Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6229407 times)
« Reply #8900 on: Tue, 08 July 2014, 20:10:10 »
Non blank cheap DSA keycaps? I've found only those blanks in the Signature Plastics site ...
How cheap?  DSA Dolch starts from $70.
yes, I saw this one and already bought it.
I'm looking for anything cheaper - around 30 or 40 bucks.
Not sure you'll find many at that price.
You just missed the Granite set, that was $35 or so.
If you look around Classifieds you will probably find a few people selling their Granite sets - seems some sets were not up to expectations.
$35 for the base but then you also had to get mods and a spacebar which put it ~$61 plus another ~$30 for the numberpad.....
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #8901 on: Tue, 08 July 2014, 20:13:59 »
35$ for alphas. You still need mods.
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
« Reply #8902 on: Tue, 08 July 2014, 20:19:06 »
... seems some sets were not up to expectations.
Gosh, IMHO this is Matt3o's best work!
Yes, I'm looking for this set - however it is way above 40 bucks ...
ty anyway.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #8903 on: Tue, 08 July 2014, 20:24:51 »
Ya. I saw those pics of the key spacing and the non centered legends. Those are SP execution issues though. The work Matt did is absolutely beautiful.
My set turned out ok. Minor cases of both his problems. The back lighting on my keyboard makes it more obvious. I can live with the quality of these, but probably won't buy any more SP. (we will see how the SA profile is to know for sure).
Offline combataran
« Reply #8904 on: Tue, 08 July 2014, 23:51:53 »
What is the pitch on a Filco(legs not extended) and a Poker II respectively, assuming stock keycaps?
Cherry G80-1000HFD | CM Storm Spawn | Keypuller.com - Key Caps News & Database
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #8905 on: Tue, 08 July 2014, 23:53:19 »
I tried to measure it and I got about 5.5º - 6º
Offline combataran
« Reply #8906 on: Tue, 08 July 2014, 23:54:17 »
On a Poker or a Filco?
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #8907 on: Tue, 08 July 2014, 23:56:37 »
What is the best place to find a new beige G80-3000 with blues?
I have been looking on ebay and can only seem to find them in black.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #8908 on: Wed, 09 July 2014, 00:02:13 »
Sorry, that's on a filco.
« Reply #8909 on: Wed, 09 July 2014, 05:53:31 »
For some reason, 7º and 11º stick out in my head respectively. But I'd trust swill's measurements more than my memory.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #8910 on: Wed, 09 July 2014, 07:19:41 »
I did not measure it recently. That is from memory as well. I measured it when I was working on my case.
« Reply #8911 on: Wed, 09 July 2014, 07:56:31 »
poker is flat iirc
filco is 6
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #8912 on: Wed, 09 July 2014, 08:02:28 »
Are there any good options for quality keycaps that support back lighting?
« Reply #8913 on: Wed, 09 July 2014, 08:09:15 »
poker is flat iirc
filco is 6
Poker case does sit flat on the desk, but it's a wedge shape so there is definitely an angle there.  Not sure exactly what it is, but it's got one.
Offline BlueBär
« Reply #8914 on: Wed, 09 July 2014, 08:09:41 »
poker is flat iirc
Definitely not: http://mechanicalkeyboards.com/shop/images/products/large_919_DSC_0759.jpg
The Poker, II and the Pure have a very similar case, my Pure has an angle of about 5-6°.
Deck if you don't mind the font.
Offline combataran
« Reply #8915 on: Wed, 09 July 2014, 08:10:19 »
poker is flat iirc
filco is 6
Yes, I was wondering about the pitch of the wedge.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #8916 on: Wed, 09 July 2014, 08:19:51 »
Can you buy the caps on their own?
Offline Battou62
« Reply #8917 on: Wed, 09 July 2014, 09:45:23 »
Would it be possible to mod the stabs on a Filco from Costar to Cherry?
« Reply #8918 on: Wed, 09 July 2014, 09:48:54 »
Possible, but a tonne of modding would be required. Really not worth the effort.
Offline phoenix1234
« Reply #8919 on: Wed, 09 July 2014, 09:50:38 »
+1
or buy a new plate which can support plate-mounted Cherry stabilizer
I like linear switches
Offline Battou62
« Reply #8920 on: Wed, 09 July 2014, 09:51:31 »
So it's not as simple as desolder switch, replace stab, resolder switch?
« Reply #8921 on: Wed, 09 July 2014, 09:52:43 »
No, the stab holes are a different size. And the Costar stab wire won't work with Cherry stabilizers. I can't remember if the Cherry wire works with Costar but I don't think so. Also plate mounted Cherry stabilizer housings aren't the same design as PCB mounted so there's that to take into consideration. Stabilizers aren't like switches in the respect you're referring to.
Offline Battou62
« Reply #8922 on: Wed, 09 July 2014, 09:53:45 »
Thanks guys, I see it now.
Offline agodinhost
    • Dr Ian O Xaman
« Reply #8923 on: Wed, 09 July 2014, 11:18:03 »
Do you know any non blank DSA keycaps vendor? (Not signature Plastics, MechanicalKeyboard nor WASD please)
« Reply #8924 on: Wed, 09 July 2014, 11:20:52 »
DSA profile is specific to Signature Plastics
Offline agodinhost
    • Dr Ian O Xaman
« Reply #8925 on: Wed, 09 July 2014, 12:13:38 »
Really?
it explains a lot ...
damm
ty
Offline intelli78
« Reply #8926 on: Wed, 09 July 2014, 14:23:58 »
Where are these teal keys from? (not the skull, the blanks--are they also from CC?)
