Author Topic: Prototyping: Custom extended numpad (31 key)  (Read 654012 times)
Offline Pacifist
  • on hiatus
Re: Prototyping: Custom extended numpad (31 key)
« Reply #50 on: Sat, 26 October 2013, 15:58:43 »
Would totally buy one of these
Offline inteli722
« Reply #51 on: Sat, 26 October 2013, 16:12:49 »
By the way, am I going to have to purchase diodes, LEDs, a controller of some sort, etc?
Switches and case are given, and based on the price, I'd assume I'd have to buy everything. However, with that MX Clear deal on Mechanicalkeyboards.com, switches shouldn't be that big of a deal.
Waiting for: Phantom Plate
« Reply #52 on: Sat, 26 October 2013, 20:12:02 »
They will have all the SMD done.  Just need to add switches, LEDs, and stabs.  If you want I can provide LEDs since I'm going to be making a big Digikey order anyway.
Offline Hak Foo
  • Make America Clicky Again!
« Reply #53 on: Sat, 26 October 2013, 20:23:12 »
Okay, I'd take one, possibly two, knowing I'd wreck the first one somehow.
/afk to desolder old Rosewill board for blue switches.
Overton130, Box Pale Blues.
Offline inteli722
« Reply #54 on: Sat, 26 October 2013, 20:50:49 »
Thank god the SMD'll be done.
Really, my only concern with LEDs is the resistance required, since I'm no electrical engineer. I can probably do LEDs myself, though.
I might as well chalk myself up for 2, for the same reasons as Hak Foo.
/afk to scrounge for $20
« Reply #55 on: Sun, 27 October 2013, 14:45:07 »
Okay so before I finalize this board, what is the best placement of the LED for the 2x vertical keys?
Looks like the Ducky Shine puts the LEDs on the left.  That's what I did in the current design.  Any other opinions?
Here are better examples...
Option A, LEDs are sideways.  This follows KPAD, Deck Legend, Ducky Shine, and GHpad
Option B, LEDs are always down.  This follows a korean pad and CODE keyboard.
Right now I'm going to go with A, except I think I'm going to change that one LED on the right to be on the left like the rest of them.  Welcoming input.
Offline inteli722
« Reply #56 on: Sun, 27 October 2013, 15:04:48 »
Really, because of the way the keycaps would be designed, I think it makes more sense to have option A, considering the keypad stems are likely to be designed for sideways switches.
« Reply #57 on: Sun, 27 October 2013, 17:10:24 »
Okay looks like estimate for the parts was fairly close.  For a low run like this, cost would be about $22 per PCB.  That includes free soldering by me and with me paying almost all of the tooling cost.
Offline inteli722
« Reply #58 on: Sun, 27 October 2013, 17:41:36 »
$22 for just the PCB and your soldering the SMD?
I'll still do at least one, hopefully 2 if I can find the money.
« Reply #59 on: Sun, 27 October 2013, 18:05:54 »
Yeah.  That's locking the bare PCB at $10.  The ATmega chip is $6.04 from digikey by itself.  The diodes are 2 bucks a board, and the USB connectors a buck.  The rest of the diodes, resistors, capacitors, and transistors add up to a few more bucks.
Offline AKmalamute
  • HHKB Scrub
« Reply #60 on: Mon, 28 October 2013, 00:06:28 »
Just round up to $25 or something. Round numbers are easier to remember good craftsmanship is worth money anyway. Actually from the sounds of it, $30 wouldn't be out of bounds. Would still be interested though unfortunately not for a few months. Hafta catch up from arranging to start on a 60% ... which will, of course, need a ten-key to compliment it :)
EDIT: now, wait a sec. I've got a 32u4 being shipped to me that's on a leonardo breakout board (2 holes few, possibly a few more, than a teensy 2 has) that I bought from some ebay store for $5.82 shipped. Why would the chip that does the work be more expensive than a breakout board that happens to use said chip?
