Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6228254 times)
Offline sakai4eva
« Reply #9150 on: Sun, 20 July 2014, 11:00:25 »
Unfortunately, I don't think I can afford to buy Autocad unless I get the eyepatch version :(
Offline Vitaly
« Reply #9151 on: Sun, 20 July 2014, 12:05:04 »
What thickness is good for PCB mount design plate?
Offline BlueBär
« Reply #9152 on: Sun, 20 July 2014, 12:26:39 »
If you're a student you get it for free on their website.
Are asking for PCB thickness?
« Reply #9153 on: Sun, 20 July 2014, 12:32:30 »
looks like he's asking for plate thickness
Offline Vitaly
« Reply #9154 on: Sun, 20 July 2014, 12:35:29 »
Yes pcb thickness (metal plate thickness for future projects also good to know)
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #9155 on: Sun, 20 July 2014, 13:32:30 »
So what in the sam hell are these (sorry, apparently the seller has the worst camera in the entire world)? The second one look mx compatibleish
Still no idea on the first one. Very tall, transparent housing and a metal slider doesn't ring a bell and I couldn't find anything in the DT wiki either.
I did find something about the other switch though: It is an unknown switch that is currently labelled USw LXBW01.
Here's the DT wiki article: http://deskthority.net/wiki/USw_LXBW01
And here is an imgur album of somebody who found some of these switches before: http://imgur.com/a/zgCm6
Ah, guess I'll just have to wait to find out on the first one ;)
Offline BlueBär
« Reply #9156 on: Sun, 20 July 2014, 14:08:26 »
PCB and plate should be 1.6mm thick.
« Reply #9157 on: Sun, 20 July 2014, 15:26:46 »
You can register any email address and just say you're a student. I have a 5 year license and I just dled it from their student side.
Offline Candyflip
« Reply #9158 on: Sun, 20 July 2014, 15:48:16 »
You can get every Autodesk product from their site for free even with a Gmail account. Just search for student downloads they don't require .edu mail like Adobe...
Offline Smasher816
  • HHKB Master
« Reply #9159 on: Sun, 20 July 2014, 16:06:15 »
Well it is a good thing I now have a college .edu email :thumb:
Offline LONGZILLA
  • ヽ(`Д´)ノ rawr
« Reply #9160 on: Sun, 20 July 2014, 18:18:36 »
The wire/clip for a cherry stabilizer got loose from the mount and inserts. Is there a trick to getting the wire back into place for a plate mounted PCB?
Offline BlueBär
« Reply #9161 on: Sun, 20 July 2014, 18:22:23 »
You can try pushing it back in with a screwdriver, but be careful to not damage anything.
Offline sakai4eva
« Reply #9162 on: Mon, 21 July 2014, 02:44:35 »
NVM my brother forwarded me a copy of Autocad. Apparently, working in as an engineer in a multinational gets him free copies, although he isn't telling me how exactly he got one :|
Well, it's off to learn how to use this befuddled software!
« Reply #9163 on: Mon, 21 July 2014, 06:14:38 »
My brother forwarded me a copy of Autocad.
If you need help, PM me. I know a lot about CAD.
For me a mix of pliers, small screwdrivers, and patience helped me reset the wire in my KMAC after I accidently loosened it.
Offline Vitaly
« Reply #9164 on: Mon, 21 July 2014, 06:48:35 »
Can you post useful links here for those who start with CAD and diy keyboards and can you explain which job you do in Autocad and which in Inventor? I thought authocad work's well for 3d ?
« Reply #9165 on: Mon, 21 July 2014, 07:14:40 »
1) Can you post useful links here for those who start with CAD and diy keyboards
2) can you explain which job you do in Autocad and which in Inventor?
3) I thought authocad work's well for 3d ?
1) I don't think there's any info I can currently think of for an introduction to CAD. I know there are books about CAD that you can buy and use to help you. There might be some information online. All my help and advice is from my own professional experience. There is a few CAD threads on Geekhack and you can go into the Making Stuff Together subforum to get some info there.
2) AutoCAD = 2D, Inventor = 3D. I model everything in 3D CAD programs just because I'm used to doing that. If you're designing a keyboard, you don't necessarily need a 3D CAD program but I recommend it because a lot of people can't visualize things in 2D space. 3D models are easier to look at and interpret.
3) No. AutoCAD is 2D AFAIK. The newer AutoCAD packages may have 3D but I have only seen it used and only used it in a 2D capacity.
Offline Candyflip
« Reply #9166 on: Mon, 21 July 2014, 13:53:40 »
AutoCAD is and always was 3D, I would recommend other 3D CAD software though
Edit: The difference between AutoCAD and Inventor is the interface and you can actually make movement animations in Inventor. For other software I would recommend SolidWorks or you can even try Maya.
« Last Edit: Mon, 21 July 2014, 13:58:02 by Candyflip »
« Reply #9167 on: Mon, 21 July 2014, 13:57:01 »
I've never used it in it's 3D capacity. I've always seen it used in industry as a 2D package and from a quick Google search, the rendering of the models looks poor. Maybe that's why I've never seen it in 3D.
