thick, that's why i looked to Originative.  Is it possible to order directly from gmk (not from Originative)? I wrote them, but they answered MOQ 250.
Offline whentheclouds
« Reply #9030 on: Sun, 13 July 2014, 11:04:26 »
you missed the GMK DOlch groupbuy here by about 2 weeks :(
Offline Vitaly
« Reply #9031 on: Sun, 13 July 2014, 11:09:24 »
bad :( Wrote message to IvanIvanovich, maybe still have a chance
« Last Edit: Sun, 13 July 2014, 11:15:44 by Vitaly »
« Reply #9032 on: Sun, 13 July 2014, 11:18:36 »
the payment deadline is in 2 days and there's always the chance of someone not paying on time, maybe you could take his spot if you ask in the thread
edit: i'm pretty sure writing a pm to Ivan won't help, the above is the only way you can get your hands on a set now. aside from waiting for one to appear on the classified board
« Last Edit: Sun, 13 July 2014, 11:20:09 by whentheclouds »
Offline BlueBär
« Reply #9033 on: Sun, 13 July 2014, 11:29:32 »
Both sets had multiple rounds, some were run by GH. They all have small differences (the font or the modifiers for example).
I know Ducky has made dyesubs in the CCnG colourscheme and Vortex has made PBT doubleshots in the RA and CCnG colourschemes.
Offline Vitaly
« Reply #9034 on: Sun, 13 July 2014, 13:18:11 »
Get one, thanks to Ivan  :)
« Reply #9035 on: Sun, 13 July 2014, 16:48:31 »
looks like i was wrong. grats!
Offline frosty
  • jukebox hero
« Reply #9036 on: Sun, 13 July 2014, 17:20:34 »
how do i wetsand? wet the plastic and just sand it?
where do i get leds that actually fit in the keyswitch and has a spherical top?
Offline BlueBär
« Reply #9037 on: Sun, 13 July 2014, 17:28:34 »
1. how do i wetsand? wet the plastic and just sand it?
2. where do i get leds that actually fit in the keyswitch and has a spherical top?
1. I found this: "As mentioned wet sanding is sanding the surface while using a lubricant (usually, as the name implies, water) to reduce surface scuffing." I think you should look it up via Google or make a seperate thread about it, I don't know if this is a simple question.
2. Ebay, you should look for 3mm LEDs. However it is generally recommended to use 2x3x4mm rectangular LEDs because the 3mm round ones can cause problems with thick keycaps.
Offline frosty
  • jukebox hero
« Reply #9038 on: Sun, 13 July 2014, 17:49:40 »
will do! thanks
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #9039 on: Sun, 13 July 2014, 20:58:48 »
Does anyone know of a good tutorial for a soarer's converter on an rj45 connector?
« Reply #9040 on: Sun, 13 July 2014, 21:26:24 »
I connected the correct wires, and it worked right away with no additional adjustments.
- Franklin Roosevelt 1933
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #9041 on: Sun, 13 July 2014, 23:51:19 »
and what is that watermark-ish thing people have in their pictures with their username?
« Reply #9042 on: Sun, 13 July 2014, 23:56:57 »
Simply that - a watermark.
To identify the picture as belonging to that person.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #9043 on: Sun, 13 July 2014, 23:57:43 »
well alrighty then
Offline EpicSNES
  • how do i keyboard
« Reply #9044 on: Mon, 14 July 2014, 03:53:25 »
I'm getting my Poker 2 this week, I'm sure the manual covers this but is there any thread or something covering the programming options?
Filco Tenkeyless mx blue
Offline BlueBär
« Reply #9045 on: Mon, 14 July 2014, 04:12:35 »
Maybe the Deskthority wiki entry is helpful to you: http://deskthority.net/wiki/KBC_Poker_II#Programming
Other than that just read the manual.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #9046 on: Mon, 14 July 2014, 04:44:52 »
If I were to send a lasercutter these DXF files, containing these drawings:
Would they be able to get the Orion TKL bottom plate and this from it?
I have never worked with DXF files before  so I am unsure if the measurements are included or not.
|||My other keyboards :
x
Offline BlueBär
« Reply #9047 on: Mon, 14 July 2014, 05:05:16 »
Are those the original drawings? If they are then you shouldn't have any problems. I'm pretty sure the measurements are included.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #9048 on: Mon, 14 July 2014, 05:19:25 »
They are. I'll ask the lasercutter if they contain everything they need.
x
Offline EpicSNES
  • how do i keyboard
« Reply #9049 on: Mon, 14 July 2014, 07:22:20 »
Thanks. That's exactly what I was looking for  :)