signed, confused forumite
« Last Edit: Mon, 28 October 2013, 00:23:26 by AKmalamute »
HHKB-lite2, Dvorak user
Offline Pacifist
  • on hiatus
« Reply #61 on: Mon, 28 October 2013, 00:15:07 »
Still, for $30 for everything except the switches, I would totally buy this.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #62 on: Mon, 28 October 2013, 00:37:45 »
« Reply #63 on: Mon, 28 October 2013, 06:48:40 »
Math helps :P
25 sets + 375 extra diodes yet $8 less
So since each set has 25 diodes, 25 sets have 625 diodes, costing $21.24.
Thus total for 25 sets including $5.23 shipping is: $183.48
Hence each set is ~$7.5.
We have 25 sets, 1 for everyone (Total 8 ) except me (4) and jdcarpe (11), that means we have 2 sets extra, raccoon you can keep them as I know you will be working on more customs, or if someone wants to buy, they can do that, since you are ordering raccoon, that is up to you, and if someone wants more, we can increase the order and maybe hit new tiers.
Also, update on the switched. I will be packaging them as 25 switches, just in case any comes out faulty or is damaged in transit. This pack would be for $9.
Costs thus far:
$6 - PCB
$13 - case
$7.5 - parts
$5 - shipping
$9 - switches
Resistors and LEDs extra.
Many similar parts.  However, not entirely the same.  I will order enough ATmegas to get to the price break and save a few bucks.  The main problem is that I'm only going to be ordering a few of these.
« Reply #64 on: Mon, 28 October 2013, 06:58:02 »
Okay it's looking like this.  I'm going to order in a few days.  Then it will be a few weeks to get the boards in from China.
metalliqaz - 2
bearcat - 1
jdcarpe - 1
MOZ - 1
HakFoo - 1
inteli722 - 1
nubbinator - 1
Pacifist - 1
TheFlyingRacoon - 1
« Last Edit: Mon, 11 November 2013, 14:01:52 by metalliqaz »
Offline MOZ
  • Busy making stuff
« Reply #65 on: Mon, 28 October 2013, 09:29:34 »
I'm definitely in.
Offline inteli722
« Reply #66 on: Tue, 29 October 2013, 17:16:10 »
As am I, definitely in for 2.
Offline Pacifist
  • on hiatus
« Reply #67 on: Tue, 29 October 2013, 17:28:24 »
metalliqaz - 2
bearcat - 1
jdcarpe - 1
MOZ - 1
HakFoo - 1
inteli722 - 1
nubbinator - 1
Pacifist - 1
F*ck Yes, dam this is sweet, and the perfect alternative to the razer orbweaver
Offline inteli722
« Reply #68 on: Tue, 29 October 2013, 17:29:29 »
metalliqaz - 2
bearcat - 1
jdcarpe - 1
MOZ - 1
HakFoo - 1
inteli722 - 1
nubbinator - 1
Pacifist - 1
Indeed it is. It is also what I would consider the perfect Numberpad.
Offline Pacifist
  • on hiatus
« Reply #69 on: Tue, 29 October 2013, 18:06:55 »
So this is my first time making a board, and the first time having one in beta.
What extra do I need to do to make this board? I'm going to assume switches and a soldering kit at the very least. Are you supplying LEDs or no? Is there anything else I need to make it?
Also, If this is successful, then for other versions, will there be changes to the design or no?
This is really promising, and fits my needs so much :) But because its my first DIY board, I don't want to screw up
Offline inteli722
« Reply #70 on: Tue, 29 October 2013, 18:37:15 »
Switches, LEDs, caps, and a case (and yes, Soldering iron and solder)
Technically, LEDs AREN'T required...
Considering the outcome of Epsilon (his first project), this seems like it'll be a one-time thing.
« Reply #71 on: Tue, 29 October 2013, 19:11:40 »
You need switches, stabilizers, LEDs, and keycaps.  You need to do a bunch of through-hole soldering.  Also you need a case.  Don't forget about that.