Offline Kblavkalash
« Reply #9168 on: Mon, 21 July 2014, 14:06:37 »
I am looking to buy o-rings for my cherry mx blue and red keyboards. There are two types available: thinner red 40A-L and thicker blue 40A-R. I am thinking about putting 40A-L on cherry mx reds, and 40A-R on cherry mx blues, what do you think? I am mainly interested to hear if someone tried 40A-R rings on blue switches, does it feel good? It seems like it should feel good, but not sure :D
« Reply #9169 on: Mon, 21 July 2014, 14:18:49 »
My personal experience with o-rings can be found in this thread. Additionally, here are some more reviews your might be interested in. I preferred the 40A-L o-rings overall as I felt the -R reduced travel too much.
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
« Reply #9170 on: Mon, 21 July 2014, 14:24:32 »
OpenSCad and FreeCad are good too (IMHO)
quite easy to learn ...
Offline Kblavkalash
« Reply #9171 on: Mon, 21 July 2014, 15:52:48 »
Yeah, I read those links, thanks. But still can't decide.. I have a feeling that those thicker o-rings will feel better for me, thinking about buying both sets, if I am lucky I can put one on each of keyboards.
P.s. are there any specialized shops which sell similar sized o-rings? Because I don't feel like paying 15 euros for pack of rings, which are essentially free.
« Last Edit: Mon, 21 July 2014, 15:56:29 by Kblavkalash »
« Reply #9172 on: Mon, 21 July 2014, 20:21:36 »
I think Max Keyboards carries O rings.
« Reply #9173 on: Mon, 21 July 2014, 20:44:05 »
http://www.maxkeyboard.com/cherry-mx-rubber-o-ring-dampeners-110pcs.html
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #9174 on: Mon, 21 July 2014, 22:12:12 »
I hate when o-rings are advertised as "0.4mm reduction".  You didn't even specify which profile keycaps you are referencing.  How do I know what keycap profile Max Keyboards uses if I don't own one (or even if I do).  That just leads to confusion around o-rings because if its 0.4mm reduction on OEM keycaps, it is going to SUCK on Cherry caps.  If it is 0.4mm on Cherry caps, then it won't even be noticeable on OEM caps.
Its frustrating because so many people are confused about o-rings and this type of advertising isn't helping at all.  I should write a proper guide with links to all the different suppliers and compare what you get...
Offline Kblavkalash
« Reply #9175 on: Tue, 22 July 2014, 01:59:14 »
Hey Swill, which o-rings (40A-L or 40A-R) would you advice for cherry mx red and cherry mx blue keyboards?
« Reply #9176 on: Tue, 22 July 2014, 05:09:28 »
Well if I'm not mistaken, swill is saying that the keycaps will influence how your O-rings feel. So perhaps you can let us know what keycaps you plan on using because he's got a good point.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #9177 on: Tue, 22 July 2014, 06:42:52 »
I will have to check what the difference is.
Do you have links to the two options you are considering?
« Last Edit: Tue, 22 July 2014, 06:46:27 by swill »
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #9178 on: Tue, 22 July 2014, 06:44:28 »
Yes. Keycaps matter. MX switch types don't.
« Reply #9179 on: Tue, 22 July 2014, 06:45:10 »
They're different thicknesses. WASD shows that the 40A-R is 0.4mm thickness and 40A-L is 0.2mm thickness. Both have a Shore Durometer hardness of 40A.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #9180 on: Tue, 22 July 2014, 06:56:25 »
Another site that advertises reduction without specifying which cap profile is being used to test. Do you know if WASD sells OEM profile? It looks like it from the bottom of the cap, but I can't tell for sure.
Also, $18 for o-rings? Really?  With the keycap profile you are using I can probably find you a less expensive alternative.
« Last Edit: Tue, 22 July 2014, 07:00:03 by swill »
« Reply #9181 on: Tue, 22 July 2014, 06:58:04 »
I'm fairly sure they sell OEM profile caps. It's been a while since I've seen WASD keycaps though.
« Reply #9182 on: Tue, 22 July 2014, 07:05:23 »
There are loads of O-rings available on ebay and elsewhere for a third of that price, but you may not find precisely the thickness and hardness that is ideal for your keyboard.
Personally, I want the thinnest and softest I can find, but most "industrial" rings are harder and fatter.
- D Trump 2026-10-24
Offline EpicSNES
  • how do i keyboard
« Reply #9183 on: Tue, 22 July 2014, 07:34:24 »
After a few days I've realized I really don't like the o-rings I've chosen for my board..... does someone know of an easy way to remove them?
Filco Tenkeyless mx blue
« Reply #9184 on: Tue, 22 July 2014, 07:36:04 »
Pull all the keycaps then use a pocket knife/screwdriver/pliers/fingers to take them out of the keycaps or off the stems. It's really easy. As easy as putting them on.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #9185 on: Tue, 22 July 2014, 07:36:17 »
You can easily remove them with your fingers. You could use a wire keycap puller as well, works pretty good.