« Last Edit: Wed, 09 July 2014, 14:25:31 by intelli78 »
Offline jonathanyu
« Reply #8927 on: Wed, 09 July 2014, 14:49:30 »
Does Cherry ever made a g80 in jis layout?
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #8928 on: Wed, 09 July 2014, 14:49:36 »
They're from CC. There is also a WASD and Arrow cluster.
« Last Edit: Wed, 09 July 2014, 14:55:24 by Photekq »
Offline intelli78
« Reply #8930 on: Wed, 09 July 2014, 14:53:23 »
Thanks very much for the info. Do you happen to know if CC gave that color a name?
« Reply #8931 on: Wed, 09 July 2014, 14:54:03 »
Mintgum ^
Offline intelli78
« Reply #8932 on: Wed, 09 July 2014, 15:06:48 »
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #8933 on: Wed, 09 July 2014, 21:27:32 »
Correct here.  Costar and cherry wires are not interchangeable.  They are completely different shapes and there is enough of a size difference in the diameter of the wire that it wouldn't work on that front either.
There is a style of stab hole that will work with both plate mounted Cherry, and Costar.  Though you will not find it on a stock plate.  Those will only support the type of stabilizer that they were designed for.  It would however be possible to mod a cherry plate mount hole to fit costar but would require a lot of VERY careful work with a file.  Both cherry plate mount and costar stabilizer holes can be modified to make PCB mount cherry stabs work but will require a different PCB unless you are building a frankenboard.
Also, there are no pcb mount costar.  All costar stabilizers are plate mount and Alps switches are their own stabilizers of which there a a number of slight variations all being plate mount as well to my knowledge.
Offline norbauer
  • Plz email shop@norbauer.com; I miss PMs sometimes
    • Ryan Norbauer's personal site
« Reply #8934 on: Wed, 09 July 2014, 23:41:41 »
Anybody have a list of the online tools used to mock-up keycap layouts (I have seen some that have the full standard Signature Plastics color ring colors, etc.) I used to have links but can't find them anymore. :S Thanks!
Offline divito
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
Offline norbauer
Offline calavera
« Reply #8937 on: Thu, 10 July 2014, 09:07:15 »
Where can I buy thick PBT blank key caps?
Offline Jixr
« Reply #8938 on: Thu, 10 July 2014, 11:01:25 »
are the rainbow sets dyed, or are they actual colored plastic, and if dye, how durable are they?
Offline BlueBär
« Reply #8939 on: Thu, 10 July 2014, 11:13:39 »
If I remember correctly Originative once offered them but I think a lot of people never eceived those. Apart from that there is a GB by Ivan that is closed but not over yet. Maybe somebody who got in is willing to sell their order.
Not sure but both should not wear off (because dye goes into the plastic and I've only seen POM and I think PBT rainbow sets).
« Reply #8940 on: Thu, 10 July 2014, 11:16:57 »
Right, there's pellets of POM or PBT which are those colors most likely. I don't think they're dye sublimated.
Offline Lain1911
  • God of the Wired
« Reply #8941 on: Thu, 10 July 2014, 12:41:43 »
Can you make a rubber dome work after you have taken it out of its case?
« Reply #8942 on: Thu, 10 July 2014, 12:43:11 »
I don't see why you couldn't.
Offline Lain1911
  • God of the Wired
« Reply #8943 on: Thu, 10 July 2014, 12:47:24 »
I was curious because I'm experimenting with it and as unscrewed it and took it out of the case it gradually stopped working. As in only a couple of keys worked and then none after I took it out. As I started to put it back in it started working again. Sound like somethings come loose?
« Reply #8944 on: Thu, 10 July 2014, 13:07:36 »
IIRC, some rubber dome boards have multiple layers plastic sheets with traces.  It's possible that these need to be held tightly together to function properly, and opening it up would allow gaps that cause it to not work.  But it's been years since I took apart a rubber dome, so my memory might be failing me here.   :thumb:
« Reply #8945 on: Thu, 10 July 2014, 13:19:27 »
I think you've got it Hoffman, gotta keep the traces in place.
Offline Battou62
« Reply #8946 on: Thu, 10 July 2014, 13:27:15 »
I have decided I want an aluminum TKL board; preferably one that has a pcb that uses cherry stabs. What would be easiest way to do this? Does anyone have any experience with these?
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=281
Would it be possible to put a Filco or Ducky TKL into this case?
« Reply #8947 on: Thu, 10 July 2014, 13:28:09 »
Just buy a KMAC. You can get them really cheap nowadays (300-400$ assembled) and they use Cherry PCB mount stabilisers.
« Reply #8948 on: Thu, 10 July 2014, 13:28:31 »
Filco for sure.  It is designed for Filcos.  I don't know about Ducky with that case, though.
Offline Battou62
« Reply #8949 on: Thu, 10 July 2014, 13:35:51 »
Ah yes, please point me in the direction of the KMAC store :) I would surely pay $300 for an assembled KMAC.