If you want me to order you some LEDs, tell me now, because I can order it with the rest of the parts.
If it works correctly, this will be the last order.  I don't have the energy for a real GB and honestly I think most people would rather get a GHpad.  If enough people wanted, though, I would give someone the designs and let them do a buy.
Don't worry about screwing up.  These are replaceable.
Offline Pacifist
  • on hiatus
« Reply #72 on: Tue, 29 October 2013, 19:21:01 »
Cool, will send you a PM.Need to buy some more novelty caps from you too.
Where do I get the case? Are you making them or someone else?
Also, is this PCB or plate mounted? If its plate mounted, did you design the PCB to have PCB mounted holes and having the plate more open so we can use PCB mounted switches and change around the switches without desoldering?
Thanks, this is a much needed addition to my mech collection!
Offline inteli722
« Reply #73 on: Tue, 29 October 2013, 19:40:09 »
AFAIK MOZ has a case design for this, and he told me it'd be about $20/case.
metalliqaz explains it best:
It is a 31 key pad with full backlighting and can use Cherry MX plate mount or PCB mount switches/stabilizers.  I will provide software but it could also use TMK if you wish.
Really, the openess of the plate is up to the designer. I wonder how much Photekq's case would be...
Offline Pacifist
  • on hiatus
« Reply #74 on: Tue, 29 October 2013, 19:58:45 »
Ah I see. Thanks. Probally will go caseless to start, and then get a proper case once I get everything I need.
There are 31 switches, and I want to try out clears. But to get the best price I would need to buy a 100 pack, leaving 69 switches unused  :confused:
Offline inteli722
« Reply #75 on: Tue, 29 October 2013, 20:05:20 »
There are 31 switches, and I want to try out clears. But to get the best price I would need to buy a 100 pack, leaving 69 switches unused  ???
I would be happy to buy those extras off you at a later date when I assemble mine. In fact, with my getting 2, that's nearly perfect.
Offline Pacifist
  • on hiatus
« Reply #76 on: Tue, 29 October 2013, 20:07:18 »
On second thought, I'll probally save them for later projects. But then again, by the time I do that, I'll need more switches.
« Reply #77 on: Tue, 29 October 2013, 20:51:07 »
I'm sure MOZ will whip himself up a nice acrylic job.  He may share.  I am creating something for myself that I will share, but it is aluminum and will be expensive in small quantities.  When it's assembled I'll post photos.
Offline Pacifist
  • on hiatus
« Reply #78 on: Tue, 29 October 2013, 22:55:24 »
OOOOO aluminum! About how much for one?
« Reply #79 on: Tue, 29 October 2013, 23:02:03 »
Not done.  Weeks to go yet.
« Reply #80 on: Tue, 29 October 2013, 23:12:57 »
Awesome to see this happening. I had totally forgotten about it. Could you share your plans for the aluminium housing? :thumb:
Offline MOZ
  • Busy making stuff
« Reply #81 on: Tue, 29 October 2013, 23:20:05 »
I will design an acrylic case for myself. However if the run for this happens anytime in the next couple of months, I might not be able to supply the case.
I can however at the least share the drawings for the case I design.
Offline MOZ
  • Busy making stuff
« Reply #82 on: Tue, 29 October 2013, 23:23:23 »
Hey qaz, can you PM me or post the PCB/layout that can be used to accurately design a case for this.
Moz out.
« Reply #83 on: Tue, 29 October 2013, 23:24:43 »
Not done yet.   More like aluminum plates than a housing.  Think what I did for the Epsilon.  I'm trying to control costs.  It's going to cost me something like $500 to make this dream a reality.