« Reply #9186 on: Tue, 22 July 2014, 07:37:21 »
You're screwed. Just burn the keyboard and move on.
Offline EpicSNES
  • how do i keyboard
« Reply #9187 on: Tue, 22 July 2014, 07:39:53 »
Yeah I felt really dumb asking. For me the o-rings were actually difficult to put on, I don't have thin fingers so I can't just pull them out. I'll use my keycap puller. Plus they're PBT caps and I just don't want to damage the keycaps, even if it's the bottom.
Offline Lpwl
  • lpwl.bigcartel.com
    • My O-ring Store
« Reply #9188 on: Tue, 22 July 2014, 07:51:12 »
If you are looking for thicker (but still soft) O-rings, you should take a look at my thread : [IC] Soft O-rings (40A)
I'm really happy with those "fat" O-rings (Cherry MX Clear switches // WASD OEM profile keycaps). If they were more people interested, this could be cheaper to produce.
By the way, I could send you some I have left (~10).
EDIT : I'm using a curved tweezer to remove my o-rings, it's really easy this way :
« Last Edit: Tue, 22 July 2014, 08:02:05 by Lpwl »
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #9189 on: Tue, 22 July 2014, 08:49:02 »
Have you tested 2.5mm o-rings on any keycaps? According to my calculations you will start to have issues with switch actuation on OEM beyond something like 2.3mm.
Offline Lpwl
    • My O-ring Store
« Reply #9190 on: Tue, 22 July 2014, 09:01:44 »
I'm using them for several months without any problem (gaming / coding / etc) on MX Clear switches.
WhireFireDragon also tried these "fat" O-rings and many geekhackers bought them from a group by (pack E & G) 2 years ago :
Quote from: WhireFireDragon
the largest "fat" O-rings (pack E or G) is the max thickness you can get without interfering with the actuation point. On my MX blues, they bottom out just after the actuation click. i have tested may times and they never bottom out before the actuation point under any circumstance.
I could send you some too Swill if you wish.
« Last Edit: Tue, 22 July 2014, 09:13:20 by Lpwl »
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #9191 on: Tue, 22 July 2014, 10:01:23 »
If you could send me 2 or 3, I will include them in my upcoming guide. I will pay for shipping.  I have asked in the 'free stuff' thread for people to send me o-rings if they have a link to where they got them so I can do a comprehensive guide with measurements and such.
My guess is that they may be called 2.5mm but a measurement of the o-ring will probably show a slightly different size.
Offline Lpwl
    • My O-ring Store
« Reply #9192 on: Tue, 22 July 2014, 11:39:46 »
Ok cool !
You can PM me with your details  ;)
« Reply #9193 on: Tue, 22 July 2014, 20:08:04 »
Anyone know how the HHKB logo is printed onto the HHKB Pro 1? Laser? Dyesub?
« Last Edit: Tue, 22 July 2014, 20:10:22 by Photekq »
Offline skuko
« Reply #9194 on: Wed, 23 July 2014, 07:16:28 »
since i didn't find any relevant forum for this, i will just ask here:
what is your experience with originative please? (if any)
i have ordered a GMK orange on charcoal from them on the 17th July (i think) and received a "shipping" mail from them on the 18th, but USPS only states that they received electronic shipping info and it does not necessarily mean that the item was indeed shipped. i have requested more info on this from originative, but only received a generic reply with the same tracking number that i already had.
i'm starting to doubt that they even have it in stock, even though it was not marked as sold out. i have ordered it assuming that the wares would be readily available.
just wanted to ask about their practices (should probably have done so before ordering), because something stinks here. i will not hesitate with a chargeback if i don't receive a satisfying answer from them within a reasonable timeframe.
Offline jorgenslee
« Reply #9195 on: Wed, 23 July 2014, 07:22:35 »
Originative Vendor Review, http://geekhack.org/index.php?topic=57652.0
Offline BlueBär
« Reply #9196 on: Wed, 23 July 2014, 07:28:14 »
Check the link jorgenslee posted: Originative is known for that, stuff simply not getting sent out happend often enough and is still happening. You can try sending Originative an email threatening chargeback, if that doesn't work don't be afraid of doing it, better safe than sorry. Be aware that there is only a certain timeframe in which you can get your money back easily (it depends on your payment method afaik).
Offline skuko
« Reply #9197 on: Wed, 23 July 2014, 07:29:03 »
yeah just read the thread...now i'm wondering if i should file a chargeback right now, or wait.
Offline intelli78
« Reply #9199 on: Wed, 23 July 2014, 09:19:31 »
Can't answer authoritatively but you can at least rule out dyesub, 'cause that would melt the ABS case.
On my HHKB 2s, the logo is pretty solidly filled yet has no texture. If I had to guess I'd say some kind of printing, since I think lasering almost always changes the texture. But I'm just guessing, and its possible the Pro 1 was different.