« Reply #84 on: Tue, 29 October 2013, 23:25:15 »
If you share to scale designs, I should be able to do it at cost locally.  I have a laser cutting place near me that's $30 an hour, $55 for two hours, or $95-140 for a month long membership (depending if I can still get a student membership or have to pay full price) and I know I could look around and find some acrylic at decent prices.  I should also be able to do wood top and bottom pieces if people wanted that.
« Reply #85 on: Tue, 29 October 2013, 23:37:43 »
* qazpad_draft.zip (6.06 kB - downloaded 761 times.)
The "Hardware" layer shows the PCB.  Layer 0 shows the switch cutouts.  I'm too lazy right now to replace the cherry cutouts with the Phantom cutouts, which I'm sure everyone would prefer.
« Reply #86 on: Wed, 30 October 2013, 08:51:45 »
PCB has passed DRC.  Should ship (to me) within 10 days.
Offline MOZ
  • Busy making stuff
« Reply #87 on: Wed, 30 October 2013, 08:59:14 »
Exact location of the USB connector? And what USB connector?
« Reply #88 on: Wed, 30 October 2013, 09:32:55 »
Yeah that is a quick a dirty draft.  I'll try to make a better one.  The USB connector is DigiKey P/N WM5461CT-ND
Offline Pacifist
  • on hiatus
« Reply #89 on: Wed, 30 October 2013, 15:07:06 »
I'd like wood if I can't get alum
« Reply #90 on: Wed, 30 October 2013, 15:13:46 »
For wood, I can either buy sheets of exotics and domestics (limited options) that are about 1/4" thick or I can buy boards and rip them into thinner pieces. Depending on wall thickness, you may only want wood tops and bottoms and a clear acrylic center pieces.
Offline inteli722
« Reply #91 on: Wed, 30 October 2013, 19:57:43 »
How much would a wood case for this cost? I wouldn't assume it'd be absurdly expensive, considering that it's wood, and we chop down trees like maniacs.
Offline Pacifist
  • on hiatus
« Reply #92 on: Wed, 30 October 2013, 20:10:48 »
The wood we chop down is pretty bad quality wood and probably not used in desks and cases etc
Offline inteli722
« Reply #93 on: Wed, 30 October 2013, 20:21:03 »
It was more meant as a species than a country, state, city, family, etc.
« Reply #94 on: Wed, 30 October 2013, 20:38:29 »
It would depend on how many people would want laser cutting done by me, the species of wood, and how cheaply I can find acrylic.  I'd be donating my time, so it would only be materials cost and time on the laser cost.  It could be as cheap as $20 or $30 and it could be a bit more.
Offline Pacifist
  • on hiatus
« Reply #95 on: Wed, 30 October 2013, 20:46:22 »
If its $20-$30, I'll probally get one.
But I can always go caseless at first right? Also do you think its possible to make a case out of Legos?
« Reply #96 on: Wed, 30 October 2013, 20:49:26 »
I suggest you have a plan for a case before you build it.  If you solder everything on PCB-mount and you end up wanting a case that is plate mount, you will be stuck.
Offline Pacifist
  • on hiatus
« Reply #97 on: Wed, 30 October 2013, 20:54:33 »
So for plate mounted cases I would need to have it on hand before I build it? Ugh, wood or acrylic
Offline regack
« Reply #98 on: Wed, 30 October 2013, 21:35:01 »
Yes, the switches go into the plate, then are soldered to the PCB.  So the plate is trapped and can't be taken out or added without soldering.
I don't think I've ever seen a wood plate... I'd like to see one, that would be interesting... but I can think of a bunch of reasons why a wood plate wouldn't (<-- no pun intended) work very well.   Probably why I haven't seen any (Not that I've been around to see everything).
You could always get JUST a plate made, then figure out the case later; You'll just have to keep in mind the various ways your plate might be attached (or not) to the case, and build the various options into the plate design.
Offline Pacifist
  • on hiatus
« Reply #99 on: Wed, 30 October 2013, 21:36:07 »
What about those cases where there is extra room so you can take off switch covers without desoldering?
